[mapserver-commits] r11183 - in trunk/msautotest/misc: . expected
Wed Mar 16 16:41:03 EDT 2011
Author: sdlime
Date: 2011-03-16 13:41:03 -0700 (Wed, 16 Mar 2011)
New Revision: 11183
Added:
   trunk/msautotest/misc/expected/style_opacity_test001.png
   trunk/msautotest/misc/expected/style_opacity_test002.png
   trunk/msautotest/misc/expected/style_opacity_test003.png
   trunk/msautotest/misc/style_opacity.map
Added simple style opacity tests (AGG)...
Added: trunk/msautotest/misc/expected/style_opacity_test001.png
(Binary files differ)
Property changes on: trunk/msautotest/misc/expected/style_opacity_test001.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/misc/expected/style_opacity_test002.png
Property changes on: trunk/msautotest/misc/expected/style_opacity_test002.png
Added: trunk/msautotest/misc/expected/style_opacity_test003.png
Property changes on: trunk/msautotest/misc/expected/style_opacity_test003.png
Added: trunk/msautotest/misc/style_opacity.map
--- trunk/msautotest/misc/style_opacity.map	                        (rev 0)
+++ trunk/msautotest/misc/style_opacity.map	2011-03-16 20:41:03 UTC (rev 11183)
@@ -0,0 +1,75 @@
+# Test Style Opacity
+# REQUIRES: INPUT=SHAPEFILE OUTPUT=PNG SUPPORTS=AGG
+# RUN_PARMS: style_opacity_test001.png [SHP2IMG] -m [MAPFILE] -l style_opacity_test001 -o [RESULT]
+# RUN_PARMS: style_opacity_test002.png [SHP2IMG] -m [MAPFILE] -l style_opacity_test002 -o [RESULT]
+# RUN_PARMS: style_opacity_test003.png [SHP2IMG] -m [MAPFILE] -l style_opacity_test003 -o [RESULT]
+MAP
+  NAME 'style_opacity'
+  EXTENT 125000 4785000 789000 5489000
+  UNITS METERS
+  SIZE 300 300
+  IMAGETYPE PNG24
+  LAYER
+    NAME 'style_opacity_base'
+    DATA '../query/data/bdry_counpy2'
+    TYPE POLYGON
+    STATUS DEFAULT
+    CLASS
+      STYLE
+        OUTLINECOLOR 0 0 0
+      END
+    END
+  END
+  LAYER
+    NAME 'style_opacity_test001'
+    TYPE POLYGON
+    STATUS OFF
+    FILTER ('[cty_name]' =* 'aitkin')
+    CLASS
+      STYLE
+        OPACITY 50
+        COLOR 255 0 0
+        OFFSET 10 10
+      END
+    END
+  END
+  LAYER
+    NAME 'style_opacity_test002'
+    TYPE POLYGON
+    STATUS OFF
+    CLASS
+      STYLE
+        OPACITY 500 # bad value
+        COLOR 255 0 0
+        OFFSET 10 10
+      END
+    END
+  END
+  LAYER
+    NAME 'style_opacity_test003'
+    TYPE POLYGON
+    STATUS OFF
+    CLASS
+      STYLE
+        OPACITY -500 # bad value
+        COLOR 255 0 0
+        OFFSET 10 10
+      END
+    END
+  END
+END
\ No newline at end of file
