[mapserver-commits] r11192 - trunk/mapserver
Thu Mar 17 10:33:48 EDT 2011
Author: warmerdam
Date: 2011-03-17 07:33:48 -0700 (Thu, 17 Mar 2011)
New Revision: 11192
   trunk/mapserver/maplexer.c
another update to match .l
Modified: trunk/mapserver/maplexer.c
--- trunk/mapserver/maplexer.c	2011-03-17 14:30:21 UTC (rev 11191)
+++ trunk/mapserver/maplexer.c	2011-03-17 14:33:48 UTC (rev 11192)
@@ -73,7 +73,6 @@
 typedef unsigned char flex_uint8_t;
 typedef unsigned short int flex_uint16_t;
 typedef unsigned int flex_uint32_t;
-#endif /* ! C99 */
 /* Limits of integral types. */
 #ifndef INT8_MIN
@@ -104,6 +103,8 @@
 #define UINT32_MAX             (4294967295U)
 #endif
+#endif /* ! C99 */
 #endif /* ! FLEXINT_H */
 #ifdef __cplusplus
@@ -160,7 +161,15 @@
 /* Size of default input buffer. */
 #ifndef YY_BUF_SIZE
+#ifdef __ia64__
+/* On IA-64, the buffer size is 16k, not 8k.
+ * Moreover, YY_BUF_SIZE is 2*YY_READ_BUF_SIZE in the general case.
+ * Ditto for the __ia64__ case accordingly.
+#define YY_BUF_SIZE 32768
+#else
 #define YY_BUF_SIZE 16384
+#endif /* __ia64__ */
 #endif
 /* The state buf must be large enough to hold one state per character in the main buffer.
@@ -172,13 +181,8 @@
 typedef struct yy_buffer_state *YY_BUFFER_STATE;
 #endif
-#ifndef YY_TYPEDEF_YY_SIZE_T
-#define YY_TYPEDEF_YY_SIZE_T
-typedef size_t yy_size_t;
-#endif
+extern int msyyleng;
-extern yy_size_t msyyleng;
 extern FILE *msyyin, *msyyout;
 #define EOB_ACT_CONTINUE_SCAN 0
@@ -203,6 +207,11 @@
 #define unput(c) yyunput( c, (yytext_ptr)  )
+#ifndef YY_TYPEDEF_YY_SIZE_T
+#define YY_TYPEDEF_YY_SIZE_T
+typedef size_t yy_size_t;
+#endif
 #ifndef YY_STRUCT_YY_BUFFER_STATE
 #define YY_STRUCT_YY_BUFFER_STATE
@@ -220,7 +229,7 @@
 	/* Number of characters read into yy_ch_buf, not including EOB
 	 * characters.
-	yy_size_t yy_n_chars;
+	int yy_n_chars;
 	/* Whether we "own" the buffer - i.e., we know we created it,
 	 * and can realloc() it to grow it, and should free() it to
@@ -290,8 +299,8 @@
 /* yy_hold_char holds the character lost when msyytext is formed. */
 static char yy_hold_char;
-static yy_size_t yy_n_chars;		/* number of characters read into yy_ch_buf */
-yy_size_t msyyleng;
+static int yy_n_chars;		/* number of characters read into yy_ch_buf */
+int msyyleng;
 /* Points to current character in buffer. */
 static char *yy_c_buf_p = (char *) 0;
@@ -319,7 +328,7 @@
 YY_BUFFER_STATE msyy_scan_buffer (char *base,yy_size_t size  );
 YY_BUFFER_STATE msyy_scan_string (yyconst char *yy_str  );
-YY_BUFFER_STATE msyy_scan_bytes (yyconst char *bytes,yy_size_t len  );
+YY_BUFFER_STATE msyy_scan_bytes (yyconst char *bytes,int len  );
 void *msyyalloc (yy_size_t  );
 void *msyyrealloc (void *,yy_size_t  );
@@ -2100,7 +2109,7 @@
 void msyyset_out  (FILE * out_str  );
-yy_size_t msyyget_leng (void );
+int msyyget_leng (void );
 char *msyyget_text (void );
@@ -2142,7 +2151,12 @@
 /* Amount of stuff to slurp up with each read. */
 #ifndef YY_READ_BUF_SIZE
+#ifdef __ia64__
+/* On IA-64, the buffer size is 16k, not 8k */
+#define YY_READ_BUF_SIZE 16384
+#else
 #define YY_READ_BUF_SIZE 8192
 #endif
 /* Copy whatever the last rule matched to the standard output. */
@@ -2150,7 +2164,7 @@
 /* This used to be an fputs(), but since the string might contain NUL's,
  * we now use fwrite().
-#define ECHO fwrite( msyytext, msyyleng, 1, msyyout )
+#define ECHO do { if (fwrite( msyytext, msyyleng, 1, msyyout )) {} } while (0)
 #endif
 /* Gets input and stuffs it into "buf".  number of characters read, or YY_NULL,
@@ -2161,7 +2175,7 @@
 	if ( YY_CURRENT_BUFFER_LVALUE->yy_is_interactive ) \
 		int c = '*'; \
-		yy_size_t n; \
+		size_t n; \
 		for ( n = 0; n < max_size && \
 			     (c = getc( msyyin )) != EOF && c != '\n'; ++n ) \
 			buf[n] = (char) c; \
@@ -4299,7 +4313,7 @@
 	else
-			yy_size_t num_to_read =
+			int num_to_read =
 			YY_CURRENT_BUFFER_LVALUE->yy_buf_size - number_to_move - 1;
 		while ( num_to_read <= 0 )
@@ -4313,7 +4327,7 @@
 			if ( b->yy_is_our_buffer )
-				yy_size_t new_size = b->yy_buf_size * 2;
+				int new_size = b->yy_buf_size * 2;
 				if ( new_size <= 0 )
 					b->yy_buf_size += b->yy_buf_size / 8;
@@ -4344,7 +4358,7 @@
 		/* Read in more data. */
 		YY_INPUT( (&YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[number_to_move]),
-			(yy_n_chars), num_to_read );
+			(yy_n_chars), (size_t) num_to_read );
 		YY_CURRENT_BUFFER_LVALUE->yy_n_chars = (yy_n_chars);
@@ -4454,7 +4468,7 @@
 	if ( yy_cp < YY_CURRENT_BUFFER_LVALUE->yy_ch_buf + 2 )
 		{ /* need to shift things up to make room */
 		/* +2 for EOB chars. */
-		register yy_size_t number_to_move = (yy_n_chars) + 2;
+		register int number_to_move = (yy_n_chars) + 2;
 		register char *dest = &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[
 					YY_CURRENT_BUFFER_LVALUE->yy_buf_size + 2];
 		register char *source =
@@ -4503,7 +4517,7 @@
 		else
 			{ /* need more input */
-			yy_size_t offset = (yy_c_buf_p) - (yytext_ptr);
+			int offset = (yy_c_buf_p) - (yytext_ptr);
 			++(yy_c_buf_p);
 			switch ( yy_get_next_buffer(  ) )
@@ -4527,7 +4541,7 @@
 				case EOB_ACT_END_OF_FILE:
 					if ( msyywrap( ) )
-						return 0;
+						return EOF;
 					if ( ! (yy_did_buffer_switch_on_eof) )
 						YY_NEW_FILE;
@@ -4779,7 +4793,7 @@
 static void msyyensure_buffer_stack (void)
-	yy_size_t num_to_alloc;
+	int num_to_alloc;
 	if (!(yy_buffer_stack)) {
@@ -4871,16 +4885,17 @@
 /** Setup the input buffer state to scan the given bytes. The next call to msyylex() will
  * scan from a @e copy of @a bytes.
- * @param bytes the byte buffer to scan
- * @param len the number of bytes in the buffer pointed to by @a bytes.
+ * @param yybytes the byte buffer to scan
+ * @param _yybytes_len the number of bytes in the buffer pointed to by @a bytes.
  * @return the newly allocated buffer state object.
-YY_BUFFER_STATE msyy_scan_bytes  (yyconst char * yybytes, yy_size_t  _yybytes_len )
+YY_BUFFER_STATE msyy_scan_bytes  (yyconst char * yybytes, int  _yybytes_len )
 	YY_BUFFER_STATE b;
 	char *buf;
-	yy_size_t n, i;
+	yy_size_t n;
+	int i;
 	/* Get memory for full buffer, including space for trailing EOB's. */
 	n = _yybytes_len + 2;
@@ -4962,7 +4977,7 @@
 /** Get the length of the current token.
-yy_size_t msyyget_leng  (void)
+int msyyget_leng  (void)
         return msyyleng;
