[mapserver-commits] r11221 - in trunk/msautotest/gdal: . expected
Fri Mar 18 10:14:15 EDT 2011
Author: warmerdam
Date: 2011-03-18 07:14:15 -0700 (Fri, 18 Mar 2011)
New Revision: 11221
Added:
   trunk/msautotest/gdal/alpha_on_alpha_overlay.map
   trunk/msautotest/gdal/expected/alpha_on_alpha_overlay.png
   trunk/msautotest/gdal/expected/simplealpha.png
   trunk/msautotest/gdal/expected/simplealpha_plug.png
   trunk/msautotest/gdal/simplealpha.map
   trunk/msautotest/gdal/simplealpha_plug.map
Removed:
   trunk/msautotest/gdal/expected/force_pc256.png
   trunk/msautotest/gdal/force_pc256.map
   trunk/msautotest/gdal/class16_oddscale.map
   trunk/msautotest/gdal/classtest2.map
   trunk/msautotest/gdal/classtest2_plugin.map
   trunk/msautotest/gdal/expected/classtest1.png
   trunk/msautotest/gdal/expected/classtest2.png
   trunk/msautotest/gdal/expected/classtest2_plugin.png
   trunk/msautotest/gdal/expected/gd_png_tr_256_res.png
   trunk/msautotest/gdal/expected/grayalpha.png
   trunk/msautotest/gdal/expected/grayalpha_plug.png
   trunk/msautotest/gdal/expected/lut_inline.png
   trunk/msautotest/gdal/expected/nonsquare.png
   trunk/msautotest/gdal/expected/processing_bands.png
   trunk/msautotest/gdal/expected/rawmode_multiband.png
   trunk/msautotest/gdal/expected/rgba_overlay_res.png
   trunk/msautotest/gdal/expected/rot_out.png
   trunk/msautotest/gdal/expected/trlay1.png
   trunk/msautotest/gdal/expected/trlay2.png
   trunk/msautotest/gdal/gd_png_tr_256_res.map
   trunk/msautotest/gdal/lut_1_crv.map
   trunk/msautotest/gdal/lut_float.map
   trunk/msautotest/gdal/nodata_8bit.map
   trunk/msautotest/gdal/nonsquare.map
   trunk/msautotest/gdal/offsite_8bitgrey.map
   trunk/msautotest/gdal/offsite_pct_rgb.map
   trunk/msautotest/gdal/ows_extent.map
   trunk/msautotest/gdal/wmsclient.map
update to reflect renderer updates, and alpha changes. A few new tests
Added: trunk/msautotest/gdal/alpha_on_alpha_overlay.map
--- trunk/msautotest/gdal/alpha_on_alpha_overlay.map	                        (rev 0)
+++ trunk/msautotest/gdal/alpha_on_alpha_overlay.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -0,0 +1,39 @@
+# This tests overlaying an RGBA image on an RGBA image (itself).  This is
+# intended to test the general mixing case in msAlphaBlend().  The resulting
+# image should be essentially the same as the source, except in areas of
+# partial alpha the alpha will "densify" somewhat.
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+EXTENT 0.5 0.5 399.5 299.5
+IMAGECOLOR 255 255 0
+OUTPUTFORMAT
+  NAME png24_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE RGBA
+  TRANSPARENT OFF
+END
+LAYER
+  NAME rgb
+  TYPE raster
+  STATUS default
+  DATA data/rgba.tif
+  OFFSITE 111 222 111
+END
+LAYER
+  NAME rgb2
+  TYPE raster
+  STATUS default
+END
+END # of map file
Modified: trunk/msautotest/gdal/class16_oddscale.map
--- trunk/msautotest/gdal/class16_oddscale.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/class16_oddscale.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -33,7 +33,7 @@
   CLASS
     NAME "red"
     EXPRESSION ([pixel] < -3)
-    COLOR 255 0 0
+    STYLE  COLOR 255 0 0  END
   END
   CLASS
     NAME "green"
Modified: trunk/msautotest/gdal/classtest2.map
--- trunk/msautotest/gdal/classtest2.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/classtest2.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -12,7 +12,11 @@
-IMAGETYPE png
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 LAYER
   NAME block
Modified: trunk/msautotest/gdal/classtest2_plugin.map
--- trunk/msautotest/gdal/classtest2_plugin.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/classtest2_plugin.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -30,7 +30,10 @@
   CLASS
     NAME "Hole"
     EXPRESSION ([pixel] == 111)
-    COLOR 255 0 0
+    STYLE
+      COLOR 255 0 0
+      OPACITY 75
+    END
   END
 END
Added: trunk/msautotest/gdal/expected/alpha_on_alpha_overlay.png
(Binary files differ)
Property changes on: trunk/msautotest/gdal/expected/alpha_on_alpha_overlay.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/msautotest/gdal/expected/classtest1.png
Modified: trunk/msautotest/gdal/expected/classtest2.png
Modified: trunk/msautotest/gdal/expected/classtest2_plugin.png
Deleted: trunk/msautotest/gdal/expected/force_pc256.png
Modified: trunk/msautotest/gdal/expected/gd_png_tr_256_res.png
Modified: trunk/msautotest/gdal/expected/grayalpha.png
Modified: trunk/msautotest/gdal/expected/grayalpha_plug.png
Modified: trunk/msautotest/gdal/expected/lut_inline.png
Modified: trunk/msautotest/gdal/expected/nonsquare.png
Modified: trunk/msautotest/gdal/expected/processing_bands.png
Modified: trunk/msautotest/gdal/expected/rawmode_multiband.png
Modified: trunk/msautotest/gdal/expected/rgba_overlay_res.png
Modified: trunk/msautotest/gdal/expected/rot_out.png
Added: trunk/msautotest/gdal/expected/simplealpha.png
Property changes on: trunk/msautotest/gdal/expected/simplealpha.png
Added: trunk/msautotest/gdal/expected/simplealpha_plug.png
Property changes on: trunk/msautotest/gdal/expected/simplealpha_plug.png
Modified: trunk/msautotest/gdal/expected/trlay1.png
Modified: trunk/msautotest/gdal/expected/trlay2.png
Deleted: trunk/msautotest/gdal/force_pc256.map
--- trunk/msautotest/gdal/force_pc256.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/force_pc256.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -1,44 +0,0 @@
-# Tests the quantization option allowing conversion of
-# RGB or RGBA images to 8bit just before saving to PNG.
-# See http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1690
-MAP
-NAME TEST
-STATUS ON
-SIZE 400 300
-EXTENT 0.5 0.5 399.5 299.5
-IMAGECOLOR 255 255 0
-IMAGETYPE png8_t
-OUTPUTFORMAT
-  NAME png8_t
-  DRIVER "GD/PNG"
-  EXTENSION "png"
-  MIMETYPE "image/png"
-  IMAGEMODE RGBA
-  TRANSPARENT OFF
-  FORMATOPTION "QUANTIZE_FORCE=ON"
-  FORMATOPTION "QUANTIZE_DITHER=OFF"
-  FORMATOPTION "QUANTIZE_COLORS=10"
-END
-LAYER
-  NAME grey
-  TYPE raster
-  STATUS default
-  DATA data/grey.tif
-END
-LAYER
-  NAME grid1
-  TYPE raster
-  STATUS default
-  DATA data/grid.gif
-END
-END # of map file
Modified: trunk/msautotest/gdal/gd_png_tr_256_res.map
--- trunk/msautotest/gdal/gd_png_tr_256_res.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/gd_png_tr_256_res.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -18,7 +18,11 @@
   "datum=WGS84"
 END
-IMAGETYPE png
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 # Start of layer definitions
Modified: trunk/msautotest/gdal/lut_1_crv.map
--- trunk/msautotest/gdal/lut_1_crv.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/lut_1_crv.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -9,6 +9,12 @@
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 LAYER
   NAME grey
   TYPE raster
Modified: trunk/msautotest/gdal/lut_float.map
--- trunk/msautotest/gdal/lut_float.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/lut_float.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -11,6 +11,12 @@
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 LAYER
   NAME grey
   TYPE raster
Modified: trunk/msautotest/gdal/nodata_8bit.map
--- trunk/msautotest/gdal/nodata_8bit.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/nodata_8bit.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -11,7 +11,11 @@
-IMAGETYPE png
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 LAYER
   NAME grey
Modified: trunk/msautotest/gdal/nonsquare.map
--- trunk/msautotest/gdal/nonsquare.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/nonsquare.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -10,8 +10,13 @@
 SIZE 500 500
 EXTENT 0.2 0.6 99.8 299.4
-IMAGETYPE PNG
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 CONFIG MS_NONSQUARE YES
 PROJECTION
Modified: trunk/msautotest/gdal/offsite_8bitgrey.map
--- trunk/msautotest/gdal/offsite_8bitgrey.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/offsite_8bitgrey.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -11,7 +11,11 @@
-IMAGETYPE png
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 LAYER
   NAME grey
Modified: trunk/msautotest/gdal/offsite_pct_rgb.map
--- trunk/msautotest/gdal/offsite_pct_rgb.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/offsite_pct_rgb.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -11,7 +11,11 @@
-IMAGETYPE png
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 LAYER
   NAME grey
Modified: trunk/msautotest/gdal/ows_extent.map
--- trunk/msautotest/gdal/ows_extent.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/ows_extent.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -11,7 +11,11 @@
 EXTENT 1000.5 1000.5 1399.5 1299.5
-IMAGETYPE png
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 LAYER
   NAME grey
Added: trunk/msautotest/gdal/simplealpha.map
--- trunk/msautotest/gdal/simplealpha.map	                        (rev 0)
+++ trunk/msautotest/gdal/simplealpha.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -0,0 +1,26 @@
+# Simple alpha image render on blank background.
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+OUTPUTFORMAT
+  NAME png24_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE RGBA
+END
+LAYER
+  NAME grey_overlay
+  TYPE raster
+  STATUS default
+  DATA data/greyalpha.vrt
+END
+END # of map file
Added: trunk/msautotest/gdal/simplealpha_plug.map
--- trunk/msautotest/gdal/simplealpha_plug.map	                        (rev 0)
+++ trunk/msautotest/gdal/simplealpha_plug.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -0,0 +1,28 @@
+# REQUIRES: SUPPORTS=AGG
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+OUTPUTFORMAT
+  NAME png24_t
+  DRIVER "AGG/PNG"
+  IMAGEMODE RGBA
+END
+LAYER
+  NAME grey_overlay
+  TYPE raster
+  STATUS default
+END
+END # of map file
Modified: trunk/msautotest/gdal/wmsclient.map
--- trunk/msautotest/gdal/wmsclient.map	2011-03-18 14:11:16 UTC (rev 11220)
+++ trunk/msautotest/gdal/wmsclient.map	2011-03-18 14:14:15 UTC (rev 11221)
@@ -11,7 +11,11 @@
 EXTENT -180 -60 180 85
-IMAGETYPE png
+OUTPUTFORMAT
+  NAME png8_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE PC256
+END
 WEB
   IMAGEPATH "./tmp/"
