[mapserver-commits] r11226 - trunk/mapserver
Fri Mar 18 10:29:21 EDT 2011
Author: sdlime
Date: 2011-03-18 07:29:21 -0700 (Fri, 18 Mar 2011)
New Revision: 11226
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/MIGRATION_GUIDE.TXT
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapserv.c
   trunk/mapserver/mapserver.h
Require validation pattern for all runtime substitutions.
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-18 14:27:47 UTC (rev 11225)
+++ trunk/mapserver/HISTORY.TXT	2011-03-18 14:29:21 UTC (rev 11226)
@@ -1,3 +1,4 @@
 MapServer Revision History
@@ -13,6 +14,9 @@
 Current Version (SVN trunk):
+- CGI runtime substitution requires a validation pattern (was optional before) (#3522)
 - add a default png8 outputformat that uses AGG/PNG with quantization
 - change MS_INIT_COLOR to take alpha as a parameter
Modified: trunk/mapserver/MIGRATION_GUIDE.TXT
--- trunk/mapserver/MIGRATION_GUIDE.TXT	2011-03-18 14:27:47 UTC (rev 11225)
+++ trunk/mapserver/MIGRATION_GUIDE.TXT	2011-03-18 14:29:21 UTC (rev 11226)
@@ -83,6 +83,11 @@
 CGI Changes
+Runtime subsitution now *requires* a validation pattern be present before the
+substitution will take place (this had been optional). This can be done via
+a layer metadata tag as before or within layer or web VALIDATION blocks. See
+ticket #3522 for more information.
 All of the query map related modes (e.g. NQUERYMAP, ITEMQUERYMAP, etc...) have
 been removed in favor of using the "qformat" parameter. That parameter takes
 an output format name or mime/type as a value and uses that to process a set
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2011-03-18 14:27:47 UTC (rev 11225)
+++ trunk/mapserver/mapfile.c	2011-03-18 14:29:21 UTC (rev 11226)
@@ -5823,36 +5823,51 @@
   return(MS_SUCCESS);
-/* look in places authorized for url substitution and replace "from" by "to" */
-void msLayerSubstituteString(layerObj *layer, const char *from, const char *to) {
-  int k;
-  char* bindvals_key = (char*)msFirstKeyFromHashTable(&layer->bindvals);
-  char* bindvals_val;
+static int layerNeedsSubstitutions(layerObj *layer, char *from) {
+  int i;
-  if(layer->data && (strcasestr(layer->data, from) != NULL))
-    layer->data = msCaseReplaceSubstring(layer->data, from, to);
-  if(layer->tileindex && (strcasestr(layer->tileindex, from) != NULL))
-    layer->tileindex = msCaseReplaceSubstring(layer->tileindex, from, to);
-  if(layer->connection && (strcasestr(layer->connection, from) != NULL))
-    layer->connection = msCaseReplaceSubstring(layer->connection, from, to);
-  if(layer->filter.string && (strcasestr(layer->filter.string, from) != NULL))
-    layer->filter.string = msCaseReplaceSubstring(layer->filter.string, from, to);
-  for(k=0; k<layer->numclasses; k++) {
-    if(layer->class[k]->expression.string && (strcasestr(layer->class[k]->expression.string, from) != NULL))
-      layer->class[k]->expression.string = msCaseReplaceSubstring(layer->class[k]->expression.string, from, to);
+  if(layer->data && (strcasestr(layer->data, from) != NULL)) return MS_TRUE;
+  if(layer->tileindex && (strcasestr(layer->tileindex, from) != NULL)) return MS_TRUE;
+  if(layer->connection && (strcasestr(layer->connection, from) != NULL)) return MS_TRUE;
+  if(layer->filter.string && (strcasestr(layer->filter.string, from) != NULL)) return MS_TRUE;
+  for(i=0; i<layer->numclasses; i++) {
+    if(layer->class[i]->expression.string && (strcasestr(layer->class[i]->expression.string, from) != NULL))
+      return MS_TRUE;
- /* The bindvalues are most useful when able to substitute values from the URL */
+  if(!msHashIsEmpty(&layer->bindvals)) return MS_TRUE;
+  return MS_FALSE;
+static void layerSubstituteString(layerObj *layer, char *from, char *to) {
+  int i;
+  char *bindvals_key, *bindvals_val;
+  if(layer->data) layer->data = msCaseReplaceSubstring(layer->data, from, to);
+  if(layer->tileindex) layer->tileindex = msCaseReplaceSubstring(layer->tileindex, from, to);
+  if(layer->connection) layer->connection = msCaseReplaceSubstring(layer->connection, from, to);
+  if(layer->filter.string) layer->filter.string = msCaseReplaceSubstring(layer->filter.string, from, to);
+    if(layer->class[i]->expression.string)
+      layer->class[i]->expression.string = msCaseReplaceSubstring(layer->class[i]->expression.string, from, to);
+  /* The bindvalues are most useful when able to substitute values from the URL */
+  bindvals_key = (char*)msFirstKeyFromHashTable(&layer->bindvals);
   while(bindvals_key != NULL) {
     bindvals_val = msStrdup((char*)msLookupHashTable(&layer->bindvals, bindvals_key));
     msInsertHashTable(&layer->bindvals, bindvals_key, msCaseReplaceSubstring(bindvals_val, from, to));
     bindvals_key = (char*)msNextKeyFromHashTable(&layer->bindvals, bindvals_key);
-/* loop through layer metadata for keys that have a default_%key% pattern to replace
-* remaining %key% entries by their default value */
+** Loop through layer metadata for keys that have a default_%key% pattern to replace
+** remaining %key% entries by their default value.
 void msApplyDefaultSubstitutions(mapObj *map) {
   int i;
   for(i=0;i<map->numlayers;i++) {
@@ -5864,7 +5879,7 @@
         char *tmpstr = (char *)msSmallMalloc(buffer_size);
         snprintf(tmpstr, buffer_size, "%%%s%%", &(defaultkey[8]));
-        msLayerSubstituteString(layer,tmpstr,msLookupHashTable(&(layer->metadata),defaultkey));
+        layerSubstituteString(layer,tmpstr,msLookupHashTable(&(layer->metadata),defaultkey));
         free(tmpstr);
       defaultkey = msNextKeyFromHashTable(&(layer->metadata),defaultkey);
@@ -5872,6 +5887,39 @@
+void msApplySubstitutions(mapObj *map, char **names, char **values, int npairs) {
+  int i,j;
+  char *tag=NULL;
+  char *validation_pattern_key=NULL;
+  for(i=0; i<npairs; i++) {
+    /* runtime subtitution string */
+    tag = (char *) msSmallMalloc(sizeof(char)*strlen(names[i]) + 3);
+    sprintf(tag, "%%%s%%", names[i]);
+    /* validation pattern key - depricated */
+    validation_pattern_key = (char *) msSmallMalloc(sizeof(char)*strlen(names[i]) + 20);
+    sprintf(validation_pattern_key,"%s_validation_pattern", names[i]);
+    for(j=0; j<map->numlayers; j++) {
+      layerObj *layer = GET_LAYER(map, j);
+      if(!layerNeedsSubstitutions(layer, tag)) continue;
+      fprintf(stderr, "Layer %s, tag %s...\n", layer->name, tag);
+      if(msValidateParameter(values[i], msLookupHashTable(&(layer->validation), names[i]), msLookupHashTable(&(layer->metadata), validation_pattern_key), msLookupHashTable(&(map->web.validation), names[i]), NULL) == MS_SUCCESS) {
+        layerSubstituteString(layer, tag, values[i]);
+    msFree(tag);
+    msFree(validation_pattern_key);
+  } /* next name/value pair */
 ** Returns an array with one entry per mapfile token.  Useful to manipulate
 ** mapfiles in MapScript.
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2011-03-18 14:27:47 UTC (rev 11225)
+++ trunk/mapserver/mapserv.c	2011-03-18 14:29:21 UTC (rev 11226)
@@ -183,9 +183,8 @@
 mapObj *loadMap(void)
-  int i,j;
+  int i;
   mapObj *map = NULL;
-  char *tmpstr, *key, *value=NULL;
   for(i=0;i<mapserv->request->NumParams;i++) /* find the mapfile parameter first */
     if(strcasecmp(mapserv->request->ParamNames[i], "map") == 0) break;
@@ -234,31 +233,9 @@
       if(msUpdateMapFromURL(map, mapserv->request->ParamNames[i], mapserv->request->ParamValues[i]) != MS_SUCCESS) writeError();
       continue;
-    /* runtime subtitution string */
-    tmpstr = (char *)msSmallMalloc(sizeof(char)*strlen(mapserv->request->ParamNames[i]) + 3);
-    sprintf(tmpstr,"%%%s%%", mapserv->request->ParamNames[i]);
-    /* validation pattern metadata key */
-    key = (char *)msSmallMalloc(sizeof(char)*strlen(mapserv->request->ParamNames[i]) + 20);
-    sprintf(key,"%s_validation_pattern", mapserv->request->ParamNames[i]);
-    for(j=0; j<map->numlayers; j++) {
-      layerObj *layer = GET_LAYER(map, j);
-      value = msLookupHashTable(&(layer->metadata), key);
-      if(value) { /* validate parameter value */
-        if(msEvalRegex(value, mapserv->request->ParamValues[i]) == MS_FALSE) {
-          msSetError(MS_WEBERR, "Parameter '%s' value fails to validate.", "loadMap()", mapserv->request->ParamNames[i]);
-          writeError();
-      msLayerSubstituteString(layer, tmpstr, mapserv->request->ParamValues[i]);
-    free(tmpstr);
-    free(key);
+  msApplySubstitutions(map, mapserv->request->ParamNames, mapserv->request->ParamValues, mapserv->request->NumParams);
   msApplyDefaultSubstitutions(map);
   /* check to see if a ogc map context is passed as argument. if there */
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2011-03-18 14:27:47 UTC (rev 11225)
+++ trunk/mapserver/mapserver.h	2011-03-18 14:29:21 UTC (rev 11226)
@@ -1702,7 +1702,7 @@
 MS_DLL_EXPORT void freeExpressionTokens(expressionObj *exp);
 MS_DLL_EXPORT void freeExpression(expressionObj *exp);
-MS_DLL_EXPORT void msLayerSubstituteString(layerObj *layer, const char *from, const char *to);
+MS_DLL_EXPORT void msApplySubstitutions(mapObj *map, char **names, char **values, int npairs);
 MS_DLL_EXPORT void msApplyDefaultSubstitutions(mapObj *map);
 MS_DLL_EXPORT int getClassIndex(layerObj *layer, char *str);
