[mapserver-commits] r11231 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Fri Mar 18 11:17:35 EDT 2011
Author: tbonfort
Date: 2011-03-18 08:17:35 -0700 (Fri, 18 Mar 2011)
New Revision: 11231
trunk/mapserver/maperror.c
trunk/mapserver/mapfile.c
trunk/mapserver/mapoutput.c
trunk/mapserver/mapserver.h
change msCreateDefaultOutputFormat to accept a name
Modified: trunk/mapserver/maperror.c
--- trunk/mapserver/maperror.c 2011-03-18 15:04:31 UTC (rev 11230)
+++ trunk/mapserver/maperror.c 2011-03-18 15:17:35 UTC (rev 11231)
@@ -417,7 +417,7 @@
/* Default to GIF if no suitable GD output format set */
if (format == NULL || !MS_RENDERER_PLUGIN(format) || !format->vtable->supports_bitmap_fonts)
- format = msCreateDefaultOutputFormat( NULL, "GD/PC256" );
+ format = msCreateDefaultOutputFormat( NULL, "GD/PC256", "gif" );
img = msImageCreate(width,height,format,imagepath,imageurl,MS_DEFAULT_RESOLUTION,MS_DEFAULT_RESOLUTION,NULL);
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c 2011-03-18 15:04:31 UTC (rev 11230)
+++ trunk/mapserver/mapfile.c 2011-03-18 15:17:35 UTC (rev 11231)
@@ -4137,7 +4137,8 @@
msyystring_buffer, msyylineno );
return -1;
- format = msCreateDefaultOutputFormat( map, driver );
+ format = msCreateDefaultOutputFormat( map, driver, name );
if( format == NULL )
msSetError(MS_MISCERR,
@@ -4147,11 +4148,6 @@
msFree( driver );
- if( name != NULL )
- msFree( format->name );
- format->name = name;
if( transparent != MS_NOOVERRIDE )
format->transparent = transparent;
if( extension != NULL )
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c 2011-03-18 15:04:31 UTC (rev 11230)
+++ trunk/mapserver/mapoutput.c 2011-03-18 15:17:35 UTC (rev 11231)
@@ -155,7 +155,8 @@
outputFormatObj *msCreateDefaultOutputFormat( mapObj *map,
- const char *driver )
+ const char *driver,
+ const char *name )
outputFormatObj *format = NULL;
@@ -163,9 +164,9 @@
if( strcasecmp(driver,"GD/PC256") == 0 )
#ifdef USE_GD_GIF
- return msCreateDefaultOutputFormat( map, "GD/GIF" );
+ return msCreateDefaultOutputFormat( map, "GD/GIF", "gif" );
#elif defined(USE_GD_PNG)
- return msCreateDefaultOutputFormat( map, "GD/PNG" );
+ return msCreateDefaultOutputFormat( map, "GD/PNG", "gdpng" );
#else
return NULL;
#endif
@@ -174,7 +175,8 @@
#ifdef USE_GD_GIF
if( strcasecmp(driver,"GD/GIF") == 0 )
- format = msAllocOutputFormat( map, "gif", driver );
+ if(!name) name="gif";
+ format = msAllocOutputFormat( map, name, driver );
format->mimetype = msStrdup("image/gif");
format->imagemode = MS_IMAGEMODE_PC256;
format->extension = msStrdup("gif");
@@ -185,7 +187,8 @@
#ifdef USE_GD_PNG
if( strcasecmp(driver,"GD/PNG") == 0 )
- format = msAllocOutputFormat( map, "png", driver );
+ if(!name) name="gdpng";
format->mimetype = msStrdup("image/png");
format->extension = msStrdup("png");
@@ -195,7 +198,8 @@
if( strcasecmp(driver,"AGG/PNG") == 0 )
- format = msAllocOutputFormat( map, "png24", driver );
+ if(!name) name="png24";
format->mimetype = msStrdup("image/png; mode=24bit");
format->imagemode = MS_IMAGEMODE_RGB;
@@ -203,7 +207,8 @@
if( strcasecmp(driver,"AGG/PNG8") == 0 )
- format = msAllocOutputFormat( map, "png8", driver );
+ if(!name) name="png8";
format->mimetype = msStrdup("image/png; mode=8bit");
@@ -214,7 +219,8 @@
if( strcasecmp(driver,"AGG/JPEG") == 0 )
- format = msAllocOutputFormat( map, "jpeg", driver );
+ if(!name) name="jpeg";
format->mimetype = msStrdup("image/jpeg");
format->extension = msStrdup("jpg");
@@ -224,7 +230,8 @@
#if defined(USE_CAIRO)
if( strcasecmp(driver,"CAIRO/PNG") == 0 )
- format = msAllocOutputFormat( map, "cairopng", driver );
+ if(!name) name="cairopng";
@@ -232,7 +239,8 @@
if( strcasecmp(driver,"CAIRO/JPEG") == 0 )
- format = msAllocOutputFormat( map, "cairojpeg", driver );
+ if(!name) name="cairojpeg";
@@ -240,7 +248,8 @@
if( strcasecmp(driver,"CAIRO/PDF") == 0 )
- format = msAllocOutputFormat( map, "pdf", driver );
+ if(!name) name="pdf";
format->mimetype = msStrdup("application/x-pdf");
format->extension = msStrdup("pdf");
@@ -248,7 +257,8 @@
if( strcasecmp(driver,"CAIRO/SVG") == 0 )
- format = msAllocOutputFormat( map, "svg", driver );
+ if(!name) name="svg";
format->mimetype = msStrdup("image/svg+xml");
format->extension = msStrdup("svg");
@@ -257,7 +267,8 @@
#ifdef _WIN32
if( strcasecmp(driver,"CAIRO/WINGDI") == 0 )
- format = msAllocOutputFormat( map, "cairowinGDI", driver );
+ if(!name) name="cairowinGDI";
format->mimetype = msStrdup("");
format->extension = msStrdup("");
@@ -265,7 +276,8 @@
if( strcasecmp(driver,"CAIRO/WINGDIPRINT") == 0 )
- format = msAllocOutputFormat( map, "cairowinGDIPrint", driver );
+ if(!name) name="cairowinGDIPrint";
@@ -277,7 +289,8 @@
#if defined(USE_OGL)
if( strcasecmp(driver,"OGL/PNG") == 0 )
- format = msAllocOutputFormat( map, "oglpng24", driver );
+ if(!name) name="oglpng24";
@@ -288,7 +301,8 @@
#if defined(USE_KML)
if( strcasecmp(driver,"KML") == 0 )
- format = msAllocOutputFormat( map, "kml", driver );
+ if(!name) name="kml";
format->mimetype = msStrdup("application/vnd.google-earth.kml+xml");
format->extension = msStrdup("kml");
@@ -297,7 +311,8 @@
if( strcasecmp(driver,"KMZ") == 0 )
- format = msAllocOutputFormat( map, "kmz", driver );
+ if(!name) name="kmz";
format->mimetype = strdup("application/vnd.google-earth.kmz");
format->extension = strdup("kmz");
@@ -311,7 +326,8 @@
#ifdef USE_GDAL
if( strncasecmp(driver,"gdal/",5) == 0 )
- format = msAllocOutputFormat( map, driver+5, driver );
+ if(!name) name=driver+5;
if( msInitDefaultGDALOutputFormat( format ) == MS_FAILURE )
if( map != NULL )
@@ -328,7 +344,8 @@
#ifdef USE_OGR
if( strncasecmp(driver,"ogr/",4) == 0 )
- format = msAllocOutputFormat( map, driver+4, driver );
+ if(!name) name=driver+4;
if( msInitDefaultOGROutputFormat( format ) == MS_FAILURE )
if( map != NULL )
@@ -344,7 +361,8 @@
#endif
if( strcasecmp(driver,"imagemap") == 0 )
- format = msAllocOutputFormat( map, "imagemap", driver );
+ if(!name) name="imagemap";
format->mimetype = msStrdup("text/html; driver=imagemap");
format->extension = msStrdup("html");
format->imagemode = MS_IMAGEMODE_NULL;
@@ -352,7 +370,8 @@
if( strcasecmp(driver,"template") == 0 ) {
- format = msAllocOutputFormat( map, "template", driver );
+ if(!name) name="template";
format->mimetype = msStrdup("text/html");
format->imagemode = MS_IMAGEMODE_FEATURE;
@@ -384,7 +403,7 @@
defEntry = defaultoutputformats;
while(defEntry->name) {
if( msSelectOutputFormat( map, defEntry->name ) == NULL )
- msCreateDefaultOutputFormat( map, defEntry->driver );
+ msCreateDefaultOutputFormat( map, defEntry->driver, defEntry->name );
defEntry++;
if( map->imagetype != NULL )
@@ -591,7 +610,7 @@
struct defaultOutputFormatEntry *formatEntry = defaultoutputformats;
while(formatEntry->name) {
if(!strcasecmp(imagetype,formatEntry->name) || !strcasecmp(imagetype,formatEntry->mimetype)) {
- format = msCreateDefaultOutputFormat( map, formatEntry->driver );
+ format = msCreateDefaultOutputFormat( map, formatEntry->driver, formatEntry->name );
break;
formatEntry++;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h 2011-03-18 15:04:31 UTC (rev 11230)
+++ trunk/mapserver/mapserver.h 2011-03-18 15:17:35 UTC (rev 11231)
@@ -2317,7 +2317,7 @@
MS_DLL_EXPORT outputFormatObj *msSelectOutputFormat( mapObj *map, const char *imagetype );
MS_DLL_EXPORT void msApplyOutputFormat( outputFormatObj **target, outputFormatObj *format, int transparent, int interlaced, int imagequality );
MS_DLL_EXPORT const char *msGetOutputFormatOption( outputFormatObj *format, const char *optionkey, const char *defaultresult );
-MS_DLL_EXPORT outputFormatObj *msCreateDefaultOutputFormat( mapObj *map, const char *driver );
+MS_DLL_EXPORT outputFormatObj *msCreateDefaultOutputFormat( mapObj *map, const char *driver, const char *name );
MS_DLL_EXPORT int msPostMapParseOutputFormatSetup( mapObj *map );
MS_DLL_EXPORT void msSetOutputFormatOption( outputFormatObj *format, const char *key, const char *value );
MS_DLL_EXPORT void msGetOutputFormatMimeList( mapObj *map, char **mime_list, int max_mime );
More information about the mapserver-commits
