[mapserver-commits] r11233 - trunk/mapserver
Fri Mar 18 12:02:16 EDT 2011
Author: jmckenna
Date: 2011-03-18 09:02:16 -0700 (Fri, 18 Mar 2011)
New Revision: 11233
Added:
   trunk/mapserver/migration_guide_.txt
temp rename, to avoid uppercase Sphinx problems
Copied: trunk/mapserver/migration_guide_.txt (from rev 11232, trunk/mapserver/MIGRATION_GUIDE.TXT)
--- trunk/mapserver/migration_guide_.txt	                        (rev 0)
+++ trunk/mapserver/migration_guide_.txt	2011-03-18 16:02:16 UTC (rev 11233)
@@ -0,0 +1,641 @@
+.. _migration:
+MapServer Migration Guide
+:Last Updated: 2011-03-17
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+MapServer 5.6 to 6.0 Migration
+This section documents the changes that must be made to MapServer
+applications when migrating from version 5.6.x (or earlier versions)
+to 6.0 (i.e. backwards incompatibilities), as well as information
+on some of the new features.
+Mapfile Changes - Expression Parsing
+Version 6.0 features an extensive reworking of the expression parsing capabilities.
+While this adds functionality it also introduces a couple of regressions:
+Logical Expressions
+* a regex is now deliniated as a string (e.g. '^a' rather than /^a/)
+* the regex operator is ~ for case sensitive comparisons and ~* for case insensitive
+* case insensitive string comparison operator is =*
+Class text expressions are true expressions in 6.0. This allows for fancy formatting
+of numeric data but also means string operators must be used to concatenate attribute
+values and string literals.
+* Old/bad: TEXT ([area] acres)
+* New (option 1)/good: TEXT ([area] + ' acres')
+* New (option 2)/good: TEXT '[area] acres'
+On the plus side you can now control the number of decimal places, round and even commify
+the area value for annotion.
+See http://mapserver.org/development/rfc/ms-rfc-64.html and http://trac.osgeo.org/mapserver/ticket/3736
+for more information.
+Mapfile Changes	- Label Styles
+As the need for more and more control of label drawing increased it became apparent that
+we couldn't extend labelObj's endlessly. In 6.0 we introduce the idea of label styles, that
+is, a styleObj inside a labelObj. The styles can be used to add accompanying markers or
+bounding box elements to a label- kinda like annotation layers. The big benefit is that
+it's done in one pass. So you can draw complex roadwork and shields all at the same time.
+Pretty neat huh? Plus you can do attribute binding for any of the styleObj attributes that
+support it.
+As a result the parameters BACKGROUNDCOLOR, BACKGROUNDSHADOWCOLOR, BACKGROUNDSHADOWSIZE
+are no more. To draw a label "box" in 6.0 you'd do:
+  LABEL
+    STYLE # a shadow
+      GEOMTRANSFORM 'labelpoly'
+      COLOR 222 222 222
+      OFFSET 2 2
+    END
+    STYLE # bbox
+      COLOR 255 255 255
+      OUTLINECOLOR 0 0 0
+    END
+  END
+More verbose but *much* more flexible in the long run.
+CGI Changes
+Runtime subsitution now *requires* a validation pattern be present before the
+substitution will take place (this had been optional). This can be done via
+a layer metadata tag as before or within layer or web VALIDATION blocks. See
+ticket #3522 for more information.
+All of the query map related modes (e.g. NQUERYMAP, ITEMQUERYMAP, etc...) have
+been removed in favor of using the "qformat" parameter. That parameter takes
+an output format name or mime/type as a value and uses that to process a set
+of query results. For example:
+  ...&mode=nquerymap&... would become ...&mode=nquery&qformat=png24&...
+OGC Web Services
+All OGC Web Services are now disabled by default. If you want to enable them as
+they were in MapServer 5.6 and older releases, add the following metadata in the
+MAP::WEB section::
+ "ows_enable_request"   "*"
+See also: http://mapserver.org/development/rfc/ms-rfc-67.html
+PHP MapScript Changes
+* PHP 5.2.0 or more recent is required.
+* PHP/MapScript now uses exceptions for error report. All errors are catchable.
+* Object properties can be set like all other php object. ie. myObj->myProperty = 10;
+  NOTE: The set/setProperty methods are still available.
+* All object constructors throw an exception on failure
+* Objects can be created with the php "new" operator. ie.
+  $myShape = ms_newShapeObj(MS_SHAPE_LINE); // or
+  $myShape = new shapeObj(MS_SHAPE_LINE);
+  NOTE: "ms_newSymbolObj()" and "new symbolObj" are different:
+        - ms_newSymbolObj() returns the id of the new/existing symbol.
+        - new symbolObj() returns the symbolObj. You don't need to
+                          get it with getSymbolObjectById().
+* Class properties that have been removed
+  - mapObj: imagequality, interlace, scale, transparent
+  - classObj: maxscale, minscale
+  - layerObj: labelsizeitem, labelangleitem, labelmaxscale, labelminscale,
+              maxscale, minscale, symbolscale, transparency
+  - legendObj: interlace, transparent
+  - scalebarObj: interlace, transparent
+  - symbolObj: gap, stylelength
+  - webObj: minscale, maxscale
+  - mapObj: imagetype
+* Class methods that have been removed
+  - projectionObj: free
+  - lineObj: free
+  - pointObj: free
+  - rectObj: free
+  - shapeObj: free, union_geos
+  - symbolObj: free, getstylearray
+  - imageObj: free
+  - outputFormatObj: getformatoption, setformatoption
+  - shapefileObj: free
+  - layerObj: getFilter, getShape
+* referenceMapObj has new properties: marker, markername, markersize, maxboxsize, minboxsize
+* shapeFileObj is automatically closed/writed on destroy. (At the end of the script or with an explicit unset())
+* layerObj->clearProcessing() method now returns void.
+* mapObj->queryByIndex(): default behavior for the addToQuery parameter was not ok, now it is.
+* Methods that now return MS_SUCCESS/MS_FAILURE:
+  - symbolObj: setPoints, setPattern
+  - scalebarObj: setImageColor
+  - outputFormatObj: validate
+  - layerObj: setProcessing, addFeature, draw
+  - mapObj: moveLayerUp, moveLayerDown, zoomRectangle, zoomScale, setProjection,
+            setWKTProjection, setLayersDrawingOrder
+* Methods that now return NULL on failure:
+  - classObj: clone
+  - styleObj: clone
+  - layerObj: nextShape, getExtent
+  - mapObj: clone, draw, drawQuery getLayerByName, getProjection,
+* Methods that now return an empty array
+  - symbolObj: getPatternArray
+  - layerObj: getItems, getProcessing, getGridIntersectionCoordinates
+  - mapObj: getLayersIndexByGroup, getAllGroupNames, getLayersDrawingOrder, getAllLayerNames
+MapScript (All Flavors)
+The layer query result handing has been re-worked (again) to address some issues introduced in
+the 5.4/5.6 versions. Gone are resultsGetShape and getFeature methods. You should now use a
+refactored getShape method to access layer shapes. That method takes a resultObj and returns
+a shapeObj. Typical use would be (in Perl):
+  $layer->queryByRect($map, $map->{extent}); # layer is still open
+  for($i=0; $i<$layer->getNumResults(); $i++) {
+    $shape = $layer->getShape($layer->getResult($i));
+    print "$i: ". $shape->getValue(1) ."\n";
+  $layer->close();
+A resultObj encapsulates the data used to manage a result set.
+To access shapes independently of a query use the new resultObj class:
+  $layer->open();
+  $shape = $layer->getShape(new mapscript::resultObj(1));
+  $layer->close();
+See http://mapserver.org/development/rfc/ms-rfc-65.html for more information.
+OUTPUTFORMAT
+The OUTPUTFORMAT parameter validation when reading from the mapfile
+will now trigger an error on some problems that in the past were
+silently fixed up.  For instance using RGBA IMAGEMODE with JPEG format
+now triggers an error instead of switching to IMAGEMODE RGB silently.
+Rasters
+* The support for rendering rasters without GDAL has been removed.  Now
+  RASTER layers (or WMS layers) require that MapServer be built against
+  the GDAL library.
+* The above change also means there is no longer support for EPPL raster layers.
+Deprecated features
+- Support for Flash/SWF output has been removed as part of the rendering overhaul
+  because it was no longer compatible with the new architecture.
+  Support for Flash/SWF could be reintroduced but would require a non trivial
+  amount of work (i.e. would require funding).
+- Support for "CONNECTIONTYPE MyGIS" has been dropped since it was no longer
+  being maintained and there are better ways to use MySQL data sources theses
+  days, going through OGR for instance.
+MapServer 5.4 to 5.6 Migration
+applications when migrating from version 5.4.x (or earlier versions)
+to 5.6 (i.e. backwards incompatibilities), as well as information
+MapScript changes related to single pass queries
+In RFC-52, MapServer was modified to perform queries using a single pass
+on the data instead of two passes. This is transparent for CGI applications,
+but MapScript scripts must be modified to use the layer.resultsGetShape()
+method instead of layer.getShape().
+See also: http://mapserver.org/development/rfc/ms-rfc-52.html
+(Note: the new resultsGetShape() method is not yet available for PHP MapScript
+in 5.6.0-beta1)
+WFS 1.1 axis orientation
+The axis order in previous versions of the WFS specifications was to always use easting (x or lon ) and northing (y or lat).  WMS 1.1 specifies that, depending on the particular SRS, the x axis may or may not be oriented West-to-East, and the y axis may or may not be oriented South-to-North. The WFS portrayal operation shall account for axis order. This affects some of the EPSG codes that were commonly used such as ESPG:4326.  The current implementation makes sure that coordinates returned to the server for the GetFeature request reflect the inverse axis orders for EPSG codes between 4000 and 5000.
+Change of mime-type for the imagemap outputformat
+RFC 36 added support for templated outptformats, but this new feature
+was not available for WMS GetFeatureInfo ouptut (see ticket #3024).
+In MapServer 5.6 this has been resolved by implementing lookup of output
+formats for query templates by mime-type. However this caused a conflict
+for the text/html mime-type between the actual text/html query
+templates and the preconfigured imagemap outputformat which also used the
+text/html mime-type.
+In order to resolve this conflict, the mime-type of the imagemap outputformat
+has been changed to "text/html; driver=imagemap". This is unlikely to cause
+much side-effects to existing applications, but the change is documented here
+just in case.
+MapServer 5.2 to 5.4 Migration
+applications when migrating from version 5.2. (or earlier versions)
+to 5.4 (i.e. backwards incompatibilities), as well as information
+New requirements for mapfiles, symbolsets and templates
+Due to some potential security vulnerabilities that were uncovered in previous
+versions of MapServer, RFC-56 introduced a number of changes to tighten
+access control on mapfiles and templates and limit the risk of leaking
+arbitrary file contents. These changes were introduced in version 5.4.0,
+and were also backported to v5.2.2 and 4.10.4.
+The new requirements are as follows:
+* The MAP and SYMBOLSET keywords must be added to any mapfile and symbolset
+  that did not contain them already.
+* All MapServer templates must be updated to contain the "MapServer Template"
+  magic string on the first line. This string can be embedded
+  in a commment depending on the template formet and the whole line will
+  be skipped in the output generation. e.g.
+  * In HTML: <!-- MapServer Template -->
+  * In JavaScript: // MapServer Template
+See also: http://mapserver.org/development/rfc/ms-rfc-56.html
+MapServer 4.10 to 5.0 Migration
+applications when migrating from version 4.10.x (or earlier versions)
+to 5.x (i.e. backwards incompatibilities), as well as information
+Mapfile changes
+Attribute Bindings: In an effort to stem the tide of keyword overload
+and add functionality MapServer 5.0 supports a new method of binding
+feature attributes to STYLE and LABEL properties. In the past keywords
+like ANGLEITEM or LABELSIZEITEM were used, now you denote the attribute
+in the context of the property being bound. For example, to bind an
+attribute to a label size you'd do:
+  LABEL
+    SIZE [mySizeItem]
+  END
+The []'s denote a binding (as with logical expressions). The following
+keywords are no longer supported and their presence will throw an error:
+* Layer: LABELANGLEITEM, LABELSIZEITEM
+* Style: ANGLEITEM, SIZEITEM
+The following properties can accept bindings:
+* Style: angle, color, outlinecolor, size, symbol
+* Label: angle, color, outlinecolor, size, font, priority
+Colors may be given as a hex value (e.g. #FFFFFF) or an RGB triplet
+(e.g. 255 255 255).
+Layer Transparency: The values for the TRANSPARENCY parameter have always
+been backwards and in an effort to resolve that the parameter has been
+renamed OPACITY. TRANSPARENCY is still recognized by the mapfile parser
+but is depricated and should be avoided.
+Scale Parameters: MapServer's handling of scale has long been a source
+for confusion. The values use in a layer MINSCALE are really the denominators
+from a representative fraction (e.g. 1:24000). To help clarify this all
+scale parameters are now end with DENOM. So MINSCALE => MINSCALEDENOM,
+SYMBOLSCALE => SYMBOLSCALEDENOM, and so on. The mapfile parser still
+recognizes the older keywords but they are depricated and should be avoided.
+Symbol file changes
+Symbol Style: STYLEs are used within a symbol definition to store dash
+patterns for line symbolization. However, there is potential confusion
+with the style object that is used within class definitions. To resolve
+that confusion the symbol STYLE parameter has been renamed PATTERN. The
+symbol file parser will still recognize the STYLE keyword but it is
+depricated and should be avoided.
+Styling/Symbolgy changes
+Prior to MapsServer 5.0, if a pixmap symbol was used in style on a Line
+Layer, the symbol was used as a brush to draw the line. In MapServer 5.0,
+it is possible to draw the pixmap symbol along the line (Note that this
+was available using a true type symbol). To achieve  this, the user needs
+to use the parameter GAP with it's pixmap symbol definition in the symbol
+file. The GAP represents the distance between the symbols. If the GAP is not
+given, the pixmap symbol will be used as a brush.
+AGG rendering changes
+see `the AGG rendering specifics`_ for the changes relating to the addition
+of the `Antigrain Geometry`_ rendering engine.
+.. _`the AGG rendering specifics`: http://mapserver.gis.umn.edu/docs/howto/agg-rendering-specifics
+.. _`Antigrain Geometry`: http://www.antigrain.com
+URL configuration changes
+Previous versions of the MapServer CGI program allowed certain parameters
+to be changed via a URL using a cumbersome syntax such as
+map_layer_0_class_0_color=255+0+0 which changes the color in one classObj.
+Not only was this cumbersome for users but also from a code maintenance
+perspective since we had to maintain seperate loaders for URL-based config
+and file-based config. RFC-31 attempts to streamline both by migrating to
+a single object loading function that can be used with strings (either in
+MapScript or via URL) or with files.
+So, in the past you have to change parameters one-at-a-time. Now you can
+pass chunks of mapfiles (with security restrictions) to the CGI interface.
+The map_object notation is still necessary to identify which object you
+want to modify but you can change multiple properties at one time. Note
+that you can use either a '_' or a '.' to seperate identifiers.
+Example 1, changing a scalebar object:
+  ...&map.scalebar=UNITS+MILES+COLOR+121+121+121+SIZE+300+2&...
+Example 2, changing a presentation style:
+ ...&map.layer[lakes].class[0].style[0]=SYMBOL+crosshatch+COLOR+151+51+151+SIZE+15&...
+Example 3, creating a new feature
+  ...&map_layer[3]=FEATURE+POINTS+500000+1000000+END+TEXT+'A+test+point'+END&...
+The variable identifies an object uniquely (by name or index in the case of
+layerObj's and classObj's). The value is a snippet of a mapfile. You
+cannot create new objects other than inline features at this point.
+Validation patterns for mapserv attribute queries
+Attribute queries (qstring) done via the mapserv CGI could theoretically
+be used for SQL injection.
+No exploit has been reported, but in order to mitigate the risk, a new
+validation pattern mechanism has been added in 5.0.
+In the case of qstring attribute queries, the qstring_validation_pattern
+layer-level metadata is required for qstring queries to work. The metadata
+value is a regular expression that the qstring value must match otherwise
+mapserv produces a fatal error. A fatal error is also produced if qstring
+is used but qstring_validation_pattern is not provided.
+Note that similar validation pattern mechanism has been available for
+%variable% substitutions since version 4.10, but in this case it is optional.
+The  pattern for %myvar% is provided via a metadata called
+myvar_validation_pattern.
+SWIG MapScript (Python, Perl, CSharp, Java) changes
+Layer Transparency: The layerObj transparency parameter is now called
+opacity. Scripts setting that value in code must be updated.
+Symbol Style: the symbolObj style parameter is now called pattern. MapScript
+does not allow direct modification of that parameter. In Swig-based languages
+the symbolObj method setStyle is now called setPattern. In PHP/MapScript, the
+methods setStyle and getStyle are now called setPattern and getPattern.
+A new msGetVersionInt() function returning the current MapServer version in
+integer format has been added to facilitate version checks in the future.
+Given version x.y.z, it returns (x*0x10000 + y*0x100 + z). For instance, for
+v5.0.0 it will return 0x050000 (note the hexadecimal notation).
+CSharp related changes
+The MapScript C# classes are now placed into the OSGeo.MapServer namespace
+The scripts should use the fully qualified names of the classes or apply
+the
+  using OSGeo.MapServer;
+or the corresponding language equivalent.
+PHP/MapScript changes
+opacity. The old "transparency" name is deprecated and will be removed in
+a future release. Scripts getting/setting that value in code must be updated.
+All occurences of scale, minscale, maxscale, etc... parameters have been
+deprecated and renamed with a "denom" suffix (e.g. minscale becomes
+minscaledenom, etc.). The deprecated parameters will be removed in a
+future release. Scripts getting/setting them must be updated.
+SymbolObj style has been renamed pattern. The old "stylelength" parameter
+and setStyle() and getStyleArray() methods have been deprecated and
+"patternlength", setPattern() and getPatternArray() should be used
+instead. They will be removed in a future release.
+layer.getShape(int tileindex, int shapeindex)) has been deprecated and
+renamed to layer.getFeature(int shapeindex [, int tileindex = -1]) to
+match the SWIG MapScript equivalent. Note that the order of the arguments
+is reversed since tileindex is optional in getFeature().
+class.getExpression() and layer.getFilter() have been deprecated and
+renamed to class.getExpressionString() and layer.getFilterString() to
+match what we have in SWIG MapScript. The String suffix in the function
+name also more clearly indicates that the return value is not an object
+but a string representation of it.
+A new ms_GetVersionInt() function returning the current MapServer version in
+OGC Web Map Service (WMS)
+Required Parameters for GetMap and GetFeatureInfo: previously, MapServer
+did not check for the following parameters when responding to an OGC:WMS
+GetMap or GetFeatureInfo request:
+ - SRS
+ - FORMAT
+ - WIDTH
+ - HEIGHT
+ - STYLES or SLD / SLD_BODY
+ - BBOX
+That is, a GetMap request would process without error if these were not
+passed by the WMS client.
+A compliant OGC:WMS 1.1.0 and 1.1.1 REQUIRES these parameters.  This may
+affect OGC:WMS client requests who were not passing these values. Ticket
+1088 fully documents this issue.  In addition to WMS compliance, this was also
+decided that by adding this constraint, if an OGC client request (as described
+earlier) breaks something, people should fix their client anyway since
+if they change WMS vendor, they will have problems as well.
+OGC Web Feature Service (WFS)
+OGC Sensor Observation Service (SOS)
+- The format of MAP/LAYER/METADATA/sos_describesensor_url
+  has been changed such that users now must format the value
+  per:
+"sos_describesensor_url" "http://example.org/sml/%procedure%.xml"
+  This change has been made to clarify and unify the meaning of procedure
+  within SOS Server's context of a DescribeSensor request.
+- Metadata associated with an observedProperty element's
+  swe:component value have been changed to support a URN
+  scheme, instead of the previous "sos_componenturl" metadata.  The
+  "sos_componenturl" metadata is no longer supported.  Instead,
+  "sos_observedproperty_authority" and "sos_observedproperty_version"
+  should be used to format the swe:component value.
+Build Changes
+MapServer's main include file has been renamed from "map.h" to "mapserver.h".
+A new mapserver-config script has been created with the following options:
+  Usage: mapserver-config [OPTIONS]
+  Options:
+   [--libs]
+   [--dep-libs]
+   [--cflags]
+   [--defines]
+   [--includes]
+   [--version]
+The shared and static link libraries for MapSserver have been renamed
+libmapserver.x.y.so and libmapserver.a respectively.
+The --enable-coverage configure option has been renamed to --enable-gcov
+since the former name led users to think it might be related to enabling
+support for WCS or Arc/Info coverages:
+  --enable-gcov           Enable source code coverage testing using gcov
+Features Heading for Deprecation
+Some features present in MapServer are likely to be removed in a future
+release. Features might be headed for deprecation because:
+ - they have been replaced by a superior or more capable solution
+ - they have stopped being maintained
+Users of these features should be prepared for these upcoming changes
+and start adapting their mapfiles in consequence. If you have strong
+and motivated objections as to the removal of one or more of these
+features please open a discussion in the usual Mapserver communication
+channels.
+Cartoline symbols: these were a hack to overcome GD weaknesses, and their
+functionality is now supported by the AGG renderer. They have become poorly
+supported in current MapServer versions. Keywords allowing for setting the
+style of line joins and caps will be moved to the STYLE block.
+RGB/RGBA output with GD: support for RGB and RGBA image types will likely not
+be maintained anymore. PC256 will continue to be supported with GD, while RGB
+and RGBA will liekly only be supported with AGG
