[mapserver-commits] r11242 - in trunk/msautotest/gdal: . expected
Fri Mar 18 12:46:17 EDT 2011
Author: warmerdam
Date: 2011-03-18 09:46:17 -0700 (Fri, 18 Mar 2011)
New Revision: 11242
Added:
   trunk/msautotest/gdal/expected/simplealpha_bg.png
   trunk/msautotest/gdal/simplealpha_bg.map
   trunk/msautotest/gdal/alpha_on_alpha_overlay.map
update to be careful about transparent flags with rgba images
Modified: trunk/msautotest/gdal/alpha_on_alpha_overlay.map
--- trunk/msautotest/gdal/alpha_on_alpha_overlay.map	2011-03-18 16:46:00 UTC (rev 11241)
+++ trunk/msautotest/gdal/alpha_on_alpha_overlay.map	2011-03-18 16:46:17 UTC (rev 11242)
@@ -17,7 +17,6 @@
   NAME png24_t
   DRIVER "GDAL/PNG"
   IMAGEMODE RGBA
-  TRANSPARENT OFF
 END
 LAYER
Added: trunk/msautotest/gdal/expected/simplealpha_bg.png
(Binary files differ)
Property changes on: trunk/msautotest/gdal/expected/simplealpha_bg.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/gdal/simplealpha_bg.map
--- trunk/msautotest/gdal/simplealpha_bg.map	                        (rev 0)
+++ trunk/msautotest/gdal/simplealpha_bg.map	2011-03-18 16:46:17 UTC (rev 11242)
@@ -0,0 +1,27 @@
+# Simple alpha image render on blank background.
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+EXTENT 0.5 0.5 399.5 299.5
+IMAGECOLOR 255 255 0
+OUTPUTFORMAT
+  NAME png24_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE RGBA
+  TRANSPARENT OFF
+END
+LAYER
+  NAME grey_overlay
+  TYPE raster
+  STATUS default
+  DATA data/greyalpha.vrt
+END
+END # of map file
