[mapserver-commits] r11246 - in trunk/docs: . en
Fri Mar 18 13:14:40 EDT 2011
Author: jmckenna
Date: 2011-03-18 10:14:40 -0700 (Fri, 18 Mar 2011)
New Revision: 11246
   trunk/docs/en/download.txt
   trunk/docs/svn-externals-notes.txt
add pointer to migration guide
Modified: trunk/docs/en/download.txt
--- trunk/docs/en/download.txt	2011-03-18 17:00:00 UTC (rev 11245)
+++ trunk/docs/en/download.txt	2011-03-18 17:14:40 UTC (rev 11246)
@@ -59,6 +59,10 @@
 Documentation
+.. note::
+    If you plan on upgrading to the MapServer 6.0 release, be sure to review the
+    :ref:`MapServer Migration Guide <migration>`.
 The entire documentation is available as a single PDF document.
 Current Release
Modified: trunk/docs/svn-externals-notes.txt
--- trunk/docs/svn-externals-notes.txt	2011-03-18 17:00:00 UTC (rev 11245)
+++ trunk/docs/svn-externals-notes.txt	2011-03-18 17:14:40 UTC (rev 11246)
@@ -1,4 +1,4 @@
-Setting SVN External for MIGRATION_GUIDE.TXT
+Setting SVN External for MIGRATION_GUIDE.txt
 follow steps: http://beerpla.net/2009/06/20/how-to-properly-set-svn-svnexternals-property-in-svn-command-line/
@@ -13,12 +13,12 @@
   should return something like:
-     Fetching external item into 'en\MIGRATION_GUIDE.TXT'
+     Fetching external item into 'en\MIGRATION_GUIDE.txt'
      External at revision 11164.
 - if you receive errors such as:
-Fetching external item into 'en/MIGRATION_GUIDE.TXT'
+Fetching external item into 'en/MIGRATION_GUIDE.txt'
 svn: warning: 'http://svn.osgeo.org/mapserver/trunk/docs/en'
 is not the same repository as
 'https://svn.osgeo.org/mapserver'
