[mapserver-commits] r11274 - in trunk/msautotest/wxs: . expected
Fri Mar 18 16:09:49 EDT 2011
Author: tbonfort
Date: 2011-03-18 13:09:49 -0700 (Fri, 18 Mar 2011)
New Revision: 11274
   trunk/msautotest/wxs/expected/wms_get_map_line_dash_sld.png
   trunk/msautotest/wxs/wms_sld.map
update sdl dash example (new renderer, and consistent dash pattern)
Modified: trunk/msautotest/wxs/expected/wms_get_map_line_dash_sld.png
(Binary files differ)
Modified: trunk/msautotest/wxs/wms_sld.map
--- trunk/msautotest/wxs/wms_sld.map	2011-03-18 19:48:52 UTC (rev 11273)
+++ trunk/msautotest/wxs/wms_sld.map	2011-03-18 20:09:49 UTC (rev 11274)
@@ -13,7 +13,7 @@
 # RUN_PARMS: wms_get_map_line_width_sld.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=<StyledLayerDescriptor version=%221.0.0%22><NamedLayer><Name>road</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><LineSymbolizer><Geometry><PropertyName>center-line</PropertyName></Geometry><Stroke><CssParameter name=%22stroke%22>#0000ff</CssParameter><CssParameter name=%22stroke-width%22>5.0</CssParameter></Stroke></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>" > [RESULT_DEMIME]
 # Generate map image with a new line style (dash-line) symbology for the road layer.
-# RUN_PARMS: wms_get_map_line_dash_sld.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=<StyledLayerDescriptor version=%221.0.0%22><NamedLayer><Name>road</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><LineSymbolizer><Geometry><PropertyName>center-line</PropertyName></Geometry><Stroke><CssParameter name=%22stroke%22>#0000ff</CssParameter><CssParameter name=%22stroke-width%22>3.0</CssParameter><CssParameter name=%22stroke-dasharray%22>10.0 5 5 10</CssParameter></Stroke></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>" > [RESULT_DEMIME]
+# RUN_PARMS: wms_get_map_line_dash_sld.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=<StyledLayerDescriptor version=%221.0.0%22><NamedLayer><Name>road</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><LineSymbolizer><Geometry><PropertyName>center-line</PropertyName></Geometry><Stroke><CssParameter name=%22stroke%22>#0000ff</CssParameter><CssParameter name=%22stroke-width%22>3.0</CssParameter><CssParameter name=%22stroke-dasharray%22>2 4</CssParameter></Stroke></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>" > [RESULT_DEMIME]
 # Generate map image by using a filter to draw the corresponding roads with a new symbology.
 # RUN_PARMS: wms_get_map_line_filter_sld.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&SRS=EPSG:4326&BBOX=-68.125,42,-58.375,48.5&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=200&STYLES=&LAYERS=road&sld_body=<StyledLayerDescriptor version=%221.0.0%22><NamedLayer><Name>road</Name><UserStyle><Title>xxx</Title><FeatureTypeStyle><Rule><Filter><PropertyIsLessThan><PropertyName>ROAD_ID</PropertyName><Literal>900</Literal></PropertyIsLessThan></Filter><LineSymbolizer><Geometry><PropertyName>center-line</PropertyName></Geometry><Stroke><CssParameter name=%22stroke%22>#0000ff</CssParameter><CssParameter name=%22stroke-width%22>2.0</CssParameter></Stroke></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>" > [RESULT_DEMIME]
