[mapserver-commits] r11283 - trunk/mapserver
Sat Mar 19 15:57:22 EDT 2011
Author: sdlime
Date: 2011-03-19 12:57:22 -0700 (Sat, 19 Mar 2011)
New Revision: 11283
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapfile.c
Allow run-time subs for class->text.
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-19 17:31:54 UTC (rev 11282)
+++ trunk/mapserver/HISTORY.TXT	2011-03-19 19:57:22 UTC (rev 11283)
@@ -15,9 +15,8 @@
 Current Version (SVN trunk):
+- Allow run-time subs in class->text (makes sense if you allow it in class->expression).
 Version 6.0.0-beta2 (2011-03-18)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2011-03-19 17:31:54 UTC (rev 11282)
+++ trunk/mapserver/mapfile.c	2011-03-19 19:57:22 UTC (rev 11283)
@@ -5875,8 +5875,8 @@
   if(layer->filter.string && (strcasestr(layer->filter.string, from) != NULL)) return MS_TRUE;
   for(i=0; i<layer->numclasses; i++) {
-    if(layer->class[i]->expression.string && (strcasestr(layer->class[i]->expression.string, from) != NULL))
-      return MS_TRUE;
+    if(layer->class[i]->expression.string && (strcasestr(layer->class[i]->expression.string, from) != NULL)) return MS_TRUE;
+    if(layer->class[i]->text.string && (strcasestr(layer->class[i]->text.string, from) != NULL)) return MS_TRUE;
   if(!msHashIsEmpty(&layer->bindvals)) return MS_TRUE;
@@ -5896,6 +5896,8 @@
     if(layer->class[i]->expression.string)
       layer->class[i]->expression.string = msCaseReplaceSubstring(layer->class[i]->expression.string, from, to);
+    if(layer->class[i]->text.string)
+      layer->class[i]->text.string = msCaseReplaceSubstring(layer->class[i]->text.string, from, to);
   /* The bindvalues are most useful when able to substitute values from the URL */
