[mapserver-commits] r11291 - trunk/msautotest/pymod
Sun Mar 20 16:18:34 EDT 2011
Author: rouault
Date: 2011-03-20 13:18:34 -0700 (Sun, 20 Mar 2011)
New Revision: 11291
   trunk/msautotest/pymod/mstestlib.py
python3 compat
Modified: trunk/msautotest/pymod/mstestlib.py
--- trunk/msautotest/pymod/mstestlib.py	2011-03-20 19:57:50 UTC (rev 11290)
+++ trunk/msautotest/pymod/mstestlib.py	2011-03-20 20:18:34 UTC (rev 11291)
@@ -211,19 +211,28 @@
     if len(strip_items) == 0:
         return
+    from sys import version_info
     data_lines = open(filename,'rb').readlines()
     out_data = ''
     for i in range(len(data_lines)):
+        data_line = data_lines[i]
+        if version_info >= (3,0,0):
+            data_line = str(data_line, 'iso-8859-1')
         discard = 0
         for item in strip_items:
-            if data_lines[i].find( item ) != -1:
+            if data_line.find( item ) != -1:
                 discard = 1
         if discard == 0:
-            out_data += data_lines[i]
+            out_data += data_line
         else:
             out_data += '[stripped line matching "%s"]\n' % item
-    open(filename,'wb').write(out_data)
+        open(filename,'wb').write(bytes(out_data, 'iso-8859-1'))
+    else:
+        open(filename,'wb').write(out_data)
     return
