[mapserver-commits] r11297 - trunk/mapserver
Mon Mar 21 17:20:21 EDT 2011
Author: assefa
Date: 2011-03-21 14:20:21 -0700 (Mon, 21 Mar 2011)
New Revision: 11297
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwfs.c
 correct bbox values for GetFeature with featureid request (#3761)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-21 17:42:51 UTC (rev 11296)
+++ trunk/mapserver/HISTORY.TXT	2011-03-21 21:20:21 UTC (rev 11297)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- WFS: correct bbox values for GetFeature with featureid request (#3761)
 - Mapscript Seg Fault on mapObj->getMetaData (#3738)
 - Correct double free in msCleanup().
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2011-03-21 17:42:51 UTC (rev 11296)
+++ trunk/mapserver/mapwfs.c	2011-03-21 21:20:21 UTC (rev 11297)
@@ -224,10 +224,9 @@
 /* msWFSLocateSRSInList()
-** Utility function to check if a space separated list contains of srs
-** contain the one passed in argument.  The list comes normaly
-** from ows_srs metadata, and is expected to using the simple EPSG notation
-** (EPSG:4326 ESPG:42304 ...). The srs comes from the query strin and can either
+** Utility function to check if a space separated list contains  the one passed in argument.
+**  The list comes normaly from ows_srs metadata, and is expected to use the simple EPSG notation
+** (EPSG:4326 ESPG:42304 ...). The srs comes from the query string and can either
 ** be of simple EPSG format or using gc:def:crs:EPSG:xxx format
 int msWFSLocateSRSInList(const char *pszList, const char *srs)
@@ -386,7 +385,17 @@
     if (pszOutputSRS && nVersion >= OWS_1_1_0)
+        projectionObj sProjTmp;
+        int nTmp=0;
+        msInitProjection(&sProjTmp);
+         nTmp = msLoadProjectionStringEPSG(&(sProjTmp), pszOutputSRS);
+         if (nTmp == 0)
+             msProjectRect(&(map->projection), &(sProjTmp), &map->extent);
+             msFreeProjection(&(sProjTmp));
           /*check if the srs passed is valid. Assuming that it is an EPSG:xxx format,
             Or urn:ogc:def:crs:EPSG:xxx format. */
         if (strncasecmp(pszOutputSRS, "EPSG:", 5) == 0 ||
@@ -401,6 +410,7 @@
             char epsg_string[100];
             const char *code;
             code = pszOutputSRS + 23;
@@ -408,6 +418,8 @@
             /*we load the projection sting in the map and possibly
               set the axis order*/
+            /*reproject the map extent from current projection to output projection*/
             msFreeProjection(&map->projection);
             msLoadProjectionStringEPSG(&(map->projection), epsg_string);
@@ -416,6 +428,19 @@
     else if (pszOutputSRS && strncasecmp(pszOutputSRS, "EPSG:", 5) == 0)
         int nTmp =0;
+        if (nVersion >= OWS_1_1_0)
+        else
+          nTmp = msLoadProjectionString(&(sProjTmp), pszOutputSRS);
+        if (nTmp == 0)
         msInitProjection(&map->projection);
@@ -2117,6 +2142,8 @@
     bFeatureIdSet = 1;
 #ifdef USE_OGR
     if (bFilterSet && pszFilter && strlen(pszFilter) > 0) {
       char **tokens = NULL;
@@ -2315,7 +2342,8 @@
          if (tokens)
            msFreeCharArray(tokens, nTokens);
+         /*turn on the layers and make sure projections are set properly*/
          for (j=0; j< iFIDLayers; j++)
              for (k=0; k<map->numlayers; k++)
@@ -2326,6 +2354,22 @@
                      strcasecmp(lp->name, aFIDLayers[j]) == 0)
                      lp->status = MS_ON;
+             if (msWFSGetFeatureApplySRS(map, paramsObj->pszSrs, paramsObj->pszVersion) == MS_FAILURE)
+               return msWFSException(map, "typename", "InvalidParameterValue", paramsObj->pszVersion);
+         for (j=0; j< iFIDLayers; j++)
+             for (k=0; k<map->numlayers; k++)
+                 layerObj *lp;
+                 lp = GET_LAYER(map, k);
+                 if (msWFSIsLayerSupported(lp) && lp->name &&
+                     strcasecmp(lp->name, aFIDLayers[j]) == 0)
+                     lp->status = MS_ON;
                      if (lp->template == NULL) {
                          /* Force setting a template to enable query. */
                          lp->template = msStrdup("ttt.html");
@@ -2379,9 +2423,10 @@
     if(layers)
       msFreeCharArray(layers, numlayers);
-    if (msWFSGetFeatureApplySRS(map, paramsObj->pszSrs, paramsObj->pszVersion) == MS_FAILURE)
     ** Perform Query (only BBOX for now)
