[mapserver-commits] r11353 - in trunk: docs/en/output mapserver
Mon Mar 28 14:45:58 EDT 2011
Author: assefa
Date: 2011-03-28 11:45:58 -0700 (Mon, 28 Mar 2011)
New Revision: 11353
   trunk/docs/en/output/kml_output.txt
   trunk/mapserver/HISTORY.TXT
Output ExtendedData (#3728)
Modified: trunk/docs/en/output/kml_output.txt
--- trunk/docs/en/output/kml_output.txt	2011-03-28 18:43:54 UTC (rev 11352)
+++ trunk/docs/en/output/kml_output.txt	2011-03-28 18:45:58 UTC (rev 11353)
@@ -185,7 +185,7 @@
 | Snippet           | No        | This is a short description the feature. If needed It could be supported.        |
-| description       | Yes       | This information is what appears in the description balloon when the user clicks on the feature. The <description> element supports plain text as well as a subset of HTML formatting elements.Two ways of defining the description: |
+| description       | Yes       | This information is what appears in the description balloon when the user clicks on the feature. The <description> element supports plain text as well as a subset of HTML formatting elements.  Used when KML/OWS_DESCRIPTION is defined |
 | AbstractView      | No        |        |
@@ -199,6 +199,9 @@
 | Metadata          | No        |        |
+| ExtendedData      | Yes       | Used when KML/OWS_INCLUDE_ITEMS is defined        |
 | Geometry          | Yes       | Depends on the layer type        |
@@ -211,7 +214,7 @@
 - Projection block should be set. If not set It will be assumed that the data is in lat/lon projection (a debug message will be sent to the user: Debug Message 1)
 - Possible to output vector layers as raster using metadata:  "KML_OUTPUTASRASTER" "true"
 - The user  can use the KML_FOLDER_DSIPLAY layer or map level metedata to choose a setting. Possible values are 'check' (default), 'radioFolder', 'checkOffOnly', 'checkHideChildren'.
-- The user can use metadata KML/OWS_DESCRIPTION or KML/OWS_INCLUDE_ITEMS to define the description attached to each feature.
+- The user can use metadata KML/OWS_DESCRIPTION or KML/OWS_INCLUDE_ITEMS to define the description attached to each feature. If  KML/OWS_DESCRIPTION are defined, the <description> tag of the Placemark will be used. If KML/OWS_INCLUDE_ITEMS, the <ExtendedData> tag will be used.
 - The user can use the metadata KML_NAME_ITEM to indicate the field name to be used a a name tag for each feature.
 - The user can use metadata KML_ALTITUDEMODE to specify how altitude components in the <coordinates> element are interpreted. Possible values are: absolute, relativeToGround, clampToGround. http://code.google.com/apis/kml/documentation/kmlreference.html#altitudemode
 - The user can use metedata KML_EXTRUDE to specify whether to connect the LinearRing to the ground. http://code.google.com/apis/kml/documentation/kmlreference.html#tessellate
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-28 18:43:54 UTC (rev 11352)
+++ trunk/mapserver/HISTORY.TXT	2011-03-28 18:45:58 UTC (rev 11353)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- KML: Output ExtendedData (#3728)
 - Fixed OWS usage of multiple layers with same name (#3778)
 - WCS implementation should not lookup wms_* metadata (#3779)
