[mapserver-commits] r11365 - trunk/mapserver
Tue Mar 29 12:08:43 EDT 2011
Author: warmerdam
Date: 2011-03-29 09:08:43 -0700 (Tue, 29 Mar 2011)
New Revision: 11365
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maptemplate.c
fix querymap production for ondemand outputformat initialization
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-29 14:30:37 UTC (rev 11364)
+++ trunk/mapserver/HISTORY.TXT	2011-03-29 16:08:43 UTC (rev 11365)
@@ -14,6 +14,9 @@
 Current Version (SVN trunk):
+- fix query map generation error introduced in beta2 when output format
+  initialized was made as needed.
 - fix incorrect PATTERN behavior on agg lines (#3787)
 - report SOS DescribeObservationType in Capabilities (#3777)
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2011-03-29 14:30:37 UTC (rev 11364)
+++ trunk/mapserver/maptemplate.c	2011-03-29 16:08:43 UTC (rev 11365)
@@ -240,10 +240,16 @@
     return MS_FAILURE;
+  msApplyDefaultOutputFormats(map);
   i = msGetOutputFormatIndex(map, queryFormat); /* queryFormat can be a mime-type or name */
   if(i >= 0) outputFormat = map->outputformatlist[i];
   if(outputFormat) {
+     if( MS_RENDERER_PLUGIN(outputFormat) ) {
+         msInitializeRendererVTable(outputFormat);
      if( MS_RENDERER_OGR(outputFormat) )
          if( mapserv != NULL )
