[mapserver-commits] r11370 - trunk/mapserver
Tue Mar 29 17:55:31 EDT 2011
Author: tamas
Date: 2011-03-29 14:55:31 -0700 (Tue, 29 Mar 2011)
New Revision: 11370
   trunk/mapserver/mapunion.c
Union layer: Prevent from the crash when failed to open the source layer
Modified: trunk/mapserver/mapunion.c
--- trunk/mapserver/mapunion.c	2011-03-29 21:37:41 UTC (rev 11369)
+++ trunk/mapserver/mapunion.c	2011-03-29 21:55:31 UTC (rev 11370)
@@ -86,6 +86,7 @@
     char **layerNames;
     mapObj* map;
     int i;
+    int layerCount;
     if (layer->layerinfo != NULL)
@@ -114,10 +115,12 @@
     layerinfo->classgroup = NULL;
     layerinfo->nclasses = 0;
+    layerinfo->layerCount = 0;
-    layerNames = msStringSplit(layer->connection, ',', &layerinfo->layerCount);
+    layerNames = msStringSplit(layer->connection, ',', &layerCount);
-    if (layerinfo->layerCount == 0)
+    if (layerCount == 0)
         msSetError(MS_MISCERR, "No source layers specified in layer: %s", layer->name);
         if(layerNames)
@@ -126,10 +129,10 @@
         return MS_FAILURE;
-    layerinfo->layers =(layerObj*)malloc(layerinfo->layerCount * sizeof(layerObj));
-    MS_CHECK_ALLOC(layerinfo->layers, layerinfo->layerCount * sizeof(layerObj), MS_FAILURE);
+    layerinfo->layers =(layerObj*)malloc(layerCount * sizeof(layerObj));
+    MS_CHECK_ALLOC(layerinfo->layers, layerCount * sizeof(layerObj), MS_FAILURE);
-    for(i=0; i < layerinfo->layerCount; i++)
+    for(i=0; i < layerCount; i++)
         int layerindex = msGetLayerIndex(map, layerNames[i]);
         if (layerindex >= 0 && layerindex < map->numlayers)
@@ -155,6 +158,8 @@
                 return MS_FAILURE;
+            ++layerinfo->layerCount;
 	        if (msCopyLayer(&layerinfo->layers[i], srclayer) != MS_SUCCESS)
 		        msSetError(MS_MISCERR, "Cannot copy source layer: %s", srclayer->name);
