[mapserver-commits] r11397 - trunk/mapserver
Wed Mar 30 16:09:01 EDT 2011
Author: sdlime
Date: 2011-03-30 13:09:01 -0700 (Wed, 30 Mar 2011)
New Revision: 11397
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/scalebar.c
   trunk/mapserver/shp2img.c
   trunk/mapserver/sortshp.c
   trunk/mapserver/sym2img.c
Make sure command-line programs use an exit status other than 0 when an error is encountered.
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-30 19:57:35 UTC (rev 11396)
+++ trunk/mapserver/HISTORY.TXT	2011-03-30 20:09:01 UTC (rev 11397)
@@ -15,6 +15,9 @@
 Current Version (SVN trunk):
+- Make sure command-line programs use an exit status other than 0
+  when an error is encountered. (#3753)
 - Applied patch to filter unwanted fribidi characters (#3763)
 - Fixed lexer to set the proper state on URL variable substitutions
Modified: trunk/mapserver/scalebar.c
--- trunk/mapserver/scalebar.c	2011-03-30 19:57:35 UTC (rev 11396)
+++ trunk/mapserver/scalebar.c	2011-03-30 20:09:01 UTC (rev 11397)
@@ -43,21 +43,21 @@
   /* ---- check the number of arguments, return syntax if not correct ---- */
   if( argc < 3 ) {
-      fprintf(stdout,"Syntax: scalebar [mapfile] [output image]\n" );
-      exit(0);
+    fprintf(stdout,"Syntax: scalebar [mapfile] [output image]\n" );
+    exit(1);
   map = msLoadMap(argv[1], NULL);
   if(!map) {
     msWriteError(stderr);
-    exit(0);
+    exit(1);
   image = msDrawScalebar(map);
   if(!image) {
-    exit(0);
+    exit(1);
   msSaveImage(map, image, argv[2]);
Modified: trunk/mapserver/shp2img.c
--- trunk/mapserver/shp2img.c	2011-03-30 19:57:35 UTC (rev 11396)
+++ trunk/mapserver/shp2img.c	2011-03-30 20:09:01 UTC (rev 11397)
@@ -120,7 +120,7 @@
       msCleanup();
-      exit(0);
+      exit(1);
   for(i=1;i<argc;i++) { /* Step though the user arguments, 1st to find map file */
@@ -130,7 +130,7 @@
       if(!map) {
         msCleanup();
-	exit(0);
+	exit(1);
       msApplyDefaultSubstitutions(map);
@@ -139,7 +139,7 @@
   if(!map) {
     fprintf(stderr, "Mapfile (-m) option not specified.\n");
     msCleanup();
-    exit(0);
+    exit(1);
@@ -243,7 +243,7 @@
             fprintf( stderr,
                      "Argument -e needs 4 space separated numbers as argument.\n" );
             msCleanup();
-            exit(0);
+            exit(1);
       map->extent.minx = atof(argv[i+1]);
       map->extent.miny = atof(argv[i+2]);
@@ -271,7 +271,7 @@
           if (layer_found==0) {
               fprintf(stderr, "Layer (-l) \"%s\" not found\n", layers[j]);
               msCleanup();
-              exit(0);
+              exit(1);
@@ -302,7 +302,7 @@
     msFreeMap(map);
     msCleanup();
-    exit(0);
+    exit(1);
   if( msSaveImage(map, image, outfile) != MS_SUCCESS ) {
Modified: trunk/mapserver/sortshp.c
--- trunk/mapserver/sortshp.c	2011-03-30 19:57:35 UTC (rev 11396)
+++ trunk/mapserver/sortshp.c	2011-03-30 20:09:01 UTC (rev 11397)
@@ -101,7 +101,7 @@
   if( argc != 5 ) {
       fprintf(stderr,"Syntax: sortshp [infile] [outfile] [item] [ascending|descending]\n" );
-      exit(0);
+      exit(1);
   msSetErrorFile("stderr", NULL);
@@ -112,7 +112,7 @@
   inSHP = msSHPOpen(argv[1], "rb" );
   if( !inSHP ) {
     fprintf(stderr,"Unable to open %s shapefile.\n",argv[1]);
-    exit(0);
+    exit(1);
   msSHPGetInfo(inSHP, &nShapes, &shpType);
@@ -123,7 +123,7 @@
   inDBF = msDBFOpen(buffer,"rb");
   if( inDBF == NULL ) {
     fprintf(stderr,"Unable to open %s XBASE file.\n",buffer);
-    exit(0);
+    exit(1);
   num_fields = msDBFGetFieldCount(inDBF);
@@ -139,13 +139,13 @@
   if(fieldNumber < 0) {
     fprintf(stderr,"Item %s doesn't exist in %s\n",argv[3],buffer);
-    exit(0);
+    exit(1);
   array = (sortStruct *)malloc(sizeof(sortStruct)*num_records); /* ---- Allocate the array ---- */
   if(!array) {
     fprintf(stderr, "Unable to allocate sort array.\n");
-    exit(0);
+    exit(1);
@@ -179,7 +179,7 @@
     break;
   default:
       fprintf(stderr,"Data type for item %s not supported.\n",argv[3]);
-      exit(0);
+      exit(1);
Modified: trunk/mapserver/sym2img.c
--- trunk/mapserver/sym2img.c	2011-03-30 19:57:35 UTC (rev 11396)
+++ trunk/mapserver/sym2img.c	2011-03-30 20:09:01 UTC (rev 11397)
@@ -73,7 +73,7 @@
   if(msLoadSymbolSet(&symbolSet) == -1) {
-    exit(0);
+    exit(1);
   ns = symbolSet.numsymbols;
@@ -162,7 +162,7 @@
  if((stream = fopen(argv[2],"wb")) == NULL) { /* open the file */
     fprintf(stderr, "Unable to open output file: %s\n", argv[2]);
-    exit(0);
+    exit(1);
 #ifndef USE_GD_1_6
   gdImageGif(img, stream);
