[mapserver-commits] r11425 - trunk/mapserver
Thu Mar 31 09:15:26 EDT 2011
Author: tbonfort
Date: 2011-03-31 06:15:26 -0700 (Thu, 31 Mar 2011)
New Revision: 11425
   trunk/mapserver/mapcluster.c
fix double typedef declaration causing a compiler warning
Modified: trunk/mapserver/mapcluster.c
--- trunk/mapserver/mapcluster.c	2011-03-31 13:08:34 UTC (rev 11424)
+++ trunk/mapserver/mapcluster.c	2011-03-31 13:15:26 UTC (rev 11425)
@@ -66,7 +66,7 @@
 #define TREE_MAX_DEPTH  10
 /* cluster data */
-typedef struct cluster_info
+struct cluster_info
     double x;    /* x position of the current point */
     double y;    /* y position of the current point */
@@ -92,7 +92,7 @@
 /* quadtree node */
-typedef struct cluster_tree_node
+struct cluster_tree_node
     /* area covered by this node */
     rectObj rect;
@@ -106,7 +106,7 @@
 /* layeinfo */
-typedef struct cluster_layer_info
+struct cluster_layer_info
     /* array of features (finalized clusters) */
     clusterInfo* finalized;
