[mapserver-commits] r11428 - trunk/mapserver
Thu Mar 31 09:53:58 EDT 2011
Author: tbonfort
Date: 2011-03-31 06:53:58 -0700 (Thu, 31 Mar 2011)
New Revision: 11428
   trunk/mapserver/mapquery.c
clean up some allocated memory in case of failed queryfile loading
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c	2011-03-31 13:48:49 UTC (rev 11427)
+++ trunk/mapserver/mapquery.c	2011-03-31 13:53:58 UTC (rev 11428)
@@ -240,12 +240,16 @@
     if(1 != fread(&(GET_LAYER(map, j)->resultcache->numresults), sizeof(int), 1, stream)) { /* number of results */
        msSetError(MS_MISCERR,"failed to read number of results from query file stream", "loadQueryResults()");
+       free(GET_LAYER(map, j)->resultcache);
+       GET_LAYER(map, j)->resultcache = NULL;
        return MS_FAILURE;
     GET_LAYER(map, j)->resultcache->cachesize = GET_LAYER(map, j)->resultcache->numresults;
     if(1 != fread(&(GET_LAYER(map, j)->resultcache->bounds), sizeof(rectObj), 1, stream)) { /* bounding box */
        msSetError(MS_MISCERR,"failed to read bounds from query file stream", "loadQueryResults()");
        return MS_FAILURE;
@@ -262,6 +266,9 @@
     for(k=0; k<GET_LAYER(map, j)->resultcache->numresults; k++) {
       if(1 != fread(&(GET_LAYER(map, j)->resultcache->results[k]), sizeof(resultObj), 1, stream)) { /* each result */
          msSetError(MS_MISCERR,"failed to read result %d from query file stream", "loadQueryResults()", k);
+         free(GET_LAYER(map, j)->resultcache->results);
          return MS_FAILURE;
       if(!GET_LAYER(map, j)->tileindex) GET_LAYER(map, j)->resultcache->results[k].tileindex = -1; /* reset the tile index for non-tiled layers */
