[mapserver-commits] r12754 - in trunk/docs/en: development/rfc images
Fri Nov 4 14:27:58 EDT 2011
Author: aboudreault
Date: 2011-11-04 11:27:58 -0700 (Fri, 04 Nov 2011)
New Revision: 12754
Added:
   trunk/docs/en/development/rfc/ms-rfc-78.txt
   trunk/docs/en/images/uv.png
Added first draft of vector field RFC
Added: trunk/docs/en/development/rfc/ms-rfc-78.txt
--- trunk/docs/en/development/rfc/ms-rfc-78.txt	                        (rev 0)
+++ trunk/docs/en/development/rfc/ms-rfc-78.txt	2011-11-04 18:27:58 UTC (rev 12754)
@@ -0,0 +1,150 @@
+.. _rfc78:
+MS RFC 78: Vector Field Rendering
+:Date:  2011/11/04
+:Author: Alan Boudreault
+:Contact: aboudreault at mapgears.com
+:Last Edited: $Date: 2011-03-03 16:29:55 -0600 (Thu, 03 Mar 2011) $
+:Status: Draft
+:Version: MapServer 6.2
+:Id: $Id: ms-rfc-77.txt 11057 2011-03-03 22:29:55Z tamas $
+1. Overview
+This is a proposal to add the ability to render vector field layer in
+MapServer. Vector fields are used for instance in meteorology to
+store/display wind direction and magnitude.
+The source is two single-band raster images, one band represents the U
+component of the vector, and the 2nd band the V component. Using the u,v
+values at a given location we can compute a rotation and magnitude and use
+that to draw an arrow of a size proportional to the magnitude and pointing
+in the direction of the phenomenon (wind, current, etc.)
+For more detail about vector field, refer to: http://en.wikipedia.org/wiki/Vector_field
+Visual example (rendered with MapServer):
+ .. image:: ../../images/uv.png
+2. The proposed solution
+This RFC proposes to add an new type of layer in MapServer. The new type is
+a hybrid layer, which has a raster data source but vector features as
+output. Initially, only the point representation of those vector features
+will be supported. Also, the query wont be supported in this phase.
+Since the data source is a raster, all raster processing options can be
+used (ie. RESAMPLE). After a few tests, we determined that the best results
+(for all different zoom levels) for vector fields was when using
+RESAMPLE=AVERAGE and has been set by default for uv layers. You can of
+course set any resample option manually.
+To render a vector field layer, we need to define a layer in the mapfile
+with the following options:
+ * Set the layer type to POINT.
+ * Set connection type to UVRASTER.
+ * Set the data to the raster file that contains u/v bands.
+ * Specify the 2 bands to use as u and v.
+ * Specify a class to render the point features.
+optionnal options:
+ * Set the UV_SPACING. The spacing is simply the space, in pixel, between
+vector fields. Default is 32.
+ * Set the UV_SIZE_SCALE. The uv size scale is used to convert the vector
+lengths (magnitude) of the raster in pixel for a better rendering. Default
+is 1.
+UV layer has 4 attribute bindings that can be used in the layer definition
+and/or class expressions:
+ * [u]: the raw u value
+ * [v]: the raw v value
+ * [uv_angle]: the vector angle
+ * [uv_length]: the vector length (scaled with the UV_SIZE_SCALE option value)
+Example of a layer definition:
+  LAYER
+   NAME "my_uv_layer"
+   TYPE POINT
+   STATUS DEFAULT
+   CONNECTIONTYPE UVRASTER
+   DATA /mnt/data/raster/grib/wind.grib2
+   PROCESSING "BANDS=1,2"
+   PROCESSING "UV_SPACING=40"
+   PROCESSING "UV_SIZE_SCALE=0.2"
+   CLASS
+    STYLE
+    ANGLE [uv_angle]
+    SYMBOL "arrow"
+    SIZE [uv_length]
+    COLOR 255 0 0
+    POSITION CC
+    MINSIZE 5
+   END
+  END
+3. Implementation Details
+Internally, a uv layer will have its own renderer/driver code. It's a
+hybrid layer because it reads the raster source as a normal raster
+layer does, but all other functions behave like a vector layer. The
+layer can be drawed as a normal point layer using whichShape, GetShape
+etc.
+Basic internal draw process of a uv layer:
+ 1. whichShape() is called: the raster data source is read using the
+    internal gdal functions, resample and all other raster options are applied
+    and the u/v pixels result is stored in the internal layer structure.
+ 2. getShape() is called: loop through the raster pixels and returns a
+    shapeObj (Point) created with the pixel location.
+ 3. MapServer draws its point feature as any other vector layer.
+3.1 Files affected
+The following files will be modified/created by this RFC:
+  mapserver.h/mapfile.c (Connection type UVRASTER support in the mapfile)
+  mapuvraster.c (new file for the UVRASTER renderer)
+  maplayer.c (new layer type handling, virtual tables init etc.)
+  maplexer.l (add additional UVRASTER keyword)
+3.2 MapScript
+No issue for any MapScript bindings. The uv layer is handled/rendered internally as
+any other layer..
+3.4 Backwards Compatibilty Issues
+This change provides a new functionality with no backwards compatibility issues being considered.
+4. Bug ID
+None assigned.
+5. Voting history
+None
Added: trunk/docs/en/images/uv.png
(Binary files differ)
Property changes on: trunk/docs/en/images/uv.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
