[mapserver-commits] r12769 - in trunk/mapserver/mapcache: include src
Tue Nov 15 05:18:11 EST 2011
Author: tbonfort
Date: 2011-11-15 02:18:11 -0800 (Tue, 15 Nov 2011)
New Revision: 12769
   trunk/mapserver/mapcache/include/mapcache.h
   trunk/mapserver/mapcache/src/cache_disk.c
   trunk/mapserver/mapcache/src/cache_memcache.c
   trunk/mapserver/mapcache/src/util.c
add a sanitization function when using dimensions in disk and memcache cache.
change the directory structure and memcache key used in case of dimensions (skip the key) to shorten the filename/memcache key.
Modified: trunk/mapserver/mapcache/include/mapcache.h
--- trunk/mapserver/mapcache/include/mapcache.h	2011-11-14 10:13:31 UTC (rev 12768)
+++ trunk/mapserver/mapcache/include/mapcache.h	2011-11-15 10:18:11 UTC (rev 12769)
@@ -1305,6 +1305,16 @@
 char *mapcache_util_str_replace(apr_pool_t *pool, const char *string, const char *substr,
       const char *replacement );
+ * \brief replace dangerous characters in string
+ * \param str the string that must be tested/replaced
+ * \param from array of chars that must be replaced
+ * \param to char that will replace a matched entry
+ * \return the original string if no matches were found, or the sanitized
+ *         string allocated from the given pool
+const char* mapcache_util_str_sanitize(apr_pool_t *pool, const char *str, const char* from, char to);
 /**\defgroup imageio Image IO */
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c	2011-11-14 10:13:31 UTC (rev 12768)
+++ trunk/mapserver/mapcache/src/cache_disk.c	2011-11-15 10:18:11 UTC (rev 12769)
@@ -54,6 +54,7 @@
       ctx->set_error(ctx,500, "failed to allocate blank tile key");
  * \brief return filename for given tile
@@ -76,16 +77,8 @@
          int i = elts->nelts;
          while(i--) {
             apr_table_entry_t *entry = &(APR_ARRAY_IDX(elts,i,apr_table_entry_t));
-            char *dimval = apr_pstrdup(ctx->pool,entry->val);
-            char *iter = dimval;
-            while(*iter) {
-               /* replace dangerous characters by '#' */
-               if(*iter == '.' || *iter == '/') {
-                  *iter = '#';
-               iter++;
-            start = apr_pstrcat(ctx->pool,start,"/",entry->key,"/",dimval,NULL);
+            const char *dimval = mapcache_util_str_sanitize(ctx->pool,entry->val,"/.",'#');
+            start = apr_pstrcat(ctx->pool,start,"/",dimval,NULL);
       *path = apr_psprintf(ctx->pool,"%s/%02d/%03d/%03d/%03d/%03d/%03d/%03d.%s",
Modified: trunk/mapserver/mapcache/src/cache_memcache.c
--- trunk/mapserver/mapcache/src/cache_memcache.c	2011-11-14 10:13:31 UTC (rev 12768)
+++ trunk/mapserver/mapcache/src/cache_memcache.c	2011-11-15 10:18:11 UTC (rev 12769)
@@ -52,18 +52,15 @@
       while(i--) {
-         start = apr_pstrcat(ctx->pool,start,"/",entry->key,"/",entry->val,NULL);
+         const char *dimval = mapcache_util_str_sanitize(ctx->pool,entry->val," \r\n\t\f\e\a\b",'#');
-   *path = apr_psprintf(ctx->pool,"%s/%02d/%03d/%03d/%03d/%03d/%03d/%03d.%s",
+   *path = apr_psprintf(ctx->pool,"%s/%d/%d/%d.%s",
          start,
          tile->z,
-         tile->x / 1000000,
-         (tile->x / 1000) % 1000,
-         tile->x % 1000,
-         tile->y / 1000000,
-         (tile->y / 1000) % 1000,
-         tile->y % 1000,
+         tile->x,
+         tile->y,
          tile->tileset->format?tile->tileset->format->extension:"png");
    if(!*path) {
       ctx->set_error(ctx,500, "failed to allocate tile key");
Modified: trunk/mapserver/mapcache/src/util.c
--- trunk/mapserver/mapcache/src/util.c	2011-11-14 10:13:31 UTC (rev 12768)
+++ trunk/mapserver/mapcache/src/util.c	2011-11-15 10:18:11 UTC (rev 12769)
@@ -107,6 +107,18 @@
    return newstr;
+const char* mapcache_util_str_sanitize(apr_pool_t *pool, const char *str, const char* from, char to) {
+   size_t pos = strcspn(str,from);
+   if(str[pos]) {
+      str = apr_pstrdup(pool,str);
+      while(str[pos]) {
+         ((char*)str)[pos]=to;
+         pos += strcspn(&str[pos],from);
+   return str;
 #if APR_MAJOR_VERSION < 1 || (APR_MAJOR_VERSION < 2 && APR_MINOR_VERSION < 3)
 APR_DECLARE(apr_table_t *) apr_table_clone(apr_pool_t *p, const apr_table_t *t)
