[mapserver-commits] r12788 - sandbox/sdlime/rfc-77
Fri Nov 18 19:37:17 EST 2011
Author: sdlime
Date: 2011-11-18 16:37:17 -0800 (Fri, 18 Nov 2011)
New Revision: 12788
   sandbox/sdlime/rfc-77/mapcopy.c
   sandbox/sdlime/rfc-77/mapfile.c
   sandbox/sdlime/rfc-77/mapserver.h
RFC-77 multi-label code. More to come...
Modified: sandbox/sdlime/rfc-77/mapcopy.c
--- sandbox/sdlime/rfc-77/mapcopy.c	2011-11-18 13:56:59 UTC (rev 12787)
+++ sandbox/sdlime/rfc-77/mapcopy.c	2011-11-19 00:37:17 UTC (rev 12788)
@@ -461,7 +461,7 @@
     msFree(dst->styles);
     dst->numstyles = 0;
-    for (i = 0; i < src->numstyles; i++) {
+    for (i=0; i<src->numstyles; i++) {
         if (msGrowClassStyles(dst) == NULL)
             return MS_FAILURE;
         if (initStyle(dst->styles[i]) != MS_SUCCESS) {
@@ -476,9 +476,14 @@
         dst->numstyles++;
-    if (msCopyLabel(&(dst->label), &(src->label)) != MS_SUCCESS) {
-        msSetError(MS_MEMERR, "Failed to copy label.", "msCopyClass()");
-        return MS_FAILURE;
+    for (i=0; i<src->numlabels; i++) {
+        if (msGrowClassLabels(dst) == NULL)
+	    return MS_FAILURE;
+	initLabel(dst->labels[i]);
+        if (msCopyLabel(dst->labels[i], src->labels[i]) != MS_SUCCESS) {
+            msSetError(MS_MEMERR, "Failed to copy label.", "msCopyClass()");
     MS_COPYSTRING(dst->keyimage, src->keyimage);
Modified: sandbox/sdlime/rfc-77/mapfile.c
--- sandbox/sdlime/rfc-77/mapfile.c	2011-11-18 13:56:59 UTC (rev 12787)
+++ sandbox/sdlime/rfc-77/mapfile.c	2011-11-19 00:37:17 UTC (rev 12788)
@@ -1655,10 +1655,12 @@
   return;
-static void freeLabel(labelObj *label)
+static int freeLabel(labelObj *label)
   int i;
+  // if( MS_REFCNT_DECR_IS_NOT_ZERO(label) ) { return MS_FAILURE; }
   msFree(label->font);
   msFree(label->encoding);
@@ -1673,6 +1675,8 @@
   for(i=0; i<MS_LABEL_BINDING_LENGTH; i++)
     msFree(label->bindings[i].item);
+  return MS_SUCCESS;
 static int loadLabel(labelObj *label)
@@ -2802,8 +2806,6 @@
 int initClass(classObj *class)
-  /* printf("Init class at %p\n", class); */
   class->status = MS_ON;
   class->debug = MS_OFF;
   MS_REFCNT_INIT(class);
@@ -2813,9 +2815,6 @@
   class->title = NULL;
   initExpression(&(class->text));
-  initLabel(&(class->label));
-  class->label.size = -1; /* no default */
   class->template = NULL;
   class->type = -1;
@@ -2832,6 +2831,12 @@
   class->numstyles = class->maxstyles = 0;
   class->styles = NULL;
+  // RFC-77 REMOVE
+  // initLabel(&(class->label));
+  // class->label.size = -1; /* no default */
+  class->numlabels = class->maxlabels = 0;
+  class->labels = NULL;
   class->keyimage = NULL;
   class->group = NULL;
@@ -2844,9 +2849,7 @@
   int i;
   if( MS_REFCNT_DECR_IS_NOT_ZERO(class) ) { return MS_FAILURE; }
-  /* printf("Freeing class at %p (%s)\n", class, class->name); */
-  freeLabel(&(class->label));
   freeExpression(&(class->expression));
   freeExpression(&(class->text));
   msFree(class->name);
@@ -2865,13 +2868,23 @@
   msFree(class->styles);
+  for(i=0;i<class->numstyles;i++) { /* each label */
+    if(class->labels[i]!=NULL) {
+      if(freeLabel(class->labels[i]) == MS_SUCCESS) {
+        msFree(class->labels[i]);
+  msFree(class->labels);
   msFree(class->keyimage);
   return MS_SUCCESS;
-** Ensure there is at least one free entry in the sttyles array of this
+** Ensure there is at least one free entry in the styles array of this
 ** classObj. Grow the allocated styles array if necessary and allocate
 ** a new style for styles[numstyles] if there is not already one,
 ** setting its contents to all zero bytes (i.e. does not call initStyle()
@@ -2974,8 +2987,6 @@
     return MS_SUCCESS;
  * Reset style info in the class to defaults
  * the only members we don't touch are name, expression, and join/query stuff
@@ -2985,7 +2996,16 @@
   int i;
+  /* reset labels */
+  for(i=0; i<class->numlabels; i++) {
+    if(class->styles[i] != NULL) {
+      if(freeLabel(class->labels[i]) == MS_SUCCESS ) {
+      class->labels[i] = NULL;
+  class->numlabels = 0;
@@ -3001,13 +3021,38 @@
   class->numstyles = 0;
   class->type = -1;
   class->layer = NULL;
+labelObj *msGrowClassLabels( classObj *class ) {
+  /* Do we need to increase the size of labels[] by  MS_LABEL_ALLOCSIZE?
+  if (class->numlabels == class->maxlabels) {
+    labelObj **newLabelPtr;
+    int i, newsize;
+    newsize = class->maxlabels + MS_LABEL_ALLOCSIZE;
+    /* Alloc/realloc labels */
+    newLabelPtr = (labelObj**)realloc(class->labels, newsize*sizeof(labelObj*));
+    MS_CHECK_ALLOC(newLabelPtr, newsize*sizeof(labelObj*), NULL);
+    class->labels = newLabelPtr;
+    class->maxlabels = newsize;
+    for(i=class->numlabels; i<class->maxlabels; i++) {
+  if (class->labels[class->numlabels]==NULL) {
+    class->labels[class->numlabels]=(labelObj*)calloc(1,sizeof(labelObj));
+    MS_CHECK_ALLOC(class->labels[class->numlabels], sizeof(labelObj), NULL);
+  return class->labels[class->numlabels];
 int loadClass(classObj *class, layerObj *layer)
   int state;
@@ -3061,8 +3106,10 @@
       break;
     case(LABEL):
-      class->label.size = MS_MEDIUM; /* only set a default if the LABEL section is present */
-      if(loadLabel(&(class->label)) == -1) return(-1);
+      if(msGrowClassLabels(class) == NULL) return(-1);
+      initLabel(class->labels[class->numlabels]);
+      class->labels[class->numlabels]->size = MS_MEDIUM; /* only set a default if the LABEL section is present */
+      if(loadLabel(class->labels[class->numlabels]) == -1) return(-1);
       break;
     case(MAXSCALE):
     case(MAXSCALEDENOM):
@@ -3228,9 +3275,37 @@
+static int classResolveSymbolNames(classObj *class) {
+  int i,j;
+  /* step through styles and labels to resolve symbol names */
+  /* class styles */
+  for(i=0; i<class->numstyles; i++) {
+    if(class->styles[i]->symbolname) {
+      if((class->styles[i]->symbol =  msGetSymbolIndex(&(class->layer->map->symbolset), class->styles[i]->symbolname, MS_TRUE)) == -1) {
+        msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class, style %d of layer %s.", "classResolveSymbolNames()", class->styles[i]->symbolname, i, class->layer->name);
+  /* label styles */
+    for(j=0; j<class->labels[i]->numstyles; j++) {
+      if(class->labels[i]->styles[j]->symbolname) {
+        if((class->labels[i]->styles[j]->symbol =  msGetSymbolIndex(&(class->layer->map->symbolset), class->labels[i]->styles[j]->symbolname, MS_TRUE)) == -1) {
+          msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class, label style %d of layer %s.", "classResolveSymbolNames()", class->labels[i]->styles[j]->symbolname, j, class->layer->name);
 int msUpdateClassFromString(classObj *class, char *string, int url_string)
-  int k;
   if(!class || !string) return MS_FAILURE;
   msAcquireLock( TLOCK_PARSER );
@@ -3252,28 +3327,8 @@
   msyylex_destroy();
-  /* step through styles and labels to resolve symbol names */
-  /* class styles */
-  for(k=0; k<class->numstyles; k++) {
-      if(class->styles[k]->symbolname) {
-          if((class->styles[k]->symbol =  msGetSymbolIndex(&(class->layer->map->symbolset), class->styles[k]->symbolname, MS_TRUE)) == -1) {
-              msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class, style %d of layer %s.", "msUpdateClassFromString()", class->styles[k]->symbolname, k, class->layer->name);
-  /* label styles */
-  for(k=0; k<class->label.numstyles; k++) {
-      if(class->label.styles[k]->symbolname) {
-          if((class->label.styles[k]->symbol =  msGetSymbolIndex(&(class->layer->map->symbolset), class->label.styles[k]->symbolname, MS_TRUE)) == -1) {
-              msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class, label style %d of layer %s.",
-                         "msUpdateClassFromString()", class->label.styles[k]->symbolname, k, class->layer->name);
+  if(classResolveSymbolNames(class) != MS_SUCCESS) return MS_FAILURE;
   return MS_SUCCESS;
@@ -3290,7 +3345,7 @@
   writeNumber(stream, indent, "DEBUG", 0, class->debug);
   writeExpression(stream, indent, "EXPRESSION", &(class->expression));
   writeString(stream, indent, "KEYIMAGE", NULL, class->keyimage);
-  writeLabel(stream, indent, &(class->label));
+  for(i=0; i<class->numlabels; i++) writeLabel(stream, indent, class->labels[i]);
   writeNumber(stream, indent, "MAXSCALEDENOM", -1, class->maxscaledenom);
   writeHashTable(stream, indent, "METADATA", &(class->metadata));
   writeNumber(stream, indent, "MINSCALEDENOM", -1, class->minscaledenom);
@@ -3923,7 +3978,7 @@
 int msUpdateLayerFromString(layerObj *layer, char *string, int url_string)
-  int j, k;
+  int i;
   if(!layer || !string) return MS_FAILURE;
@@ -3947,28 +4002,8 @@
   msyylex_destroy();
   /* step through classes to resolve symbol names */
-  for(j=0; j<layer->numclasses; j++) {
-      for(k=0; k<layer->class[j]->numstyles; k++) {
-          if(layer->class[j]->styles[k]->symbolname) {
-              if((layer->class[j]->styles[k]->symbol =  msGetSymbolIndex(&(layer->map->symbolset), layer->class[j]->styles[k]->symbolname, MS_TRUE)) == -1) {
-                  msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class %d, style %d of layer %s.", "msUpdateLayerFromString()", layer->class[j]->styles[k]->symbolname, j, k, layer->name);
-      for(k=0; k<layer->class[j]->label.numstyles; k++) {
-          if(layer->class[j]->label.styles[k]->symbolname) {
-              if((layer->class[j]->label.styles[k]->symbol =  msGetSymbolIndex(&(layer->map->symbolset), layer->class[j]->label.styles[k]->symbolname, MS_TRUE)) == -1) {
-                  msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class %d, label style %d of layer %s.",
-                             "msUpdateLayerFromString()", layer->class[j]->label.styles[k]->symbolname, j, k, layer->name);
+  for(i=0; i<layer->numclasses; i++) {
+    if(classResolveSymbolNames(layer->class[i]) != MS_SUCCESS) return MS_FAILURE;
   return MS_SUCCESS;
@@ -6216,36 +6251,14 @@
 static int msResolveSymbolNames(mapObj* map)
-    int i, j, k;
-    /* step through layers and classes to resolve symbol names */
-    for(i=0; i<map->numlayers; i++) {
-        for(j=0; j<GET_LAYER(map, i)->numclasses; j++) {
-            for(k=0; k<GET_LAYER(map, i)->class[j]->numstyles; k++) {
-                if(GET_LAYER(map, i)->class[j]->styles[k]->symbolname) {
-                    if((GET_LAYER(map, i)->class[j]->styles[k]->symbol =  msGetSymbolIndex(&(map->symbolset), GET_LAYER(map, i)->class[j]->styles[k]->symbolname, MS_TRUE)) == -1) {
-                        msSetError(MS_MISCERR, "Undefined symbol \"%s\" in class %d, style %d of layer %s.", "msLoadMap()", GET_LAYER(map, i)->class[j]->styles[k]->symbolname, j, k, GET_LAYER(map, i)->name);
-                if(!MS_IS_VALID_ARRAY_INDEX(GET_LAYER(map, i)->class[j]->styles[k]->symbol, map->symbolset.numsymbols)) {
-                    msSetError(MS_MISCERR, "Invalid symbol index in class %d, style %d of layer %s.", "msLoadMap()", j, k, GET_LAYER(map, i)->name);
+  int i, j;
-            for(k=0; k<GET_LAYER(map, i)->class[j]->label.numstyles; k++) {
-                if(GET_LAYER(map, i)->class[j]->label.styles[k]->symbolname) {
-                    if((GET_LAYER(map, i)->class[j]->label.styles[k]->symbol =  msGetSymbolIndex(&(map->symbolset), GET_LAYER(map, i)->class[j]->label.styles[k]->symbolname, MS_TRUE)) == -1) {
-                                   "msLoadMap()", GET_LAYER(map, i)->class[j]->label.styles[k]->symbolname, j, k, GET_LAYER(map, i)->name);
+  /* step through layers and classes to resolve symbol names */
+  for(i=0; i<map->numlayers; i++) {
+    for(j=0; j<GET_LAYER(map, i)->numclasses; j++) {
+      if(classResolveSymbolNames(GET_LAYER(map, i)->class[j]) != MS_SUCCESS) return MS_FAILURE;
-    return MS_SUCCESS;
Modified: sandbox/sdlime/rfc-77/mapserver.h
--- sandbox/sdlime/rfc-77/mapserver.h	2011-11-18 13:56:59 UTC (rev 12787)
+++ sandbox/sdlime/rfc-77/mapserver.h	2011-11-19 00:37:17 UTC (rev 12788)
@@ -225,6 +225,7 @@
 #define MS_LAYER_ALLOCSIZE 64
 #define MS_CLASS_ALLOCSIZE 8
 #define MS_STYLE_ALLOCSIZE 4
+#define MS_LABEL_ALLOCSIZE 1 /* not too common */
 #define MS_MAX_LABEL_PRIORITY     10
 #define MS_DEFAULT_LABEL_PRIORITY 1
@@ -991,16 +992,15 @@
   styleObj **styles;
   int maxstyles;
 #endif
-  int numstyles;
+  int numstyles; /* should be immutable */
-#ifdef SWIG
-%immutable;
-#endif /* SWIG */
-  labelObj label;
-#ifdef SWIG
-%mutable;
-#endif /* SWIG */
+#ifndef SWIG
+  labelObj **labels;
+  int maxlabels;
+#endif
+  int numlabels; /* should be immutable */
   char *name; /* should be unique within a layer */
   char *title; /* used for legend labeling */
@@ -1702,6 +1702,7 @@
 MS_DLL_EXPORT int initClass(classObj *_class);
 MS_DLL_EXPORT int freeClass( classObj * );
 MS_DLL_EXPORT styleObj *msGrowClassStyles( classObj *_class );
+MS_DLL_EXPORT labelObj *msGrowClassLabels( classObj *_class );
 MS_DLL_EXPORT styleObj *msGrowLabelStyles( labelObj *label );
 MS_DLL_EXPORT int msMaybeAllocateClassStyle(classObj* c, int idx);
 MS_DLL_EXPORT void initLabel(labelObj *label);
