[mapserver-commits] r12793 - trunk/mapserver
Tue Nov 22 14:45:54 EST 2011
Author: assefa
Date: 2011-11-22 11:45:54 -0800 (Tue, 22 Nov 2011)
New Revision: 12793
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapogcfilter.c
   trunk/mapserver/mapogcfilter.h
   trunk/mapserver/mapwms.c
add wms dimensions support (#3466)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-11-22 13:17:42 UTC (rev 12792)
+++ trunk/mapserver/HISTORY.TXT	2011-11-22 19:45:54 UTC (rev 12793)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Add wms dimensions support (#3466)
 - Fixed segfault when calling classObj::updateFromString() with SYMBOL (#4062)
 - Use a renderer native follow text implementation if available.
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2011-11-22 13:17:42 UTC (rev 12792)
+++ trunk/mapserver/mapogcfilter.c	2011-11-22 19:45:54 UTC (rev 12793)
@@ -282,7 +282,250 @@
     return MS_FALSE;
+char *FLTGetExpressionForValuesRanges(layerObj *lp, char *item, char *value,  int forcecharcter)
+    int bIscharacter, bSqlLayer;
+    char *pszExpression = NULL, *pszEscapedStr=NULL, *pszTmpExpression=NULL;
+    char **paszElements = NULL, **papszRangeElements=NULL;
+    int numelements,i,nrangeelements;
+    double minval, maxval;
+    if (lp && item && value)
+	if (lp->connectiontype == MS_POSTGIS || lp->connectiontype ==  MS_ORACLESPATIAL ||
+	    lp->connectiontype == MS_SDE || lp->connectiontype == MS_PLUGIN)
+	  bSqlLayer = MS_TRUE;
+	else
+	  bSqlLayer = MS_FALSE;
+	if (strstr(value, "/") == NULL)
+	    /*value(s)*/
+	    paszElements = msStringSplit (value, ',', &numelements);
+	    if (paszElements && numelements > 0)
+		if (forcecharcter)
+		  bIscharacter = MS_TRUE;
+		bIscharacter= !FLTIsNumeric(paszElements[0]);
+		pszTmpExpression = msStringConcatenate(pszTmpExpression, "(");
+		for (i=0; i<numelements; i++)
+		    if (bSqlLayer)
+		      pszTmpExpression = msStringConcatenate(pszTmpExpression, item);
+		    else
+			if (bIscharacter)
+			  pszTmpExpression = msStringConcatenate(pszTmpExpression, "\"");
+			pszTmpExpression = msStringConcatenate(pszTmpExpression, "[");
+			pszTmpExpression = msStringConcatenate(pszTmpExpression, "]");
+			if (bIscharacter)
+		    if (bIscharacter)
+		      pszTmpExpression = msStringConcatenate(pszTmpExpression, " = \"");
+		    else
+		      pszTmpExpression = msStringConcatenate(pszTmpExpression, " = ");
+		    pszEscapedStr = msLayerEscapeSQLParam(lp, paszElements[i]);
+		    pszTmpExpression = msStringConcatenate(pszTmpExpression, pszEscapedStr);
+		    if (bIscharacter)
+		    pszTmpExpression = msStringConcatenate(pszTmpExpression, ")");
+		    msFree(pszEscapedStr);
+		    pszEscapedStr=NULL;
+		    if (pszExpression != NULL)
+		      pszExpression = msStringConcatenate(pszExpression, " OR ");
+		    pszExpression =  msStringConcatenate(pszExpression, pszTmpExpression);
+		    msFree(pszTmpExpression);
+		    pszTmpExpression = NULL;
+		pszExpression = msStringConcatenate(pszExpression, ")");
+		msFreeCharArray(paszElements, numelements);
+	else
+	    /*range(s)*/
+		    papszRangeElements = msStringSplit (paszElements[i], '/', &nrangeelements);
+		    if (papszRangeElements && nrangeelements > 0)
+			if (nrangeelements == 2 || nrangeelements == 3)
+			    minval = atof(papszRangeElements[0]);
+			    maxval = atof(papszRangeElements[1]);
+			    if (bSqlLayer)
+			    else
+			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " >= ");
+			    pszEscapedStr = msLayerEscapeSQLParam(lp, papszRangeElements[0]);
+			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " AND ");
+			    if (bSqlLayer)
+			    else
+			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " <= ");
+			    pszEscapedStr = msLayerEscapeSQLParam(lp, papszRangeElements[1]);
+			else if (nrangeelements == 1)
+			    if (bSqlLayer)
+			    else
+			msFreeCharArray(papszRangeElements, nrangeelements);
+    return pszExpression;
+** Apply an expression to the layer's filter element.
+int FLTApplyExpressionToLayer(layerObj *lp, char *pszExpression)
+    char *pszFinalExpression=NULL, *pszBuffer = NULL;
+    /*char *escapedTextString=NULL;*/
+    int bConcatWhere=0, bHasAWhere=0;
+    if (lp && pszExpression)
+	     pszFinalExpression = msStrdup("(");
+	     pszFinalExpression = msStringConcatenate(pszFinalExpression, pszExpression);
+	     pszFinalExpression = msStringConcatenate(pszFinalExpression, ")");
+	 else if (lp->connectiontype == MS_OGR)
+	     pszFinalExpression = msStrdup(pszExpression);
+	     if (lp->filter.type != MS_EXPRESSION)
+		 bConcatWhere = 1;
+	     else
+		 if (lp->filter.string && EQUALN(lp->filter.string,"WHERE ",6))
+		     bHasAWhere = 1;
+		     bConcatWhere =1;
+	 else
+	 if (bConcatWhere)
+	   pszBuffer = msStringConcatenate(pszBuffer, "WHERE ");
+	 /* if the filter is set and it's an expression type, concatenate it with
+               this filter. If not just free it */
+	 if (lp->filter.string && lp->filter.type == MS_EXPRESSION)
+	     pszBuffer = msStringConcatenate(pszBuffer, "((");
+	    if (bHasAWhere)
+	      pszBuffer = msStringConcatenate(pszBuffer, lp->filter.string+6);
+	    else
+	      pszBuffer = msStringConcatenate(pszBuffer, lp->filter.string);
+	    pszBuffer = msStringConcatenate(pszBuffer, ") and ");
+	 else if (lp->filter.string)
+	   freeExpression(&lp->filter);
+	 pszBuffer = msStringConcatenate(pszBuffer, pszFinalExpression);
+	if(lp->filter.string && lp->filter.type == MS_EXPRESSION)
+	  pszBuffer = msStringConcatenate(pszBuffer, ")");
+	/*assuming that expression was properly escaped
+        escapedTextString = msStringEscape(pszBuffer);
+        msLoadExpressionString(&lp->filter,
+                               (char*)CPLSPrintf("%s", escapedTextString));
+        msFree(escapedTextString);
+                               (char*)CPLSPrintf("%s", pszBuffer));
+        msFree(pszFinalExpression);
+	if (pszBuffer)
+	  msFree(pszBuffer);
+	return MS_TRUE;
+    return MS_FALSE;
 /*                      FLTApplySimpleSQLFilter()                       */
Modified: trunk/mapserver/mapogcfilter.h
--- trunk/mapserver/mapogcfilter.h	2011-11-22 13:17:42 UTC (rev 12792)
+++ trunk/mapserver/mapogcfilter.h	2011-11-22 19:45:54 UTC (rev 12793)
@@ -105,6 +105,8 @@
 /*SQL expressions related functions.*/
 MS_DLL_EXPORT int FLTApplySimpleSQLFilter(FilterEncodingNode *psNode, mapObj *map,
                           int iLayerIndex);
+MS_DLL_EXPORT int FLTApplyExpressionToLayer(layerObj *lp, char *pszExpression);
+MS_DLL_EXPORT  char *FLTGetExpressionForValuesRanges(layerObj *lp, char *item, char *value,  int forcecharcter);
 MS_DLL_EXPORT char *FLTGetSQLExpression(FilterEncodingNode *psFilterNode,layerObj *lp);
 MS_DLL_EXPORT char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp);
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2011-11-22 13:17:42 UTC (rev 12792)
+++ trunk/mapserver/mapwms.c	2011-11-22 19:45:54 UTC (rev 12793)
@@ -36,6 +36,7 @@
 #include "maptemplate.h"
 #include "mapogcsld.h"
+#include "mapogcfilter.h"
 #include "maptime.h"
 #include "mapproject.h"
@@ -371,7 +372,408 @@
+** Validate that a given dimension is inside the extents defined
+int msWMSValidateDimensionValue(char *value, const char *dimensionextent, int forcecharcter)
+    char **extents=NULL, **ranges=NULL, **onerange=NULL;
+    int numextents;
+    char **aextentvalues = NULL;  int nextentvalues=0;
+    pointObj *aextentranges=NULL;   int nextentranges=0;
+    int isextentavalue = MS_FALSE, isextentarange=MS_FALSE;
+    int i,j, ntmp;
+    char **uservalues=NULL;
+    int numuservalues=0;
+    char *stmp = NULL;
+    int ischaracter = MS_FALSE;
+    float minval, maxval,currentval,mincurrentval,maxcurrentval, mincurrentrange, maxcurrentrange;
+    int uservaluevalid= MS_FALSE;
+      ischaracter = MS_TRUE;
+    if (!value || !dimensionextent)
+      return MS_FALSE;
+    /*for the value, we support descrete values (2005) */
+    /* multiple values (abc, def, ...) */
+    /* and range(s) (1000/2000, 3000/5000) */
+    /** we do not support resolution*/
+/*      parse the extent first.                                         */
+    extents = msStringSplit (dimensionextent, ',', &numextents);
+    if (numextents == 1)
+	if (strstr(dimensionextent, "/") == NULL)
+	    /*single value*/
+	    isextentavalue = MS_TRUE;
+	    nextentvalues = 1;
+	    aextentvalues = (char **)msSmallMalloc(sizeof(char *));
+	    msStringTrim(extents[0]);
+	    aextentvalues[0] = msStrdup(dimensionextent);
+	    if (!forcecharcter)
+	      ischaracter= !FLTIsNumeric((char *)dimensionextent);
+	else
+	    ntmp = -1;
+	    ranges = msStringSplit (dimensionextent, '/', &ntmp);
+	    if(ranges && (ntmp == 2 || ntmp == 3))
+		/*single range*/
+		isextentarange = MS_TRUE;
+		aextentranges = msSmallMalloc(sizeof(pointObj));
+		nextentranges=1;
+		aextentranges[0].x = atof(ranges[0]);
+		aextentranges[0].y = atof(ranges[1]);
+		/*ranges should be numeric*/
+		ischaracter = MS_FALSE;
+	    if (ranges && ntmp > 0)
+		msFreeCharArray(ranges, ntmp);
+	        ranges = NULL;
+    else if (numextents > 1) /*check if it is muliple values or mutliple ranges*/
+	    /*multiple values*/
+	    aextentvalues = (char **)msSmallMalloc(sizeof(char *)*numextents);
+	    for (i=0; i<numextents; i++)
+		stmp = msStrdup(extents[i]);
+		msStringTrim(stmp);
+		aextentvalues[i] = msStrdup(stmp);
+		msFree(stmp);
+	    nextentvalues = numextents;
+	      ischaracter= !FLTIsNumeric(aextentvalues[0]);
+	else /*multiple range extent*/
+	    int isvalidextent = MS_TRUE;
+	    aextentranges = msSmallMalloc(sizeof(pointObj) * numextents);
+	    nextentranges=0;
+	    for (i=0; i<numextents;i++)
+		onerange = msStringSplit(extents[i], '/', &ntmp);
+		if (!onerange || (ntmp != 2 && ntmp != 3))
+		    isvalidextent = MS_FALSE;
+		    break;
+		if (isvalidextent)
+		    aextentranges[nextentranges].x = atof(onerange[0]);
+		    aextentranges[nextentranges++].y = atof(onerange[1]);
+		if (onerange && ntmp > 0 )
+		    msFreeCharArray(onerange, ntmp);
+		    onerange = NULL;
+	    if (!isvalidextent)
+		msFree(aextentranges);
+		nextentranges = 0;
+		isextentarange = MS_FALSE;
+    if (numextents > 0)
+	msFreeCharArray(extents, numextents);
+	extents = NULL;
+    /* make sure that we got a valid extent*/
+    if (!isextentavalue && !isextentarange)
+	return MS_FALSE;
+    /*for the extent of the dimesion, we support
+    single value,  or list of mulitiple values comma separated,
+    a single range or multipe ranges */
+    uservalues = msStringSplit (value, ',', &numuservalues);
+    uservaluevalid = MS_FALSE;
+    if (numuservalues == 1)
+	/*user iput=single*/
+	/*is it descret or range*/
+	ranges = msStringSplit(uservalues[0], '/', &ntmp);
+	if (ntmp == 1) /*discrete*/
+	    if (isextentavalue)
+		/*single user value, single/multiple values extent*/
+		for (i=0; i<nextentvalues; i++)
+		    if (ischaracter)
+		      uservaluevalid = !strcmp(uservalues[0], aextentvalues[i]);
+		    else
+			if (atof(uservalues[0]) == atof(aextentvalues[i]))
+			  uservaluevalid = MS_TRUE;
+		    if(uservaluevalid)
+		      break;
+	    else if (isextentarange)
+		/*single user value, single/multiple range extent*/
+		currentval = atof(uservalues[0]);
+		for (i=0; i<nextentranges; i++)
+		    minval = aextentranges[i].x;
+		    maxval = aextentranges[i].y;
+		    if (currentval >= minval && currentval <= maxval)
+			uservaluevalid= MS_TRUE;
+			break;
+	else if (ntmp == 2 || ntmp == 3) /*range*/
+	    /*user input=single range. In this case the extents must
+	     be of a range type.*/
+	    mincurrentval = atof(ranges[0]);
+	    maxcurrentval = atof(ranges[1]);
+	    if (isextentarange)
+		    if(minval <= mincurrentval && maxval >= maxcurrentval &&
+		       minval <= maxval)
+			break;
+    else if (numuservalues > 1)	/*user input=multiple*/
+	    /*user input=multiple value*/
+	    int valueisvalid = MS_FALSE;
+	    for (i=0; i<numuservalues;i++)
+		valueisvalid = MS_FALSE;
+		    /*user input is multiple values, extent is defned as one or multiple values*/
+		    for (j=0; j<nextentvalues; j++)
+			if (ischaracter)
+			    if (strcmp(uservalues[i], aextentvalues[j]) == 0)
+				valueisvalid = MS_TRUE;
+				break;
+			else
+			    if (atof(uservalues[i]) == atof(aextentvalues[j]))
+				break;
+		    /*every value shoule be valid*/
+		    if (!valueisvalid)
+		      break;
+		    /*user input is multiple values, extent is defned as one or multiple ranges*/
+		    for (j=0; j<nextentranges; j++)
+			minval = aextentranges[j].x;
+			maxval = aextentranges[j].y;
+			currentval = atof(uservalues[i]);
+			if(minval <= currentval && maxval >= currentval &&
+			   minval <= maxval)
+			    break;
+		      break;
+	    uservaluevalid = valueisvalid;
+	else /*user input multiple ranges*/
+	    int valueisvalid = MS_TRUE;
+		/*each ranges should be valid*/
+		onerange = msStringSplit(uservalues[i], '/', &ntmp);
+		if (ntmp == 2 || ntmp == 3)
+		    mincurrentval = atof(onerange[0]);
+		    maxcurrentval = atof(onerange[1]);
+		    /*extent must be defined also as a rangle*/
+			for (j=0; j<nextentranges;j++)
+			    mincurrentrange = aextentranges[j].x;
+			    maxcurrentrange = aextentranges[j].y;
+			    if(mincurrentval >=mincurrentrange && maxcurrentval <= maxcurrentrange &&
+			       mincurrentval <= maxcurrentval)
+				break;
+			if (j == nextentranges)
+			    break;
+		else
+		if (onerange && ntmp > 0)
+    if(uservalues && numuservalues > 0)
+      msFreeCharArray(uservalues, numuservalues);
+      return MS_TRUE;
+    return MS_FALSE;
+int msWMSApplyDimensionLayer(layerObj *lp, const char *item, char *value, int forcecharcter)
+    int result = MS_FALSE;
+    char *pszExpression=NULL;
+	pszExpression = FLTGetExpressionForValuesRanges(lp, (char *)item, value,  forcecharcter);
+	if (pszExpression)
+	    if(FLTApplyExpressionToLayer(lp, pszExpression))
+	      result = MS_TRUE;
+	    msFree(pszExpression);
+    return result;
+int msWMSApplyDimension(layerObj *lp, int version, char *dimensionname, char *value,
+			char *wms_exception_format)
+    char *dimensionitemname=NULL, *dimensionextentname=NULL, *dimensiontypename=NULL;
+    const char *dimensionitem, *dimensionextent, *dimensiontype;
+    int forcecharcter;
+    char *dimension = NULL;
+    if (lp && dimensionname && value && strlen(value) > 0)
+	/*check if the dimension name passes starts with dim_. All deimensions should start with dim_, except elevation*/
+	if (strncasecmp(dimensionname, "dim_", 4) == 0)
+	  dimension = msStrdup(dimensionname+4);
+	else
+	   dimension = msStrdup(dimensionname);
+	/*check if the manadatory metada related to the dimension are set*/
+	dimensionitemname = msStrdup(dimension);
+	dimensionitemname = msStringConcatenate(dimensionitemname, "_item");
+	dimensionitem = msOWSLookupMetadata(&(lp->metadata), "M", dimensionitemname);
+	dimensionextentname = msStrdup(dimension);
+	dimensionextentname = msStringConcatenate(dimensionextentname, "_extent");
+	dimensionextent = msOWSLookupMetadata(&(lp->metadata), "M", dimensionextentname);
+	/*if the server want to force the type to character*/
+	dimensiontypename = msStrdup(dimension);
+	dimensiontypename = msStringConcatenate(dimensiontypename, "_type");
+	dimensiontype = msOWSLookupMetadata(&(lp->metadata), "M", dimensiontypename);
+	forcecharcter = MS_FALSE;
+	if (dimensiontype && strcasecmp(dimensiontype, "Character") == 0)
+	  forcecharcter = MS_TRUE;
+	if (dimensionitem && dimensionextent)
+	    if(msWMSValidateDimensionValue(value, dimensionextent, forcecharcter))
+		result = msWMSApplyDimensionLayer(lp, dimensionitem, value, forcecharcter);
+	    else
+		msSetError(MS_WMSERR, "Dimension %s with a value of %s is invalid or outside the extents defined", "msWMSApplyDimension",
+			   dimension, value);
+		result =  MS_FALSE;
+	msFree(dimensionitemname);
+	msFree(dimensionextentname);
+	msFree(dimensiontypename);
+	msFree(dimension);
+    return result;
 int msWMSLoadGetMapParams(mapObj *map, int nVersion,
@@ -861,7 +1263,78 @@
           return MS_FAILURE;/* msWMSException(map, nVersion, "InvalidTimeRequest"); */
+  ** Check/apply  wms dimensions
+  ** all dimension requests shoul start with dim_xxxx, except time and elevation.
+  for (i=0; i<map->numlayers; i++)
+      layerObj *lp = NULL;
+      const char *dimensionlist = NULL;
+      char **tokens;
+      int ntokens=0,k;
+      lp = (GET_LAYER(map, i));
+      if (lp->status != MS_ON && lp->status != MS_DEFAULT)
+	continue;
+      dimensionlist = msOWSLookupMetadata(&(lp->metadata), "M", "dimensionlist");
+      if (!dimensionlist)
+	dimensionlist = msOWSLookupMetadata(&(map->web.metadata), "M", "dimensionlist");
+      if (dimensionlist)
+	   tokens = msStringSplit(dimensionlist,  ',', &ntokens);
+	   if (tokens && ntokens > 0)
+	       char *dimensionname=NULL;
+	       for (j=0; j<ntokens; j++)
+		   for(k=0; map && k<numentries; k++)
+		       if (strcasecmp(names[k], "elevation") == 0)
+			 dimensionname = msStrdup(names[k]);
+		       else
+			     dimensionname = msStrdup("dim_");
+			     dimensionname = msStringConcatenate(dimensionname, names[k]);
+		       /*the dim_ is supposed to be part of the dimension name in the request*/
+		       if (strcasecmp(tokens[j], "elevation") == 0)
+			 stmp = msStrdup(tokens[j]);
+		       else
+			   stmp =  msStrdup("dim_");
+			   msStringTrim(tokens[j]);
+			   stmp = msStringConcatenate(stmp, tokens[j]);
+		       if (strcasecmp(dimensionname, stmp) == 0)
+			   if (!msWMSApplyDimension(lp, nVersion, dimensionname, values[k],
+						    wms_exception_format))
+			       msFreeCharArray(tokens, ntokens);
+			       msFree(dimensionname);
+			       return msWMSException(lp->map, nVersion, "InvalidDimensionValue",  wms_exception_format);
+			   break;
   ** Apply the selected output format (if one was selected), and override
   ** the transparency if needed.
