[mapserver-commits] r12795 - in trunk/msautotest/wxs: . expected
Tue Nov 22 18:06:27 EST 2011
Author: assefa
Date: 2011-11-22 15:06:27 -0800 (Tue, 22 Nov 2011)
New Revision: 12795
Added:
   trunk/msautotest/wxs/expected/wms_dimension_cap.xml
   trunk/msautotest/wxs/expected/wms_dimension_cap130.xml
   trunk/msautotest/wxs/expected/wms_dimension_misc_1.png
   trunk/msautotest/wxs/wms_dimensions.map
add tests for wms dimension capabilities (#3466)
Added: trunk/msautotest/wxs/expected/wms_dimension_cap.xml
--- trunk/msautotest/wxs/expected/wms_dimension_cap.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_dimension_cap.xml	2011-11-22 23:06:27 UTC (rev 12795)
@@ -0,0 +1,142 @@
+<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.0/capabilities_1_1_0.dtd"
+ <!ELEMENT VendorSpecificCapabilities EMPTY>
+ ]>  <!-- end of DOCTYPE declaration -->
+<WMT_MS_Capabilities version="1.1.0">
+<!-- MapServer version 6.1-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
+<Service>
+  <Name>OGC:WMS</Name>
+<!-- WARNING: Mandatory metadata '..._title' was missing in this context. -->
+  <Title>wms_dimesion</Title>
+  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/mswms?"/>
+  <ContactInformation>
+  </ContactInformation>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <Format>application/vnd.ogc.wms_xml</Format>
+      <DCPType>
+        <HTTP>
+          <Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/mswms?"/></Get>
+          <Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/path/to/mswms?"/></Post>
+        </HTTP>
+      </DCPType>
+    </GetCapabilities>
+    <GetMap>
+      <Format>image/png</Format>
+      <Format>image/jpeg</Format>
+      <Format>image/gif</Format>
+      <Format>image/png; mode=8bit</Format>
+      <Format>application/x-pdf</Format>
+      <Format>image/svg+xml</Format>
+      <Format>image/tiff</Format>
+      <Format>application/vnd.google-earth.kml+xml</Format>
+      <Format>application/vnd.google-earth.kmz</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <Format>text/plain</Format>
+      <Format>application/vnd.ogc.gml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+    <DescribeLayer>
+      <Format>text/xml</Format>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </DescribeLayer>
+  </Request>
+  <Exception>
+    <Format>application/vnd.ogc.se_xml</Format>
+    <Format>application/vnd.ogc.se_inimage</Format>
+    <Format>application/vnd.ogc.se_blank</Format>
+  </Exception>
+  <VendorSpecificCapabilities />
+  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
+  <Layer>
+    <Name>wms_dimesion</Name>
+    <Abstract>wms_dimesion</Abstract>
+    <SRS>EPSG:4326</SRS>
+    <LatLonBoundingBox minx="0.000178" miny="-0.002134" maxx="0.00342" maxy="0.000314" />
+    <BoundingBox SRS="EPSG:4326"
+                minx="0.000178" miny="-0.002134" maxx="0.00342" maxy="0.000314" />
+    <Layer queryable="0" opaque="0" cascaded="0">
+        <Name>lakes_elev</Name>
+        <Title>Lakes</Title>
+        <LatLonBoundingBox minx="0.000178263" miny="-0.002134" maxx="0.0034202" maxy="0.000313775" />
+                    minx="0.000178263" miny="-0.002134" maxx="0.0034202" maxy="0.000313775" />
+        <Dimension name="elevation" units="meters"/>
+        <Extent name="elevation" default="500" nearestValue="0">500, 490, 480</Extent>
+        <Dimension name="text_dimension" units="my_units"/>
+        <Extent name="text_dimension" nearestValue="0">first, second, third</Extent>
+        <Style>
+          <Name>default</Name>
+          <Title>default</Title>
+          <LegendURL width="155" height="21">
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/mswms?version=1.1.0&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=lakes_elev&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Name>lakes_elev_range</Name>
+        <Extent name="elevation" nearestValue="0">490/800</Extent>
+        <Style>
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/mswms?version=1.1.0&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=lakes_elev_range&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Name>lakes_elev_multi_range</Name>
+        <Extent name="elevation" nearestValue="0">480/500,800/900</Extent>
+        <Style>
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/mswms?version=1.1.0&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=lakes_elev_multi_range&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+  </Layer>
+</Capability>
+</WMT_MS_Capabilities>
Added: trunk/msautotest/wxs/expected/wms_dimension_cap130.xml
--- trunk/msautotest/wxs/expected/wms_dimension_cap130.xml	                        (rev 0)
+++ trunk/msautotest/wxs/expected/wms_dimension_cap130.xml	2011-11-22 23:06:27 UTC (rev 12795)
@@ -0,0 +1,175 @@
+<WMS_Capabilities version="1.3.0"  xmlns="http://www.opengis.net/wms"   xmlns:sld="http://www.opengis.net/sld"   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"   xmlns:ms="http://mapserver.gis.umn.edu/mapserver"   xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd  http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd  http://mapserver.gis.umn.edu/mapserver http://localhost/path/to/mswms?service=WMS&amp;version=1.3.0&amp;request=GetSchemaExtension">
+<Service>
+  <Name>WMS</Name>
+  <MaxWidth>2048</MaxWidth>
+  <MaxHeight>2048</MaxHeight>
+</Service>
+<Capability>
+  <Request>
+    <GetCapabilities>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    <GetMap>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetMap>
+    <GetFeatureInfo>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </GetFeatureInfo>
+    <sld:DescribeLayer>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </sld:DescribeLayer>
+    <sld:GetLegendGraphic>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </sld:GetLegendGraphic>
+    <ms:GetStyles>
+      <DCPType>
+        <HTTP>
+        </HTTP>
+      </DCPType>
+    </ms:GetStyles>
+  </Request>
+  <Exception>
+    <Format>XML</Format>
+    <Format>INIMAGE</Format>
+    <Format>BLANK</Format>
+  </Exception>
+  <sld:UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0" InlineFeature="0" RemoteWCS="0"/>
+  <Layer>
+    <CRS>EPSG:4326</CRS>
+    <EX_GeographicBoundingBox>
+        <westBoundLongitude>0.000178</westBoundLongitude>
+        <eastBoundLongitude>0.00342</eastBoundLongitude>
+        <southBoundLatitude>-0.002134</southBoundLatitude>
+        <northBoundLatitude>0.000314</northBoundLatitude>
+    </EX_GeographicBoundingBox>
+    <BoundingBox CRS="EPSG:4326"
+                minx="-0.002134" miny="0.000178" maxx="0.000314" maxy="0.00342" />
+        <westBoundLongitude>0.000178263</westBoundLongitude>
+        <eastBoundLongitude>0.0034202</eastBoundLongitude>
+        <northBoundLatitude>0.000313775</northBoundLatitude>
+                    minx="-0.002134" miny="0.000178263" maxx="0.000313775" maxy="0.0034202" />
+        <Dimension name="elevation" units="meters" default="500" multipleValues="1" nearestValue="0">500, 490, 480</Dimension>
+        <Dimension name="text_dimension" units="my_units"  multipleValues="1"  nearestValue="0">first, second, third</Dimension>
+        <Style>
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/mswms?version=1.3.0&amp;service=WMS&amp;request=GetLegendGraphic&amp;sld_version=1.1.0&amp;layer=lakes_elev&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Dimension name="elevation" units="meters"  multipleValues="1"  nearestValue="0">490/800</Dimension>
+        <Style>
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/mswms?version=1.3.0&amp;service=WMS&amp;request=GetLegendGraphic&amp;sld_version=1.1.0&amp;layer=lakes_elev_range&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+        <Dimension name="elevation" units="meters"  multipleValues="1"  nearestValue="0">480/500,800/900</Dimension>
+        <Style>
+             <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost/path/to/mswms?version=1.3.0&amp;service=WMS&amp;request=GetLegendGraphic&amp;sld_version=1.1.0&amp;layer=lakes_elev_multi_range&amp;format=image/png&amp;STYLE=default"/>
+          </LegendURL>
+        </Style>
+    </Layer>
+  </Layer>
+</Capability>
+</WMS_Capabilities>
Added: trunk/msautotest/wxs/expected/wms_dimension_misc_1.png
(Binary files differ)
Property changes on: trunk/msautotest/wxs/expected/wms_dimension_misc_1.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/msautotest/wxs/wms_dimensions.map
--- trunk/msautotest/wxs/wms_dimensions.map	2011-11-22 19:56:11 UTC (rev 12794)
+++ trunk/msautotest/wxs/wms_dimensions.map	2011-11-22 23:06:27 UTC (rev 12795)
@@ -104,6 +104,18 @@
 # h- one valid range and one invalid range
 # RUN_PARMS: wms_dimension_extent_multi_range_8.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOX=0.000178,-0.002134,0.003420,0.000314&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=lakes_elev_multi_range&STYLES=&elevation=490/500,300/600" > [RESULT_DEVERSION]
+# 6- capabilities
+# RUN_PARMS: wms_dimension_cap.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetCapabilities" > [RESULT_DEMIME]
+# Capabilities 1.3.0
+# RUN_PARMS: wms_dimension_cap130.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities" > [RESULT_DEMIME]
+# 7 Misc
+# a- empty value: use default
+# RUN_PARMS: wms_dimension_misc_1.png [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOX=0.000178,-0.002134,0.003420,0.000314&FORMAT=image/png; mode=24bit&WIDTH=300&HEIGHT=300&STYLES=&LAYERS=lakes_elev&elevation=" > [RESULT_DEMIME]
 MAP
 NAME wms_dimesion
@@ -124,6 +136,7 @@
    METADATA
+     "WMS_ONLINERESOURCE"   "http://localhost/path/to/mswms?"
      "ows_enable_request" "*"
      "wms_srs"		   "EPSG:4326"
   END
@@ -148,9 +161,12 @@
     "wms_dimensionlist" "elevation, text_dimension"
     "wms_elevation_item" "ELEV"
     "wms_elevation_extent" "500, 490, 480"
+    "wms_elevation_units" "meters"
+     "wms_elevation_default" "500"
     "wms_text_dimension_item" "text_dimen"
     "wms_text_dimension_extent" "first, second, third"
+    "wms_text_dimension_units" "my_units"
   END
   TYPE POLYGON
@@ -180,6 +196,7 @@
     "wms_dimensionlist" "elevation"
     "wms_elevation_extent" "490/800"
   END
   TYPE POLYGON
   STATUS ON
@@ -206,6 +223,7 @@
     "wms_elevation_extent" "480/500,800/900"
   END
   TYPE POLYGON
   STATUS ON
