[mapserver-commits] r12800 - trunk/docs/en/ogc
svn at osgeo.org
svn at osgeo.org
Wed Nov 23 13:43:35 EST 2011
Author: assefa
Date: 2011-11-23 10:43:35 -0800 (Wed, 23 Nov 2011)
New Revision: 12800
trunk/docs/en/ogc/wms_dimension.txt
add example for wms dimensions (#3466)
Modified: trunk/docs/en/ogc/wms_dimension.txt
--- trunk/docs/en/ogc/wms_dimension.txt 2011-11-23 18:42:13 UTC (rev 12799)
+++ trunk/docs/en/ogc/wms_dimension.txt 2011-11-23 18:43:35 UTC (rev 12800)
@@ -143,6 +143,15 @@
expressions and set it on the :ref:`LAYER` `FILTER` object.
If there was already a Logical “MapServer expressions”, It will be concatenated with it.
+For example a request such as &elevation=490/500&... on a MapServer layer (with an empty FILTER) would give
.. code-block:: mapfile
FILTER (([ELEV] >= 490 AND [ELEV] <= 500))
+For example a request such as &elevation=600&... on a postgis layer with an existing FILTER would give
+.. code-block:: guess
+- FILTER (elev > 500) #before request
+- FILTER ((elev > 500) and (((ELEV = 600)))) #after request
More information about the mapserver-commits
