[mapserver-commits] r12819 - trunk/mapserver
Mon Nov 28 09:49:09 EST 2011
Author: assefa
Date: 2011-11-28 06:49:09 -0800 (Mon, 28 Nov 2011)
New Revision: 12819
   trunk/mapserver/mapogcfilter.c
   trunk/mapserver/mapogcfilter.h
correct build issues when mapserver is built without ogr (#3466)
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2011-11-28 10:35:01 UTC (rev 12818)
+++ trunk/mapserver/mapogcfilter.c	2011-11-28 14:49:09 UTC (rev 12819)
@@ -40,7 +40,6 @@
 MS_CVSID("$Id$")
-#ifdef USE_OGR
 int FLTIsNumeric(char *pszValue)
@@ -79,6 +78,261 @@
     return MS_FALSE;
+** Apply an expression to the layer's filter element.
+int FLTApplyExpressionToLayer(layerObj *lp, char *pszExpression)
+    char *pszFinalExpression=NULL, *pszBuffer = NULL;
+    /*char *escapedTextString=NULL;*/
+    int bConcatWhere=0, bHasAWhere=0;
+    if (lp && pszExpression)
+	 if (lp->connectiontype == MS_POSTGIS || lp->connectiontype ==  MS_ORACLESPATIAL ||
+	     lp->connectiontype == MS_SDE || lp->connectiontype == MS_PLUGIN)
+	     pszFinalExpression = msStrdup("(");
+	     pszFinalExpression = msStringConcatenate(pszFinalExpression, pszExpression);
+	     pszFinalExpression = msStringConcatenate(pszFinalExpression, ")");
+	 else if (lp->connectiontype == MS_OGR)
+	     pszFinalExpression = msStrdup(pszExpression);
+	     if (lp->filter.type != MS_EXPRESSION)
+		 bConcatWhere = 1;
+	     else
+		 if (lp->filter.string && EQUALN(lp->filter.string,"WHERE ",6))
+		     bHasAWhere = 1;
+		     bConcatWhere =1;
+	 else
+	 if (bConcatWhere)
+	   pszBuffer = msStringConcatenate(pszBuffer, "WHERE ");
+	 /* if the filter is set and it's an expression type, concatenate it with
+               this filter. If not just free it */
+	 if (lp->filter.string && lp->filter.type == MS_EXPRESSION)
+	     pszBuffer = msStringConcatenate(pszBuffer, "((");
+	    if (bHasAWhere)
+	      pszBuffer = msStringConcatenate(pszBuffer, lp->filter.string+6);
+	    else
+	      pszBuffer = msStringConcatenate(pszBuffer, lp->filter.string);
+	    pszBuffer = msStringConcatenate(pszBuffer, ") and ");
+	 else if (lp->filter.string)
+	   freeExpression(&lp->filter);
+	 pszBuffer = msStringConcatenate(pszBuffer, pszFinalExpression);
+	if(lp->filter.string && lp->filter.type == MS_EXPRESSION)
+	  pszBuffer = msStringConcatenate(pszBuffer, ")");
+	/*assuming that expression was properly escaped
+        escapedTextString = msStringEscape(pszBuffer);
+        msLoadExpressionString(&lp->filter,
+                               (char*)CPLSPrintf("%s", escapedTextString));
+        msFree(escapedTextString);
+	msLoadExpressionString(&lp->filter, pszBuffer);
+        msFree(pszFinalExpression);
+	if (pszBuffer)
+	  msFree(pszBuffer);
+	return MS_TRUE;
+    return MS_FALSE;
+char *FLTGetExpressionForValuesRanges(layerObj *lp, char *item, char *value,  int forcecharcter)
+    int bIscharacter, bSqlLayer;
+    char *pszExpression = NULL, *pszEscapedStr=NULL, *pszTmpExpression=NULL;
+    char **paszElements = NULL, **papszRangeElements=NULL;
+    int numelements,i,nrangeelements;
+    double minval, maxval;
+    if (lp && item && value)
+	  bSqlLayer = MS_TRUE;
+	else
+	  bSqlLayer = MS_FALSE;
+	if (strstr(value, "/") == NULL)
+	    /*value(s)*/
+	    paszElements = msStringSplit (value, ',', &numelements);
+	    if (paszElements && numelements > 0)
+		if (forcecharcter)
+		  bIscharacter = MS_TRUE;
+		bIscharacter= !FLTIsNumeric(paszElements[0]);
+		pszTmpExpression = msStringConcatenate(pszTmpExpression, "(");
+		for (i=0; i<numelements; i++)
+		    if (bSqlLayer)
+		      pszTmpExpression = msStringConcatenate(pszTmpExpression, item);
+		    else
+			if (bIscharacter)
+			  pszTmpExpression = msStringConcatenate(pszTmpExpression, "\"");
+			pszTmpExpression = msStringConcatenate(pszTmpExpression, "[");
+			pszTmpExpression = msStringConcatenate(pszTmpExpression, "]");
+			if (bIscharacter)
+		    if (bIscharacter)
+		       if (bSqlLayer)
+			 pszTmpExpression = msStringConcatenate(pszTmpExpression, " = '");
+		       else
+			 pszTmpExpression = msStringConcatenate(pszTmpExpression, " = \"");
+		    else
+		      pszTmpExpression = msStringConcatenate(pszTmpExpression, " = ");
+		    pszEscapedStr = msLayerEscapeSQLParam(lp, paszElements[i]);
+		    pszTmpExpression = msStringConcatenate(pszTmpExpression, pszEscapedStr);
+		    if (bIscharacter)
+			if (bSqlLayer)
+			  pszTmpExpression = msStringConcatenate(pszTmpExpression, "'");
+			else
+		    pszTmpExpression = msStringConcatenate(pszTmpExpression, ")");
+		    msFree(pszEscapedStr);
+		    pszEscapedStr=NULL;
+		    if (pszExpression != NULL)
+		      pszExpression = msStringConcatenate(pszExpression, " OR ");
+		    pszExpression =  msStringConcatenate(pszExpression, pszTmpExpression);
+		    msFree(pszTmpExpression);
+		    pszTmpExpression = NULL;
+		pszExpression = msStringConcatenate(pszExpression, ")");
+		msFreeCharArray(paszElements, numelements);
+	else
+	    /*range(s)*/
+		    papszRangeElements = msStringSplit (paszElements[i], '/', &nrangeelements);
+		    if (papszRangeElements && nrangeelements > 0)
+			if (nrangeelements == 2 || nrangeelements == 3)
+			    minval = atof(papszRangeElements[0]);
+			    maxval = atof(papszRangeElements[1]);
+			    if (bSqlLayer)
+			    else
+			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " >= ");
+			    pszEscapedStr = msLayerEscapeSQLParam(lp, papszRangeElements[0]);
+			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " AND ");
+			    if (bSqlLayer)
+			    else
+			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " <= ");
+			    pszEscapedStr = msLayerEscapeSQLParam(lp, papszRangeElements[1]);
+			else if (nrangeelements == 1)
+			    if (bSqlLayer)
+			    else
+			msFreeCharArray(papszRangeElements, nrangeelements);
+    return pszExpression;
+#ifdef USE_OGR
 int FLTogrConvertGeometry(OGRGeometryH hGeometry, shapeObj *psShape,
                           OGRwkbGeometryType nType)
@@ -282,259 +536,9 @@
     return MS_FALSE;
-char *FLTGetExpressionForValuesRanges(layerObj *lp, char *item, char *value,  int forcecharcter)
-    int bIscharacter, bSqlLayer;
-    char *pszExpression = NULL, *pszEscapedStr=NULL, *pszTmpExpression=NULL;
-    char **paszElements = NULL, **papszRangeElements=NULL;
-    int numelements,i,nrangeelements;
-    double minval, maxval;
-    if (lp && item && value)
-	if (lp->connectiontype == MS_POSTGIS || lp->connectiontype ==  MS_ORACLESPATIAL ||
-	    lp->connectiontype == MS_SDE || lp->connectiontype == MS_PLUGIN)
-	  bSqlLayer = MS_TRUE;
-	else
-	  bSqlLayer = MS_FALSE;
-	if (strstr(value, "/") == NULL)
-	    /*value(s)*/
-	    paszElements = msStringSplit (value, ',', &numelements);
-	    if (paszElements && numelements > 0)
-		if (forcecharcter)
-		  bIscharacter = MS_TRUE;
-		bIscharacter= !FLTIsNumeric(paszElements[0]);
-		pszTmpExpression = msStringConcatenate(pszTmpExpression, "(");
-		for (i=0; i<numelements; i++)
-		    if (bSqlLayer)
-		      pszTmpExpression = msStringConcatenate(pszTmpExpression, item);
-		    else
-			if (bIscharacter)
-			  pszTmpExpression = msStringConcatenate(pszTmpExpression, "\"");
-			pszTmpExpression = msStringConcatenate(pszTmpExpression, "[");
-			pszTmpExpression = msStringConcatenate(pszTmpExpression, "]");
-			if (bIscharacter)
-		    if (bIscharacter)
-		       if (bSqlLayer)
-			 pszTmpExpression = msStringConcatenate(pszTmpExpression, " = '");
-		       else
-			 pszTmpExpression = msStringConcatenate(pszTmpExpression, " = \"");
-		    else
-		      pszTmpExpression = msStringConcatenate(pszTmpExpression, " = ");
-		    pszEscapedStr = msLayerEscapeSQLParam(lp, paszElements[i]);
-		    pszTmpExpression = msStringConcatenate(pszTmpExpression, pszEscapedStr);
-		    if (bIscharacter)
-			if (bSqlLayer)
-			  pszTmpExpression = msStringConcatenate(pszTmpExpression, "'");
-			else
-		    pszTmpExpression = msStringConcatenate(pszTmpExpression, ")");
-		    msFree(pszEscapedStr);
-		    pszEscapedStr=NULL;
-		    if (pszExpression != NULL)
-		      pszExpression = msStringConcatenate(pszExpression, " OR ");
-		    pszExpression =  msStringConcatenate(pszExpression, pszTmpExpression);
-		    msFree(pszTmpExpression);
-		    pszTmpExpression = NULL;
-		pszExpression = msStringConcatenate(pszExpression, ")");
-		msFreeCharArray(paszElements, numelements);
-	else
-	    /*range(s)*/
-		    papszRangeElements = msStringSplit (paszElements[i], '/', &nrangeelements);
-		    if (papszRangeElements && nrangeelements > 0)
-			if (nrangeelements == 2 || nrangeelements == 3)
-			    minval = atof(papszRangeElements[0]);
-			    maxval = atof(papszRangeElements[1]);
-			    if (bSqlLayer)
-			    else
-			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " >= ");
-			    pszEscapedStr = msLayerEscapeSQLParam(lp, papszRangeElements[0]);
-			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " AND ");
-			    if (bSqlLayer)
-			    else
-			    pszTmpExpression = msStringConcatenate(pszTmpExpression, " <= ");
-			    pszEscapedStr = msLayerEscapeSQLParam(lp, papszRangeElements[1]);
-			else if (nrangeelements == 1)
-			    if (bSqlLayer)
-			    else
-			msFreeCharArray(papszRangeElements, nrangeelements);
-    return pszExpression;
-** Apply an expression to the layer's filter element.
-int FLTApplyExpressionToLayer(layerObj *lp, char *pszExpression)
-    char *pszFinalExpression=NULL, *pszBuffer = NULL;
-    /*char *escapedTextString=NULL;*/
-    int bConcatWhere=0, bHasAWhere=0;
-    if (lp && pszExpression)
-	     pszFinalExpression = msStrdup("(");
-	     pszFinalExpression = msStringConcatenate(pszFinalExpression, pszExpression);
-	     pszFinalExpression = msStringConcatenate(pszFinalExpression, ")");
-	 else if (lp->connectiontype == MS_OGR)
-	     pszFinalExpression = msStrdup(pszExpression);
-	     if (lp->filter.type != MS_EXPRESSION)
-		 bConcatWhere = 1;
-	     else
-		 if (lp->filter.string && EQUALN(lp->filter.string,"WHERE ",6))
-		     bHasAWhere = 1;
-		     bConcatWhere =1;
-	 else
-	 if (bConcatWhere)
-	   pszBuffer = msStringConcatenate(pszBuffer, "WHERE ");
-	 /* if the filter is set and it's an expression type, concatenate it with
-               this filter. If not just free it */
-	 if (lp->filter.string && lp->filter.type == MS_EXPRESSION)
-	     pszBuffer = msStringConcatenate(pszBuffer, "((");
-	    if (bHasAWhere)
-	      pszBuffer = msStringConcatenate(pszBuffer, lp->filter.string+6);
-	    else
-	      pszBuffer = msStringConcatenate(pszBuffer, lp->filter.string);
-	    pszBuffer = msStringConcatenate(pszBuffer, ") and ");
-	 else if (lp->filter.string)
-	   freeExpression(&lp->filter);
-	 pszBuffer = msStringConcatenate(pszBuffer, pszFinalExpression);
-	if(lp->filter.string && lp->filter.type == MS_EXPRESSION)
-	  pszBuffer = msStringConcatenate(pszBuffer, ")");
-	/*assuming that expression was properly escaped
-        escapedTextString = msStringEscape(pszBuffer);
-        msLoadExpressionString(&lp->filter,
-                               (char*)CPLSPrintf("%s", escapedTextString));
-        msFree(escapedTextString);
-                               (char*)CPLSPrintf("%s", pszBuffer));
-        msFree(pszFinalExpression);
-	if (pszBuffer)
-	  msFree(pszBuffer);
-	return MS_TRUE;
-    return MS_FALSE;
 /*                      FLTApplySimpleSQLFilter()                       */
@@ -672,6 +676,7 @@
     if (szExpression)
         char *escapedTextString;
+	char *pszTmp= NULL;
         if (bConcatWhere)
@@ -697,8 +702,11 @@
-                               (char*)CPLSPrintf("\"%s\"", escapedTextString));
+	pszTmp =  (char *)msSmallMalloc(sizeof(char)*(strlen(lp->filter.string)+3));
+	sprintf(pszTmp,"\"%s\"",escapedTextString);
+	msLoadExpressionString(&lp->filter, pszTmp);
+	free(pszTmp);
+        /*msLoadExpressionString(&lp->filter,  (char*)CPLSPrintf("\"%s\"", escapedTextString)); */
         free(escapedTextString);
         free(szExpression);
Modified: trunk/mapserver/mapogcfilter.h
--- trunk/mapserver/mapogcfilter.h	2011-11-28 10:35:01 UTC (rev 12818)
+++ trunk/mapserver/mapogcfilter.h	2011-11-28 14:49:09 UTC (rev 12819)
@@ -30,6 +30,12 @@
 #define MAPOGCFILTER_H
 #include "mapserver.h"
+/*dont need ogr for these functikons*/
+MS_DLL_EXPORT int FLTIsNumeric(char *pszValue);
+MS_DLL_EXPORT int FLTApplyExpressionToLayer(layerObj *lp, char *pszExpression);
+MS_DLL_EXPORT  char *FLTGetExpressionForValuesRanges(layerObj *lp, char *item, char *value,  int forcecharcter);
 #ifdef USE_OGR
 /* There is a dependency to OGR for the MiniXML parser */
@@ -105,8 +111,6 @@
 /*SQL expressions related functions.*/
 MS_DLL_EXPORT int FLTApplySimpleSQLFilter(FilterEncodingNode *psNode, mapObj *map,
                           int iLayerIndex);
-MS_DLL_EXPORT int FLTApplyExpressionToLayer(layerObj *lp, char *pszExpression);
-MS_DLL_EXPORT  char *FLTGetExpressionForValuesRanges(layerObj *lp, char *item, char *value,  int forcecharcter);
 MS_DLL_EXPORT char *FLTGetSQLExpression(FilterEncodingNode *psFilterNode,layerObj *lp);
 MS_DLL_EXPORT char *FLTGetBinaryComparisonSQLExpresssion(FilterEncodingNode *psFilterNode, layerObj *lp);
@@ -122,7 +126,6 @@
 MS_DLL_EXPORT int FLTParseGMLEnvelope(CPLXMLNode *psRoot, rectObj *psBbox, char **ppszSRS);
 MS_DLL_EXPORT  int FLTParseGMLBox(CPLXMLNode *psBox, rectObj *psBbox, char **ppszSRS);
-MS_DLL_EXPORT int FLTIsNumeric(char *pszValue);
 /*common-expressions*/
 MS_DLL_EXPORT   char *FLTGetBinaryComparisonCommonExpression(FilterEncodingNode *psFilterNode, layerObj *lp);
 MS_DLL_EXPORT  char *FLTGetCommonExpression(FilterEncodingNode *psFilterNode, layerObj *lp);
