[mapserver-commits] r12617 - branches/branch-5-6/mapserver
Tue Oct 4 11:01:41 EDT 2011
Author: dmorissette
Date: 2011-10-04 08:01:41 -0700 (Tue, 04 Oct 2011)
New Revision: 12617
   branches/branch-5-6/mapserver/HISTORY.TXT
   branches/branch-5-6/mapserver/configure
   branches/branch-5-6/mapserver/configure.in
Fix Linux build vs strlcpy (#4008)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT	2011-10-04 13:16:41 UTC (rev 12616)
+++ branches/branch-5-6/mapserver/HISTORY.TXT	2011-10-04 15:01:41 UTC (rev 12617)
@@ -16,6 +16,8 @@
 - define Z_BEST_COMPRESSION for newer libpng versions (#4033)
+- Fixes to support latest PROJ versions (#4008)
 Version 5.6.7 (2011-07-12):
Modified: branches/branch-5-6/mapserver/configure
--- branches/branch-5-6/mapserver/configure	2011-10-04 13:16:41 UTC (rev 12616)
+++ branches/branch-5-6/mapserver/configure	2011-10-04 15:01:41 UTC (rev 12617)
@@ -4444,6 +4444,102 @@
   STRINGS="-DNEED_STRLCAT $STRINGS"
 fi
+echo "$as_me:$LINENO: checking for strlcpy" >&5
+echo $ECHO_N "checking for strlcpy... $ECHO_C" >&6
+if test "${ac_cv_func_strlcpy+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+/* Define strlcpy to an innocuous variant, in case <limits.h> declares strlcpy.
+   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
+#define strlcpy innocuous_strlcpy
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char strlcpy (); below.
+    Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+    <limits.h> exists even on freestanding compilers.  */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef strlcpy
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char strlcpy ();
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_strlcpy) || defined (__stub___strlcpy)
+choke me
+#else
+char (*f) () = strlcpy;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != strlcpy;
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+  ac_cv_func_strlcpy=yes
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_func_strlcpy=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_strlcpy" >&5
+echo "${ECHO_T}$ac_cv_func_strlcpy" >&6
+if test $ac_cv_func_strlcpy = yes; then
+else
+  STRINGS="-DNEED_STRLCPY $STRINGS"
+fi
 echo "$as_me:$LINENO: checking for vsnprintf" >&5
 echo $ECHO_N "checking for vsnprintf... $ECHO_C" >&6
 if test "${ac_cv_func_vsnprintf+set}" = set; then
Modified: branches/branch-5-6/mapserver/configure.in
--- branches/branch-5-6/mapserver/configure.in	2011-10-04 13:16:41 UTC (rev 12616)
+++ branches/branch-5-6/mapserver/configure.in	2011-10-04 15:01:41 UTC (rev 12617)
@@ -70,6 +70,7 @@
 AC_CHECK_FUNC(strrstr, ,      STRINGS="-DNEED_STRRSTR $STRINGS")
 AC_CHECK_FUNC(strcasestr, ,      STRINGS="-DNEED_STRCASESTR $STRINGS")
 AC_CHECK_FUNC(strlcat, ,      STRINGS="-DNEED_STRLCAT $STRINGS")
+AC_CHECK_FUNC(strlcpy, ,      STRINGS="-DNEED_STRLCPY $STRINGS")
 AC_CHECK_FUNC(vsnprintf, STRINGS="-DHAVE_VSNPRINTF $STRINGS", )
 AC_SUBST(STRINGS, $STRINGS)
