[mapserver-commits] r12620 - trunk/docs/en/mapcache
    svn at osgeo.org
    svn at osgeo.org
    Wed Oct  5 13:25:51 EDT 2011
Author: tbonfort
Date: 2011-10-05 10:25:51 -0700 (Wed, 05 Oct 2011)
New Revision: 12620
Added:
   trunk/docs/en/mapcache/mapcache_caches.txt
   trunk/docs/en/mapcache/index.txt
   trunk/docs/en/mapcache/mapcache_config.txt
   trunk/docs/en/mapcache/mapcache_install.txt
   trunk/docs/en/mapcache/mapcache_seed.txt
add documentation for different mapcache caches, along with the documentation for upcoming TIFF caches
Modified: trunk/docs/en/mapcache/index.txt
--- trunk/docs/en/mapcache/index.txt	2011-10-05 12:55:28 UTC (rev 12619)
+++ trunk/docs/en/mapcache/index.txt	2011-10-05 17:25:51 UTC (rev 12620)
@@ -1,7 +1,7 @@
 .. _mapcache:
- Mapserver MapCache
+MapCache
 :Author: Thomas Bonfort
@@ -19,6 +19,7 @@
    mapcache_install
    mapcache_config
    mapcache_seed
+   mapcache_caches
 Features
Added: trunk/docs/en/mapcache/mapcache_caches.txt
--- trunk/docs/en/mapcache/mapcache_caches.txt	                        (rev 0)
+++ trunk/docs/en/mapcache/mapcache_caches.txt	2011-10-05 17:25:51 UTC (rev 12620)
@@ -0,0 +1,249 @@
+.. _mapcache_caches:
+Cache Types
+:Author: Thomas Bonfort
+:Contact: tbonfort at terriscope.fr
+This document details the different cache backends that can be used to store tiles
+Disk Caches
+The disk based cache is the simplest cache to configure, and the one with the
+the fastest access to existing tiles. It is ideal for small tile repositories,
+but may cause trouble for sites hosting millions of tiles, as the number of
+files or directory may rapidly overcome the capabilities of the underlying
+filesystem. Additionaly, the block size chosen for the filesystem must closely
+match the mean size of a stored tile: ideally, any given tile should just fit
+inside a filesystem block, so as not to waste storage space inside each block,
+and not have to use up multiple blocks per tile.
+The location of the files/directories has to be readable and writable by the
+user running the tile server.
+There are two types of disk caches, that create a different hierarchy of files:
+Default Structure
+The default disk cache stores tiles in a structure nearly identical to the
+file/directory hierarchy used by TileCache. The only change is that a top level
+directory corresponding to the name of the grid is added (as MapCache supports
+multiple grids per tileset)
+This cache is capable of detecting blank (i.e. uniform color) tiles and using
+a symbolic link to a single blank tile to gain disk space.
+.. code-block:: xml
+   <cache name="disk" type="disk">
+      <base>/tmp</base>
+      <symlink_blank/>
+   </cache>
+The two only configuration keys are the root directory where the tiles will be
+stored, and a key to activate the symbolic linking of blank tiles
+Template Structure
+The template based disk cache allows you to create (or reuse an existing) tile
+structure that you define in advance. The <template> parameter takes a string
+argument where various template entries will be replaced at runtime by the correct
+value for each tile to store.
+   <cache name="tmpl" type="disk">
+      <!-- template
+          string template that will be used to map a tile (by tileset, grid name, dimension,
+          format, x, y, and z) to a filename on the filesystem.
+          the following replacements are performed:
+          - {tileset} : the tileset name
+          - {grid} : the grid name
+          - {dim} : a string that concatenates the tile's dimension
+          - {ext} : the filename extension for the tile's image format
+          - {x},{y},{z} : the tile x,y,z values
+          - {inv_x}, {inv_y}, {inv_z} : inverted x,y,z values (inv_x = level->maxx - x - 1). This
+               is mainly used to support grids where one axis is inverted (e.g. the google schema)
+               and you want to create on offline cache.
+         * note that this type of cache does not support blank-tile detection and symlinking.
+         * warning: it is up to you to make sure that the template you chose creates a unique
+           filename for your given tilesets. e.g. do not ommit the {grid} parameter if your
+           tilesets reference multiple grids. Failure to do so will result in filename
+           collisions !
+      <template>/tmp/template-test/{tileset}#{grid}#{dim}/{z}/{x}/{y}.{ext}</template>
+   </cache>
+Sqlite Caches
+There are three different sqlite caches that vary by the database schema they
+create and query. Sqlite caches have the advantage that they store tiles as
+blobs inside a single database file, and therefore do not have the
+disadvantages of disk caches with regards to the number of files stored. As the
+image blobs are stored contiguously, the block size chosen for the filesystem
+has no influence on the storage capacity of he volume.
+The sqlite based caches are a bit slower than the disk based caches, and may
+have write-locking issues at seed time if a high number of threads all try to
+insert new tiles concurrently.
+Default Schema
+There are two different configuration options for sqlite caches, which drive how
+the database files are named on the filesystem for each tileset. You can either
+supply a base directory, where multiple database files will be created, or
+supply a template that will be populated with the name of the tileset and grid.
+Note
+   <cache name="sqlite" type="sqlite3">
+      <base>/tmp/sqlitecachedir</base>
+   </cache>
+   <cache name="sqlitetemplate" type="sqlite3">
+      <dbname_template>/tmp/{tileset}-{grid}.db</dbname_template>
+   </cache>
+The default sqlite schema is created by the call
+.. code-block:: sql
+   create table tiles(x integer, y integer, z integer, data blob, dim text, ctime datetime, atime datetime, hitcount integer default 0, primary key(x,y,z,dim))
+Custom Schema
+This cache can use any database schema, it is up to you to supply the SQL that
+will be exectuted to select or insert a new tile.
+This cache type is not fully implemented yet (there is no way to configure it
+from the mapcache.xml configuration file yet)
+MBTiles Schema
+This cache type is a shortcut to the previous custom schema sqlite cache, with
+pre-populated SQL queries that correspond to the MBTiles specification.
+Note that most mbtiles file you download cannot be populated on demand as the
+spec-mandated table names are actually views and not simple tables.
+   <cache name="mbtiles" type="mbtiles">
+      <dbname_template>/Users/XXX/Documents/MapBox/tiles/natural-earth-1.mbtiles</dbname_template>
+   </cache>
+Memcache Caches
+This cache type stores tile to an external memcached server running on the local
+machine or accessible on the network. This cache type has the advantage that
+memcached takes care of expiring tiles, so the size of the cache will never
+exceed what has been configured in the memcache instance.
+Memcache support requires a rather recent version of the apr-util library. Note
+that under very high loads (usually only atainable on synthetic benchmarks on
+localhost), the memcache implementation of apr-util may fail and start dropping
+connections for some intervals of time before coming back online afterwards.
+You can add multiple <server> entries.
+   <cache name="memcache" type="memcache">
+      <server>
+         <host>localhost</host>
+         <port>11211</port>
+      </server>
+   </cache>
+TIFF Caches
+TIFF caches are the most recent addition to the family of caches, and use the
+internal tile structure of the TIFF specification to access tile data. Tiles can
+be stored in JPEG only (TIFF does not support PNG tiles).
+As a single tiff file may contain many tiles, there is a drastic reduction in
+the number of files that have to be stored on the filesystem, which solves the
+major shortcomings of the disk cache. Another advantage is that the same TIFF
+files can be used by programs or WMS servers that only understand regular GIS
+raster formats, and be served up with high performance for tile access.
+The TIFF cache should be considered read-only for the time being. Write access
+is already possible but not ready for production, and is missing basic
+functionality (such as choosing the JPEG compression level, or adding the
+geotiff referencing).
+Note that the tiff tile structure must
+exactly match the structure of the grid used by the tileset, and the tif file
+names must follow strict naming rules.
+There are three parameters to configure a TIFF cache:
+- <xcount> the number of tiles stored along the x (horizontal) direction of
+  the TIFF file.
+- <ycount> the number of tiles stored along the y (vertical) direction of
+  the TIFF file.
+- <template> the template to use when looking up a TIFF file name given the
+  x,y,z of the requested tile
+  - {x} is replaced by the x value of the leftmost tile inside the TIFF file
+    containing the requested tile
+  - {inv_x} is replaced by the x value of the rightmost tile.
+  - {y} is replaced by the y value of the bottommost tile.
+  - {inv_y} is replaced by the y value of the topmost tile.
+  - {div_x} is replaced by the index of the TIFF file starting from the left
+    of the grid (i.e. {div_x} = {x}/<countx>)
+  - {inv_div_x} same as {div_x} but starting from the right.
+  - {div_y} is replaced by the index of the TIFF file starting from the bottom
+    of the grid (i.e. {div_y} = {y}/<county>)
+  - {inv_div_y} same as {div_y} but starting from the top.
+  Note that {inv_x} and {inv_div_x} will probably be rarely used, whereas
+  {inv_y} and {inv_div_y} will find some usage for people who prefer to index
+  their TIFF files from top to bottom rather than bottom to top.
+   <cache name="tiff" type="tiff">
+      <template>/data/tiffs/{tileset}/{grid}/L{z}/R{inv_y}/C{x}.tif</template>
+      <xcount>64</xcount>
+      <ycount>64</ycount>
+   </cache>
+In this example, assuming a grid using 256x256 tiles, the files that are read
+to load the tiles are tiled TIFFs with jpeg compression, who's size are
+16384x16384. The number of files to store on disk is thus reduced 4096 times
+compared to the basic disk cache.
Modified: trunk/docs/en/mapcache/mapcache_config.txt
--- trunk/docs/en/mapcache/mapcache_config.txt	2011-10-05 12:55:28 UTC (rev 12619)
+++ trunk/docs/en/mapcache/mapcache_config.txt	2011-10-05 17:25:51 UTC (rev 12620)
@@ -1,8 +1,7 @@
 .. _mapcache_config:
+***************************************************************************** Configuration File
- Mapserver MapCache Configuration File
Modified: trunk/docs/en/mapcache/mapcache_install.txt
--- trunk/docs/en/mapcache/mapcache_install.txt	2011-10-05 12:55:28 UTC (rev 12619)
+++ trunk/docs/en/mapcache/mapcache_install.txt	2011-10-05 17:25:51 UTC (rev 12620)
@@ -1,7 +1,7 @@
 .. _mapcache_install:
- Mapserver MapCache Compilation/Installation Instructions
+Compilation/Installation Instructions
Modified: trunk/docs/en/mapcache/mapcache_seed.txt
--- trunk/docs/en/mapcache/mapcache_seed.txt	2011-10-05 12:55:28 UTC (rev 12619)
+++ trunk/docs/en/mapcache/mapcache_seed.txt	2011-10-05 17:25:51 UTC (rev 12620)
@@ -1,7 +1,7 @@
 .. _mapcache_seed:
- MapCache Seeder
+Seeder
@@ -41,6 +41,7 @@
                 the value chosen here should never be much higher than the number
                 of cpus on the wms server)
    -q: don't print progress messages to the standard output
+   -v: print verbose debugging info (if compiled in)
    -D "DIMENSION=VALUE": used to specify which dimension to use if the tileset supports
                          dimensions. Can be used multiple times to set multiple
                          dimensions, e.g. -D "DIM1=VAL1" -D "DIM2=VAL2"
More information about the mapserver-commits
