[mapserver-commits] r12623 - trunk/mapserver/mapcache/src
Thu Oct 6 07:10:23 EDT 2011
Author: tbonfort
Date: 2011-10-06 04:10:23 -0700 (Thu, 06 Oct 2011)
New Revision: 12623
   trunk/mapserver/mapcache/src/source_mapserver.c
adjust wms extent to mapserver extent.
use a copy of the mapObj instead of reparsing it from the mapfile
Modified: trunk/mapserver/mapcache/src/source_mapserver.c
--- trunk/mapserver/mapcache/src/source_mapserver.c	2011-10-06 10:04:53 UTC (rev 12622)
+++ trunk/mapserver/mapcache/src/source_mapserver.c	2011-10-06 11:10:23 UTC (rev 12623)
@@ -41,7 +41,17 @@
 void _mapcache_source_mapserver_render_map(mapcache_context *ctx, mapcache_map *map) {
    mapcache_source_mapserver *mapserver = (mapcache_source_mapserver*)map->tileset->source;
-   mapObj *omap = msLoadMap(mapserver->mapfile,NULL);
+   static mapObj *origmap = NULL;
+   if(!origmap) {
+      origmap = msLoadMap(mapserver->mapfile,NULL);
+   if(!origmap) {
+      msWriteError(stderr);
+      ctx->set_error(ctx,500,"failed to load mapfile %s",mapserver->mapfile);
+      return;
+   mapObj *omap = msNewMapObj();
+   msCopyMap(omap,origmap);
   /* copy the original mapfile's projection to any layer that doesn't already
@@ -78,10 +88,19 @@
-   omap->extent.minx = map->extent[0];
-   omap->extent.miny = map->extent[1];
-   omap->extent.maxx = map->extent[2];
-   omap->extent.maxy = map->extent[3];
+  ** WMS extents are edge to edge while MapServer extents are center of
+  ** pixel to center of pixel.  Here we try to adjust the WMS extents
+  ** in by half a pixel.
+   double	dx, dy;
+   dx = (map->extent[2] - map->extent[0]) / (map->width*2);
+   dy = (map->extent[3] - map->extent[1]) / (map->height*2);
+   omap->extent.minx = map->extent[0] + dx;
+   omap->extent.miny = map->extent[1] + dy;
+   omap->extent.maxx = map->extent[2] - dx;
+   omap->extent.maxy = map->extent[3] - dy;
    msMapSetSize(omap, map->width, map->height);
    imageObj *image = msDrawMap(omap, MS_FALSE);
@@ -160,13 +179,15 @@
       ctx->set_error(ctx,400,"mapserver source \"%s\" has no mapfile configured",src->source.name);
       return;
+   msSetup();
    mapObj *map = msLoadMap(src->mapfile, NULL);
    if(!map) {
       ctx->set_error(ctx,400,"failed to load mapfile \"%s\"",src->mapfile);
       return;
    msFreeMap(map);
-   msCleanup();
 mapcache_source* mapcache_source_mapserver_create(mapcache_context *ctx) {
