[mapserver-commits] r12651 - branches/branch-6-0/docs/en/output trunk/docs/en/output
Sat Oct 8 15:13:26 EDT 2011
Author: havatv
Date: 2011-10-08 12:13:25 -0700 (Sat, 08 Oct 2011)
New Revision: 12651
   branches/branch-6-0/docs/en/output/template_output.txt
   trunk/docs/en/output/template_output.txt
Added documentation on nodata to the template_output document (#3701).  Plus some formatting...
Modified: branches/branch-6-0/docs/en/output/template_output.txt
--- branches/branch-6-0/docs/en/output/template_output.txt	2011-10-08 17:24:04 UTC (rev 12650)
+++ branches/branch-6-0/docs/en/output/template_output.txt	2011-10-08 19:13:25 UTC (rev 12651)
@@ -1,295 +1,317 @@
-.. _template_output:
- Template-Driven Output
-:Author: Chris Hodgson
-:Contact: chodgson at refractions.net
-:Last Updated: 2011-04-13
-.. contents:: Table of Contents
-    :depth: 2
-    :backlinks: top
-Introduction
-RFC 36 added support for defining template-driven OUTPUTFORMATs for use with
-feature queries, including WMS GetFeatureInfo and WFS GetFeature. This allows
-for custom text-oriented output such as GeoJSON, KML, or XML.
+.. index::
+   single: Template-driven output
+.. _template_output:
+ Template-Driven Output
+:Author: Chris Hodgson
+:Contact: chodgson at refractions.net
+:Last Updated: 2011-04-13
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+RFC 36 added support for defining template-driven OUTPUTFORMATs for use with
+feature queries, including WMS GetFeatureInfo and WFS GetFeature. This allows
+for custom text-oriented output such as GeoJSON, KML, or XML.
 The templates are essentially the same as with the standard MapServer query
 :ref:`Template`, however there are some additional tags to allow for template
-definition in a single file instead of the standard header/template/footer.
-.. note::
-    There are other, simpler, ways to output some of these formats using MapServer.
-    However, template-driven output provides maximal flexibility and customization
-    of the output, at the cost of additional complexity and configuration.
-OUTPUTFORMAT Declarations
-Details of template-driven output formats are controlled by an :ref:`OUTPUTFORMAT`
-declaration.  The declarations define the template file to be used, as well as
-other standard OUTPUTFORMAT options.
-Examples:
-.. code-block:: mapfile
-  OUTPUTFORMAT
-    NAME "kayml"
-    DRIVER "TEMPLATE"
-    MIMETYPE "application/vnd.google-earth.kml+xml"
-    FORMATOPTION "FILE=myTemplate.kml"
-    FORMATOPTION "ATTACHMENT=queryResults.kml"
-  END
-  OUTPUTFORMAT
-    NAME "geojson"
-    DRIVER "TEMPLATE"
-    FORMATOPTION "FILE=myTemplate.json"
-  END
-  OUTPUTFORMAT
-    NAME "customxml"
-    DRIVER "TEMPLATE"
-    FORMATOPTION "FILE=myTemplate.xml"
-  END
-The template file to be used is determined by the "FILE=..." FORMATOPTION.
-The template filename is relative to the mapfile's path. As is standard with
-MapServer template files, the file must containt the magic string
-‘mapserver template’ in the first line of the file, usually within a comment,
-but this line is not output to the client.
-Note that both the MIMETYPE and FORMATOPTION "ATTACHMENT=..." parameters are
-very useful for controlling how a web browser handles the output file.
-Template Substitution Tags
-These tags only work in query result templates, and their purpose is primarily
-to simplify the templating to a single file for custom ouput formats.
-[include src="otherTemplate.txt"]
-    Includes another template file; the path to the template file is relative
-    to the mapfile path.
-[resultset name=layername]...[/resultset]
-    Defines the location of the results for a given layer.
-[feature]...[/feature]
-    Defines the loop around the features returned for a given layer.
-    Optional arguments:
-    - limit=
-        specifies the maximum number of features to output for this layer.
-    - trimlast=
-        specifies a string to be trimmed off of the end of the final feature
-        that is output. This is intended to allow for trailing record
-        delimiters to be removed. See the examples below.
-[join name=join1]...[/join]
-    defines the loop around the features join from another layer.
-Examples
-This example shows how to emulate the old 3-file system using the new system,
-to compare the usage:
-  <!-- mapserver template -->
-  [include src="templates/header.html"]
-  [resultset name=lakes]
-    ... old layer HEADER stuff goes here, if a layer has no results this block disappears...
-    [feature]
-      ...repeat this block for each feature in the result set...
-      [join name=join1]
-        ...repeat this block for each joined row...
-      [/join]
-    [/feature]
-    ...old layer FOOTER stuff goes here...
-  [/resultset]
-  [resulset name=streams]
-    [feature]
-    [/feature]
-  [/resultset]
-  [include src="templates/footer.html"]
-A specific GML3 example:
-  <?xml version="1.0" encoding="ISO-8859-1"?>
-  [resultset layer=mums]
-  <MapServerUserMeetings xmlns="http://localhost/ms_ogc_workshop" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://localhost/ms_ogc_workshop ./mums.xsd">
-   <gml:description>This is a GML document which provides locations of all MapServer User Meeting that have taken place</gml:description>
-   <gml:name>MapServer User Meetings</gml:name>
-   <gml:boundedBy>
-    <gml:Envelope>
-     <gml:coordinates>-93.093055556,44.944444444 -75.7,45.4166667</gml:coordinates>
-    </gml:Envelope>
-   </gml:boundedBy>
-   [feature]
-   <gml:featureMember>
-    <Meeting>
-     <gml:description>[desc]</gml:description>
-     <gml:name>[name]</gml:name>
-     <gml:location>
-      <gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
-       <gml:pos>[x] [y]</gml:pos>
-      </gml:Point>
-     </gml:location>
-     <year>[year]</year>
-     <venue>[venue]</venue>
-     <website>[url]</website>
-    </Meeting>
-   </gml:featureMember>
-   [/feature]
-   <dateCreated>2007-08-13T17:17:32Z</dateCreated>
-  </MapServerUserMeetings>
-  [resultset]
-A GeoJSON example:
-  // mapserver template
-    "type": "FeatureCollection",
-    "features": [
-      [feature trimlast=',']
-        "type": "Feature",
-        "id": "[id]",
-        "geometry": {
-          "type": "PointLineString",
-          "coordinates": [
-              "type": "Point",
-              "coordinates": [[x], [y]]
-        "properties": {
-          "description": "[description]",
-          "venue": "[venue]",
-          "year": "[year]"
-      [/feature]
-  [/resultset]
-A more complicated KML example. Note the use of [shpxy] to support multipolygons
-with holes, and also that a point placemark is included with each feature using
-[shplabel]:
-    <!--MapServer Template-->
-    <?xml version="1.0" encoding="UTF-8"?>
-    <kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom">
-    <Document>
-	<Style id="parks_highlight">
-		<IconStyle>
-			<scale>1.4</scale>
-			<Icon>
-				<href>http://maps.google.com/mapfiles/kml/shapes/parks.png</href>
-			</Icon>
-			<hotSpot x="0.5" y="0" xunits="fraction" yunits="fraction"/>
-		</IconStyle>
-		<LineStyle>
-			<color>ffff5500</color>
-			<width>4.2</width>
-		</LineStyle>
-		<PolyStyle>
-			<color>aaaaaaaa</color>
-		</PolyStyle>
-		<BalloonStyle>
-			<text>
-				<![CDATA[
-					<p ALIGN="center"><b>$[name]</b></p>
-					$[description]
-			</text>
-		</BalloonStyle>
-	</Style>
-	<Style id="parks_normal">
-		<IconStyle>
-			<scale>1.2</scale>
-			<Icon>
-			</Icon>
-		</IconStyle>
-		<LineStyle>
-		</LineStyle>
-		<PolyStyle>
-			<color>ff7fff55</color>
-		</PolyStyle>
-		<BalloonStyle>
-			<text>
-				<![CDATA[
-					$[description]
-			</text>
-		</BalloonStyle>
-	</Style>
-	<StyleMap id="parks_map">
-		<Pair>
-			<key>normal</key>
-			<styleUrl>#parks_normal</styleUrl>
-		</Pair>
-		<Pair>
-			<key>highlight</key>
-			<styleUrl>#parks_highlight</styleUrl>
-		</Pair>
-	</StyleMap>
-    [resultset layer=parks]
-	<Folder>
-		<name>Parks</name>
-                [feature trimlast=',' limit=1]
-		<Placemark>
-			<name>[NAME]</name>
-			<Snippet/>
-			<description>
-				<![CDATA[
-					<p>Year Established: [YEAR_ESTABLISHED]</p>
-					<p>Area: [AREA_KILOMETERS_SQUARED] sq km</p>
-			</description>
-			<styleUrl>#parks_map</styleUrl>
-			<ExtendedData>
-			  <Data name="Year Established">[YEAR_ESTABLISHED]</Data>
-		          <Data name="Area">[AREA_KILOMETERS_SQUARED]</Data>
-			</ExtendedData>
-			<MultiGeometry>
-			<Point>
-				<coordinates>[shplabel proj=epsg:4326 precision=10],0</coordinates>
-			</Point>
-    [shpxy ph="<Polygon><tessellate>1</tessellate>" pf="</Polygon>" xf="," xh=" " yh=" " yf=",0 " orh="<outerBoundaryIs><LinearRing><coordinates>" orf="</coordinates></LinearRing></outerBoundaryIs>" irh="<innerBoundaryIs><LinearRing><coordinates>" irf="</coordinates></LinearRing></innerBoundaryIs>" proj=epsg:4326 precision=10]
-			</MultiGeometry>
-		</Placemark>
-                [/feature]
-	</Folder>
-    [/resultset]
-    </Document>
-    </kml>
+definition in a single file instead of the standard header/template/footer.
+.. note::
+    There are other, simpler, ways to output some of these formats using MapServer.
+    However, template-driven output provides maximal flexibility and customization
+    of the output, at the cost of additional complexity and configuration.
+.. index::
+   pair: Template-driven output; OUTPUTFORMAT
+OUTPUTFORMAT Declarations
+Details of template-driven output formats are controlled by an :ref:`OUTPUTFORMAT`
+declaration.  The declarations define the template file to be used, as well as
+other standard OUTPUTFORMAT options.
+Examples:
+.. code-block:: mapfile
+  OUTPUTFORMAT
+    NAME "kayml"
+    DRIVER "TEMPLATE"
+    MIMETYPE "application/vnd.google-earth.kml+xml"
+    FORMATOPTION "FILE=myTemplate.kml"
+    FORMATOPTION "ATTACHMENT=queryResults.kml"
+  END
+  OUTPUTFORMAT
+    NAME "geojson"
+    DRIVER "TEMPLATE"
+    FORMATOPTION "FILE=myTemplate.json"
+  END
+  OUTPUTFORMAT
+    NAME "customxml"
+    DRIVER "TEMPLATE"
+    FORMATOPTION "FILE=myTemplate.xml"
+  END
+The template file to be used is determined by the "FILE=..." FORMATOPTION.
+The template filename is relative to the mapfile's path. As is standard with
+MapServer template files, the file must containt the magic string
+‘mapserver template’ in the first line of the file, usually within a comment,
+but this line is not output to the client.
+Note that both the MIMETYPE and FORMATOPTION "ATTACHMENT=..." parameters are
+very useful for controlling how a web browser handles the output file.
+.. index::
+   pair: Template-driven output; Template substitution tags
+Template Substitution Tags
+These tags only work in query result templates, and their purpose is primarily
+to simplify the templating to a single file for custom ouput formats.
+[include src="otherTemplate.txt"]
+    Includes another template file; the path to the template file is relative
+    to the mapfile path.
+    Attributes:
+    * src: The file to be included.
+[resultset layer=layername]...[/resultset]
+    Defines the location of the results for a given layer.
+    Attributes:
+    * layer: The layer to be used
+    * nodata: (optional) A string to return if no results are returned.
+[feature]...[/feature]
+    Defines the loop around the features returned for a given layer.
+    Attributes:
+    * limit: (optional) Specifies the maximum number of features to
+      output for this layer.
+    * trimlast: (optional) Specifies a string to be trimmed off of the
+      end of the final feature that is output.  This is intended to
+      allow for trailing record delimiters to be removed.  See the
+      examples below.
+[join name=join1]...[/join]
+    defines the loop around the features join from another layer.
+.. seealso::
+   :ref:`template`
+Examples
+This example shows how to emulate the old 3-file system using the new system,
+to compare the usage:
+  <!-- mapserver template -->
+  [include src="templates/header.html"]
+  [resultset layer=lakes]
+    ... old layer HEADER stuff goes here, if a layer has no results this block disappears...
+    [feature]
+      ...repeat this block for each feature in the result set...
+      [join name=join1]
+        ...repeat this block for each joined row...
+      [/join]
+    [/feature]
+    ...old layer FOOTER stuff goes here...
+  [/resultset]
+  [resulset layer=streams]
+    [feature]
+    [/feature]
+  [/resultset]
+  [include src="templates/footer.html"]
+A specific GML3 example:
+  <?xml version="1.0" encoding="ISO-8859-1"?>
+  [resultset layer=mums]
+  <MapServerUserMeetings xmlns="http://localhost/ms_ogc_workshop" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://localhost/ms_ogc_workshop ./mums.xsd">
+   <gml:description>This is a GML document which provides locations of all MapServer User Meeting that have taken place</gml:description>
+   <gml:name>MapServer User Meetings</gml:name>
+   <gml:boundedBy>
+    <gml:Envelope>
+     <gml:coordinates>-93.093055556,44.944444444 -75.7,45.4166667</gml:coordinates>
+    </gml:Envelope>
+   </gml:boundedBy>
+   [feature]
+   <gml:featureMember>
+    <Meeting>
+     <gml:description>[desc]</gml:description>
+     <gml:name>[name]</gml:name>
+     <gml:location>
+      <gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
+       <gml:pos>[x] [y]</gml:pos>
+      </gml:Point>
+     </gml:location>
+     <year>[year]</year>
+     <venue>[venue]</venue>
+     <website>[url]</website>
+    </Meeting>
+   </gml:featureMember>
+   [/feature]
+   <dateCreated>2007-08-13T17:17:32Z</dateCreated>
+  </MapServerUserMeetings>
+  [resultset]
+A GeoJSON example:
+  // mapserver template
+    "type": "FeatureCollection",
+    "features": [
+      [feature trimlast=',']
+        "type": "Feature",
+        "id": "[id]",
+        "geometry": {
+          "type": "PointLineString",
+          "coordinates": [
+              "type": "Point",
+              "coordinates": [[x], [y]]
+        "properties": {
+          "description": "[description]",
+          "venue": "[venue]",
+          "year": "[year]"
+      [/feature]
+  [/resultset]
+A more complicated KML example. Note the use of [shpxy] to support multipolygons
+with holes, and also that a point placemark is included with each feature using
+[shplabel]:
+    <!--MapServer Template-->
+    <?xml version="1.0" encoding="UTF-8"?>
+    <kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom">
+    <Document>
+	<Style id="parks_highlight">
+		<IconStyle>
+			<scale>1.4</scale>
+			<Icon>
+				<href>http://maps.google.com/mapfiles/kml/shapes/parks.png</href>
+			</Icon>
+			<hotSpot x="0.5" y="0" xunits="fraction" yunits="fraction"/>
+		</IconStyle>
+		<LineStyle>
+			<color>ffff5500</color>
+			<width>4.2</width>
+		</LineStyle>
+		<PolyStyle>
+			<color>aaaaaaaa</color>
+		</PolyStyle>
+		<BalloonStyle>
+			<text>
+				<![CDATA[
+					<p ALIGN="center"><b>$[name]</b></p>
+					$[description]
+			</text>
+		</BalloonStyle>
+	</Style>
+	<Style id="parks_normal">
+		<IconStyle>
+			<scale>1.2</scale>
+			<Icon>
+			</Icon>
+		</IconStyle>
+		<LineStyle>
+		</LineStyle>
+		<PolyStyle>
+			<color>ff7fff55</color>
+		</PolyStyle>
+		<BalloonStyle>
+			<text>
+				<![CDATA[
+					$[description]
+			</text>
+		</BalloonStyle>
+	</Style>
+	<StyleMap id="parks_map">
+		<Pair>
+			<key>normal</key>
+			<styleUrl>#parks_normal</styleUrl>
+		</Pair>
+		<Pair>
+			<key>highlight</key>
+			<styleUrl>#parks_highlight</styleUrl>
+		</Pair>
+	</StyleMap>
+    [resultset layer=parks]
+	<Folder>
+		<name>Parks</name>
+                [feature trimlast=',' limit=1]
+		<Placemark>
+			<name>[NAME]</name>
+			<Snippet/>
+			<description>
+				<![CDATA[
+					<p>Year Established: [YEAR_ESTABLISHED]</p>
+					<p>Area: [AREA_KILOMETERS_SQUARED] sq km</p>
+			</description>
+			<styleUrl>#parks_map</styleUrl>
+			<ExtendedData>
+			  <Data name="Year Established">[YEAR_ESTABLISHED]</Data>
+		          <Data name="Area">[AREA_KILOMETERS_SQUARED]</Data>
+			</ExtendedData>
+			<MultiGeometry>
+			<Point>
+				<coordinates>[shplabel proj=epsg:4326 precision=10],0</coordinates>
+			</Point>
+    [shpxy ph="<Polygon><tessellate>1</tessellate>" pf="</Polygon>" xf="," xh=" " yh=" " yf=",0 " orh="<outerBoundaryIs><LinearRing><coordinates>" orf="</coordinates></LinearRing></outerBoundaryIs>" irh="<innerBoundaryIs><LinearRing><coordinates>" irf="</coordinates></LinearRing></innerBoundaryIs>" proj=epsg:4326 precision=10]
+			</MultiGeometry>
+		</Placemark>
+                [/feature]
+	</Folder>
+    [/resultset]
+    </Document>
+    </kml>
Modified: trunk/docs/en/output/template_output.txt
--- trunk/docs/en/output/template_output.txt	2011-10-08 17:24:04 UTC (rev 12650)
+++ trunk/docs/en/output/template_output.txt	2011-10-08 19:13:25 UTC (rev 12651)
@@ -1,295 +1,317 @@
-    :depth: 2
-    :backlinks: top
-Introduction
+.. index::
+    :depth: 2
+    :backlinks: top
+Introduction
-.. note::
-Examples:
-  OUTPUTFORMAT
-    NAME "kayml"
-    DRIVER "TEMPLATE"
-  END
-  OUTPUTFORMAT
-    NAME "geojson"
-    DRIVER "TEMPLATE"
-  END
-  OUTPUTFORMAT
-    NAME "customxml"
-    DRIVER "TEMPLATE"
-  END
-    - limit=
-    - trimlast=
-Examples
-    [feature]
-      [join name=join1]
-      [/join]
-    [/feature]
-  [/resultset]
-    [feature]
-    [/feature]
-  [/resultset]
-   <gml:boundedBy>
-    <gml:Envelope>
-    </gml:Envelope>
-   </gml:boundedBy>
-   [feature]
-    <Meeting>
-     <gml:location>
-      </gml:Point>
-     </gml:location>
-    </Meeting>
-   [/feature]
-  [resultset]
-A GeoJSON example:
-    "features": [
-        "id": "[id]",
-        "geometry": {
-          "coordinates": [
-              "type": "Point",
-        "properties": {
-          "year": "[year]"
-      [/feature]
-  [/resultset]
-[shplabel]:
-    <Document>
-		<IconStyle>
-			<Icon>
-			</Icon>
-		</IconStyle>
-		<LineStyle>
-		</LineStyle>
-		<PolyStyle>
-		</PolyStyle>
-		<BalloonStyle>
-			<text>
-				<![CDATA[
-					$[description]
-			</text>
-		</BalloonStyle>
-	</Style>
-		<IconStyle>
-			<Icon>
-			</Icon>
-		</IconStyle>
-		<LineStyle>
-		</LineStyle>
-		<PolyStyle>
-		</PolyStyle>
-		<BalloonStyle>
-			<text>
-				<![CDATA[
-					$[description]
-			</text>
-		</BalloonStyle>
-	</Style>
-		<Pair>
-			<key>normal</key>
-		</Pair>
-		<Pair>
-		</Pair>
-	</StyleMap>
-	<Folder>
-		<Placemark>
-			<Snippet/>
-			<description>
-				<![CDATA[
-			</description>
-			<ExtendedData>
-			</ExtendedData>
-			<MultiGeometry>
-			<Point>
-			</Point>
-			</MultiGeometry>
-		</Placemark>
-                [/feature]
-	</Folder>
-    [/resultset]
-    </Document>
-    </kml>
+.. note::
+.. index::
+Examples:
+  OUTPUTFORMAT
+    NAME "kayml"
+    DRIVER "TEMPLATE"
+  END
+  OUTPUTFORMAT
+    NAME "geojson"
+    DRIVER "TEMPLATE"
+  END
+  OUTPUTFORMAT
+    NAME "customxml"
+    DRIVER "TEMPLATE"
+  END
+.. index::
+    Attributes:
+    Attributes:
+    Attributes:
+      examples below.
+.. seealso::
+   :ref:`template`
+Examples
+    [feature]
+      [join name=join1]
+      [/join]
+    [/feature]
+  [/resultset]
+    [feature]
+    [/feature]
+  [/resultset]
+   <gml:boundedBy>
+    <gml:Envelope>
+    </gml:Envelope>
+   </gml:boundedBy>
+   [feature]
+    <Meeting>
+     <gml:location>
+      </gml:Point>
+     </gml:location>
+    </Meeting>
+   [/feature]
+  [resultset]
+A GeoJSON example:
+    "features": [
+        "id": "[id]",
+        "geometry": {
+          "coordinates": [
+              "type": "Point",
+        "properties": {
+          "year": "[year]"
+      [/feature]
+  [/resultset]
+[shplabel]:
+    <Document>
+		<IconStyle>
+			<Icon>
+			</Icon>
+		</IconStyle>
+		<LineStyle>
+		</LineStyle>
+		<PolyStyle>
+		</PolyStyle>
+		<BalloonStyle>
+			<text>
+				<![CDATA[
+					$[description]
+			</text>
+		</BalloonStyle>
+	</Style>
+		<IconStyle>
+			<Icon>
+			</Icon>
+		</IconStyle>
+		<LineStyle>
+		</LineStyle>
+		<PolyStyle>
+		</PolyStyle>
+		<BalloonStyle>
+			<text>
+				<![CDATA[
+					$[description]
+			</text>
+		</BalloonStyle>
+	</Style>
+		<Pair>
+			<key>normal</key>
+		</Pair>
+		<Pair>
+		</Pair>
+	</StyleMap>
+	<Folder>
+		<Placemark>
+			<Snippet/>
+			<description>
+				<![CDATA[
+			</description>
+			<ExtendedData>
+			</ExtendedData>
+			<MultiGeometry>
+			<Point>
+			</Point>
+			</MultiGeometry>
+		</Placemark>
+                [/feature]
+	</Folder>
+    [/resultset]
+    </Document>
+    </kml>
