[mapserver-commits] r12664 - in trunk/mapserver/mapcache: include src
Fri Oct 14 11:33:26 EDT 2011
Author: tbonfort
Date: 2011-10-14 08:33:26 -0700 (Fri, 14 Oct 2011)
New Revision: 12664
   trunk/mapserver/mapcache/include/mapcache.h
   trunk/mapserver/mapcache/src/cache_disk.c
   trunk/mapserver/mapcache/src/cache_memcache.c
   trunk/mapserver/mapcache/src/cache_sqlite.c
   trunk/mapserver/mapcache/src/cache_tiff.c
   trunk/mapserver/mapcache/src/configuration_xml.c
   trunk/mapserver/mapcache/src/imageio_jpeg.c
   trunk/mapserver/mapcache/src/imageio_png.c
make the tiff cache reference a jpeg format so that compression quality can be configured
Modified: trunk/mapserver/mapcache/include/mapcache.h
--- trunk/mapserver/mapcache/include/mapcache.h	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/include/mapcache.h	2011-10-14 15:33:26 UTC (rev 12664)
@@ -390,7 +390,7 @@
     void (*tile_set)(mapcache_context *ctx, mapcache_tile * tile);
-    void (*configuration_parse_xml)(mapcache_context *ctx, ezxml_t xml, mapcache_cache * cache);
+    void (*configuration_parse_xml)(mapcache_context *ctx, ezxml_t xml, mapcache_cache * cache, mapcache_cfg *config);
     void (*configuration_post_config)(mapcache_context *ctx, mapcache_cache * cache, mapcache_cfg *config);
@@ -1357,6 +1357,7 @@
     mapcache_buffer* (*create_empty_image)(mapcache_context *ctx, mapcache_image_format *format,
           size_t width, size_t height, unsigned int color);
     apr_table_t *metadata;
+    mapcache_image_format_type type;
 /**\defgroup imageio_png PNG Image IO
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/src/cache_disk.c	2011-10-14 15:33:26 UTC (rev 12664)
@@ -421,7 +421,7 @@
  * \private \memberof mapcache_cache_disk
-static void _mapcache_cache_disk_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache) {
+static void _mapcache_cache_disk_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache, mapcache_cfg *config) {
    ezxml_t cur_node;
    mapcache_cache_disk *dcache = (mapcache_cache_disk*)cache;
Modified: trunk/mapserver/mapcache/src/cache_memcache.c
--- trunk/mapserver/mapcache/src/cache_memcache.c	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/src/cache_memcache.c	2011-10-14 15:33:26 UTC (rev 12664)
@@ -68,6 +68,10 @@
    if(!*path) {
       ctx->set_error(ctx,500, "failed to allocate tile key");
+#ifdef DEBUG
+   ctx->log(ctx,MAPCACHE_DEBUG,"memcache key is %s (length:%d)",
+         *path,strlen(*path));
+#endif
@@ -178,7 +182,7 @@
  * \private \memberof mapcache_cache_memcache
-static void _mapcache_cache_memcache_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache) {
+static void _mapcache_cache_memcache_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache, mapcache_cfg *config) {
    ezxml_t cur_node;
    mapcache_cache_memcache *dcache = (mapcache_cache_memcache*)cache;
    int servercount = 0;
Modified: trunk/mapserver/mapcache/src/cache_sqlite.c
--- trunk/mapserver/mapcache/src/cache_sqlite.c	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/src/cache_sqlite.c	2011-10-14 15:33:26 UTC (rev 12664)
@@ -256,7 +256,7 @@
-static void _mapcache_cache_sqlite_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache) {
+static void _mapcache_cache_sqlite_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache, mapcache_cfg *config) {
    ezxml_t cur_node;
    sqlite3_initialize();
    sqlite3_config(SQLITE_CONFIG_MULTITHREAD);
Modified: trunk/mapserver/mapcache/src/cache_tiff.c
--- trunk/mapserver/mapcache/src/cache_tiff.c	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/src/cache_tiff.c	2011-10-14 15:33:26 UTC (rev 12664)
@@ -640,6 +640,9 @@
       GTIFFree( psGTIF );
 #endif
+   mapcache_image_format_jpeg *format = (mapcache_image_format_jpeg*) dcache->format;
+   TIFFSetField(hTIFF, TIFFTAG_JPEGQUALITY, format->quality);
    int tiff_offx, tiff_offy; /* the x and y offset of the tile inside the tiff image */
    int tiff_off; /* the index of the tile inside the list of tiles of the tiff image */
@@ -698,7 +701,7 @@
  * \private \memberof mapcache_cache_tiff
-static void _mapcache_cache_tiff_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache) {
+static void _mapcache_cache_tiff_configuration_parse_xml(mapcache_context *ctx, ezxml_t node, mapcache_cache *cache, mapcache_cfg *config) {
    ezxml_t cur_node;
    mapcache_cache_tiff *dcache = (mapcache_cache_tiff*)cache;
@@ -723,24 +726,27 @@
          return;
- * \private \memberof mapcache_cache_tiff
-static void _mapcache_cache_tiff_configuration_post_config(mapcache_context *ctx, mapcache_cache *cache,
-      mapcache_cfg *cfg) {
-   mapcache_cache_tiff *dcache = (mapcache_cache_tiff*)cache;
-   /* check all required parameters are configured */
-   if((!dcache->filename_template || !strlen(dcache->filename_template))) {
-      ctx->set_error(ctx, 400, "tiff cache %s has no template pattern",dcache->cache.name);
+   ezxml_t xformat = ezxml_child(node,"format");
+   char * format_name;
+   if(xformat && xformat->txt && *xformat->txt) {
+      format_name = xformat->txt;
+   } else {
+      format_name = "JPEG";
+   mapcache_image_format *pformat = mapcache_configuration_get_image_format(
+         config,format_name);
+   if(!pformat) {
+      ctx->set_error(ctx,500,"TIFF cache %s references unknown image format %s",
+            cache->name, format_name);
       return;
-   if(dcache->count_x <= 0 || dcache->count_y <= 0) {
-      ctx->set_error(ctx, 400, "tiff cache %s has invalid count (%d,%d)",dcache->count_x,dcache->count_y);
+   if(pformat->type != GC_JPEG) {
+      ctx->set_error(ctx,500,"TIFF cache %s can only reference a JPEG image format",
+            cache->name);
       return;
+   dcache->format = (mapcache_image_format_jpeg*)pformat;
 #ifdef USE_TIFF_WRITE
 #if APR_HAS_THREADS
    if(ctx->has_threads) {
@@ -757,6 +763,23 @@
+ * \private \memberof mapcache_cache_tiff
+static void _mapcache_cache_tiff_configuration_post_config(mapcache_context *ctx, mapcache_cache *cache,
+      mapcache_cfg *cfg) {
+   mapcache_cache_tiff *dcache = (mapcache_cache_tiff*)cache;
+   /* check all required parameters are configured */
+   if((!dcache->filename_template || !strlen(dcache->filename_template))) {
+      ctx->set_error(ctx, 400, "tiff cache %s has no template pattern",dcache->cache.name);
+      return;
+   if(dcache->count_x <= 0 || dcache->count_y <= 0) {
+      ctx->set_error(ctx, 400, "tiff cache %s has invalid count (%d,%d)",dcache->count_x,dcache->count_y);
+      return;
  * \brief creates and initializes a mapcache_tiff_cache
 mapcache_cache* mapcache_cache_tiff_create(mapcache_context *ctx) {
Modified: trunk/mapserver/mapcache/src/configuration_xml.c
--- trunk/mapserver/mapcache/src/configuration_xml.c	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/src/configuration_xml.c	2011-10-14 15:33:26 UTC (rev 12664)
@@ -450,7 +450,7 @@
    cache->name = name;
-   cache->configuration_parse_xml(ctx,node,cache);
+   cache->configuration_parse_xml(ctx,node,cache,config);
    GC_CHECK_ERROR(ctx);
    mapcache_configuration_add_cache(config,cache,name);
    return;
Modified: trunk/mapserver/mapcache/src/imageio_jpeg.c
--- trunk/mapserver/mapcache/src/imageio_jpeg.c	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/src/imageio_jpeg.c	2011-10-14 15:33:26 UTC (rev 12664)
@@ -313,6 +313,7 @@
    format->format.create_empty_image = _mapcache_imageio_jpg_create_empty;
    format->format.write = _mapcache_imageio_jpeg_encode;
    format->quality = quality;
+   format->format.type = GC_JPEG;
    return (mapcache_image_format*)format;
Modified: trunk/mapserver/mapcache/src/imageio_png.c
--- trunk/mapserver/mapcache/src/imageio_png.c	2011-10-14 13:17:39 UTC (rev 12663)
+++ trunk/mapserver/mapcache/src/imageio_png.c	2011-10-14 15:33:26 UTC (rev 12664)
@@ -1233,6 +1233,7 @@
    format->format.metadata = apr_table_make(pool,3);
    format->format.write = _mapcache_imageio_png_encode;
    format->format.create_empty_image = _mapcache_imageio_png_create_empty;
+   format->format.type = GC_PNG;
@@ -1246,6 +1247,7 @@
    format->format.format.create_empty_image = _mapcache_imageio_png_create_empty;
    format->format.format.metadata = apr_table_make(pool,3);
    format->ncolors = ncolors;
+   format->format.format.type = GC_PNG;
