[mapserver-commits] r12668 - in trunk/mapserver: . mapscript/php mapscript/swiginc
Mon Oct 17 16:49:43 EDT 2011
Author: aboudreault
Date: 2011-10-17 13:49:43 -0700 (Mon, 17 Oct 2011)
New Revision: 12668
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maplabel.c
   trunk/mapserver/mapscript/php/label.c
   trunk/mapserver/mapscript/php/mapscript_i.c
   trunk/mapserver/mapscript/php/php_mapscript.h
   trunk/mapserver/mapscript/php/style.c
   trunk/mapserver/mapscript/swiginc/label.i
   trunk/mapserver/mapserver.h
Fixed cannot add a style to a label in PHP/SWIG Mapscript (#4038)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/HISTORY.TXT	2011-10-17 20:49:43 UTC (rev 12668)
@@ -14,6 +14,9 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Fixed cannot add a style to a label in PHP/SWIG Mapscript (#4038)
 - Fixed schema validity issue for WCS 1.1 GetCoverage responses (#4047)
 - remove default compiler search paths from the GD CFLAGS/LDFLAGS (#4046)
Modified: trunk/mapserver/maplabel.c
--- trunk/mapserver/maplabel.c	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/maplabel.c	2011-10-17 20:49:43 UTC (rev 12668)
@@ -1017,3 +1017,140 @@
   return(MS_FALSE);
+/* For MapScript, exactly the same the msInsertStyle */
+int msInsertLabelStyle(labelObj *label, styleObj *style, int nStyleIndex) {
+    int i;
+    if (!style)
+        msSetError(MS_CHILDERR, "Can't insert a NULL Style", "msInsertLabelStyle()");
+        return -1;
+    /* Ensure there is room for a new style */
+    if (msGrowLabelStyles(label) == NULL) {
+        return -1;
+    /* Catch attempt to insert past end of styles array */
+    else if (nStyleIndex >= label->numstyles) {
+        msSetError(MS_CHILDERR, "Cannot insert style beyond index %d", "insertLabelStyle()", label->numstyles-1);
+        return -1;
+    else if (nStyleIndex < 0) { /* Insert at the end by default */
+        label->styles[label->numstyles]=style;
+	MS_REFCNT_INCR(style);
+        label->numstyles++;
+        return label->numstyles-1;
+    else if (nStyleIndex >= 0 && nStyleIndex < label->numstyles) {
+        /* Move styles existing at the specified nStyleIndex or greater */
+        /* to a higher nStyleIndex */
+        for (i=label->numstyles-1; i>=nStyleIndex; i--) {
+            label->styles[i+1] = label->styles[i];
+        label->styles[nStyleIndex]=style;
+        return nStyleIndex;
+    else {
+        msSetError(MS_CHILDERR, "Invalid nStyleIndex", "insertLabelStyle()");
+        return -1;
+ * Move the style up inside the array of styles.
+int msMoveLabelStyleUp(labelObj *label, int nStyleIndex)
+    styleObj *psTmpStyle = NULL;
+    if (label && nStyleIndex < label->numstyles && nStyleIndex >0)
+        psTmpStyle = (styleObj *)malloc(sizeof(styleObj));
+        initStyle(psTmpStyle);
+        msCopyStyle(psTmpStyle, label->styles[nStyleIndex]);
+        msCopyStyle(label->styles[nStyleIndex],
+                    label->styles[nStyleIndex-1]);
+        msCopyStyle(label->styles[nStyleIndex-1], psTmpStyle);
+        return(MS_SUCCESS);
+    msSetError(MS_CHILDERR, "Invalid index: %d", "msMoveLabelStyleUp()",
+               nStyleIndex);
+    return (MS_FAILURE);
+ * Move the style down inside the array of styles.
+int msMoveLabelStyleDown(labelObj *label, int nStyleIndex)
+    if (label && nStyleIndex < label->numstyles-1 && nStyleIndex >=0)
+                    label->styles[nStyleIndex+1]);
+        msCopyStyle(label->styles[nStyleIndex+1], psTmpStyle);
+    msSetError(MS_CHILDERR, "Invalid index: %d", "msMoveLabelStyleDown()",
+               nStyleIndex);
+ * Delete the style identified by the index and shift
+ * styles that follows the deleted style.
+int msDeleteLabelStyle(labelObj *label, int nStyleIndex)
+    int i = 0;
+    if (label && nStyleIndex < label->numstyles && nStyleIndex >=0)
+        if (freeStyle(label->styles[nStyleIndex]) == MS_SUCCESS)
+            msFree(label->styles[nStyleIndex]);
+        for (i=nStyleIndex; i< label->numstyles-1; i++)
+            label->styles[i] = label->styles[i+1];
+        label->styles[label->numstyles-1] = NULL;
+        label->numstyles--;
+    msSetError(MS_CHILDERR, "Invalid index: %d", "msDeleteLabelStyle()",
+               nStyleIndex);
+styleObj *msRemoveLabelStyle(labelObj *label, int nStyleIndex) {
+    int i;
+    styleObj *style;
+    if (nStyleIndex < 0 || nStyleIndex >= label->numstyles) {
+        msSetError(MS_CHILDERR, "Cannot remove style, invalid nStyleIndex %d", "removeLabelStyle()", nStyleIndex);
+        return NULL;
+    else {
+        style=label->styles[nStyleIndex];
+        for (i=nStyleIndex; i<label->numstyles-1; i++) {
+             label->styles[i]=label->styles[i+1];
+	label->styles[label->numstyles-1]=NULL;
+	MS_REFCNT_DECR(style);
+        return style;
Modified: trunk/mapserver/mapscript/php/label.c
--- trunk/mapserver/mapscript/php/label.c	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/mapscript/php/label.c	2011-10-17 20:49:43 UTC (rev 12668)
@@ -60,6 +60,22 @@
   ZEND_ARG_INFO(0, labelBinding)
 ZEND_END_ARG_INFO()
+ZEND_BEGIN_ARG_INFO_EX(label_getStyle_args, 0, 0, 1)
+  ZEND_ARG_INFO(0, index)
+ZEND_END_ARG_INFO()
+ZEND_BEGIN_ARG_INFO_EX(label_moveStyleUp_args, 0, 0, 1)
+ZEND_BEGIN_ARG_INFO_EX(label_moveStyleDown_args, 0, 0, 1)
+ZEND_BEGIN_ARG_INFO_EX(label_deleteStyle_args, 0, 0, 1)
 /* {{{ proto void __construct()
    labelObj CANNOT be instanciated, this will throw an exception on use */
 PHP_METHOD(labelObj, __construct)
@@ -104,6 +120,7 @@
     else IF_GET_LONG("minfeaturesize", php_label->label->minfeaturesize)
     else IF_GET_LONG("autominfeaturesize", php_label->label->autominfeaturesize)
     else IF_GET_LONG("repeatdistance", php_label->label->repeatdistance)
+    else IF_GET_LONG("numstyles", php_label->label->numstyles)
     else IF_GET_LONG("mindistance", php_label->label->mindistance)
     else IF_GET_LONG("partials", php_label->label->partials)
     else IF_GET_LONG("force", php_label->label->force)
@@ -174,6 +191,10 @@
         mapscript_throw_exception("Property '%s' is an object and can only be modified through its accessors." TSRMLS_CC, property);
+    else if (STRING_EQUAL("numstyles", property))
+        mapscript_throw_exception("Property '%s' is read-only and cannot be set." TSRMLS_CC, property);
     else
         mapscript_throw_exception("Property '%s' does not exist in this object." TSRMLS_CC, property);
@@ -331,6 +352,111 @@
+/* {{{ proto int getstyle(int index)
+   return the style object. */
+PHP_METHOD(labelObj, getStyle)
+    long index;
+    zval *zobj = getThis();
+    php_label_object *php_label;
+    styleObj *style = NULL;
+    parent_object parent;
+    PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l",
+                              &index) == FAILURE) {
+        PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
+        return;
+    php_label = (php_label_object *) zend_object_store_get_object(zobj TSRMLS_CC);
+    if (index < 0 || index >= php_label->label->numstyles)
+        mapscript_throw_exception("Invalid style index." TSRMLS_CC);
+        return;
+    style = php_label->label->styles[index];
+    MAPSCRIPT_MAKE_PARENT(zobj, NULL);
+    mapscript_create_style(style, parent, return_value TSRMLS_CC);
+/* {{{ proto int moveStyleUp(int index)  */
+PHP_METHOD(labelObj, moveStyleUp)
+    long index;
+    int status = MS_FAILURE;
+        return;
+    status = labelObj_moveStyleUp(php_label->label, index);
+    RETURN_LONG(status);
+/* {{{ proto int moveStyleDown(int index) */
+PHP_METHOD(labelObj, moveStyleDown)
+    long index;
+        return;
+    status = labelObj_moveStyleDown(php_label->label, index);
+ /* {{{ proto int deleteStyle(int index) */
+PHP_METHOD(labelObj, deleteStyle)
+    long index;
+        return;
+    status =  labelObj_deleteStyle(php_label->label, index);
 /* {{{ proto int label.free()
    Free the object */
 PHP_METHOD(labelObj, free)
@@ -362,6 +488,10 @@
     PHP_ME(labelObj, setBinding, label_setBinding_args, ZEND_ACC_PUBLIC)
     PHP_ME(labelObj, getBinding, label_getBinding_args, ZEND_ACC_PUBLIC)
     PHP_ME(labelObj, removeBinding, label_removeBinding_args, ZEND_ACC_PUBLIC)
+    PHP_ME(labelObj, getStyle, label_getStyle_args, ZEND_ACC_PUBLIC)
+    PHP_ME(labelObj, moveStyleUp, label_moveStyleUp_args, ZEND_ACC_PUBLIC)
+    PHP_ME(labelObj, moveStyleDown, label_moveStyleDown_args, ZEND_ACC_PUBLIC)
+    PHP_ME(labelObj, deleteStyle, label_deleteStyle_args, ZEND_ACC_PUBLIC)
     PHP_ME(labelObj, free, NULL, ZEND_ACC_PUBLIC)
     {NULL, NULL, NULL}
Modified: trunk/mapserver/mapscript/php/mapscript_i.c
--- trunk/mapserver/mapscript/php/mapscript_i.c	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/mapscript/php/mapscript_i.c	2011-10-17 20:49:43 UTC (rev 12668)
@@ -723,6 +723,21 @@
    return msUpdateLabelFromString(self, snippet);
+int labelObj_moveStyleUp(labelObj *self, int index)
+    return msMoveLabelStyleUp(self, index);
+int labelObj_moveStyleDown(labelObj *self, int index)
+    return msMoveLabelStyleDown(self, index);
+int labelObj_deleteStyle(labelObj *self, int index)
+    return msDeleteLabelStyle(self, index);
  * class extensions for legendObj
@@ -1389,6 +1404,21 @@
     return class->styles[class->numstyles-1];
+styleObj *styleObj_label_new(labelObj *label, styleObj *style) {
+    if(msGrowLabelStyles(label) == NULL)
+      return NULL;
+    if(initStyle(label->styles[label->numstyles]) == -1)
+      return NULL;
+    if (style)
+      msCopyStyle(label->styles[label->numstyles], style);
+    return label->styles[label->numstyles-1];
 int styleObj_updateFromString(styleObj *self, char *snippet) {
    return msUpdateStyleFromString(self, snippet, MS_FALSE);
Modified: trunk/mapserver/mapscript/php/php_mapscript.h
--- trunk/mapserver/mapscript/php/php_mapscript.h	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/mapscript/php/php_mapscript.h	2011-10-17 20:49:43 UTC (rev 12668)
@@ -610,6 +610,9 @@
                                            const char *library_str) ;
 int             labelObj_updateFromString(labelObj *self, char *snippet);
+int             labelObj_moveStyleUp(labelObj *self, int index);
+int             labelObj_moveStyleDown(labelObj *self, int index);
+int             labelObj_deleteStyle(labelObj *self, int index);
 int             legendObj_updateFromString(legendObj *self, char *snippet);
@@ -741,6 +744,7 @@
 DBFFieldType    DBFInfo_getFieldType(DBFInfo *self, int iField);
 styleObj       *styleObj_new(classObj *class, styleObj *style);
+styleObj       *styleObj_label_new(labelObj *label, styleObj *style);
 int             styleObj_updateFromString(styleObj *self, char *snippet);
 int             styleObj_setSymbolByName(styleObj *self, mapObj *map,
                                          char* pszSymbolName);
Modified: trunk/mapserver/mapscript/php/style.c
--- trunk/mapserver/mapscript/php/style.c	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/mapscript/php/style.c	2011-10-17 20:49:43 UTC (rev 12668)
@@ -35,7 +35,7 @@
 zend_object_handlers mapscript_style_object_handlers;
 ZEND_BEGIN_ARG_INFO_EX(style___construct_args, 0, 0, 1)
-  ZEND_ARG_OBJ_INFO(0, class, classObj, 0)
+  ZEND_ARG_INFO(0, parent)
   ZEND_ARG_OBJ_INFO(0, style, styleObj, 0)
 ZEND_END_ARG_INFO()
@@ -73,20 +73,21 @@
   ZEND_ARG_INFO(0, pattern)
 ZEND_END_ARG_INFO()
-/* {{{ proto void __construct(classObj class [, styleObj style])
-   Create a new styleObj instance */
+/* {{{ proto void __construct(parent [, styleObj style])
+   Create a new styleObj instance. parent has to be a classObj or labelObj. */
 PHP_METHOD(styleObj, __construct)
-    zval *zclass, *zstyle = NULL;
+    zval *zparent, *zstyle = NULL;
     styleObj *style;
-    php_class_object *php_class;
+    php_class_object *php_class = NULL;
+    php_label_object *php_label = NULL;
     php_style_object *php_style, *php_style2;
-    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "O|O",
-                              &zclass, mapscript_ce_class,
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "z|O",
+                              &zparent,
                               &zstyle, mapscript_ce_style) == FAILURE) {
         return;
@@ -94,21 +95,42 @@
     php_style = (php_style_object *)zend_object_store_get_object(zobj TSRMLS_CC);
-    php_class = (php_class_object *)zend_object_store_get_object(zclass TSRMLS_CC);
+    if (Z_TYPE_P(zparent) == IS_OBJECT && Z_OBJCE_P(zparent) == mapscript_ce_class)
+        php_class = (php_class_object *)zend_object_store_get_object(zparent TSRMLS_CC);
+    else if (Z_TYPE_P(zparent) == IS_OBJECT && Z_OBJCE_P(zparent) == mapscript_ce_label)
+        php_label = (php_label_object *)zend_object_store_get_object(zparent TSRMLS_CC);
+    else
+        mapscript_throw_mapserver_exception("Invalid argument 1: should be a classObj or labelObj" TSRMLS_CC);
+        return;
     if (zstyle)
         php_style2 = (php_style_object *)zend_object_store_get_object(zstyle TSRMLS_CC);
-    if ((style = styleObj_new(php_class->class, (zstyle ? php_style2->style : NULL))) == NULL)
+    if (php_class)
-        mapscript_throw_mapserver_exception("" TSRMLS_CC);
-        return;
+        if ((style = styleObj_new(php_class->class, (zstyle ? php_style2->style : NULL))) == NULL)
+            mapscript_throw_mapserver_exception("" TSRMLS_CC);
+            return;
+    else
+        if ((style = styleObj_label_new(php_label->label, (zstyle ? php_style2->style : NULL))) == NULL)
+            return;
     php_style->style = style;
-    MAPSCRIPT_MAKE_PARENT(zclass, NULL);
+    MAPSCRIPT_MAKE_PARENT(zparent, NULL);
     php_style->parent = parent;
-    MAPSCRIPT_ADDREF(zclass);
+    MAPSCRIPT_ADDREF(zparent);
Modified: trunk/mapserver/mapscript/swiginc/label.i
--- trunk/mapserver/mapscript/swiginc/label.i	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/mapscript/swiginc/label.i	2011-10-17 20:49:43 UTC (rev 12668)
@@ -73,4 +73,41 @@
     return MS_SUCCESS;
+  %newobject getStyle;
+  styleObj *getStyle(int i) {
+      if (i >= 0 && i < self->numstyles) {
+          MS_REFCNT_INCR(self->styles[i]);
+          return self->styles[i];
+      } else {
+          msSetError(MS_CHILDERR, "Invalid index: %d", "getStyle()", i);
+          return NULL;
+#ifdef SWIGCSHARP
+%apply SWIGTYPE *SETREFERENCE {styleObj *style};
+#endif
+    int insertStyle(styleObj *style, int index=-1) {
+        return msInsertLabelStyle(self, style, index);
+#ifdef SWIGCSHARP
+%clear styleObj *style;
+#endif
+    %newobject removeStyle;
+    styleObj *removeStyle(int index) {
+	styleObj* style = (styleObj *) msRemoveLabelStyle(self, index);
+	if (style)
+        return style;
+    int moveStyleUp(int index) {
+    int moveStyleDown(int index) {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2011-10-16 12:32:08 UTC (rev 12667)
+++ trunk/mapserver/mapserver.h	2011-10-17 20:49:43 UTC (rev 12668)
@@ -2304,6 +2304,14 @@
                                 int nStyleIndex);
 MS_DLL_EXPORT styleObj *msRemoveStyle(classObj *classo, int index);
+/* maplabel.c */
+MS_DLL_EXPORT int msInsertLabelStyle(labelObj *label, styleObj *style,
+                                     int nStyleIndex);
+MS_DLL_EXPORT int msMoveLabelStyleUp(labelObj *label, int nStyleIndex);
+MS_DLL_EXPORT int msMoveLabelStyleDown(labelObj *label, int nStyleIndex);
+MS_DLL_EXPORT int msDeleteLabelStyle(labelObj *label, int nStyleIndex);
+MS_DLL_EXPORT styleObj *msRemoveLabelStyle(labelObj *label, int nStyleIndex);
 /* Measured shape utility functions. */
 MS_DLL_EXPORT pointObj *msGetPointUsingMeasure(shapeObj *shape, double m);
 MS_DLL_EXPORT pointObj *msGetMeasureUsingPoint(shapeObj *shape, pointObj *point);
