[mapserver-commits] r12687 - trunk/docs/en/mapfile
svn at osgeo.org
svn at osgeo.org
Sun Oct 23 11:23:11 EDT 2011
Author: tamas
Date: 2011-10-23 08:23:11 -0700 (Sun, 23 Oct 2011)
New Revision: 12687
trunk/docs/en/mapfile/cluster.txt
Document the BUFFER option for the cluster layer (#4056)
Modified: trunk/docs/en/mapfile/cluster.txt
--- trunk/docs/en/mapfile/cluster.txt 2011-10-23 15:22:53 UTC (rev 12686)
+++ trunk/docs/en/mapfile/cluster.txt 2011-10-23 15:23:11 UTC (rev 12687)
@@ -46,6 +46,14 @@
Can be 'rectangle' or 'ellipse'.
.. index::
+ pair: CLUSTER; BUFFER
+BUFFER [double]
+ Defines a buffer region around the map extent in pixels. Default is 0.
+ Using a buffer allows that the neighbouring shapes around the map
+ are also considered during the cluster creation.
+.. index::
pair: CLUSTER; GROUP
:ref:`GROUP <expressions>` [string]
More information about the mapserver-commits
