[mapserver-commits] r12697 - in trunk/mapserver/mapcache: include src
Tue Oct 25 11:28:33 EDT 2011
Author: tbonfort
Date: 2011-10-25 08:28:33 -0700 (Tue, 25 Oct 2011)
New Revision: 12697
   trunk/mapserver/mapcache/include/mapcache.h
   trunk/mapserver/mapcache/src/cache_disk.c
   trunk/mapserver/mapcache/src/cache_memcache.c
   trunk/mapserver/mapcache/src/cache_sqlite.c
   trunk/mapserver/mapcache/src/cache_tiff.c
   trunk/mapserver/mapcache/src/core.c
   trunk/mapserver/mapcache/src/image.c
   trunk/mapserver/mapcache/src/source_mapserver.c
   trunk/mapserver/mapcache/src/source_wms.c
   trunk/mapserver/mapcache/src/tileset.c
avoid some superfluous image compression/decompression steps in some cases
Modified: trunk/mapserver/mapcache/include/mapcache.h
--- trunk/mapserver/mapcache/include/mapcache.h	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/include/mapcache.h	2011-10-25 15:28:33 UTC (rev 12697)
@@ -499,8 +499,8 @@
    mapcache_tileset *tileset;
    mapcache_grid_link *grid_link;
    apr_table_t *dimensions;
-   mapcache_buffer *data;
-   mapcache_image *image;
+   mapcache_buffer *encoded_data;
+   mapcache_image *raw_image;
    int width, height;
    double extent[4];
    apr_time_t mtime; /**< last modification time */
@@ -511,6 +511,7 @@
    mapcache_map map;
    int i,j;
    char *format;
+   mapcache_buffer *data;
 struct mapcache_request_get_feature_info {
@@ -1004,7 +1005,8 @@
      * \sa mapcache_source::render_map()
      * \sa mapcache_image_format
     int expires; /**< time in seconds after which the tile should be rechecked for validity */
Modified: trunk/mapserver/mapcache/src/cache_disk.c
--- trunk/mapserver/mapcache/src/cache_disk.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/cache_disk.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -232,7 +232,7 @@
        * i.e. normally only once.
       tile->mtime = finfo.mtime;
-      tile->data = mapcache_buffer_create(size,ctx->pool);
+      tile->encoded_data = mapcache_buffer_create(size,ctx->pool);
 #ifndef NOMMAP
       apr_mmap_t *tilemmap;
@@ -242,16 +242,16 @@
          ctx->set_error(ctx, 500,  "mmap error: %s",apr_strerror(rv,errmsg,120));
          return MAPCACHE_FAILURE;
-      tile->data->buf = tilemmap->mm;
-      tile->data->size = tile->data->avail = finfo.size;
+      tile->encoded_data->buf = tilemmap->mm;
+      tile->encoded_data->size = tile->encoded_data->avail = finfo.size;
 #else
       //manually add the data to our buffer
-      apr_file_read(f,(void*)tile->data->buf,&size);
-      tile->data->size = size;
-      tile->data->avail = size;
+      apr_file_read(f,(void*)tile->encoded_data->buf,&size);
+      tile->encoded_data->size = size;
+      tile->encoded_data->avail = size;
 #endif
       apr_file_close(f);
-      if(tile->data->size != finfo.size) {
+      if(tile->encoded_data->size != finfo.size) {
          ctx->set_error(ctx, 500,  "failed to copy image data, got %d of %d bytes",(int)size, (int)finfo.size);
@@ -285,11 +285,16 @@
    char *filename, *hackptr1, *hackptr2=NULL;
 #ifdef DEBUG
    /* all this should be checked at a higher level */
-   if(!tile->data || !tile->data->size) {
+   if(!tile->encoded_data && !tile->raw_image) {
       ctx->set_error(ctx,500,"attempting to write empty tile to disk");
       return;
+   if(!tile->encoded_data && !tile->tileset->format) {
+      ctx->set_error(ctx,500,"received a raw tile image for a tileset with no format");
+      return;
 #endif
    _mapcache_cache_disk_tile_key(ctx, tile, &filename);
    GC_CHECK_ERROR(ctx);
@@ -327,12 +332,18 @@
 #ifdef HAVE_SYMLINK
    if(((mapcache_cache_disk*)tile->tileset->cache)->symlink_blank) {
-      mapcache_image *image = mapcache_imageio_decode(ctx, tile->data);
-      GC_CHECK_ERROR(ctx);
-      if(mapcache_image_blank_color(image) != MAPCACHE_FALSE) {
+      if(!tile->raw_image) {
+         tile->raw_image = mapcache_imageio_decode(ctx, tile->encoded_data);
+         GC_CHECK_ERROR(ctx);
+      if(mapcache_image_blank_color(tile->raw_image) != MAPCACHE_FALSE) {
          char *blankname;
-         _mapcache_cache_disk_blank_tile_key(ctx,tile,image->data,&blankname);
+         _mapcache_cache_disk_blank_tile_key(ctx,tile,tile->raw_image->data,&blankname);
          if(apr_file_open(&f, blankname, APR_FOPEN_READ, APR_OS_DEFAULT, ctx->pool) != APR_SUCCESS) {
+            if(!tile->encoded_data) {
+               tile->encoded_data = tile->tileset->format->write(ctx, tile->raw_image, tile->tileset->format);
             /* create the blank file */
             char *blankdirname = apr_psprintf(ctx->pool, "%s/%s/%s/blanks",
                         ((mapcache_cache_disk*)tile->tileset->cache)->base_directory,
@@ -359,16 +370,16 @@
                   return; /* we could not create the file */
-               bytes = (apr_size_t)tile->data->size;
-               ret = apr_file_write(f,(void*)tile->data->buf,&bytes);
+               bytes = (apr_size_t)tile->encoded_data->size;
+               ret = apr_file_write(f,(void*)tile->encoded_data->buf,&bytes);
                if(ret != APR_SUCCESS) {
-                  ctx->set_error(ctx, 500,  "failed to write data to file %s (wrote %d of %d bytes): %s",blankname, (int)bytes, (int)tile->data->size, apr_strerror(ret,errmsg,120));
+                  ctx->set_error(ctx, 500,  "failed to write data to file %s (wrote %d of %d bytes): %s",blankname, (int)bytes, (int)tile->encoded_data->size, apr_strerror(ret,errmsg,120));
                   mapcache_unlock_resource(ctx,blankname);
-               if(bytes != tile->data->size) {
-                  ctx->set_error(ctx, 500,  "failed to write image data to %s, wrote %d of %d bytes", blankname, (int)bytes, (int)tile->data->size);
+               if(bytes != tile->encoded_data->size) {
+                  ctx->set_error(ctx, 500,  "failed to write image data to %s, wrote %d of %d bytes", blankname, (int)bytes, (int)tile->encoded_data->size);
                   return;
@@ -395,6 +406,12 @@
 #endif /*HAVE_SYMLINK*/
    /* go the normal way: either we haven't configured blank tile detection, or the tile was not blank */
    if((ret = apr_file_open(&f, filename,
          APR_FOPEN_CREATE|APR_FOPEN_WRITE|APR_FOPEN_BUFFERED|APR_FOPEN_BINARY,
          APR_OS_DEFAULT, ctx->pool)) != APR_SUCCESS) {
@@ -402,15 +419,15 @@
-      ctx->set_error(ctx, 500,  "failed to write data to file %s (wrote %d of %d bytes): %s",filename, (int)bytes, (int)tile->data->size, apr_strerror(ret,errmsg,120));
+      ctx->set_error(ctx, 500,  "failed to write data to file %s (wrote %d of %d bytes): %s",filename, (int)bytes, (int)tile->encoded_data->size, apr_strerror(ret,errmsg,120));
-      ctx->set_error(ctx, 500, "failed to write image data to %s, wrote %d of %d bytes", filename, (int)bytes, (int)tile->data->size);
+      ctx->set_error(ctx, 500, "failed to write image data to %s, wrote %d of %d bytes", filename, (int)bytes, (int)tile->encoded_data->size);
    ret = apr_file_close(f);
Modified: trunk/mapserver/mapcache/src/cache_memcache.c
--- trunk/mapserver/mapcache/src/cache_memcache.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/cache_memcache.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -123,23 +123,23 @@
    if(GC_HAS_ERROR(ctx)) {
-   tile->data = mapcache_buffer_create(0,ctx->pool);
-   rv = apr_memcache_getp(cache->memcache,ctx->pool,key,(char**)&tile->data->buf,&tile->data->size,NULL);
+   tile->encoded_data = mapcache_buffer_create(0,ctx->pool);
+   rv = apr_memcache_getp(cache->memcache,ctx->pool,key,(char**)&tile->encoded_data->buf,&tile->encoded_data->size,NULL);
    if(rv != APR_SUCCESS) {
       return MAPCACHE_CACHE_MISS;
-   if(tile->data->size == 0) {
+   if(tile->encoded_data->size == 0) {
       ctx->set_error(ctx,500,"memcache cache returned 0-length data for tile %d %d %d\n",tile->x,tile->y,tile->z);
    /* extract the tile modification time from the end of the data returned */
    memcpy(
          &tile->mtime,
-         &(((char*)tile->data->buf)[tile->data->size-sizeof(apr_time_t)]),
+         &(((char*)tile->encoded_data->buf)[tile->encoded_data->size-sizeof(apr_time_t)]),
          sizeof(apr_time_t));
-   ((char*)tile->data->buf)[tile->data->size+sizeof(apr_time_t)]='\0';
-   tile->data->avail = tile->data->size;
-   tile->data->size -= sizeof(apr_time_t);
+   ((char*)tile->encoded_data->buf)[tile->encoded_data->size+sizeof(apr_time_t)]='\0';
+   tile->encoded_data->avail = tile->encoded_data->size;
+   tile->encoded_data->size -= sizeof(apr_time_t);
    return MAPCACHE_SUCCESS;
@@ -162,16 +162,21 @@
    mapcache_cache_memcache *cache = (mapcache_cache_memcache*)tile->tileset->cache;
    _mapcache_cache_memcache_tile_key(ctx, tile, &key);
    /* concatenate the current time to the end of the memcache data so we can extract it out
     * when we re-get the tile */
-   char *data = calloc(1,tile->data->size+sizeof(apr_time_t));
+   char *data = calloc(1,tile->encoded_data->size+sizeof(apr_time_t));
    apr_time_t now = apr_time_now();
    apr_pool_cleanup_register(ctx->pool, data, (void*)free, apr_pool_cleanup_null);
-   memcpy(data,tile->data->buf,tile->data->size);
-   memcpy(&(data[tile->data->size]),&now,sizeof(apr_time_t));
+   memcpy(data,tile->encoded_data->buf,tile->encoded_data->size);
+   memcpy(&(data[tile->encoded_data->size]),&now,sizeof(apr_time_t));
-   rv = apr_memcache_set(cache->memcache,key,data,tile->data->size+sizeof(apr_time_t),expires,0);
+   rv = apr_memcache_set(cache->memcache,key,data,tile->encoded_data->size+sizeof(apr_time_t),expires,0);
       ctx->set_error(ctx,500,"failed to store tile %d %d %d to memcache cache %s",
             tile->x,tile->y,tile->z,cache->cache.name);
Modified: trunk/mapserver/mapcache/src/cache_sqlite.c
--- trunk/mapserver/mapcache/src/cache_sqlite.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/cache_sqlite.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -129,8 +129,12 @@
    /* tile blob data */
    paramidx = sqlite3_bind_parameter_index(stmt, ":data");
    if(paramidx) {
-      if(tile->data && tile->data->size) {
-         sqlite3_bind_blob(stmt,paramidx,tile->data->buf, tile->data->size,SQLITE_STATIC);
+      if(tile->encoded_data && tile->encoded_data->size) {
+         sqlite3_bind_blob(stmt,paramidx,tile->encoded_data->buf, tile->encoded_data->size,SQLITE_STATIC);
       } else {
          sqlite3_bind_text(stmt,paramidx,"",-1,SQLITE_STATIC);
@@ -210,9 +214,9 @@
    } else {
       const void *blob = sqlite3_column_blob(stmt,0);
       int size = sqlite3_column_bytes(stmt, 0);
-      memcpy(tile->data->buf, blob,size);
+      memcpy(tile->encoded_data->buf, blob,size);
       if(sqlite3_column_count(stmt) > 1) {
          time_t mtime = sqlite3_column_int64(stmt, 1);
          apr_time_ansi_put(&(tile->mtime),mtime);
Modified: trunk/mapserver/mapcache/src/cache_tiff.c
--- trunk/mapserver/mapcache/src/cache_tiff.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/cache_tiff.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -406,16 +406,16 @@
                void *bufptr;
                /* create a memory buffer to contain the jpeg data */
-               tile->data = mapcache_buffer_create((jpegtable_size+sizes[tiff_off]-4),ctx->pool);
+               tile->encoded_data = mapcache_buffer_create((jpegtable_size+sizes[tiff_off]-4),ctx->pool);
                 * copy the jpeg header to the beginning of the memory buffer,
                 * omitting the last 2 bytes
-               memcpy(tile->data->buf,jpegtable_ptr,(jpegtable_size-2));
+               memcpy(tile->encoded_data->buf,jpegtable_ptr,(jpegtable_size-2));
                /* advance the data pointer to after the header data */
-               bufptr = tile->data->buf + (jpegtable_size-2);
+               bufptr = tile->encoded_data->buf + (jpegtable_size-2);
                /* go to the specified offset in the tiff file, plus 2 bytes */
@@ -437,7 +437,7 @@
-               tile->data->size = (jpegtable_size+sizes[tiff_off]-4);
+               tile->encoded_data->size = (jpegtable_size+sizes[tiff_off]-4);
                /* finalize and cleanup */
                apr_file_close(f);
@@ -529,15 +529,18 @@
    int tilew = tile->grid_link->grid->tile_sx;
    int tileh = tile->grid_link->grid->tile_sy;
-   mapcache_image *tileimg = mapcache_imageio_decode(ctx, tile->data);
    /* remap xrgb to rgb */
    unsigned char *rgb = (unsigned char*)malloc(tilew*tileh*3);
    int r,c;
-   for(r=0;r<tileimg->h;r++) {
-      unsigned char *imptr = tileimg->data + r * tileimg->stride;
+   for(r=0;r<tile->raw_image->h;r++) {
+      unsigned char *imptr = tile->raw_image->data + r * tile->raw_image->stride;
       unsigned char *rgbptr = rgb + r * tilew * 3;
-      for(c=0;c<tileimg->w;c++) {
+      for(c=0;c<tile->raw_image->w;c++) {
          rgbptr[0] = imptr[2];
          rgbptr[1] = imptr[1];
          rgbptr[2] = imptr[0];
Modified: trunk/mapserver/mapcache/src/core.c
--- trunk/mapserver/mapcache/src/core.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/core.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -66,8 +66,11 @@
          expires = tile->expires;
          /* if we have multiple tiles to merge, decode the image data */
          if(req_tile->ntiles>1) {
-            base = mapcache_imageio_decode(ctx, tile->data);
-            if(!base) return NULL;
+               if(!tile->raw_image) return NULL;
+            base = tile->raw_image;
       } else {
          if(response->mtime < tile->mtime)
@@ -75,8 +78,11 @@
          if(tile->expires < expires) {
-         overlay = mapcache_imageio_decode(ctx, tile->data);
-         if(!overlay) return NULL;
+         overlay = tile->raw_image;
          mapcache_image_merge(ctx, base, overlay);
             return NULL;
@@ -101,7 +107,7 @@
          return NULL;
    } else {
-      response->data = req_tile->tiles[0]->data;
+      response->data = req_tile->tiles[0]->encoded_data;
       format = req_tile->tiles[0]->tileset->format;
@@ -132,7 +138,7 @@
-mapcache_image* _core_get_single_map(mapcache_context *ctx, mapcache_map *map, mapcache_resample_mode mode) {
+void _core_get_single_map(mapcache_context *ctx, mapcache_map *map, mapcache_resample_mode mode) {
    mapcache_tile **maptiles;
    int i,nmaptiles;
@@ -143,8 +149,7 @@
       mapcache_tile *tile = maptiles[i];
       tile->dimensions = map->dimensions;
       mapcache_tileset_tile_get(ctx, tile);
-      if(GC_HAS_ERROR(ctx))
-         return NULL;
       /* update the map modification time if it is older than the tile mtime */
       if(tile->mtime>map->mtime) map->mtime = tile->mtime;
@@ -155,11 +160,10 @@
       if(!map->expires || tile->expires<map->expires) map->expires = tile->expires;
-   mapcache_image *getmapim = mapcache_tileset_assemble_map_tiles(ctx,map->tileset,map->grid_link,
+   map->raw_image = mapcache_tileset_assemble_map_tiles(ctx,map->tileset,map->grid_link,
          map->extent, map->width, map->height,
          nmaptiles, maptiles,
          mode);
-   return getmapim;
 mapcache_http_response *mapcache_core_get_map(mapcache_context *ctx, mapcache_request_get_map *req_map) {
@@ -180,19 +184,16 @@
    mapcache_http_response *response = mapcache_http_response_create(ctx->pool);
    mapcache_map *basemap = req_map->maps[0];
-   /* raw image data. if left NULL, there is no need to reencode the image */
-   mapcache_image *baseim = NULL;
    int i;
    char *timestr;
    if(req_map->getmap_strategy == MAPCACHE_GETMAP_ASSEMBLE) {
-      baseim = _core_get_single_map(ctx,basemap,req_map->resample_mode);
+      _core_get_single_map(ctx,basemap,req_map->resample_mode);
       if(GC_HAS_ERROR(ctx)) return NULL;
       for(i=1;i<req_map->nmaps;i++) {
          mapcache_map *overlaymap = req_map->maps[i];
-         mapcache_image *overlayim = _core_get_single_map(ctx,overlaymap,req_map->resample_mode);
+         _core_get_single_map(ctx,overlaymap,req_map->resample_mode);
-         mapcache_image_merge(ctx,baseim,overlayim);
+         mapcache_image_merge(ctx,basemap->raw_image,overlaymap->raw_image);
          if(overlaymap->mtime > basemap->mtime) basemap->mtime = overlaymap->mtime;
          if(!basemap->expires || overlaymap->expires<basemap->expires) basemap->expires = overlaymap->expires;
@@ -209,30 +210,41 @@
       basemap->tileset->source->render_map(ctx, basemap);
       if(req_map->nmaps>1) {
-         baseim = mapcache_imageio_decode(ctx,basemap->data);
-         if(GC_HAS_ERROR(ctx)) return NULL;
+         if(!basemap->raw_image) {
+            basemap->raw_image = mapcache_imageio_decode(ctx,basemap->encoded_data);
+            if(GC_HAS_ERROR(ctx)) return NULL;
             overlaymap->tileset->source->render_map(ctx, overlaymap);
-            mapcache_image *overlayim = mapcache_imageio_decode(ctx,overlaymap->data);
+            if(!overlaymap->raw_image) {
+               overlaymap->raw_image = mapcache_imageio_decode(ctx,overlaymap->encoded_data);
-   if(baseim) {
+   if(basemap->raw_image) {
       format = req_map->getmap_format; /* always defined, defaults to JPEG */
-      response->data = format->write(ctx,baseim,format);
+      response->data = format->write(ctx,basemap->raw_image,format);
          return NULL;
    } else {
       /* this case happens when we have a forward strategy for a single tileset */
-      response->data = basemap->data;
+#ifdef DEBUG
+      if(!basemap->encoded_data) {
+         ctx->set_error(ctx,500,"###BUG### core_get_map failed with null encoded_data");
+         return;
+#endif
+      response->data = basemap->encoded_data;
    /* compute the content-type */
@@ -304,7 +316,7 @@
       tileset->source->query_info(ctx,fi);
-      response->data = fi->map.data;
+      response->data = fi->data;
       apr_table_set(response->headers,"Content-Type",fi->format);
       return response;
    } else {
Modified: trunk/mapserver/mapcache/src/image.c
--- trunk/mapserver/mapcache/src/image.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/image.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -228,33 +228,33 @@
 void mapcache_image_metatile_split(mapcache_context *ctx, mapcache_metatile *mt) {
    if(mt->map.tileset->format) {
       /* the tileset has a format defined, we will use it to encode the data */
-      mapcache_image tileimg;
+      mapcache_image *tileimg;
       mapcache_image *metatile;
       int i,j;
       int sx,sy;
-      tileimg.w = mt->map.grid_link->grid->tile_sx;
-      tileimg.h = mt->map.grid_link->grid->tile_sy;
-      if(mt->map.image) {
-         metatile = mt->map.image;
+      if(mt->map.raw_image) {
+         metatile = mt->map.raw_image;
       } else {
-         metatile = mapcache_imageio_decode(ctx, mt->map.data);
+         metatile = mapcache_imageio_decode(ctx, mt->map.encoded_data);
       if(!metatile) {
          ctx->set_error(ctx, 500, "failed to load image data from metatile");
          return;
-      tileimg.stride = metatile->stride;
       for(i=0;i<mt->metasize_x;i++) {
          for(j=0;j<mt->metasize_y;j++) {
-            sx = mt->map.tileset->metabuffer + i * tileimg.w;
-            sy = mt->map.height - (mt->map.tileset->metabuffer + (j+1) * tileimg.w);
-            tileimg.data = &(metatile->data[sy*metatile->stride + 4 * sx]);
+            tileimg = (mapcache_image*)apr_pcalloc(ctx->pool,sizeof(mapcache_image));
+            tileimg->w = mt->map.grid_link->grid->tile_sx;
+            tileimg->h = mt->map.grid_link->grid->tile_sy;
+            tileimg->stride = metatile->stride;
+            sx = mt->map.tileset->metabuffer + i * tileimg->w;
+            sy = mt->map.height - (mt->map.tileset->metabuffer + (j+1) * tileimg->w);
+            tileimg->data = &(metatile->data[sy*metatile->stride + 4 * sx]);
             if(mt->map.tileset->watermark) {
-                mapcache_image_merge(ctx,&tileimg,mt->map.tileset->watermark);
+                mapcache_image_merge(ctx,tileimg,mt->map.tileset->watermark);
-            mt->tiles[i*mt->metasize_y+j].data =
-               mt->map.tileset->format->write(ctx, &tileimg, mt->map.tileset->format);
+            mt->tiles[i*mt->metasize_y+j].raw_image = tileimg;
@@ -263,12 +263,12 @@
       if(mt->map.tileset->metasize_x != 1 ||
             mt->map.tileset->metasize_y != 1 ||
             mt->map.tileset->metabuffer != 0 ||
-            !mt->map.data) {
+            !mt->map.encoded_data) {
          ctx->set_error(ctx, 500, "##### BUG ##### using a metatile with no format");
          return;
 #endif
-      mt->tiles[0].data = mt->map.data;
+      mt->tiles[0].encoded_data = mt->map.encoded_data;
Modified: trunk/mapserver/mapcache/src/source_mapserver.c
--- trunk/mapserver/mapcache/src/source_mapserver.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/source_mapserver.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -119,13 +119,13 @@
       return;
-   map->image = mapcache_image_create(ctx);
-   map->image->w = map->width;
-   map->image->h = map->height;
-   map->image->stride = 4 * map->width;
-   map->image->data = malloc(map->width*map->height*4);
-   memcpy(map->image->data,rb.data.rgba.pixels,map->width*map->height*4);
-   apr_pool_cleanup_register(ctx->pool, map->image->data,(void*)free, apr_pool_cleanup_null);
+   map->raw_image = mapcache_image_create(ctx);
+   map->raw_image->w = map->width;
+   map->raw_image->h = map->height;
+   map->raw_image->stride = 4 * map->width;
+   map->raw_image->data = malloc(map->width*map->height*4);
+   memcpy(map->raw_image->data,rb.data.rgba.pixels,map->width*map->height*4);
+   apr_pool_cleanup_register(ctx->pool, map->raw_image->data,(void*)free, apr_pool_cleanup_null);
    msFreeImage(image);
    msFreeMap(omap);
Modified: trunk/mapserver/mapcache/src/source_wms.c
--- trunk/mapserver/mapcache/src/source_wms.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/source_wms.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -57,12 +57,12 @@
-    map->data = mapcache_buffer_create(30000,ctx->pool);
-    mapcache_http_do_request_with_params(ctx,wms->http,params,map->data,NULL,NULL);
+    map->encoded_data = mapcache_buffer_create(30000,ctx->pool);
+    mapcache_http_do_request_with_params(ctx,wms->http,params,map->encoded_data,NULL,NULL);
-    if(!mapcache_imageio_is_valid_format(ctx,map->data)) {
-       char *returned_data = apr_pstrndup(ctx->pool,(char*)map->data->buf,map->data->size);
+    if(!mapcache_imageio_is_valid_format(ctx,map->encoded_data)) {
+       char *returned_data = apr_pstrndup(ctx->pool,(char*)map->encoded_data->buf,map->encoded_data->size);
        ctx->set_error(ctx, 502, "wms request for tileset %s returned an unsupported format:\n%s",
              map->tileset->name, returned_data);
@@ -95,8 +95,8 @@
+    fi->data = mapcache_buffer_create(30000,ctx->pool);
+    mapcache_http_do_request_with_params(ctx,wms->http,params,fi->data,NULL,NULL);
Modified: trunk/mapserver/mapcache/src/tileset.c
--- trunk/mapserver/mapcache/src/tileset.c	2011-10-25 15:26:54 UTC (rev 12696)
+++ trunk/mapserver/mapcache/src/tileset.c	2011-10-25 15:28:33 UTC (rev 12697)
@@ -249,7 +249,18 @@
       mapcache_image fakeimg;
       fakeimg.stride = srcimage->stride;
       fakeimg.data = &(srcimage->data[oy*srcimage->stride+ox*4]);
-      mapcache_imageio_decode_to_image(ctx,tile->data,&fakeimg);
+         mapcache_imageio_decode_to_image(ctx,tile->encoded_data,&fakeimg);
+      } else {
+         int r;
+         unsigned char *srcptr = tile->raw_image->data;
+         unsigned char *dstptr = fakeimg.data;
+            memcpy(dstptr,srcptr,tile->raw_image->stride);
+            srcptr += tile->raw_image->stride;
+            dstptr += fakeimg.stride;
    assert(toplefttile);
