[mapserver-commits] r12511 - in trunk: mapserver msautotest/wxs/expected
Fri Sep 2 08:49:20 EDT 2011
Author: schpidi
Date: 2011-09-02 05:49:20 -0700 (Fri, 02 Sep 2011)
New Revision: 12511
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwcs20.c
   trunk/msautotest/wxs/expected/wcs_20_desc.xml
   trunk/msautotest/wxs/expected/wcs_20_desc_bands.xml
   trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name.dat
   trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name_new.dat
   trunk/msautotest/wxs/expected/wcs_20_getcov_full.dat
   trunk/msautotest/wxs/expected/wcs_20_getcov_grd_mp.dat
   trunk/msautotest/wxs/expected/wcs_20_post_bands_name.dat
   trunk/msautotest/wxs/expected/wcs_20_post_bands_name_new.dat
   trunk/msautotest/wxs/expected/wcs_20_post_desc.xml
   trunk/msautotest/wxs/expected/wcs_20_post_getcov_full_multipart.dat
WCS 2.0: Adjusting offset vector and origin (#4006).
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/mapserver/HISTORY.TXT	2011-09-02 12:49:20 UTC (rev 12511)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- WCS 2.0: Adjusted offset vector and origin (#4006)
 - Added addParameter() method to MapScript (#3973)
 - Changed msDrawVectorLayer() not to cache shapes if attribute binding is present after	the first style	(#3976)
Modified: trunk/mapserver/mapwcs20.c
--- trunk/mapserver/mapwcs20.c	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/mapserver/mapwcs20.c	2011-09-02 12:49:20 UTC (rev 12511)
@@ -1693,7 +1693,7 @@
             psOrigin = xmlNewChild(psGrid, psGmlNs, BAD_CAST "origin", NULL);
-                snprintf(point, sizeof(point), "%f %f", cm->extent.minx, cm->extent.miny);
+                snprintf(point, sizeof(point), "%f %f", cm->extent.minx, cm->extent.maxy);
                 psOrigin = xmlNewChild(psOrigin, psGmlNs, BAD_CAST "Point", NULL);
                 snprintf(id, sizeof(id), "grid_origin_%s", layer->name);
                 xmlNewNsProp(psOrigin, psGmlNs, BAD_CAST "id", BAD_CAST id);
@@ -1702,7 +1702,7 @@
                 psPos = xmlNewChild(psOrigin, psGmlNs, BAD_CAST "pos", BAD_CAST point);
             snprintf(resx, sizeof(resx), "%f 0", cm->xresolution);
-            snprintf(resy, sizeof(resy), "0 %f", cm->yresolution);
+            snprintf(resy, sizeof(resy), "0 %f", -fabs(cm->yresolution));
             psOffsetX = xmlNewChild(psGrid, psGmlNs, BAD_CAST "offsetVector", BAD_CAST resx);
             xmlNewProp(psOffsetX, BAD_CAST "srsName", BAD_CAST cm->srs_uri);
             psOffsetY = xmlNewChild(psGrid, psGmlNs, BAD_CAST "offsetVector", BAD_CAST resy);
Modified: trunk/msautotest/wxs/expected/wcs_20_desc.xml
--- trunk/msautotest/wxs/expected/wcs_20_desc.xml	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_desc.xml	2011-09-02 12:49:20 UTC (rev 12511)
@@ -19,11 +19,11 @@
         <gml:axisLabels>x y</gml:axisLabels>
         <gml:origin>
           <gml:Point gml:id="grid_origin_grey" srsName="http://www.opengis.net/def/crs/EPSG/0/32611">
-            <gml:pos>0.000000 0.000000</gml:pos>
+            <gml:pos>0.000000 300.000000</gml:pos>
           </gml:Point>
         </gml:origin>
         <gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/32611">10.000000 0</gml:offsetVector>
-        <gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/32611">0 10.000000</gml:offsetVector>
+        <gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/32611">0 -10.000000</gml:offsetVector>
       </gml:RectifiedGrid>
     </gml:domainSet>
     <gmlcov:rangeType>
Modified: trunk/msautotest/wxs/expected/wcs_20_desc_bands.xml
--- trunk/msautotest/wxs/expected/wcs_20_desc_bands.xml	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_desc_bands.xml	2011-09-02 12:49:20 UTC (rev 12511)
@@ -19,11 +19,11 @@
         <gml:axisLabels>lat long</gml:axisLabels>
         <gml:origin>
           <gml:Point gml:id="grid_origin_multi" srsName="http://www.opengis.net/def/crs/EPSG/0/4326">
-            <gml:pos>14.470271 47.818838</gml:pos>
+            <gml:pos>14.470271 49.891143</gml:pos>
           </gml:Point>
         </gml:origin>
         <gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/4326">0.033722 0</gml:offsetVector>
-        <gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/4326">0 0.033972</gml:offsetVector>
+        <gml:offsetVector srsName="http://www.opengis.net/def/crs/EPSG/0/4326">0 -0.033972</gml:offsetVector>
     </gml:domainSet>
     <gmlcov:rangeType>
@@ -213,11 +213,11 @@
         <gml:origin>
           <gml:Point gml:id="grid_origin_multi_new" srsName="http://www.opengis.net/def/crs/EPSG/0/4326">
           </gml:Point>
         </gml:origin>
     </gml:domainSet>
     <gmlcov:rangeType>
Modified: trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name.dat
--- trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name.dat	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name.dat	2011-09-02 12:49:20 UTC (rev 12511)
@@ -20,11 +20,11 @@
       <gml:origin>
         </gml:Point>
       </gml:origin>
   </gml:domainSet>
   <gml:rangeSet>
@@ -42,7 +42,7 @@
           <swe:description>Test description</swe:description>
           <swe:nilValues>
             <swe:NilValues>
-              <swe:nilValue reason="">-99</swe:nilValue>
+              <swe:nilValue reason="">0</swe:nilValue>
             </swe:NilValues>
           </swe:nilValues>
           <swe:uom code="W.m-2.Sr-1"/>
@@ -59,7 +59,7 @@
           <swe:nilValues>
             <swe:NilValues>
             </swe:NilValues>
           </swe:nilValues>
@@ -76,7 +76,7 @@
           <swe:nilValues>
             <swe:NilValues>
             </swe:NilValues>
           </swe:nilValues>
Modified: trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name_new.dat
--- trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name_new.dat	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_getcov_bands_name_new.dat	2011-09-02 12:49:20 UTC (rev 12511)
@@ -20,11 +20,11 @@
       <gml:origin>
         </gml:Point>
       </gml:origin>
   </gml:domainSet>
   <gml:rangeSet>
Modified: trunk/msautotest/wxs/expected/wcs_20_getcov_full.dat
--- trunk/msautotest/wxs/expected/wcs_20_getcov_full.dat	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_getcov_full.dat	2011-09-02 12:49:20 UTC (rev 12511)
@@ -20,11 +20,11 @@
       <gml:origin>
         </gml:Point>
       </gml:origin>
   </gml:domainSet>
   <gml:rangeSet>
Modified: trunk/msautotest/wxs/expected/wcs_20_getcov_grd_mp.dat
--- trunk/msautotest/wxs/expected/wcs_20_getcov_grd_mp.dat	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_getcov_grd_mp.dat	2011-09-02 12:49:20 UTC (rev 12511)
@@ -22,11 +22,11 @@
       <gml:origin>
         </gml:Point>
       </gml:origin>
   </gml:domainSet>
   <gml:rangeSet>
Modified: trunk/msautotest/wxs/expected/wcs_20_post_bands_name.dat
--- trunk/msautotest/wxs/expected/wcs_20_post_bands_name.dat	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_post_bands_name.dat	2011-09-02 12:49:20 UTC (rev 12511)
@@ -20,11 +20,11 @@
       <gml:origin>
         </gml:Point>
       </gml:origin>
   </gml:domainSet>
   <gml:rangeSet>
@@ -42,7 +42,7 @@
           <swe:nilValues>
             <swe:NilValues>
             </swe:NilValues>
           </swe:nilValues>
@@ -59,7 +59,7 @@
           <swe:nilValues>
             <swe:NilValues>
             </swe:NilValues>
           </swe:nilValues>
@@ -76,7 +76,7 @@
           <swe:nilValues>
             <swe:NilValues>
             </swe:NilValues>
           </swe:nilValues>
Modified: trunk/msautotest/wxs/expected/wcs_20_post_bands_name_new.dat
--- trunk/msautotest/wxs/expected/wcs_20_post_bands_name_new.dat	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_post_bands_name_new.dat	2011-09-02 12:49:20 UTC (rev 12511)
@@ -20,11 +20,11 @@
       <gml:origin>
         </gml:Point>
       </gml:origin>
   </gml:domainSet>
   <gml:rangeSet>
Modified: trunk/msautotest/wxs/expected/wcs_20_post_desc.xml
--- trunk/msautotest/wxs/expected/wcs_20_post_desc.xml	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_post_desc.xml	2011-09-02 12:49:20 UTC (rev 12511)
@@ -19,11 +19,11 @@
         <gml:origin>
           </gml:Point>
         </gml:origin>
     </gml:domainSet>
     <gmlcov:rangeType>
Modified: trunk/msautotest/wxs/expected/wcs_20_post_getcov_full_multipart.dat
--- trunk/msautotest/wxs/expected/wcs_20_post_getcov_full_multipart.dat	2011-09-01 16:29:20 UTC (rev 12510)
+++ trunk/msautotest/wxs/expected/wcs_20_post_getcov_full_multipart.dat	2011-09-02 12:49:20 UTC (rev 12511)
@@ -20,11 +20,11 @@
       <gml:origin>
         </gml:Point>
       </gml:origin>
   </gml:domainSet>
   <gml:rangeSet>
