[mapserver-commits] r12524 - branches/branch-6-0/docs/en/cgi trunk/docs/en/cgi
Tue Sep 6 16:09:55 EDT 2011
Author: havatv
Date: 2011-09-06 13:09:55 -0700 (Tue, 06 Sep 2011)
New Revision: 12524
   branches/branch-6-0/docs/en/cgi/controls.txt
   trunk/docs/en/cgi/controls.txt
Added index entries (#4001) - cgi controls.  Also fixed some sorting issues.
Modified: branches/branch-6-0/docs/en/cgi/controls.txt
--- branches/branch-6-0/docs/en/cgi/controls.txt	2011-09-06 19:37:54 UTC (rev 12523)
+++ branches/branch-6-0/docs/en/cgi/controls.txt	2011-09-06 20:09:55 UTC (rev 12524)
@@ -1,3 +1,6 @@
+.. index::
+   simple: CGI controls
 .. _cgi_controls:
@@ -8,23 +11,38 @@
 Variables
+.. index::
+   pair: CGI; buffer
 BUFFER [distance]
     A distance, in the same coordinate system as the map file, used in
     conjunction with MAPXY to create an new map extent.
+.. index::
+   pair: CGI; context
 CONTEXT [filename]
     Path to a context file. Path is relative to the map file to be used, or
     can also be a URL path (See the section "Map Context Support Through
     CGI" below for more details).
+.. index::
+   pair: CGI; icon
 ICON [layername],[classindex]
     Used in MODE=legendicon to generate a legend icon for a layer.  The
     class index value is optional and defaults to 0.
+.. index::
+   pair: CGI; id
 ID [id-string]
     By default MapServer generates a uniq session id based on system time
     and process id. This parameter overwrites the default.
+.. index::
+   pair: CGI; img
     The name associated with the inline map image used to record user clicks.
     What actually is passed are two variables, img.x and img.y.
@@ -32,14 +50,23 @@
     For the CGI Applications this is an essential variable, see the examples
     for sample usage.
+.. index::
+   pair: CGI; imgbox
 IMGBOX [x1] [y1] [x2] [y2]
     Coordinates (in pixels) of a box drag in the image. Most often used in
     conjunction with Java based front ends to the MapServer.
+.. index::
+   pair: CGI; imgext
 IMGEXT [minx] [miny] [maxx] [maxy]
     The spatial extent of the existing inline image, that is, the image the
     users can see in their browser.
+.. index::
+   pair: CGI; imgshape
 IMGSHAPE [x1 y1 x2 y2 x3 y3 ...] | [WKT]
     An arbitrary polygon shape (specified using **image coordinates**)
     to be used for query purposes.
@@ -51,17 +78,29 @@
     Used with modes NQUERY and NQUERYMAP.
+.. index::
+   pair: CGI; imgsize
 IMGSIZE [cols] [rows]
     The size (in pixels) of the exiting inline image.
+.. index::
+   pair: CGI; imgxy
 IMGXY [x] [y]
     Coordinates (in pixels) of a single mouse click. Used most often in
+.. index::
+   pair: CGI; layer
 LAYER [name]
     The name of a layer as it appears in the map file. Sending mapserv a layer
     name sets that layer's STATUS to ON.
+.. index::
+   pair: CGI; layers
 LAYERS [name name ...]
     The names of the layers to be turned on. Layer names must be seperated by
     spaces.
@@ -69,18 +108,23 @@
     Version 4.4 and above: passing 'LAYERS=all' will automatically turn on all
     layers.
+.. index::
+   pair: CGI; map
 MAP [filename]
     Path, relative to the CGI directory, of the map file to be used.
+.. index::
+   pair: CGI; mapext
 MAPEXT [minx] [miny] [maxx] [maxy] , MAPEXT (shape)
     The spatial extent of the map to be created.
     Can be set to shape as an alternative option. In this case mapextent is
     set to the extent of a selected shape. Used with queries.
-MAPSIZE [cols] [rows]
-    The size (in pixels) of the image to be created. Useful for allowing users
-    to change the resolution of the output map dynamically.
+.. index::
+   pair: CGI; mapshape
 MAPSHAPE [x1 y1 x2 y2 x3 y3 ...] | [WKT]
     An arbitrary polygon shape (specified using **map coordinates**)
@@ -93,6 +137,16 @@
+.. index::
+   pair: CGI; mapsize
+MAPSIZE [cols] [rows]
+    The size (in pixels) of the image to be created. Useful for allowing users
+    to change the resolution of the output map dynamically.
+.. index::
+   pair: CGI; mapxy
 MAPXY [x] [y] , MAPXY (shape)
     A point, in the same coordinate system as the shapefiles, to be used in
     conjuction with a buffer or a scale to construct a map extent.
@@ -100,54 +154,100 @@
+.. index::
+   pair: CGI; minx
+.. index::
+   pair: CGI; miny
+.. index::
+   pair: CGI; maxx
+.. index::
+   pair: CGI; maxy
 MINX | MINY | MAXX | MAXY [number]
     Minimum/Maximum x/y coordinate of the spatial extent for a new map/query.
     This set of parameters are the pieces of MAPEXT.
+.. index::
+   pair: CGI; mode
 MODE [value]
     Mode of operation. The following options are supported (note that all of
     the query modes also support map-only modes, e.g. ITEMQUERYMAP, which
     for brevity are not all listed):
+    .. index::
+       triple: CGI; mode; browse
     BROWSE
         Fully interactive interface where maps (and interactive pages) are
         created. This is the default mode.
-    QUERY
-        A spatial search (finds closest) is triggered by a click in a map.
+    .. index::
+       triple: CGI; mode; featurenquery
-    NQUERY
-        A spatial search (finds all) is triggered by a click in a map or by
-        user-define selection box.
+    FEATURENQUERY
+        A spatial search that uses multiple features from SLAYER to query
+        other layers.
-    ITEMQUERY
-        A text search of attribute data is triggered using a layer QSTRING.
-        Returns 1st match.
+    .. index::
+       triple: CGI; mode; featurequery
-    ITEMNQUERY
-        A text search of attribute data is triggered using a QSTRING.
-        Returns all matches.
     FEATUREQUERY
         A spatial search that uses one feature from SLAYER to query other
         layers.
-    FEATURENQUERY
-        A spatial search that uses multiple features from SLAYER to query
-        other layers.
+    .. index::
+       triple: CGI; mode; indexquery
-    ITEMFEATUREQUERY
+    INDEXQUERY
+        Looks up a feature based on the values of SHAPEINDEX and TILEINDEX
+        parameters. SHAPEINDEX is required, TILEINDEX is optional and is only
+        used with tiled shapefile layers.
+    .. index::
+       triple: CGI; mode; itemfeaturenquery
+    ITEMFEATURENQUERY
         A text search of attribute data is triggered using a QSTRING. Returns
-        first match. Layer to be searched is defined using slayer parameter.
+        all matches. Layer to be searched is defined using slayer parameter.
         The results of this search are applied to other searchable layers
         (which can be limited using the QLAYER parameter).
-    ITEMFEATURENQUERY
+    .. index::
+       triple: CGI; mode; itemfeaturequery
+    ITEMFEATUREQUERY
-        all matches. Layer to be searched is defined using slayer parameter.
+        first match. Layer to be searched is defined using slayer parameter.
+    .. index::
+       triple: CGI; mode; itemnquery
+    ITEMNQUERY
+        A text search of attribute data is triggered using a QSTRING.
+        Returns all matches.
+    .. index::
+       triple: CGI; mode; itemquery
+    ITEMQUERY
+        A text search of attribute data is triggered using a layer QSTRING.
+        Returns 1st match.
+    .. index::
+       triple: CGI; mode; legend
+    LEGEND
+        The created legend is returned. Used within an <img ... > tag.
+    .. index::
+       triple: CGI; mode; legendicon
     LEGENDICON
         A legend icon is returned.  The ICON parameter must also be used
         to specify the layername and a class index.  Class index value is
@@ -157,44 +257,79 @@
           mapserv.exe?map=/ms4w/apps/gmap/htdocs/gmap75.map&MODE=legendicon&ICON=popplace,0
+    .. index::
+       triple: CGI; mode; map
     MAP
         The created map is returned. Used within an <img ... > tag.
+    .. index::
+       triple: CGI; mode; nquery
+    NQUERY
+        A spatial search (finds all) is triggered by a click in a map or by
+        user-define selection box.
+    .. index::
+       triple: CGI; mode; query
+    QUERY
+        A spatial search (finds closest) is triggered by a click in a map.
+    .. index::
+       triple: CGI; mode; reference
     REFERENCE
         The created reference map is returned. Used within an <img ... > tag.
+    .. index::
+       triple: CGI; mode; scalebar
     SCALEBAR
         The created scalebar is returned. Used within an <img ... > tag.
-    LEGEND
-        The created legend is returned. Used within an <img ... > tag.
+    .. index::
+       triple: CGI; mode; zoomin
     ZOOMIN
         Switch to mode BROWSE with ZOOMDIR=1
+    .. index::
+       triple: CGI; mode; zoomout
     ZOOMOUT
         Switch to mode BROWSE with ZOOMDIR=-1
-    INDEXQUERY
-        Looks up a feature based on the values of SHAPEINDEX and TILEINDEX
-        parameters. SHAPEINDEX is required, TILEINDEX is optional and is only
-        used with tiled shapefile layers.
+    .. index::
+       triple: CGI; mode; coordinate
     COORDINATE
         To be clarified.
-QLAYER [name]
-    Query layer. The name of the layer to be queried as it appears in the map
-    file. If not specified then all layers are searched in turn.
+.. index::
+   pair: CGI; qitem
 QITEM [name] (optional)
     The name of an attribute in a layer attribute table to query on. The
     parameter is optional and used in conjunction with the QSTRING for
     attribute queries.
+.. index::
+   pair: CGI; qlayer
+QLAYER [name]
+    Query layer. The name of the layer to be queried as it appears in the map
+    file. If not specified then all layers are searched in turn.
+.. index::
+   pair: CGI; qstring
 QSTRING [expression]
     Attribute queries: Query string passed to the query function.
+.. index::
+   pair: CGI; queryfile
 QUERYFILE [filename]
     Used with BROWSE or NQUERY mode. This option identifies a query file to
     load before any regular processing. In BROWSE mode this result in a query
@@ -204,6 +339,9 @@
     so you have access to query maps AND attribute information.
     See the SAVEQUERY option.
+.. index::
+   pair: CGI; ref
 REF
     The name associated with the inline reference map image used to record
     user clicks. What actually is passed are two variables, ref.x and ref.y.
@@ -211,15 +349,24 @@
     For the CGI Applications this is an essential variable when reference
     maps are used, see the examples for sample usage.
+.. index::
+   pair: CGI; refxy
 REFXY [x] [y]
     Coordinates (in pixels) of a single mouse click in the reference image.
     Used in conjunction with Java based front ends to the MapServer.
+.. index::
+   pair: CGI; savequery
 SAVEQUERY
     When used with any of the query modes this tells the MapServer to save the
     query results to a temporary file for use in subsequent operations
     (see QUERYFILE). Useful for making queries persistent.
+.. index::
+   pair: CGI; scaledenom
 SCALEDENOM [number]
     Scale to create a new map at. Used with mapxy. Scale is given as the
     denominator of the actual scale fraction, for example for a map at a scale
@@ -232,6 +379,9 @@
     with mapxy. Scale is given as the denominator of the actual scale fraction,
     for example for a map at a scale of 1:24,000 use 24000.
+.. index::
+   pair: CGI; searchmap
 SEARCHMAP
     It is possible to do pan/zoom interfaces using querymaps. In these cases
     you will likey want information about the contents of the new map rather
@@ -239,18 +389,30 @@
     searchmap is specified the new map is created and it's extent is used
     to query layers. Useful with NQUERY mode only.
+.. index::
+   pair: CGI; shapeindex
 SHAPEINDEX [index]
     Used for index queries (in conjunction with INDEXQUERY).
+.. index::
+   pair: CGI; slayer
 SLAYER [name]
     Select layer. The name of the layer to be used for any of the feature
     (i.e. staged) query modes. The select layer must be a polygon layer. The
     selection feature(s) are available for presentation to the user.
+.. index::
+   pair: CGI; tileindex
 TILEINDEX [index]
     Used for index queries (in conjunction with INDEXQUERY), used with tiled
     shapefile layers.
+.. index::
+   pair: CGI; zoom
 ZOOM [number]
     Zoom scaling to apply to the creation of the new map. Values greater than
     0 resulting in zooming in, 0 is a pan, and values less than zero are for
@@ -260,14 +422,24 @@
     The zoom is limited by the MINZOOM/MAXZOOM settings compiled into the
     MapServer (-25/25) by default.
+.. index::
+   pair: CGI; zoomdir
 ZOOMDIR [1 | 0 | -1]
     Direction to zoom. See above.
+.. index::
+   pair: CGI; zoomsize
 ZOOMSIZE [number]
     Absolute magnitude of a zoom. Used with ZOOMDIR.
     ZOOMDIR is limited to MAXZOOM compiled into the MapServer (25 by default).
+.. index::
+   single: Change map file parameters
 Changing map file parameters via a form or a URL
@@ -356,6 +528,9 @@
 feature. You can repeat the process to create additional features. This is
 really intended for very small (point, rectangle) amounts of data.
+.. index::
+   single: Apache variables
 Specifying the location of mapfiles using an Apache variables
@@ -377,6 +552,9 @@
+.. index::
+   single: ROSA-Applet controls
 ROSA-Applet Controls
Modified: trunk/docs/en/cgi/controls.txt
--- trunk/docs/en/cgi/controls.txt	2011-09-06 19:37:54 UTC (rev 12523)
+++ trunk/docs/en/cgi/controls.txt	2011-09-06 20:09:55 UTC (rev 12524)
@@ -1,3 +1,6 @@
+.. index::
 .. _cgi_controls:
@@ -8,23 +11,38 @@
 Variables
+.. index::
+   pair: CGI; buffer
 BUFFER [distance]
+.. index::
 CONTEXT [filename]
+.. index::
+   pair: CGI; icon
+.. index::
+   pair: CGI; id
 ID [id-string]
+.. index::
+   pair: CGI; img
@@ -32,14 +50,23 @@
     for sample usage.
+.. index::
+   pair: CGI; imgbox
+.. index::
+   pair: CGI; imgext
+.. index::
@@ -51,17 +78,29 @@
+.. index::
+.. index::
+   pair: CGI; imgxy
 IMGXY [x] [y]
+.. index::
+   pair: CGI; layer
 LAYER [name]
+.. index::
+   pair: CGI; layers
     spaces.
     layers.
+.. index::
+   pair: CGI; map
 MAP [filename]
+.. index::
+   pair: CGI; mapext
+.. index::
@@ -93,6 +137,16 @@
+.. index::
+.. index::
+   pair: CGI; mapxy
+.. index::
+   pair: CGI; minx
+.. index::
+   pair: CGI; miny
+.. index::
+   pair: CGI; maxx
+.. index::
+   pair: CGI; maxy
+.. index::
+   pair: CGI; mode
 MODE [value]
+    .. index::
     BROWSE
-    QUERY
+    .. index::
-    NQUERY
+    FEATURENQUERY
+        other layers.
-    ITEMQUERY
+    .. index::
-    ITEMNQUERY
     FEATUREQUERY
         layers.
-    FEATURENQUERY
-        other layers.
+    .. index::
-    ITEMFEATUREQUERY
+    INDEXQUERY
+    .. index::
+    ITEMFEATURENQUERY
-    ITEMFEATURENQUERY
+    .. index::
+    ITEMFEATUREQUERY
+    .. index::
+    ITEMNQUERY
+    .. index::
+    ITEMQUERY
+    .. index::
+    LEGEND
+    .. index::
     LEGENDICON
+    .. index::
     MAP
+    .. index::
+    NQUERY
+    .. index::
+    QUERY
+    .. index::
     REFERENCE
+    .. index::
     SCALEBAR
-    LEGEND
+    .. index::
     ZOOMIN
+    .. index::
     ZOOMOUT
-    INDEXQUERY
+    .. index::
     COORDINATE
         To be clarified.
-QLAYER [name]
+.. index::
+   pair: CGI; qitem
     attribute queries.
+.. index::
+   pair: CGI; qlayer
+QLAYER [name]
+.. index::
+.. index::
@@ -204,6 +339,9 @@
+.. index::
+   pair: CGI; ref
 REF
+.. index::
+   pair: CGI; refxy
 REFXY [x] [y]
+.. index::
 SAVEQUERY
+.. index::
 SCALEDENOM [number]
@@ -232,6 +379,9 @@
+.. index::
 SEARCHMAP
+.. index::
 SHAPEINDEX [index]
+.. index::
+   pair: CGI; slayer
 SLAYER [name]
+.. index::
 TILEINDEX [index]
     shapefile layers.
+.. index::
+   pair: CGI; zoom
 ZOOM [number]
+.. index::
+.. index::
 ZOOMSIZE [number]
+.. index::
@@ -356,6 +528,9 @@
+.. index::
@@ -377,6 +552,9 @@
+.. index::
