[mapserver-commits] r12547 - trunk/mapserver
Sat Sep 17 15:54:32 EDT 2011
Author: tbonfort
Date: 2011-09-17 12:54:32 -0700 (Sat, 17 Sep 2011)
New Revision: 12547
   trunk/mapserver/mapimageio.c
don't use libPNG pre-zlib filtering (#4017)
Modified: trunk/mapserver/mapimageio.c
--- trunk/mapserver/mapimageio.c	2011-09-17 19:48:53 UTC (rev 12546)
+++ trunk/mapserver/mapimageio.c	2011-09-17 19:54:32 UTC (rev 12547)
@@ -28,7 +28,7 @@
 #include "mapserver.h"
-#include "png.h"
+#include "/opt/local/include/png.h"
 #include "setjmp.h"
 #include <assert.h>
 #include "jpeglib.h"
@@ -262,6 +262,9 @@
    if (!png_ptr)
       return (MS_FAILURE);
+   png_set_compression_level(png_ptr, compression);
+   png_set_filter (png_ptr,0, PNG_FILTER_NONE);
    info_ptr = png_create_info_struct(png_ptr);
    if (!info_ptr)
@@ -281,7 +284,6 @@
    else
       png_set_write_fn(png_ptr,info, png_write_data_to_buffer, png_flush_data);
-   png_set_compression_level(png_ptr, compression);
    if (rb->data.palette.num_entries <= 2)
     sample_depth = 1;
@@ -450,6 +452,9 @@
         if (!png_ptr)
         if (!info_ptr)
@@ -473,7 +478,6 @@
         else
             color_type = PNG_COLOR_TYPE_RGB;
         png_set_IHDR(png_ptr, info_ptr, rb->width, rb->height,
                      8, color_type, PNG_INTERLACE_NONE,
                      PNG_COMPRESSION_TYPE_DEFAULT, PNG_FILTER_TYPE_DEFAULT);
