[mapserver-commits] r12551 - trunk/docs/en/development/rfc
Sat Sep 17 17:07:36 EDT 2011
Author: jmckenna
Date: 2011-09-17 14:07:36 -0700 (Sat, 17 Sep 2011)
New Revision: 12551
Added:
   trunk/docs/en/development/rfc/ms-rfc-74.txt
   trunk/docs/en/development/rfc/index.txt
add Mike's DBINCLUDE rfc doc
Modified: trunk/docs/en/development/rfc/index.txt
--- trunk/docs/en/development/rfc/index.txt	2011-09-17 20:36:10 UTC (rev 12550)
+++ trunk/docs/en/development/rfc/index.txt	2011-09-17 21:07:36 UTC (rev 12551)
@@ -83,3 +83,4 @@
    ms-rfc-71
    ms-rfc-72
    ms-rfc-73
+   ms-rfc-74
Added: trunk/docs/en/development/rfc/ms-rfc-74.txt
--- trunk/docs/en/development/rfc/ms-rfc-74.txt	                        (rev 0)
+++ trunk/docs/en/development/rfc/ms-rfc-74.txt	2011-09-17 21:07:36 UTC (rev 12551)
@@ -0,0 +1,132 @@
+.. _rfc74:
+MS RFC 74: Includes from non-file connections (eg Databases)
+:Date:  2011/07/29
+:Author: Michael Smith, Daniel Morissette
+:Contact: michael.smith at usace.army.mil, dmorissette at mapgears.com
+:Last Edited: 09/17/2011
+:Status: Draft
+:Version: MapServer 6.2
+1. Overview
+MapServer 4.10 introduced the concept of INCLUDE files. When this directive is encountered parsing switches to the included file immediately.
+As a result the included file can be comprised of any valid mapfile syntax.
+For example, one could write:
+  INCLUDE 'myLayer.map'
+This would include the contents in the mapfile at runtime.
+It would be useful to extend this to allow INCLUDEs from database connections. This provides another mechanism for dynamic mapfiles
+without requiring MapScript.
+2. The proposed solution
+This RFC proposes to add a new DBINCLUDE mapfile item. This item would have a number of associated mapfile items including:
+ CONNECTIONTYPE
+ CONNECTION
+ DATA
+ INCLUDEITEM
+ FILTER
+ METADATA
+And be closed with an END keyword.
+Example
+.. code-block:: mapfile
+   DBINCLUDE
+     CONNECTIONTYPE oraclespatial
+     CONNECTION "%uid%/%passwd%@tns_connection"
+     DATA "MAPLAYER_TABLE_NAME"
+     INCLUDEITEM "MAPLAYERS"
+     FILTER "condition=%layer_variable%"
+     METADATA
+        "layer_variable_validation_pattern"  "^condition1|condition2$"
+     END
+   END
+The only new item, beside the DBINCLUDE keyword, is the INCLUDEITEM. It defines the attribute from which to to pull
+the layers definitions. It functions similarly to TILEITEM.
+Allowed CONNECTIONTYPEs would include OGR, POSTGIS, ORACLESPATIAL.
+An Example of the query would be
+    select maplayers from maplayer_table_name where condition = condition1;
+The content of the MAPLAYERS content would be strings to include in the mapfile just and INCLUDE would do. One difference
+is that the query could return a resultset of strings to add, and would be equivalent to N INCLUDE statements.
+2.5 Use Cases
+A common use case is providing a custom classed layer for an individual. Currently, this is very difficult to do without MapScript.
+For example, in a table one column would be username and the second column would be the layer class level text string.
+..   csv-table:: Example Table
+     user,class
+     jeff,CLASS Name "Jeff Layer"   STYLE OUTLINECOLOR 255 0 0 SYMBOL 0 COLOR 0 0 255 END END
+     daniel,CLASS Name "Daniel Layer" STYLE OUTLINECOLOR 122 180 200 SYMBOL 0 END END
+     steve,CLASS Name "Steve Layer"  EXPRESSION "type=brewery" STYLE SYMBOL 0 COLOR 0 255 255 WIDTH 4 END END
+Another common case is dynamically classifying a layer as the data changes. With SQL, a text string can be calculated on
+the fly from the data itself, by looking at the DISTINCT values of a dataset to generate the classes that will be
+used to display that data.
+3. Implementation Details
+3.1 Files affected
+The following files will be modified/created by this RFC:
+  mapfile.c
+  mapogr.c
+  maplayer.c
+  maplexer.l
+  mapparser.y
+3.2 MapScript Issues
+There should be no mapscript issues, this is really only useful for CGI
+3.3 Security Issues
+The security issues should be the same as any existing database connection layer
+3.4 Backwards Compatibility Issues
+This change provides a new functionality with no backwards compatibility issues being considered.
+4. Bug ID
+None assigned.
+5. Voting history
+None
