[mapserver-commits] r12559 - in trunk/mapserver/xmlmapfile: . tests
svn at osgeo.org
svn at osgeo.org
Tue Sep 20 11:02:49 EDT 2011
Author: aboudreault
Date: 2011-09-20 08:02:49 -0700 (Tue, 20 Sep 2011)
New Revision: 12559
trunk/mapserver/xmlmapfile/mapfile.xsd
trunk/mapserver/xmlmapfile/mapfile.xsl
trunk/mapserver/xmlmapfile/tests/layerset.xml
trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
trunk/mapserver/xmlmapfile/tests/symbolset.xml
Updated XMLMapfile stuff for MapServer 6.0
Modified: trunk/mapserver/xmlmapfile/mapfile.xsd
--- trunk/mapserver/xmlmapfile/mapfile.xsd 2011-09-19 21:54:31 UTC (rev 12558)
+++ trunk/mapserver/xmlmapfile/mapfile.xsd 2011-09-20 15:02:49 UTC (rev 12559)
@@ -1,5 +1,5 @@
<?xml version="1.0" encoding="utf-8"?>
-<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ms="http://www.mapserver.org/mapserver" targetNamespace="http://www.mapserver.org/mapserver" elementFormDefault="qualified" attributeFormDefault="unqualified" version="5.6.3">
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ms="http://www.mapserver.org/mapserver" targetNamespace="http://www.mapserver.org/mapserver" elementFormDefault="qualified" attributeFormDefault="unqualified" version="6.0.1">
<!-- Definition of types -->
<xs:simpleType name="rgbColorValueType">
<xs:restriction base="xs:integer">
@@ -278,10 +278,10 @@
<xs:element name="colorAttribute" type="ms:attributeType"/>
</xs:choice>
<xs:element name="encoding" minOccurs="0"/>
- <xs:element name="maxoverlapangle" minOccurs="0"/>
<xs:element name="font" type="xs:string" minOccurs="0"/>
<xs:element name="force" type="ms:booleanEnum" default="FALSE" minOccurs="0"/>
<xs:element name="maxLength" type="xs:integer" default="0" minOccurs="0"/>
+ <xs:element name="maxOverlapAngle" type="xs:float" minOccurs="0"/>
<xs:element name="maxSize" type="xs:integer" default="256" minOccurs="0"/>
<xs:element name="minDistance" type="xs:integer" minOccurs="0"/>
<xs:element name="minFeatureSize" minOccurs="0">
@@ -344,6 +344,7 @@
</xs:union>
</xs:simpleType>
</xs:element>
+ <xs:element name="Style" type="ms:Style" minOccurs="0"/>
<xs:element name="wrap" type="xs:string" minOccurs="0"/>
</xs:sequence>
<xs:attribute name="type" use="required">
@@ -369,31 +370,61 @@
</xs:union>
</xs:simpleType>
</xs:element>
- <xs:element name="antialias" type="ms:booleanEnum"/>
+ <xs:element name="antialias" type="ms:booleanEnum" minOccurs="0"/>
<xs:element name="backgroundColor" type="ms:rgbColorType" minOccurs="0"/>
<xs:choice minOccurs="0">
<xs:element name="color" type="ms:rgbColorType"/>
</xs:choice>
+ <xs:element name="gap" type="xs:integer" default="0" minOccurs="0"/>
<xs:element name="geomTransform" minOccurs="0">
<xs:simpleType>
<xs:restriction base="xs:string">
+ <xs:enumeration value="BBOX"/>
+ <xs:enumeration value="END"/>
+ <xs:enumeration value="LABELPNT"/>
+ <xs:enumeration value="LABELPOLY"/>
<xs:enumeration value="START"/>
- <xs:enumeration value="END"/>
<xs:enumeration value="VERTICES"/>
- <xs:enumeration value="BBOX"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
- <xs:element name="maxSize" type="xs:integer" default="50" minOccurs="0"/>
- <xs:element name="minSize" type="xs:integer" default="0" minOccurs="0"/>
- <xs:element name="minWidth" type="xs:integer" minOccurs="0"/>
+ <xs:element name="lineCap" default="BUTT" minOccurs="0">
+ <xs:simpleType>
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="BUTT"/>
+ <xs:enumeration value="ROUND"/>
+ <xs:enumeration value="SQUARE"/>
+ <xs:enumeration value="TRIANGLE"/>
+ <xs:enumeration value="SVG"/>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="lineJoin" minOccurs="0">
+ <xs:simpleType>
+ <xs:enumeration value="MITER"/>
+ <xs:enumeration value="BEVEL"/>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="lineJoinMaxSize" type="xs:integer" default="3" minOccurs="0"/>
+ <xs:element name="maxSize" type="xs:float" default="500" minOccurs="0"/>
+ <xs:element name="maxWidth" type="xs:float" default="32" minOccurs="0"/>
+ <xs:element name="minSize" type="xs:float" default="0" minOccurs="0"/>
+ <xs:element name="minWidth" type="xs:float" default="0" minOccurs="0"/>
<xs:element name="offset" type="ms:sizeType" minOccurs="0"/>
<xs:element name="opacity" type="xs:integer" default="0" minOccurs="0"/>
<xs:element name="outlineColor" type="ms:rgbColorType"/>
<xs:element name="outlineColorAttribute" type="ms:attributeType"/>
</xs:choice>
+ <xs:element name="pattern" minOccurs="0">
+ <xs:simpleType>
+ <xs:list itemType="xs:float"/>
+ </xs:simpleType>
+ </xs:element>
<xs:element name="size" default="1" minOccurs="0">
<xs:simpleType>
<xs:union memberTypes="xs:positiveInteger ms:attributeType"/>
@@ -441,34 +472,7 @@
<xs:element name="character" type="xs:string" minOccurs="0"/>
<xs:element name="filled" type="ms:booleanEnum" minOccurs="0"/>
- <xs:element name="gap" type="xs:integer" default="0" minOccurs="0"/>
<xs:element name="image" type="xs:string" minOccurs="0"/>
- <xs:element name="lineCap" default="BUTT" minOccurs="0">
- <xs:simpleType>
- <xs:restriction base="xs:string">
- <xs:enumeration value="BUTT"/>
- <xs:enumeration value="ROUND"/>
- <xs:enumeration value="SQUARE"/>
- <xs:enumeration value="TRIANGLE"/>
- <xs:enumeration value="SVG"/>
- </xs:restriction>
- </xs:simpleType>
- </xs:element>
- <xs:element name="lineJoin" minOccurs="0">
- <xs:simpleType>
- <xs:enumeration value="MITER"/>
- <xs:enumeration value="BEVEL"/>
- </xs:restriction>
- </xs:simpleType>
- </xs:element>
- <xs:element name="lineJoinMaxSize" type="xs:integer" default="3" minOccurs="0"/>
- <xs:element name="pattern" minOccurs="0">
- <xs:simpleType>
- <xs:list itemType="xs:integer"/>
- </xs:simpleType>
- </xs:element>
<xs:element name="Points" minOccurs="0">
<xs:complexType>
<xs:sequence>
@@ -478,7 +482,7 @@
</xs:element>
<xs:element name="transparent" type="xs:integer" minOccurs="0"/>
</xs:sequence>
- <xs:attribute name="name" type="xs:string"/>
+ <xs:attribute name="name" type="xs:string"/>
<xs:simpleType>
@@ -486,7 +490,6 @@
<xs:enumeration value="ELLIPSE"/>
<xs:enumeration value="PIXMAP"/>
<xs:enumeration value="TRUETYPE"/>
- <xs:enumeration value="CARTOLINE"/>
<xs:enumeration value="HATCH"/>
<xs:enumeration value="SIMPLE"/>
</xs:restriction>
@@ -576,7 +579,6 @@
<!-- CLUSTER Definition -->
<xs:complexType name="Cluster">
<xs:sequence>
- <xs:element name="buffer" type="xs:positiveInteger" minOccurs="0"/>
<xs:element name="filter" type="ms:expressionType" minOccurs="0"/>
<xs:element name="group" type="ms:expressionType" minOccurs="0"/>
<xs:element name="maxdistance" type="xs:positiveInteger" minOccurs="0"/>
@@ -594,6 +596,7 @@
<xs:element name="connectionType" minOccurs="0">
<xs:simpleType>
+ <xs:enumeration value="LOCAL"/>
<xs:enumeration value="SDE"/>
<xs:enumeration value="OGR"/>
<xs:enumeration value="WFS"/>
Modified: trunk/mapserver/xmlmapfile/mapfile.xsl
--- trunk/mapserver/xmlmapfile/mapfile.xsl 2011-09-19 21:54:31 UTC (rev 12558)
+++ trunk/mapserver/xmlmapfile/mapfile.xsl 2011-09-20 15:02:49 UTC (rev 12559)
@@ -595,7 +595,7 @@
</xsl:call-template>
<xsl:call-template name="print">
<xsl:with-param name="indent" select="$indent"/>
- <xsl:with-param name="node" select="'ms:maxoverlapangle'"/>
+ <xsl:with-param name="node" select="'ms:maxOverlapAngle'"/>
<xsl:apply-templates select="ms:color">
@@ -677,6 +677,9 @@
<xsl:with-param name="node" select="'ms:size'"/>
+ <xsl:apply-templates select="ms:Style">
+ <xsl:with-param name="indent" select="$indent + 1"/>
+ </xsl:apply-templates>
<xsl:with-param name="node" select="'ms:wrap'"/>
@@ -786,12 +789,35 @@
+ <xsl:with-param name="node" select="'ms:maxWidth'"/>
+ </xsl:call-template>
+ <xsl:call-template name="print">
+ <xsl:with-param name="indent" select="$indent"/>
<xsl:with-param name="node" select="'ms:minSize'"/>
<xsl:with-param name="node" select="'ms:minWidth'"/>
+ <xsl:with-param name="node" select="'ms:gap'"/>
+ <xsl:with-param name="node" select="'ms:lineCap'"/>
+ <xsl:with-param name="node" select="'ms:lineJoin'"/>
+ <xsl:with-param name="node" select="'ms:lineJoinMaxSize'"/>
+ <xsl:apply-templates select="ms:pattern">
<xsl:apply-templates select="ms:offset">
@@ -957,28 +983,9 @@
- <xsl:with-param name="node" select="'ms:gap'"/>
- </xsl:call-template>
- <xsl:call-template name="print">
- <xsl:with-param name="indent" select="$indent"/>
<xsl:with-param name="node" select="'ms:image'"/>
<xsl:with-param name="quote" select="1"/>
- <xsl:with-param name="node" select="'ms:lineCap'"/>
- <xsl:with-param name="node" select="'ms:lineJoin'"/>
- <xsl:with-param name="node" select="'ms:lineJoinMaxSize'"/>
- <xsl:apply-templates select="ms:pattern">
- </xsl:apply-templates>
<xsl:apply-templates select="ms:Points">
@@ -1367,10 +1374,6 @@
- <xsl:with-param name="node" select="'ms:buffer'"/>
<xsl:with-param name="node" select="'ms:region'"/>
Modified: trunk/mapserver/xmlmapfile/tests/layerset.xml
--- trunk/mapserver/xmlmapfile/tests/layerset.xml 2011-09-19 21:54:31 UTC (rev 12558)
+++ trunk/mapserver/xmlmapfile/tests/layerset.xml 2011-09-20 15:02:49 UTC (rev 12559)
@@ -45,13 +45,19 @@
<antialias>TRUE</antialias>
<backgroundColor red="244" green="43" blue="22"/>
<color red="244" green="43" blue="22"/>
+ <gap>13</gap>
<geomTransform>VERTICES</geomTransform>
+ <lineCap>ROUND</lineCap>
+ <lineJoin>BEVEL</lineJoin>
+ <lineJoinMaxSize>3</lineJoinMaxSize>
<maxSize>244</maxSize>
+ <maxWidth>28</maxWidth>
<minSize>6</minSize>
<minWidth>24</minWidth>
<offset x="12" y="33"/>
<opacity>1253</opacity>
<outlineColorAttribute>[myOulineColorAttribute]</outlineColorAttribute>
+ <pattern>2 3</pattern>
<size>[mySize]</size>
<symbol type="NAME">star.gif</symbol>
<width>[myWidth]</width>
@@ -63,7 +69,6 @@
<classGroup>group1</classGroup>
<classItem>population</classItem>
<Cluster>
- <buffer>2</buffer>
<filter type="MSEXPR">(type=’road’ and size < 2)</filter>
<group type="REGEX">/ddea/i</group>
<maxdistance>20</maxdistance>
@@ -94,7 +99,7 @@
<header>http://mapgears.com/templates/myHeader1.html</header>
<Join name="myJoin1" type="ONE-TO-MANY">
<connection>user=nobody password=****** dbname=dbname host=localhost port=5432</connection>
- <connectionType>OGR</connectionType>
+ <connectionType>POSTGRESQL</connectionType>
<from>ID</from>
<table>./data/lookup.dbf</table>
<template>http://mapgears.com/templates/myJoin1.html</template>
Modified: trunk/mapserver/xmlmapfile/tests/mapfile-test.xml
--- trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2011-09-19 21:54:31 UTC (rev 12558)
+++ trunk/mapserver/xmlmapfile/tests/mapfile-test.xml 2011-09-20 15:02:49 UTC (rev 12559)
@@ -23,15 +23,13 @@
<align>CENTER</align>
<angle>FOLLOW</angle>
- <backgroundColor red="244" green="43" blue="22"/>
- <backgroundShadowColor red="244" green="43" blue="22"/>
- <backgroundShadowSize x="2" y="2"/>
<buffer>2</buffer>
<colorAttribute>[myColor]</colorAttribute>
<encoding>ISO 8859-1</encoding>
<font>serif</font>
<force>TRUE</force>
<maxLength>244</maxLength>
+ <maxOverlapAngle>30</maxOverlapAngle>
<minDistance>24</minDistance>
<minFeatureSize>AUTO</minFeatureSize>
@@ -107,9 +105,6 @@
<angle>[myAngle]</angle>
<antialias>FALSE</antialias>
<buffer>2</buffer>
@@ -129,6 +124,9 @@
<shadowColor red="244" green="43" blue="22"/>
<shadowSize x="15" y="14"/>
<size>SMALL</size>
+ <Style>
+ <geomTransform>VERTICES</geomTransform>
+ </Style>
<wrap>\n</wrap>
</Label>
<outlineColor red="12" green="45" blue="12"/>
@@ -142,33 +140,23 @@
<shapePath>../data</shapePath>
<size x="600" y="400"/>
<symbolSet>/tmp/mySymbolSet.sym</symbolSet>
- <Symbol name="mySymbol2-test2" type="CARTOLINE">
+ <Symbol name="mySymbol2-test2" type="SIMPLE">
<character>C</character>
<filled>TRUE</filled>
<font>serif</font>
- <gap>13</gap>
<image>/tmp/test.gif</image>
- <lineCap>ROUND</lineCap>
- <lineJoin>BEVEL</lineJoin>
- <lineJoinMaxSize>3</lineJoinMaxSize>
- <pattern>2 3</pattern>
<Points>
<point x="2" y="-3"/>
</Points>
<transparent>123</transparent>
</Symbol>
- <Symbol name="mySymbol222-test1" type="CARTOLINE">
+ <Symbol name="mySymbol222-test1" type="SIMPLE">
<font>serif</font>
- <gap>13</gap>
<Points>
</Points>
Modified: trunk/mapserver/xmlmapfile/tests/symbolset.xml
--- trunk/mapserver/xmlmapfile/tests/symbolset.xml 2011-09-19 21:54:31 UTC (rev 12558)
+++ trunk/mapserver/xmlmapfile/tests/symbolset.xml 2011-09-20 15:02:49 UTC (rev 12559)
@@ -1,32 +1,22 @@
<SymbolSet xmlns="http://www.mapserver.org/mapserver" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.mapserver.org/mapserver ../mapfile.xsd">
- <Symbol name="mySymbol2" type="CARTOLINE">
+ <Symbol name="mySymbol2" type="SIMPLE">
<font>serif</font>
- <gap>13</gap>
<Points>
</Points>
<transparent>0</transparent>
</Symbol>
- <Symbol name="mySymbol222" type="CARTOLINE">
+ <Symbol name="mySymbol222" type="SIMPLE">
<font>serif</font>
- <gap>13</gap>
<Points>
</Points>
More information about the mapserver-commits
