[mapserver-commits] r12563 - in branches/branch-6-0/mapserver: . mapscript/php
Tue Sep 20 11:47:05 EDT 2011
Author: aboudreault
Date: 2011-09-20 08:47:05 -0700 (Tue, 20 Sep 2011)
New Revision: 12563
   branches/branch-6-0/mapserver/HISTORY.TXT
   branches/branch-6-0/mapserver/mapscript/php/php_mapscript.h
   branches/branch-6-0/mapserver/mapscript/php/style.c
   branches/branch-6-0/mapserver/mapscript/php/symbol.c
Backport in 6-0: PHP MapScript is missing many styleObj properties (#3901)
Modified: branches/branch-6-0/mapserver/HISTORY.TXT
--- branches/branch-6-0/mapserver/HISTORY.TXT	2011-09-20 15:37:48 UTC (rev 12562)
+++ branches/branch-6-0/mapserver/HISTORY.TXT	2011-09-20 15:47:05 UTC (rev 12563)
@@ -15,6 +15,8 @@
 Current Version (future 6.0.2, SVN branch-6-0):
+- PHP MapScript is missing many styleObj properties (#3901)
 - Added GEOMTRANSFORM in writeStyle function
 - WCS 1.0: Fix crash with some _rangeset_axes values (#4020)
Modified: branches/branch-6-0/mapserver/mapscript/php/php_mapscript.h
--- branches/branch-6-0/mapserver/mapscript/php/php_mapscript.h	2011-09-20 15:37:48 UTC (rev 12562)
+++ branches/branch-6-0/mapserver/mapscript/php/php_mapscript.h	2011-09-20 15:47:05 UTC (rev 12563)
@@ -73,18 +73,6 @@
 #define TRUE 1
 #endif
-#ifndef Z_ADDREF_P
-#define Z_ADDREF_P(pz)                (pz)->refcount++
-#endif
-#ifndef Z_DELREF_P
-#define Z_DELREF_P(pz)                (pz)->refcount--
-#endif
-#ifndef Z_SET_REFCOUNT_P
-#define Z_SET_REFCOUNT_P(pz, rc)      (pz)->refcount = rc
-#endif
 /* Taken from the CAIRO php extension */
 /* turn error handling to exception mode and restore */
 #if defined(PHP_VERSION_ID) && PHP_VERSION_ID >= 50300
@@ -226,6 +214,8 @@
     zval *color;
     zval *outlinecolor;
     zval *backgroundcolor;
+    zval *mincolor;
+    zval *maxcolor;
     styleObj *style;
 } php_style_object;
Modified: branches/branch-6-0/mapserver/mapscript/php/style.c
--- branches/branch-6-0/mapserver/mapscript/php/style.c	2011-09-20 15:37:48 UTC (rev 12562)
+++ branches/branch-6-0/mapserver/mapscript/php/style.c	2011-09-20 15:47:05 UTC (rev 12563)
@@ -69,6 +69,9 @@
   ZEND_ARG_INFO(0, transform)
 ZEND_END_ARG_INFO()
+ZEND_BEGIN_ARG_INFO_EX(style_setPattern_args, 0, 0, 1)
+  ZEND_ARG_INFO(0, pattern)
+ZEND_END_ARG_INFO()
 /* {{{ proto void __construct(classObj class [, styleObj style])
    Create a new styleObj instance */
@@ -132,6 +135,7 @@
     else IF_GET_DOUBLE("minsize", php_style->style->minsize)
     else IF_GET_DOUBLE("maxsize", php_style->style->maxsize)
     else IF_GET_DOUBLE("width", php_style->style->width)
+    else IF_GET_DOUBLE("outlinewidth", php_style->style->outlinewidth)
     else IF_GET_DOUBLE("minwidth", php_style->style->minwidth)
     else IF_GET_DOUBLE("maxwidth", php_style->style->maxwidth)
     else IF_GET_LONG("offsetx", php_style->style->offsetx)
@@ -141,10 +145,21 @@
     else IF_GET_DOUBLE("minvalue", php_style->style->minvalue)
     else IF_GET_DOUBLE("maxvalue", php_style->style->maxvalue)
     else IF_GET_STRING("rangeitem", php_style->style->rangeitem)
+    else IF_GET_LONG("rangeitemindex", php_style->style->rangeitemindex)
+    else IF_GET_DOUBLE("gap", php_style->style->gap)
+    else IF_GET_LONG("patternlength", php_style->style->patternlength)
+    else IF_GET_LONG("position", php_style->style->position)
+    else IF_GET_LONG("linecap", php_style->style->linecap)
+    else IF_GET_LONG("linejoin", php_style->style->linejoin)
+    else IF_GET_LONG("linejoinmaxsize", php_style->style->linejoinmaxsize)
+    else IF_GET_DOUBLE("angle", php_style->style->angle)
+    else IF_GET_LONG("autoangle", php_style->style->autoangle)
     else IF_GET_LONG("opacity", php_style->style->opacity)
     else IF_GET_OBJECT("color", mapscript_ce_color, php_style->color, &php_style->style->color)
     else IF_GET_OBJECT("outlinecolor", mapscript_ce_color, php_style->outlinecolor, &php_style->style->outlinecolor)
     else IF_GET_OBJECT("backgroundcolor", mapscript_ce_color, php_style->backgroundcolor, &php_style->style->backgroundcolor)
+    else IF_GET_OBJECT("mincolor", mapscript_ce_color, php_style->mincolor, &php_style->style->mincolor)
+    else IF_GET_OBJECT("maxcolor", mapscript_ce_color, php_style->maxcolor, &php_style->style->maxcolor)
     else
         mapscript_throw_exception("Property '%s' does not exist in this object." TSRMLS_CC, property);
@@ -178,6 +193,7 @@
     else IF_SET_DOUBLE("minsize", php_style->style->minsize, value)
     else IF_SET_DOUBLE("maxsize", php_style->style->maxsize, value)
     else IF_SET_DOUBLE("width", php_style->style->width, value)
+    else IF_SET_DOUBLE("outlinewidth", php_style->style->outlinewidth, value)
     else IF_SET_DOUBLE("minwidth", php_style->style->minwidth, value)
     else IF_SET_DOUBLE("maxwidth", php_style->style->maxwidth, value)
     else IF_SET_LONG("offsetx", php_style->style->offsetx, value)
@@ -230,10 +246,15 @@
     else if ( (STRING_EQUAL("color", property)) ||
               (STRING_EQUAL("outlinecolor", property)) ||
-              (STRING_EQUAL("backgroundcolor", property)))
+              (STRING_EQUAL("backgroundcolor", property)) ||
+              (STRING_EQUAL("maxcolor", property)) ||
+              (STRING_EQUAL("mincolor", property)))
         mapscript_throw_exception("Property '%s' is an object and can only be modified through its accessors." TSRMLS_CC, property);
+    else if ( (STRING_EQUAL("patternlength", property)))    {
+        mapscript_throw_exception("Property '%s' is read-only and cannot be set." TSRMLS_CC, property);
     else
@@ -472,6 +493,83 @@
+/* {{{ proto int style.setpattern(array points)
+   Set the pattern of the style ) */
+PHP_METHOD(styleObj, setPattern)
+    zval *zpattern, **ppzval;
+    HashTable *pattern_hash = NULL;
+    zval *zobj = getThis();
+    int index = 0, numelements = 0;
+    php_style_object *php_style;
+    PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "a",
+                              &zpattern) == FAILURE) {
+        PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
+        return;
+    php_style = (php_style_object *) zend_object_store_get_object(zobj TSRMLS_CC);
+    pattern_hash = Z_ARRVAL_P(zpattern);
+    numelements = zend_hash_num_elements(pattern_hash);
+    if (numelements == 0)
+        mapscript_report_php_error(E_WARNING,
+                                   "style->setpoints : invalid array of %d element(s) as parameter." TSRMLS_CC, numelements);
+        RETURN_LONG(MS_FAILURE);
+    for(zend_hash_internal_pointer_reset(pattern_hash);
+        zend_hash_has_more_elements(pattern_hash) == SUCCESS;
+        zend_hash_move_forward(pattern_hash))
+        zend_hash_get_current_data(pattern_hash, (void **)&ppzval);
+        if (Z_TYPE_PP(ppzval) != IS_LONG)
+            convert_to_long(*ppzval);
+        php_style->style->pattern[index] = Z_LVAL_PP(ppzval);
+        index++;
+    php_style->style->patternlength = numelements;
+    RETURN_LONG(MS_SUCCESS);
+/* {{{ proto int style.getPatternArray()
+   Returns an array containing the pattern.*/
+PHP_METHOD(styleObj, getPatternArray)
+    int index;
+    if (zend_parse_parameters_none() == FAILURE) {
+        return;
+    array_init(return_value);
+    if (php_style->style->patternlength > 0)
+        for (index=0; index < php_style->style->patternlength; index++)
+            add_next_index_long(return_value, php_style->style->pattern[index]);
 zend_function_entry style_functions[] = {
     PHP_ME(styleObj, __construct, style___construct_args, ZEND_ACC_PUBLIC|ZEND_ACC_CTOR)
     PHP_ME(styleObj, __get, style___get_args, ZEND_ACC_PUBLIC)
@@ -483,6 +581,8 @@
     PHP_ME(styleObj, removeBinding, style_removeBinding_args, ZEND_ACC_PUBLIC)
     PHP_ME(styleObj, getGeomTransform, NULL, ZEND_ACC_PUBLIC)
     PHP_ME(styleObj, setGeomTransform, style_setGeomTransform_args, ZEND_ACC_PUBLIC)
+    PHP_ME(styleObj, setPattern, style_setPattern_args, ZEND_ACC_PUBLIC)
+    PHP_ME(styleObj, getPatternArray, NULL, ZEND_ACC_PUBLIC)
     PHP_ME(styleObj, free, NULL, ZEND_ACC_PUBLIC)
     {NULL, NULL, NULL}
Modified: branches/branch-6-0/mapserver/mapscript/php/symbol.c
--- branches/branch-6-0/mapserver/mapscript/php/symbol.c	2011-09-20 15:37:48 UTC (rev 12562)
+++ branches/branch-6-0/mapserver/mapscript/php/symbol.c	2011-09-20 15:47:05 UTC (rev 12563)
@@ -51,10 +51,6 @@
   ZEND_ARG_INFO(0, points)
 ZEND_END_ARG_INFO()
-ZEND_BEGIN_ARG_INFO_EX(symbol_setPattern_args, 0, 0, 1)
-  ZEND_ARG_INFO(0, pattern)
-ZEND_END_ARG_INFO()
 ZEND_BEGIN_ARG_INFO_EX(symbol_setImagePath_args, 0, 0, 1)
   ZEND_ARG_INFO(0, filename)
 ZEND_END_ARG_INFO()
@@ -165,7 +161,6 @@
     else IF_SET_LONG("antialias", php_symbol->symbol->antialias, value)
     else IF_SET_STRING("font", php_symbol->symbol->font, value)
     else if ( (STRING_EQUAL("numpoints", property)) ||
-         (STRING_EQUAL("patternlength", property)) ||
          (STRING_EQUAL("imagepath", property)))
