[mapserver-commits] r12583 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Sat Sep 24 16:29:22 EDT 2011
Author: havatv
Date: 2011-09-24 13:29:22 -0700 (Sat, 24 Sep 2011)
New Revision: 12583
   branches/branch-6-0/docs/en/mapfile/template.txt
   trunk/docs/en/mapfile/template.txt
Added the date tag to the template document (#3502).
Modified: branches/branch-6-0/docs/en/mapfile/template.txt
--- branches/branch-6-0/docs/en/mapfile/template.txt	2011-09-24 20:18:12 UTC (rev 12582)
+++ branches/branch-6-0/docs/en/mapfile/template.txt	2011-09-24 20:29:22 UTC (rev 12583)
@@ -13,7 +13,6 @@
 :Contact: jmckenna at gatewaygeomatics.com
 :Revision: $Revision$
 :Date: $Date$
-:Last Updated: 2010/01/25
 .. contents:: Table of Contents
     :depth: 2
@@ -94,6 +93,38 @@
 General
+[date]
+     Outputs the date (as per the web server's clock). The default
+     format is the same as is used by Apache's Common Log format,
+     which looks like:
+         01/Dec/2010:17:34:58 -0800
+     Available arguments:
+     - format=
+         A format string as supported by the standard C strftime()
+         function.  As an example, the default format is defined as:
+             [date format="%d/%b/%Y:%H:%M:%S %z"]
+     - tz=
+         timezone to use for the date returned. Default is
+         "local". Valid values are:
+         - "gmt"
+             Output date will be Greenwich time
+         - "local"
+             Output the time in the web server's local time zone.
+         Additionally or alternatively, the %z and %Z strftime format
+         strings allow the timezone offset or name to be output.
 [version]
      The MapServer version number.
Modified: trunk/docs/en/mapfile/template.txt
--- trunk/docs/en/mapfile/template.txt	2011-09-24 20:18:12 UTC (rev 12582)
+++ trunk/docs/en/mapfile/template.txt	2011-09-24 20:29:22 UTC (rev 12583)
@@ -13,7 +13,6 @@
 :Date: $Date$
     :depth: 2
@@ -94,6 +93,38 @@
 General
+[date]
+     which looks like:
+     - format=
+     - tz=
+         - "gmt"
+         - "local"
 [version]
