[mapserver-commits] r12592 - trunk/mapserver
Wed Sep 28 10:25:10 EDT 2011
Author: aboudreault
Date: 2011-09-28 07:25:10 -0700 (Wed, 28 Sep 2011)
New Revision: 12592
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapows.h
   trunk/mapserver/mapwms.c
   trunk/mapserver/mapwmslayer.c
Added GetLegendGraphic Cascading support
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-09-27 14:22:55 UTC (rev 12591)
+++ trunk/mapserver/HISTORY.TXT	2011-09-28 14:25:10 UTC (rev 12592)
@@ -14,6 +14,9 @@
 Current Version (SVN trunk, 6.1-dev, future 6.2):
+- Added GetLegendGraphic Cascading support (#3923)
 - Rewrite  postgres TIME queries to take advantage of indexes (#3374)
 - Unified OWS requests and applied to WCS (defaults to version 2.0 now) (#3925)
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2011-09-27 14:22:55 UTC (rev 12591)
+++ trunk/mapserver/mapows.h	2011-09-28 14:25:10 UTC (rev 12592)
@@ -382,6 +382,10 @@
  *   mapwmslayer.c
+#define WMS_GETMAP         1
+#define WMS_GETFEATUREINFO 2
+#define WMS_GETLEGENDGRAPHIC 3
 int msInitWmsParamsObj(wmsParamsObj *wmsparams);
 void msFreeWmsParamsObj(wmsParamsObj *wmsparams);
@@ -396,8 +400,8 @@
 MS_DLL_EXPORT char *msWMSGetFeatureInfoURL(mapObj *map, layerObj *lp,
                              int nClickX, int nClickY, int nFeatureCount,
                              const char *pszInfoFormat);
-int msWMSLayerFeatureInfo(mapObj *map, int nOWSLayers, int nClickX, int nClickY,
-                          int nFeatureCount, const char *pszInfoFormat);
+int msWMSLayerExecuteRequest(mapObj *map, int nOWSLayers, int nClickX, int nClickY,
+                             int nFeatureCount, const char *pszInfoFormat, int type);
  *   mapwfs.c
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2011-09-27 14:22:55 UTC (rev 12591)
+++ trunk/mapserver/mapwms.c	2011-09-28 14:25:10 UTC (rev 12592)
@@ -3301,7 +3301,8 @@
   /* It's a valid Cascading WMS GetFeatureInfo request */
   if (wms_layer)
-      return msWMSLayerFeatureInfo(map, numOWSLayers, point.x, point.y, feature_count, info_format);
+      return msWMSLayerExecuteRequest(map, numOWSLayers, point.x, point.y,
+                                      feature_count, info_format, WMS_GETFEATUREINFO);
   if( use_bbox == MS_FALSE ) {
@@ -3675,8 +3676,8 @@
 ** msWMSGetLegendGraphic()
-int msWMSGetLegendGraphic(mapObj *map, int nVersion, char **names,
-                          char **values, int numentries, char *wms_exception_format, owsRequestObj *ows_request)
+int msWMSLegendGraphic(mapObj *map, int nVersion, char **names,
+                       char **values, int numentries, char *wms_exception_format, owsRequestObj *ows_request)
     char *pszLayer = NULL;
     char *pszFormat = NULL;
@@ -3685,10 +3686,11 @@
     int iLayerIndex = -1;
     outputFormatObj *psFormat = NULL;
     imageObj *img=NULL;
-    int i = 0;
+    int j, i = 0;
     int nWidth = -1, nHeight =-1;
     char *pszStyle = NULL;
     char *sld_version = NULL;
+    int wms_layer =  MS_FALSE;
     const char *sldenabled = NULL;
     const char *format_list = NULL;
     layerObj *lp;
@@ -3768,6 +3770,18 @@
                nLayers++;
                lp->status = MS_ON;
                iLayerIndex = i;
+               if (GET_LAYER(map, i)->connectiontype == MS_WMS) {
+                   /* we do not cascade a wms layer if it contains at least
+                    * one class with the property name set */
+                   wms_layer = MS_TRUE;
+                   for (j=0; j<lp->numclasses; j++)
+                       if (lp->class[j]->name != NULL && strlen(lp->class[j]->name)>0) {
+                           wms_layer = MS_FALSE;
+                           break;
          else
            lp->status = MS_OFF;
@@ -3814,7 +3828,12 @@
      msApplyOutputFormat(&(map->outputformat), psFormat, MS_NOOVERRIDE,
                           MS_NOOVERRIDE, MS_NOOVERRIDE );
+     /* It's a valid Cascading WMS GetLegendGraphic request */
+     if (wms_layer)
+         return msWMSLayerExecuteRequest(map, 1, 0, 0,
+                                         0, NULL, WMS_GETLEGENDGRAPHIC);
      /*if STYLE is set, check if it is a valid style (valid = at least one
        of the classes have a the group value equals to the style */
      /*style is only validated when there is only one layer #3411*/
@@ -4279,7 +4298,7 @@
     return msWMSException(map, nVersion, NULL, wms_exception_format);
   if (strcasecmp(request, "GetLegendGraphic") == 0)
-    return msWMSGetLegendGraphic(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams,
+    return msWMSLegendGraphic(map, nVersion, req->ParamNames, req->ParamValues, req->NumParams,
                                  wms_exception_format, ows_request);
   if (strcasecmp(request, "GetStyles") == 0)
Modified: trunk/mapserver/mapwmslayer.c
--- trunk/mapserver/mapwmslayer.c	2011-09-27 14:22:55 UTC (rev 12591)
+++ trunk/mapserver/mapwmslayer.c	2011-09-28 14:25:10 UTC (rev 12592)
@@ -454,8 +454,6 @@
  * Returns a reference to a newly allocated string that should be freed
  * by the caller.
-#define WMS_GETMAP         1
-#define WMS_GETFEATUREINFO 2
 static int
 msBuildWMSLayerURL(mapObj *map, layerObj *lp, int nRequestType,
@@ -466,11 +464,12 @@
 #ifdef USE_WMS_LYR
     char *pszEPSG = NULL;
-    const char *pszVersion, *pszTmp, *pszRequestParam, *pszExceptionsParam, *pszQueryLayers=NULL;
+    const char *pszVersion, *pszTmp, *pszRequestParam, *pszExceptionsParam,
+        *pszLayer=NULL, *pszQueryLayers=NULL;
     rectObj bbox;
     int bbox_width = map->width, bbox_height = map->height;
     int nVersion=OWS_VERSION_NOTSET;
     if (lp->connectiontype != MS_WMS)
         msSetError(MS_WMSCONNERR, "Call supported only for CONNECTIONTYPE WMS",
@@ -549,6 +548,22 @@
+ * For GetLegendGraphic requests, make sure LAYER is included
+    if  (nRequestType == WMS_GETLEGENDGRAPHIC &&
+         strstr(psWMSParams->onlineresource, "LAYER=") == NULL &&
+         strstr(psWMSParams->onlineresource, "layer=") == NULL &&
+         msLookupHashTable(psWMSParams->params, "LAYER") == NULL)
+        pszLayer = msOWSLookupMetadata(&(lp->metadata), "MO", "name");
+        if (pszLayer == NULL) {
+             msSetError(MS_WMSCONNERR, "wms_name not set or WMS Connection String must contain the LAYER parameter to support GetLegendGraphic requests (with name in uppercase).", "msBuildWMSLayerURL()");
+             return MS_FAILURE;
  * Figure the SRS we'll use for the request.
  * - Fetch the map SRS (if it's EPSG)
  * - Check if map SRS is listed in layer wms_srs metadata
@@ -849,6 +864,28 @@
+    else if (nRequestType == WMS_GETLEGENDGRAPHIC)
+        pszRequestParam = "GetLegendGraphic";
+        pszExceptionsParam = msOWSLookupMetadata(&(lp->metadata),
+                                                 "MO", "exceptions_format");
+        if (pszExceptionsParam == NULL)
+            if (nVersion >= OWS_1_1_0)
+                pszExceptionsParam = "application/vnd.ogc.se_inimage";
+            else
+                pszExceptionsParam = "INIMAGE";
+        if (pszLayer) { /* not set in CONNECTION string */
+          msSetWMSParamString(psWMSParams, "LAYER", pszLayer, MS_FALSE);
+        msSetWMSParamString(psWMSParams, "REQUEST", pszRequestParam, MS_FALSE);
+        msSetWMSParamString(psWMSParams, "SRS",     pszEPSG, MS_FALSE);
     else /* if (nRequestType == WMS_GETMAP) */
         char szBuf[100] = "";
@@ -927,7 +964,6 @@
     return pszURL;
  *                          msPrepareWMSLayerRequest()
@@ -986,7 +1022,18 @@
         msFreeWmsParamsObj(&sThisWMSParams);
         return MS_FAILURE;
+    else if (nRequestType == WMS_GETLEGENDGRAPHIC &&
+             msBuildWMSLayerURL(map, lp, WMS_GETLEGENDGRAPHIC,
+                                0, 0, 0, NULL,
+                                NULL, NULL, NULL,
+                                &sThisWMSParams) != MS_SUCCESS )
+        /* an error was already reported. */
+        msFreeWmsParamsObj(&sThisWMSParams);
  * Check if the request is empty, perhaps due to reprojection problems
  * or wms_extents restrictions.
@@ -1336,6 +1383,7 @@
         pasReqInfo[(*numRequests)].nLayerId = nLayerId;
         pasReqInfo[(*numRequests)].pszGetUrl = pszURL;
         pszURL = NULL;
         pasReqInfo[(*numRequests)].pszHTTPCookieData = pszHTTPCookieData;
         pszHTTPCookieData = NULL;
@@ -1365,7 +1413,7 @@
         (*numRequests)++;
  * Replace contents of psLastWMSParams with sThisWMSParams
  * unless bForceSeparateRequest is set in which case we make it empty
@@ -1642,8 +1690,8 @@
 #ifdef USE_WMS_LYR
@@ -1662,7 +1710,9 @@
         if (GET_LAYER(map,map->layerorder[i])->status == MS_ON)
-            if (msPrepareWMSLayerRequest(map->layerorder[i], map, GET_LAYER(map,map->layerorder[i]), WMS_GETFEATUREINFO,
+            if (type == WMS_GETFEATUREINFO &&
+                msPrepareWMSLayerRequest(map->layerorder[i], map, GET_LAYER(map,map->layerorder[i]),
+                                         WMS_GETFEATUREINFO,
                                          MS_WMS, &sLastWMSParams,
                                          nClickX, nClickY, nFeatureCount, pszInfoFormat,
                                          pasReqInfo, &numReq) == MS_FAILURE)
@@ -1671,6 +1721,16 @@
                 msFree(pasReqInfo);
                 return MS_FAILURE;
+            else if (msPrepareWMSLayerRequest(map->layerorder[i], map, GET_LAYER(map,map->layerorder[i]),
+                                           WMS_GETLEGENDGRAPHIC,
+                                           MS_WMS, &sLastWMSParams,
+                                           0, 0, 0, NULL,
+                                           pasReqInfo, &numReq) == MS_FAILURE)
+                     msFreeWmsParamsObj(&sLastWMSParams);
+                     msFree(pasReqInfo);
@@ -1719,7 +1779,7 @@
         else
             msSetError(MS_IOERR, "'%s'.",
-                       "msWMSLayerFeatureInfo()", pasReqInfo[0].pszOutputFile);
+                       "msWMSLayerExecuteRequest()", pasReqInfo[0].pszOutputFile);
             return MS_FAILURE;
@@ -1740,7 +1800,7 @@
  * WMS CONNECTION Support not included...
   msSetError(MS_WMSCONNERR, "WMS CLIENT CONNECTION support is not available.",
-             "msWMSLayerFeatureInfo()");
+             "msWMSLayerExecuteRequest()");
   return(MS_FAILURE);
 #endif /* USE_WMS_LYR */
