[mapserver-commits] r12599 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Wed Sep 28 19:25:04 EDT 2011
Author: havatv
Date: 2011-09-28 16:25:04 -0700 (Wed, 28 Sep 2011)
New Revision: 12599
   branches/branch-6-0/docs/en/mapfile/web.txt
   trunk/docs/en/mapfile/web.txt
Supplemented the description of TEMPATE in the web document (#3432).
Modified: branches/branch-6-0/docs/en/mapfile/web.txt
--- branches/branch-6-0/docs/en/mapfile/web.txt	2011-09-28 22:54:04 UTC (rev 12598)
+++ branches/branch-6-0/docs/en/mapfile/web.txt	2011-09-28 23:25:04 UTC (rev 12599)
@@ -180,9 +180,16 @@
    pair: WEB; TEMPLATE
 TEMPLATE [filename|url]
-    Template file or URL to use in presenting the results to the user in an
-    interactive mode (i.e. map generates map and so on ... )
+    Template file or URL to use in presenting the results to the user
+    in an interactive mode (i.e. map generates map and so on ... ).
+    URL is not a remote file, rather a template.  For example:
+    .. code-block:: mapfile
+       TEMPLATE 'http://someurl/somescript.cgi?mapext=[mapext]'
 .. index::
    pair: WEB; VALIDATION
Modified: trunk/docs/en/mapfile/web.txt
--- trunk/docs/en/mapfile/web.txt	2011-09-28 22:54:04 UTC (rev 12598)
+++ trunk/docs/en/mapfile/web.txt	2011-09-28 23:25:04 UTC (rev 12599)
    pair: WEB; TEMPLATE
 .. index::
