[mapserver-commits] r12604 - branches/branch-6-0/docs/en/input/vector branches/branch-6-0/docs/en/mapfile branches/branch-6-0/docs/en/mapscript branches/branch-6-0/docs/en/mapscript/php branches/branch-6-0/docs/en/ogc trunk/docs/en/input/vector trunk/docs/en/mapfile trunk/docs/en/mapscript trunk/docs/en/mapscript/php trunk/docs/en/ogc
Thu Sep 29 11:46:25 EDT 2011
Author: havatv
Date: 2011-09-29 08:46:24 -0700 (Thu, 29 Sep 2011)
New Revision: 12604
   branches/branch-6-0/docs/en/input/vector/oracle.txt
   branches/branch-6-0/docs/en/mapfile/layer.txt
   branches/branch-6-0/docs/en/mapscript/mapscript.txt
   branches/branch-6-0/docs/en/mapscript/php/index.txt
   branches/branch-6-0/docs/en/ogc/filter_encoding.txt
   branches/branch-6-0/docs/en/ogc/wcs_format.txt
   branches/branch-6-0/docs/en/ogc/wcs_server.txt
   branches/branch-6-0/docs/en/ogc/wfs_server.txt
   branches/branch-6-0/docs/en/ogc/wms_server.txt
   branches/branch-6-0/docs/en/ogc/wms_time.txt
   trunk/docs/en/input/vector/oracle.txt
   trunk/docs/en/mapfile/layer.txt
   trunk/docs/en/mapscript/mapscript.txt
   trunk/docs/en/mapscript/php/index.txt
   trunk/docs/en/ogc/filter_encoding.txt
   trunk/docs/en/ogc/wcs_format.txt
   trunk/docs/en/ogc/wcs_server.txt
   trunk/docs/en/ogc/wfs_server.txt
   trunk/docs/en/ogc/wms_server.txt
   trunk/docs/en/ogc/wms_time.txt
Updated documentation to reflect the deprecation of the DUMP parameter (#3830).
Modified: branches/branch-6-0/docs/en/input/vector/oracle.txt
--- branches/branch-6-0/docs/en/input/vector/oracle.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/input/vector/oracle.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -308,7 +308,6 @@
         CONNECTIONTYPE oraclespatial
         CONNECTION "user/pwd"
         DATA "GEOMETRIE FROM KWADRANTEN USING SRID 90112"
-        DUMP TRUE
         CLASS
             STYLE
                 OUTLINECOLOR 0 0 0
@@ -357,4 +356,4 @@
 .. _`Oracle Spatial FAQ`: http://www.orafaq.com/faqsdo.htm
-.. _`instant client`: http://www.oracle.com/technology/software/tech/oci/instantclient/index.html
\ No newline at end of file
+.. _`instant client`: http://www.oracle.com/technology/software/tech/oci/instantclient/index.html
Modified: branches/branch-6-0/docs/en/mapfile/layer.txt
--- branches/branch-6-0/docs/en/mapfile/layer.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/mapfile/layer.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -185,6 +185,10 @@
     Switch to allow MapServer to return data in GML format. Useful when
     used with WMS GetFeatureInfo operations. "false" by default.
+    .. deprecated:: 6.0 `LAYER` `METADATA` is used instead.
+    .. seealso:: :ref:`WMS_SERVER`
 .. index::
    pair: LAYER; EXTENT
Modified: branches/branch-6-0/docs/en/mapscript/mapscript.txt
--- branches/branch-6-0/docs/en/mapscript/mapscript.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/mapscript/mapscript.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -903,6 +903,8 @@
     Switch to allow mapserver to return data in GML format.  MS_TRUE or
     MS_FALSE.  Default is MS_FALSE.
+    .. deprecated:: 6.0 metadata is used instead.
 extent : rectObj_
     optional limiting extent for layer features.
Modified: branches/branch-6-0/docs/en/mapscript/php/index.txt
--- branches/branch-6-0/docs/en/mapscript/php/index.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/mapscript/php/index.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -808,7 +808,7 @@
 int             connectiontype      read-only, use setConnectionType() to set it
 string          data
 int             debug
-int             dump
+int             dump                deprecated since 6.0
 string          filteritem
 string          footer
 gridObj         grid                only available on a layer defined as grid (MS_GRATICULE)
Modified: branches/branch-6-0/docs/en/ogc/filter_encoding.txt
--- branches/branch-6-0/docs/en/ogc/filter_encoding.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/ogc/filter_encoding.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -265,7 +265,6 @@
 	    "init=epsg:4326"
 	  END
 	  LABELITEM    'NAME'
-	  DUMP TRUE
 	  CLASS
 	    NAME       'World Cities'
 	    STYLE
Modified: branches/branch-6-0/docs/en/ogc/wcs_format.txt
--- branches/branch-6-0/docs/en/ogc/wcs_format.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/ogc/wcs_format.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -50,9 +50,6 @@
         EXTENSION "ecw"
     END
-The keyword "DUMP" must be set to true to allow the data to download during a
-GetCoverage request.
 .. code-block:: mapfile
     LAYER
@@ -61,7 +58,6 @@
         TYPE RASTER
         PROCESSING "SCALE=AUTO"
         UNITS Meters
-        DUMP TRUE
         TILEINDEX "MapServer/wcs/landsat7/l7mosaic15m.shp"
         TILEITEM "Location"
         METADATA
@@ -106,7 +102,6 @@
         TYPE RASTER
         UNITS Meters
-        DUMP TRUE
         TILEINDEX "MapServer/wcs/orthospot/spot.shp"
         TILEITEM "Location"
         METADATA
@@ -127,7 +122,6 @@
     - Layer Name = Create a short name for the data
     - Layer Type = Raster
-    - Layer Dump = True
 The following examples further demonstrate how WCS can be implemented and also
 how to create WCS containing layers with a temporal dimension (see NetCDF
@@ -151,7 +145,7 @@
       EXTENSION "tif"
     END
-and in the corresponding layer to specify the keyword "DUMP" to be true
+and the corresponding layer
@@ -159,7 +153,6 @@
       NAME "srtm"
       STATUS OFF
       TYPE RASTER
-      DUMP TRUE
       DATA "srtm.tif"
       PROJECTION
         "init=epsg:4326"
@@ -297,7 +290,6 @@
       NAME 'TempData'
       STATUS OFF
       TYPE RASTER
-      DUMP TRUE
       TILEINDEX 'time_idx'
       PROJECTION
         "init=epsg:4326"
Modified: branches/branch-6-0/docs/en/ogc/wcs_server.txt
--- branches/branch-6-0/docs/en/ogc/wcs_server.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/ogc/wcs_server.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -77,7 +77,6 @@
   (e.g GeoTIFF, Erdas Imagine, ...)
 - LAYER NAME must be set
 - LAYER TYPE is set to RASTER
-- LAYER DUMP parameter set to TRUE
 - WEB metadata "wcs_enable_request" must be set
 - WEB metadata "wcs_label" must be set
 - LAYER metadata "wcs_label" must be set
@@ -156,7 +155,6 @@
           PROJECTION
             "init=epsg:42304"
           END
-          DUMP TRUE ### required
         END
       END # Map File
Modified: branches/branch-6-0/docs/en/ogc/wfs_server.txt
--- branches/branch-6-0/docs/en/ogc/wfs_server.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/ogc/wfs_server.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -99,8 +99,6 @@
 - LAYER TYPE is one of: LINE, POINT, POLYGON
 - The "wfs_onlineresource" metadata:
   The wfs_onlineresource metadata is set in the map's web object
@@ -199,7 +197,6 @@
           PROJECTION
             "init=epsg:4326"
           END
-          DUMP TRUE             ## REQUIRED
           CLASS
             NAME 'World Continents'
             STYLE
Modified: branches/branch-6-0/docs/en/ogc/wms_server.txt
--- branches/branch-6-0/docs/en/ogc/wms_server.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/ogc/wms_server.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -172,7 +172,6 @@
   - Layers set to STATUS DEFAULT will always be sent to the client.
   - Layers set to STATUS ON or STATUS OFF can be requested by the client.
 - Layer TEMPLATE (required for GetFeatureInfo requests - see :ref:`template`)
-- Layer DUMP TRUE (only required for GetFeatureInfo GML requests)
 Let's go through each of these parameters in more detail:
@@ -316,12 +315,10 @@
   requests of type "text/html" you should also set the layer HEADER
   and FOOTER parameters.
-  For GetFeatureInfo requests of GML you must set the layer to DUMP
-  TRUE in the mapfile.  As of MapServer 4.6 you must set the *gml_\**
-  metadata for the layer attributes to be served (see the Layer Object
-  metadata in the Reference Section later in this document).  To
-  include geometry, gml_geometries and gml_[name]_type has to be
-  specified.
+  As of MapServer 4.6 you must set the *gml_\** metadata for the layer
+  attributes to be served (see the Layer Object metadata in the
+  Reference Section later in this document).  To include geometry,
+  gml_geometries and gml_[name]_type has to be specified.
   Here are working examples of GetFeatureInfo requests: `text/plain`_
   / `text/html`_ / `gml`_ (for gml, your browser might ask you to save
@@ -982,8 +979,6 @@
     call the server with INFO_FORMAT=text/html.
   - If not specified, MapServer by default has text/plain and GML implemented.
-  - Note that for GML to be returned the layer in the wms-server mapfile must
-    be set to DUMP TRUE.
 **wms_fees**
Modified: branches/branch-6-0/docs/en/ogc/wms_time.txt
--- branches/branch-6-0/docs/en/ogc/wms_time.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ branches/branch-6-0/docs/en/ogc/wms_time.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -243,6 +243,7 @@
        "wms_timeextent" "2003-08-01/2006-12-31/PT5M"
        "wms_timeitem" "datetime" #column in postgis table of type timestamp
        "wms_timedefault" "2006-06-23T03:10:00Z"
+       "wms_enable_request" "*"
      END
      CONNECTION "dbname=postgis host=10.10.10.20"
      CONNECTIONTYPE postgis
@@ -254,7 +255,6 @@
      TYPE RASTER
      STATUS ON
      DEBUG ON
-     DUMP TRUE
      PROJECTION
        "init=epsg:4326"
      END
Modified: trunk/docs/en/input/vector/oracle.txt
--- trunk/docs/en/input/vector/oracle.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/input/vector/oracle.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -308,7 +308,6 @@
-        DUMP TRUE
         CLASS
             STYLE
                 OUTLINECOLOR 0 0 0
@@ -357,4 +356,4 @@
Modified: trunk/docs/en/mapfile/layer.txt
--- trunk/docs/en/mapfile/layer.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/mapfile/layer.txt	2011-09-29 15:46:24 UTC (rev 12604)
 .. index::
    pair: LAYER; EXTENT
Modified: trunk/docs/en/mapscript/mapscript.txt
--- trunk/docs/en/mapscript/mapscript.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/mapscript/mapscript.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -903,6 +903,8 @@
 extent : rectObj_
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/mapscript/php/index.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -808,7 +808,7 @@
 string          data
 int             debug
-int             dump
 string          filteritem
 string          footer
Modified: trunk/docs/en/ogc/filter_encoding.txt
--- trunk/docs/en/ogc/filter_encoding.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/ogc/filter_encoding.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -265,7 +265,6 @@
 	    "init=epsg:4326"
 	  END
 	  LABELITEM    'NAME'
-	  DUMP TRUE
 	  CLASS
 	    NAME       'World Cities'
 	    STYLE
Modified: trunk/docs/en/ogc/wcs_format.txt
--- trunk/docs/en/ogc/wcs_format.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/ogc/wcs_format.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -50,9 +50,6 @@
         EXTENSION "ecw"
     END
     LAYER
@@ -61,7 +58,6 @@
         TYPE RASTER
         UNITS Meters
-        DUMP TRUE
         TILEITEM "Location"
         METADATA
@@ -106,7 +102,6 @@
         TYPE RASTER
         UNITS Meters
-        DUMP TRUE
         TILEITEM "Location"
         METADATA
@@ -127,7 +122,6 @@
@@ -151,7 +145,7 @@
       EXTENSION "tif"
     END
@@ -159,7 +153,6 @@
       NAME "srtm"
       STATUS OFF
       TYPE RASTER
-      DUMP TRUE
       DATA "srtm.tif"
       PROJECTION
         "init=epsg:4326"
@@ -297,7 +290,6 @@
       NAME 'TempData'
       STATUS OFF
       TYPE RASTER
-      DUMP TRUE
       PROJECTION
         "init=epsg:4326"
Modified: trunk/docs/en/ogc/wcs_server.txt
--- trunk/docs/en/ogc/wcs_server.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/ogc/wcs_server.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -77,7 +77,6 @@
@@ -156,7 +155,6 @@
           PROJECTION
             "init=epsg:42304"
           END
         END
       END # Map File
Modified: trunk/docs/en/ogc/wfs_server.txt
--- trunk/docs/en/ogc/wfs_server.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/ogc/wfs_server.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -99,8 +99,6 @@
@@ -199,7 +197,6 @@
           PROJECTION
             "init=epsg:4326"
           END
           CLASS
             STYLE
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/ogc/wms_server.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -172,7 +172,6 @@
-  specified.
@@ -982,8 +979,6 @@
 **wms_fees**
Modified: trunk/docs/en/ogc/wms_time.txt
--- trunk/docs/en/ogc/wms_time.txt	2011-09-29 15:31:44 UTC (rev 12603)
+++ trunk/docs/en/ogc/wms_time.txt	2011-09-29 15:46:24 UTC (rev 12604)
@@ -243,6 +243,7 @@
      END
@@ -254,7 +255,6 @@
      TYPE RASTER
      STATUS ON
      DEBUG ON
-     DUMP TRUE
      PROJECTION
        "init=epsg:4326"
      END
