[mapserver-commits] r12937 - trunk/mapserver/mapcache/src
Mon Jan 2 04:31:04 EST 2012
Author: tbonfort
Date: 2012-01-02 01:31:04 -0800 (Mon, 02 Jan 2012)
New Revision: 12937
   trunk/mapserver/mapcache/src/cache_tiff.c
do some more error checking in tiff cache, use apr_stat instead of opening the tiff file to check for existence
Modified: trunk/mapserver/mapcache/src/cache_tiff.c
--- trunk/mapserver/mapcache/src/cache_tiff.c	2011-12-30 11:32:59 UTC (rev 12936)
+++ trunk/mapserver/mapcache/src/cache_tiff.c	2012-01-02 09:31:04 UTC (rev 12937)
@@ -284,7 +284,7 @@
 static int _mapcache_cache_tiff_get(mapcache_context *ctx, mapcache_tile *tile) {
    char *filename;
-   TIFF *hTIFF;
+   TIFF *hTIFF = NULL;
    int rv;
    _mapcache_cache_tiff_tile_key(ctx, tile, &filename);
    mapcache_cache_tiff *dcache = (mapcache_cache_tiff*)tile->tileset->cache;
@@ -489,7 +489,7 @@
 static void _mapcache_cache_tiff_set(mapcache_context *ctx, mapcache_tile *tile) {
 #ifdef USE_TIFF_WRITE
    char *filename;
-   TIFF *hTIFF;
    int rv;
    int create;
    char errmsg[120];
@@ -554,27 +554,15 @@
-    * aquire a lock on the tiff file. This lock does not work for multiple threads of
-    * a same process, but should work on network filesystems.
-    * we previously aquired a thread lock so we should be ok here
+    * aquire a lock on the tiff file.
    while(mapcache_lock_or_wait_for_resource(ctx,filename) == MAPCACHE_FALSE);
-   apr_file_t *ftiff;
-   rv = apr_file_open(&ftiff,filename,APR_FOPEN_READ|APR_FOPEN_CREATE,APR_OS_DEFAULT,ctx->pool);
-   if(rv != APR_SUCCESS) {
-      ctx->set_error(ctx, 500,  "failed to remove existing file %s: %s",filename, apr_strerror(rv,errmsg,120));
-      return; /* we could not delete the file */
+   /* check if the tiff file exists already */
    apr_finfo_t finfo;
-   rv = apr_file_info_get(&finfo, APR_FINFO_SIZE, ftiff);
-    * check if the file exists by looking at its size
-   if(finfo.size) {
+   rv = apr_stat(&finfo,filename,0,ctx->pool);
+   if(!APR_STATUS_IS_ENOENT(rv)) {
       hTIFF = MyTIFFOpen(filename,"r+");
       create = 0;
    } else {
@@ -583,9 +571,7 @@
    if(!hTIFF) {
       ctx->set_error(ctx,500,"failed to open/create tiff file %s\n",filename);
-      mapcache_unlock_resource(ctx,filename);
-      apr_file_close(ftiff);
-      return;
+      goto close_tiff;
@@ -696,19 +682,30 @@
    tiff_off = tiff_offy * ntilesx + tiff_offx;
-   TIFFWriteEncodedTile(hTIFF, tiff_off, rgb, tilew*tileh*3);
+   rv = TIFFWriteEncodedTile(hTIFF, tiff_off, rgb, tilew*tileh*3);
    free(rgb);
-   TIFFWriteCheck( hTIFF, 1, "cache_set()");
+   if(!rv) {
+      ctx->set_error(ctx,500,"failed TIFFWriteEncodedTile to %s",filename);
+      goto close_tiff;
+   rv = TIFFWriteCheck( hTIFF, 1, "cache_set()");
+   if(!rv) {
+      ctx->set_error(ctx,500,"failed TIFFWriteCheck %s",filename);
+      goto close_tiff;
-   if(create)
-      TIFFWriteDirectory(hTIFF);
-   TIFFFlush( hTIFF );
+   if(create) {
+      rv = TIFFWriteDirectory(hTIFF);
+      if(!rv) {
+         ctx->set_error(ctx,500,"failed TIFFWriteDirectory to %s",filename);
+         goto close_tiff;
-   MyTIFFClose(hTIFF);
+close_tiff:
+   if(hTIFF)
+      MyTIFFClose(hTIFF);
 #else
    ctx->set_error(ctx,500,"tiff write support disabled by default");
 #endif
