[mapserver-commits] r12946 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Tue Jan 3 07:11:14 EST 2012
Author: havatv
Date: 2012-01-03 04:11:14 -0800 (Tue, 03 Jan 2012)
New Revision: 12946
   branches/branch-6-0/docs/en/mapfile/label.txt
   branches/branch-6-0/docs/en/mapfile/map.txt
   branches/branch-6-0/docs/en/mapfile/outputformat.txt
   branches/branch-6-0/docs/en/mapfile/scalebar.txt
   branches/branch-6-0/docs/en/mapfile/style.txt
   branches/branch-6-0/docs/en/mapfile/symbol.txt
   trunk/docs/en/mapfile/label.txt
   trunk/docs/en/mapfile/map.txt
   trunk/docs/en/mapfile/outputformat.txt
   trunk/docs/en/mapfile/scalebar.txt
   trunk/docs/en/mapfile/style.txt
   trunk/docs/en/mapfile/symbol.txt
Added index entries (#4001) - join, label, map, outputformat, scalebar, style, symbol
Modified: branches/branch-6-0/docs/en/mapfile/label.txt
--- branches/branch-6-0/docs/en/mapfile/label.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ branches/branch-6-0/docs/en/mapfile/label.txt	2012-01-03 12:11:14 UTC (rev 12946)
@@ -423,6 +423,12 @@
 .. index::
    pair: LABEL; TYPE
+.. index::
+   triple: LABEL; TYPE; bitmap
+.. index::
+   triple: LABEL; TYPE; truetype
 TYPE [bitmap|truetype]
     Type of font to use. Generally bitmap fonts are faster to draw
     then TrueType fonts. However, TrueType fonts are scalable and
Modified: branches/branch-6-0/docs/en/mapfile/map.txt
--- branches/branch-6-0/docs/en/mapfile/map.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ branches/branch-6-0/docs/en/mapfile/map.txt	2012-01-03 12:11:14 UTC (rev 12946)
@@ -283,9 +283,21 @@
 .. index::
    pair: MAP; IMAGETYPE
+.. index::
+   triple: MAP; IMAGETYPE; jpeg
+.. index::
+   triple: MAP; IMAGETYPE; pdf
+.. index::
+   triple: MAP; IMAGETYPE; png
+.. index::
+   triple: MAP; IMAGETYPE; svg
 .. _imagetype:
-IMAGETYPE [png|jpeg|pdf|...|userdefined]
+IMAGETYPE [jpeg|pdf|png|svg|...|userdefined]
     Output format (raster or vector) to generate.  The name used here
     must match the 'NAME' of a user defined or internally available
     :ref:`OUTPUTFORMAT`. For a complete list of available
@@ -441,7 +453,28 @@
 .. index::
    pair: MAP; UNITS
-UNITS [feet|inches|kilometers|meters|miles|nauticalmiles|dd]
+.. index::
+   triple: MAP; UNITS; dd
+.. index::
+   triple: MAP; UNITS; feet
+.. index::
+   triple: MAP; UNITS; inches
+.. index::
+   triple: MAP; UNITS; kilometers
+.. index::
+   triple: MAP; UNITS; meters
+.. index::
+   triple: MAP; UNITS; miles
+.. index::
+   triple: MAP; UNITS; nauticalmiles
+UNITS [dd|feet|inches|kilometers|meters|miles|nauticalmiles]
     Units of the map coordinates. Used for scalebar and scale
     computations.  `Nauticalmiles` was added in MapServer 5.6.
Modified: branches/branch-6-0/docs/en/mapfile/outputformat.txt
--- branches/branch-6-0/docs/en/mapfile/outputformat.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ branches/branch-6-0/docs/en/mapfile/outputformat.txt	2012-01-03 12:11:14 UTC (rev 12946)
@@ -243,21 +243,48 @@
     for non-raster formats like Flash. Not all formats support all
     combinations. For instance GD supports only PC256. (optional)
+    .. index::
+       triple: OUTPUTFORMAT; IMAGEMODE; PC256
     - PC256: Produced a pseudocolored result with up to 256 colors in
       the palette (legacy MapServer mode). Only supported for GD/GIF
       and GD/PNG.
+    .. index::
+       triple: OUTPUTFORMAT; IMAGEMODE; RGB
     - RGB: Render in 24bit Red/Green/Blue mode. Supports all colors
       but does not support transparency.
+    .. index::
+       triple: OUTPUTFORMAT; IMAGEMODE; RGBA
     - RGBA: Render in 32bit Red/Green/Blue/Alpha mode. Supports all
       colors, and alpha based transparency. All features are rendered
       against an initially transparent background.
+    .. index::
+       triple: OUTPUTFORMAT; IMAGEMODE; BYTE
     - BYTE:  Render raw 8bit pixel values (no presentation).  Only
       works for RASTER layers (through GDAL) and WMS layers currently.
+    .. index::
+       triple: OUTPUTFORMAT; IMAGEMODE; INT16
     - INT16: Render raw 16bit signed pixel values (no presentation).
       Only works for RASTER layers (through GDAL) and WMS layers currently.
+    .. index::
+       triple: OUTPUTFORMAT; IMAGEMODE; FLOAT32
     - FLOAT32: Render raw 32bit floating point pixel values
       (no presentation). Only works for RASTER layers (through GDAL)
+    .. index::
+       triple: OUTPUTFORMAT; IMAGEMODE; FEATURE
     - FEATURE: Output is a non-image result, such as features written
       via templates or OGR.
Modified: branches/branch-6-0/docs/en/mapfile/scalebar.txt
--- branches/branch-6-0/docs/en/mapfile/scalebar.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ branches/branch-6-0/docs/en/mapfile/scalebar.txt	2012-01-03 12:11:14 UTC (rev 12946)
@@ -109,6 +109,24 @@
 .. index::
    pair: SCALEBAR; UNITS
+.. index::
+   triple: SCALEBAR; UNITS; feet
+.. index::
+   triple: SCALEBAR; UNITS; inches
+.. index::
+   triple: SCALEBAR; UNITS; kilometers
+.. index::
+   triple: SCALEBAR; UNITS; meters
+.. index::
+   triple: SCALEBAR; UNITS; miles
+.. index::
+   triple: SCALEBAR; UNITS; nauticalmiles
 UNITS [feet|inches|kilometers|meters|miles|nauticalmiles]
     Output scalebar units, default is miles. Used in conjunction with the
     map's units to develop the actual graphic. Note that decimal degrees
Modified: branches/branch-6-0/docs/en/mapfile/style.txt
--- branches/branch-6-0/docs/en/mapfile/style.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ branches/branch-6-0/docs/en/mapfile/style.txt	2012-01-03 12:11:14 UTC (rev 12946)
@@ -156,6 +156,24 @@
 .. index::
    pair: STYLE; GEOMTRANSFORM
+.. index::
+   triple: STYLE; GEOMTRANSFORM; bbox
+.. index::
+   triple: STYLE; GEOMTRANSFORM; end
+.. index::
+   triple: STYLE; GEOMTRANSFORM; labelpnt
+.. index::
+   triple: STYLE; GEOMTRANSFORM; labelpoly
+.. index::
+   triple: STYLE; GEOMTRANSFORM; start
+.. index::
+   triple: STYLE; GEOMTRANSFORM; vertices
 GEOMTRANSFORM [bbox|end|labelpnt|labelpoly|start|vertices]
     Used to indicate that the current feature will be transformed
     before the actual style is applied. Introduced in version 5.4.
@@ -182,6 +200,15 @@
 .. index::
    pair: STYLE; LINECAP
+.. index::
+   triple: STYLE; LINECAP; butt
+.. index::
+   triple: STYLE; LINECAP; round
+.. index::
+   triple: STYLE; LINECAP; square
 LINECAP [butt|round|square]
     Sets the line cap type for lines. Default is `round`.  See
     :ref:`sym_construction` for explanation and examples.
@@ -191,6 +218,15 @@
 .. index::
    pair: STYLE; LINEJOIN
+.. index::
+   triple: STYLE; LINEJOIN; round
+.. index::
+   triple: STYLE; LINEJOIN; miter
+.. index::
+   triple: STYLE; LINEJOIN; bevel
 LINEJOIN [round|miter|bevel]
     Sets the line join type for lines. Default is `round`.  See
Modified: branches/branch-6-0/docs/en/mapfile/symbol.txt
--- branches/branch-6-0/docs/en/mapfile/symbol.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ branches/branch-6-0/docs/en/mapfile/symbol.txt	2012-01-03 12:11:14 UTC (rev 12946)
@@ -29,20 +29,25 @@
   :ref:`Construction of Cartographic Symbols <sym_construction>`
   document.
 .. index::
-    pair: ANTIALIAS; SYMBOL
+   pair: SYMBOL; ANTIALIAS
 ANTIALIAS [true|false]
     Should TrueType fonts be antialiased.  Only useful for GD (gif)
     rendering.  Default is false.  Has no effect for the other
     renderers (where anti-aliasing can not be turned off).
+.. index::
+   pair: SYMBOL; CHARACTER
 CHARACTER [char]
     Character used to reference a particular TrueType font character.
     You'll need to figure out the mapping from the keyboard character
     to font character.
+.. index::
+   pair: SYMBOL; FILLED
 FILLED [true|false]
     If `true`, the symbol will be filled with a user defined color
     (using :ref:`STYLE` `COLOR`).  Default is `false`.
@@ -56,19 +61,27 @@
     treated as lines (the lines can be given a color using
     :ref:`style` `COLOR` and a width using :ref:`style` `WIDTH`).
+.. index::
+   pair: SYMBOL; FONT
 FONT [string]
     Name of TrueType font to use as defined in the :ref:`FONTSET`.
 GAP [int]
     This keyword has been moved to :ref:`STYLE` in version 6.0.
     .. deprecated:: 6.0
+.. index::
+   pair: SYMBOL; IAMGE
 IMAGE [string]
     Image (GIF or PNG) to use as a marker or brush for type `pixmap`
     symbols.
+.. index::
+   pair: SYMBOL; NAME
 NAME [string]
     Alias for the symbol.  To be used in :ref:`CLASS` :ref:`STYLE`
     objects.
@@ -93,6 +106,9 @@
     .. deprecated:: 6.0
+.. index::
+   pair: SYMBOL; POINTS
 POINTS [x y] [x y] ... END
     Signifies the start of a sequence of points that make up a symbol
@@ -124,6 +140,9 @@
     .. deprecated:: 5.0
+.. index::
+   pair: SYMBOL; TRANSPARENT
 TRANSPARENT [color index]
     Sets a transparent color for the input image for pixmap symbols,
     or determines whether all shade symbols should have a transparent
@@ -138,6 +157,27 @@
       The default (AGG) renderer does not support the `TRANSPARENT`
       parameter. It is supported by the GD renderer (GIF).
+.. index::
+   pair: SYMBOL; TYPE
+.. index::
+   triple: SYMBOL; TYPE; ellipse
+.. index::
+   triple: SYMBOL; TYPE; hatch
+.. index::
+   triple: SYMBOL; TYPE; pixmap
+.. index::
+   triple: SYMBOL; TYPE; simple
+.. index::
+   triple: SYMBOL; TYPE; truetype
+.. index::
+   triple: SYMBOL; TYPE; vector
 TYPE [ellipse|hatch|pixmap|simple|truetype|vector]
     -  `ellipse`: radius values in the x and y directions define an ellipse.
     -  `hatch`: produces hatched lines throughout the (polygon) shape.
Modified: trunk/docs/en/mapfile/label.txt
--- trunk/docs/en/mapfile/label.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ trunk/docs/en/mapfile/label.txt	2012-01-03 12:11:14 UTC (rev 12946)
 .. index::
    pair: LABEL; TYPE
+.. index::
+.. index::
Modified: trunk/docs/en/mapfile/map.txt
--- trunk/docs/en/mapfile/map.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ trunk/docs/en/mapfile/map.txt	2012-01-03 12:11:14 UTC (rev 12946)
 .. index::
+.. index::
+.. index::
+.. index::
+.. index::
 .. _imagetype:
 .. index::
    pair: MAP; UNITS
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
Modified: trunk/docs/en/mapfile/outputformat.txt
--- trunk/docs/en/mapfile/outputformat.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ trunk/docs/en/mapfile/outputformat.txt	2012-01-03 12:11:14 UTC (rev 12946)
+    .. index::
       and GD/PNG.
+    .. index::
+    .. index::
+    .. index::
+    .. index::
+    .. index::
+    .. index::
Modified: trunk/docs/en/mapfile/scalebar.txt
--- trunk/docs/en/mapfile/scalebar.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ trunk/docs/en/mapfile/scalebar.txt	2012-01-03 12:11:14 UTC (rev 12946)
 .. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ trunk/docs/en/mapfile/style.txt	2012-01-03 12:11:14 UTC (rev 12946)
 .. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
@@ -229,6 +247,15 @@
 .. index::
+.. index::
+.. index::
+.. index::
@@ -238,6 +265,15 @@
 .. index::
+.. index::
+.. index::
+.. index::
Modified: trunk/docs/en/mapfile/symbol.txt
--- trunk/docs/en/mapfile/symbol.txt	2012-01-03 10:18:57 UTC (rev 12945)
+++ trunk/docs/en/mapfile/symbol.txt	2012-01-03 12:11:14 UTC (rev 12946)
@@ -31,7 +31,7 @@
 .. index::
-    pair: ANCHORPOINT; SYMBOL
+   pair: SYMBOL; ANCHORPOINT
 ANCHORPOINT [x] [y]
     Used to specify the location (within the symbol) that is to be
@@ -57,18 +57,24 @@
     .. versionadded:: 6.2
 .. index::
+.. index::
 CHARACTER [char]
     to font character.
+.. index::
 FILLED [true|false]
@@ -82,19 +88,27 @@
+.. index::
 FONT [string]
 GAP [int]
     .. deprecated:: 6.0
+.. index::
+   pair: SYMBOL; IMAGE
 IMAGE [string]
     symbols.
+.. index::
 NAME [string]
     objects.
@@ -119,6 +133,9 @@
     .. deprecated:: 6.0
+.. index::
@@ -150,6 +167,9 @@
     .. deprecated:: 5.0
+.. index::
@@ -164,6 +184,27 @@
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
