[mapserver-commits] r12950 - trunk/docs/en/mapfile
Tue Jan 3 09:30:43 EST 2012
Author: havatv
Date: 2012-01-03 06:30:43 -0800 (Tue, 03 Jan 2012)
New Revision: 12950
Removed:
   trunk/docs/en/mapfile/Include.txt
updated filename
Deleted: trunk/docs/en/mapfile/Include.txt
--- trunk/docs/en/mapfile/Include.txt	2012-01-03 14:30:15 UTC (rev 12949)
+++ trunk/docs/en/mapfile/Include.txt	2012-01-03 14:30:43 UTC (rev 12950)
@@ -1,101 +0,0 @@
-.. index::
-   single: Include
-.. _include:
- INCLUDE
-.. index::
-    pair: INCLUDE; MAP
-When this directive is encountered parsing switches to the included file
-immediately. As a result the included file can be comprised of any valid
-mapfile syntax. For example:
-.. code-block:: mapfile
-    INCLUDE 'myLayer.map'
-Performance does not seem to be seriously impacted with limited use, however
-in high performance instances you may want to use includes in a pre-processing
-step to build a production mapfile. The C pre-processor can also be used
-(albeit with a different syntax) and is far more powerful.
-Notes
-- Supported in versions 4.10 and higher.
-- The name of the file to be included **MUST be quoted** (single or
-  double quotes).
-- Includes may be nested, up to 5 deep.
-- File location can be given as a full path to the file, or (in MapServer >=
-  4.10.1) as a path relative to the mapfile.
-- Debugging can be problematic because:
-  1) the file an error occurs in does not get output to the user
-  2) the line number counter is not reset for each file. Here is one possible
-     error that is thrown when the include file cannot be found:
-          msyylex(): Unable to access file. Error opening included file "parks_include.map"
-Example
-      MAP
-       NAME "include_mapfile"
-       EXTENT 0 0 500 500
-       SIZE 250 250
-       INCLUDE "test_include_symbols.map"
-       INCLUDE "test_include_layer.map"
-      END
-where test_include_symbols.map contains:
-      SYMBOL
-         NAME 'square'
-         TYPE VECTOR
-         FILLED TRUE
-         POINTS 0 0 0 1 1 1 1 0 0 0 END
-      END
-and test_include_layer.map contains:
-      LAYER
-        TYPE POINT
-        STATUS DEFAULT
-        FEATURE
-          POINTS 10 10 40 20 300 300 400 10 10 400 END
-        END
-        CLASS
-          NAME 'Church'
-          COLOR 0 0 0
-          SYMBOL 'square'
-          SIZE 7
-          STYLE
-            SYMBOL "square"
-            SIZE 5
-            COLOR 255 255 255
-          END
-          STYLE
-            SYMBOL "square"
-            SIZE 3
-            COLOR 0 0 255
-          END
-        END
-      END
