[mapserver-commits] r12988 - sandbox/sdlime/rfc-77
Mon Jan 16 13:04:55 EST 2012
Author: sdlime
Date: 2012-01-16 10:04:54 -0800 (Mon, 16 Jan 2012)
New Revision: 12988
   sandbox/sdlime/rfc-77/mapdraw.c
   sandbox/sdlime/rfc-77/mapfile.c
   sandbox/sdlime/rfc-77/maplabel.c
   sandbox/sdlime/rfc-77/mapserver.h
Multiple labels rendering for points. Still need to work on within group collisions and other stuff but it's progress.
Modified: sandbox/sdlime/rfc-77/mapdraw.c
--- sandbox/sdlime/rfc-77/mapdraw.c	2012-01-16 16:09:43 UTC (rev 12987)
+++ sandbox/sdlime/rfc-77/mapdraw.c	2012-01-16 18:04:54 UTC (rev 12988)
@@ -1423,7 +1423,7 @@
   double r; /* circle radius */
   int csz; /* clip over size */
   double buffer;
-  int minfeaturesize;
+  int minfeaturesize=-1;
   int numpaths = 1, numpoints = 1, numRegularLines = 0;
   shapeObj *annoshape = NULL; /* holds the version of the shape to be labeled- may be clipped or may not */
@@ -2279,12 +2279,12 @@
         if(map->debug) msDebug("msDrawLabelCache(): labelcache_map_edge_buffer = %d\n", map_edge_buffer);
-      fprintf(stderr, "  map_edge_buffer=%d\n", map_edge_buffer);
       for(priority=MS_MAX_LABEL_PRIORITY-1; priority>=0; priority--) {
         labelCacheSlotObj *cacheslot;
         cacheslot = &(map->labelcache.slots[priority]);
+        fprintf(stderr, "  priority=%d has %d labels\n", priority, cacheslot->numlabels);
         for(l=cacheslot->numlabels-1; l>=0; l--) {
           double scalefactor,size;
           cachePtr = &(cacheslot->labels[l]); /* point to right spot in the label cache */
@@ -2293,9 +2293,11 @@
           if(cachePtr->markerid != -1) markerPtr = &(cacheslot->markers[cachePtr->markerid]); /* point to the right sport in the marker cache (if available) */
           layerPtr = (GET_LAYER(map, cachePtr->layerindex)); /* set a couple of other pointers, avoids nasty references */
-          if(cachePtr->labelpath) {
-            labelPtr = &(cachePtr->labels[ll]);
+          fprintf(stderr, "    working on label %d which has %d labelObj's, first bit of text='%s'\n", l, cachePtr->numlabels, cachePtr->labels[0].annotext);
+          if(cachePtr->labelpath) { /* path-based label */
+            labelPtr = &(cachePtr->labels[0]);
             if(!labelPtr->annotext || strlen(labelPtr->annotext) == 0)
               continue; /* skip this label, nothing to with curved labels when there is nothing to draw */
@@ -2305,19 +2307,19 @@
             size = MS_MIN(size, labelPtr->maxsize*image->resolutionfactor);
             scalefactor = size / labelPtr->size;
-            if(msGetLabelSize(map, labelPtr, cachePtr->text, size, &r, NULL) != MS_SUCCESS)
+            if(msGetLabelSize(map, labelPtr, labelPtr->annotext, size, &r, NULL) != MS_SUCCESS)
               return MS_FAILURE;
             /* adjust the baseline (see #1449) (RFC 77 TODO - is this relevant for path following labels?) */
             if(labelPtr->type == MS_TRUETYPE) {
-              int nNewlines = msCountChars(cachePtr->text,'\n');
+              int nNewlines = msCountChars(labelPtr->annotext,'\n');
               if(!nNewlines) {
                 labelPtr->offsety += MS_NINT((((r.miny + r.maxy) + size) / 2.0)/scalefactor);
                 labelPtr->offsetx += MS_NINT((r.minx / 2)/scalefactor);
               } else {
                 rectObj rect2; /* bbox of first line only */
-                char *firstLine = msGetFirstLine(cachePtr->text);
-                msGetLabelSize(map,labelPtr,firstLine,size,&rect2,NULL);
+                char *firstLine = msGetFirstLine(labelPtr->annotext);
+                msGetLabelSize(map, labelPtr, firstLine, size, &rect2, NULL);
                 labelPtr->offsety += (MS_NINT(((rect2.miny+rect2.maxy) + size) / 2))/scalefactor;
                 labelPtr->offsetx += (MS_NINT(rect2.minx / 2))/scalefactor;
                 free(firstLine);
@@ -2343,17 +2345,60 @@
             msDrawTextLine(image, cachePtr->text, labelPtr, cachePtr->labelpath, &(map->fontset), layerPtr->scalefactor); /* Draw the curved label */
-          } else {
+          } else { /* point-based label */
             int drawLabelText=MS_TRUE; // not used yet
             /* all other cases *could* have multiple labels defined */
             for(ll=(cachePtr->numlabels-1); ll>=0; ll--) {
+              // start missing section...
+              if(!labelPtr->annotext || strlen(labelPtr->annotext) == 0)
+                continue; /* skip this label (RFC 77 TODO: ok to bail here?) */
+	      // RFC 77 TODO: account for raster fonts
+              if(labelPtr->type == MS_TRUETYPE) {
+                size = labelPtr->size * layerPtr->scalefactor;
+                size = MS_MAX(size, labelPtr->minsize*image->resolutionfactor);
+                size = MS_MIN(size, labelPtr->maxsize*image->resolutionfactor);
+                scalefactor = size / labelPtr->size;
+              } else {
+                size = labelPtr->size;
+                scalefactor = 1;
+                return MS_FAILURE;
+              /* adjust the baseline (see #1449) */
+                if(!nNewlines) {
+                  labelPtr->offsety += MS_NINT((((r.miny + r.maxy) + size) / 2.0)/scalefactor);
+                  labelPtr->offsetx += MS_NINT((r.minx / 2)/scalefactor);
+                } else {
+                  rectObj rect2; /* bbox of first line only */
+                  labelPtr->offsety += (MS_NINT(((rect2.miny+rect2.maxy) + size) / 2))/scalefactor;
+                  labelPtr->offsetx += (MS_NINT(rect2.minx / 2))/scalefactor;
+                  free(firstLine);
+              label_offset_x = labelPtr->offsetx*scalefactor;
+              label_offset_y = labelPtr->offsety*scalefactor;
+              label_buffer = MS_NINT(labelPtr->buffer*image->resolutionfactor);
+              label_mindistance = MS_NINT(labelPtr->mindistance*image->resolutionfactor);
+              if(labelPtr->autominfeaturesize && (cachePtr->featuresize != -1) && ((r.maxx-r.minx) > cachePtr->featuresize))
+                continue; /* label too large relative to the feature */
+              // end missing section
+              fprintf(stderr, "      got label size\n");
               marker_offset_x = marker_offset_y = 0; /* assume no marker */
               marker_width = marker_height = 0;
               if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0) {
                 /* TODO: at the moment only checks the bottom (first) marker style since it *should* be the
                    largest, perhaps we should check all of them and build a composite size */
                 if(msGetMarkerSize(&map->symbolset, &(cachePtr->styles[0]), &marker_width, &marker_height, layerPtr->scalefactor) != MS_SUCCESS)
@@ -2398,7 +2443,7 @@
                   marker_rect.maxx = MS_NINT(cachePtr->point.x + .5 * marker_width) + labelPtr->buffer; // marker_rect.minx + (marker_width-1) + labelPtr->buffer;
                   marker_rect.maxy = MS_NINT(cachePtr->point.y + .5 * marker_height) + labelPtr->buffer; // marker_rect.miny + (marker_height-1) + labelPtr->buffer;
               if(drawLabelText && labelPtr->position == MS_AUTO) {
                 int positions[MS_POSITIONS_LENGTH], npositions=0;
@@ -2422,7 +2467,7 @@
                   msFreeShape(cachePtr->poly);
                   cachePtr->status = MS_TRUE; /* assume label *can* be drawn */
-                  p = get_metrics(&(cachePtr->point), positions[i], r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, label_buffer, cachePtr->poly);
+                  labelPtr->annopoint = get_metrics(&(cachePtr->point), positions[i], r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, label_buffer, cachePtr->poly);
                   if(marker_width > 0 && marker_height > 0)
                     msRectToPolygon(marker_rect, cachePtr->poly); /* save marker bounding polygon (TODO: could do this once!) */
@@ -2447,11 +2492,13 @@
               } else { /* explicit position */
+                fprintf(stderr, "    explicit position case (ll=%d)\n", ll);
                 if(labelPtr->position == MS_CC) { /* don't need the marker_offset */
-                  p = get_metrics(&(cachePtr->point), labelPtr->position, r, label_offset_x, label_offset_y, labelPtr->angle, label_buffer, cachePtr->poly);
+                  labelPtr->annopoint = get_metrics(&(cachePtr->point), labelPtr->position, r, label_offset_x, label_offset_y, labelPtr->angle, label_buffer, cachePtr->poly);
                   if(drawLabelPoly) get_metrics_line(&(cachePtr->point), labelPtr->position, r, label_offset_x, label_offset_y, labelPtr->angle, 1, labelPoly.line);
                 } else {
-                  p = get_metrics(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, label_buffer, cachePtr->poly);
+                  labelPtr->annopoint = get_metrics(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, label_buffer, cachePtr->poly);
                   if(drawLabelPoly) get_metrics_line(&(cachePtr->point), labelPtr->position, r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, 1, labelPoly.line);
@@ -2467,6 +2514,8 @@
             if(!cachePtr->status)
               continue; /* next label */
+            fprintf(stderr, "    label can be drawn!\n");
             if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0) { /* need to draw a marker */
               for(i=0; i<cachePtr->numstyles; i++)
                 msDrawMarkerSymbol(&map->symbolset, image, &(cachePtr->point), &(cachePtr->styles[i]), layerPtr->scalefactor);
@@ -2489,7 +2538,7 @@
-              msDrawText(image, p, cachePtr->text, labelPtr, &(map->fontset), layerPtr->scalefactor); /* actually draw the label */
+              msDrawText(image, labelPtr->annopoint, labelPtr->annotext, labelPtr, &(map->fontset), layerPtr->scalefactor); /* actually draw the label */
 	} /* next label */
Modified: sandbox/sdlime/rfc-77/mapfile.c
--- sandbox/sdlime/rfc-77/mapfile.c	2012-01-16 16:09:43 UTC (rev 12987)
+++ sandbox/sdlime/rfc-77/mapfile.c	2012-01-16 18:04:54 UTC (rev 12988)
@@ -2833,13 +2833,13 @@
    * to msGrowClassStyles()
   class->numstyles = class->maxstyles = 0;
-  class->styles = NULL;
+  class->styles = NULL;
   // RFC-77 REMOVE
   // initLabel(&(class->label));
   // class->label.size = -1; /* no default */
   class->numlabels = class->maxlabels = 0;
-  class->labels = NULL;
+  class->labels = NULL;
   class->keyimage = NULL;
@@ -3030,7 +3030,9 @@
 labelObj *msGrowClassLabels( classObj *class ) {
-  /* Do we need to increase the size of labels[] by  MS_LABEL_ALLOCSIZE?
+  fprintf(stderr, "in msGrowClassLabels, numlabels=%d\n", class->numlabels);
+  /* Do we need to increase the size of labels[] by MS_LABEL_ALLOCSIZE?
   if (class->numlabels == class->maxlabels) {
     labelObj **newLabelPtr;
@@ -3114,6 +3116,7 @@
       initLabel(class->labels[class->numlabels]);
       class->labels[class->numlabels]->size = MS_MEDIUM; /* only set a default if the LABEL section is present */
       if(loadLabel(class->labels[class->numlabels]) == -1) return(-1);
+      class->numlabels++;
       break;
     case(MAXSCALE):
     case(MAXSCALEDENOM):
Modified: sandbox/sdlime/rfc-77/maplabel.c
--- sandbox/sdlime/rfc-77/maplabel.c	2012-01-16 16:09:43 UTC (rev 12987)
+++ sandbox/sdlime/rfc-77/maplabel.c	2012-01-16 18:04:54 UTC (rev 12988)
@@ -319,7 +319,7 @@
   /* if the number of labels is 1 then call msAddLabel() accordingly */
   if(classPtr->numlabels == 1) {
-    msAddLabel(map, classPtr->labels[0], layerindex, classindex, shape, point, NULL, featuresize);
+    return msAddLabel(map, classPtr->labels[0], layerindex, classindex, shape, point, NULL, featuresize);
   // if( label == NULL )
@@ -340,6 +340,8 @@
   else if (priority > MS_MAX_LABEL_PRIORITY)
     priority = MS_MAX_LABEL_PRIORITY;
+  fprintf(stderr, "  priority=%d\n", priority);
   cacheslot = &(map->labelcache.slots[priority-1]);
   if(cacheslot->numlabels == cacheslot->cachesize) { /* just add it to the end */
@@ -353,6 +355,8 @@
   cachePtr->layerindex = layerindex; /* so we can get back to this *raw* data if necessary */
   cachePtr->classindex = classindex;
+  fprintf(stderr, "  assigned indexes\n");
   if(shape) {
     cachePtr->tileindex = shape->tileindex;
     cachePtr->shapeindex = shape->index;
@@ -368,6 +372,8 @@
   cachePtr->point.y = MS_NINT(cachePtr->point.y);
   cachePtr->labelpath = NULL;
+  fprintf(stderr, "  stored label point (%g,%g)\n", point->x, point->y);
   // cachePtr->text = msStrdup(string); /* the actual text */
   /* TODO: perhaps we can get rid of this next section and just store a marker size? Why do we cache the styles for a point layer? */
@@ -389,14 +395,18 @@
-  ** copy the labels:
+  ** copy the labels (we are guaranteed to have more than one):
   **   we cannot simply keep refs because the rendering code alters some members of the style objects
   cachePtr->numlabels = classPtr->numlabels;
-  cachePtr->labels = (labelObj *) msSmallMalloc(sizeof(labelObj)*cachePtr->numlabels);
-  for(i=0; i<cachePtr->numlabels; i++)
+  cachePtr->labels = (labelObj *) msSmallMalloc(sizeof(labelObj)*classPtr->numlabels);
+  for(i=0; i<classPtr->numlabels; i++) {
+    initLabel(&(cachePtr->labels[i]));
     msCopyLabel(&(cachePtr->labels[i]), classPtr->labels[i]);
+  fprintf(stderr, "  copied %d labels\n", classPtr->numlabels);
   cachePtr->markerid = -1;
   cachePtr->featuresize = featuresize;
Modified: sandbox/sdlime/rfc-77/mapserver.h
--- sandbox/sdlime/rfc-77/mapserver.h	2012-01-16 16:09:43 UTC (rev 12987)
+++ sandbox/sdlime/rfc-77/mapserver.h	2012-01-16 18:04:54 UTC (rev 12988)
@@ -225,7 +225,7 @@
 #define MS_LAYER_ALLOCSIZE 64
 #define MS_CLASS_ALLOCSIZE 8
 #define MS_STYLE_ALLOCSIZE 4
-#define MS_LABEL_ALLOCSIZE 1 /* not too common */
+#define MS_LABEL_ALLOCSIZE 2 /* not too common */
 #define MS_MAX_LABEL_PRIORITY     10
 #define MS_DEFAULT_LABEL_PRIORITY 1
@@ -974,6 +974,7 @@
   /* book keeping variable- used on a feature-by-feature basis (similar to bindings) */
   char *annotext;
+  pointObj annopoint;
   shapeObj *annopoly;
 #endif
 } labelObj;
