[mapserver-commits] r12998 - trunk/docs/en/mapcache
Wed Jan 18 13:32:07 EST 2012
Author: jmckenna
Date: 2012-01-18 10:32:07 -0800 (Wed, 18 Jan 2012)
New Revision: 12998
   trunk/docs/en/mapcache/install.txt
add windows config notes
Modified: trunk/docs/en/mapcache/install.txt
--- trunk/docs/en/mapcache/install.txt	2012-01-18 17:57:44 UTC (rev 12997)
+++ trunk/docs/en/mapcache/install.txt	2012-01-18 18:32:07 UTC (rev 12998)
@@ -1,65 +1,28 @@
 .. _mapcache_install:
-Compilation - Installation
+Compilation & Installation
 :Author: Thomas Bonfort
 :Contact: tbonfort at terriscope.fr
 :Author: Alan Boudreault
 :Contact: aboudreaut at magears.com
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
-Windows Instructions
+.. contents:: Table of Contents
+    :depth: 3
+    :backlinks: top
-These instructions target a Windows 7 setup with a Apache httpd
-compiled from source. I have successfully built the module with VC
-2003, 2008 and 2010.
+Getting the Source
-Dependencies
+MapCache source is stored in the */mapserver/mapcache/* directory in :ref:`svn`.
+You can visually browse the Subversion repository at http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapcache
-Required:
-- **apache / apr / apr-util**: included with apache httpd installation
-Those can be installed manually, or using the appropriate Windows SDK
-- **png**
-- **jpeg**
-- **curl**
-Recommended:
-- **pcre**: ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
-Optional:
-- **fcgi**: Needed to build a fastcgi program if you don't want to run
-  mapcache as an apache module.
-- **gdal / geos**: Needed to enable advanced seeding options (for only
-  seeding tiles that intersect a given geographical feature)
-- **sqlite**: For enabling the sqlite backend storages
-- **tiff**: For enabling the TIFF backend storages
-Configuration
-Open nmake.opt and modify the paths to point to the various libraries.
-Compilation
-.. code-block:: bash
-  $ nmake /f Makefile.vc
-The result libraries and executables will be in their associated
-directory. ie. apache/mod_mapcache.dll for the apache module.
 Linux Instructions
 These instructions target a debian/ubuntu setup, but should apply with few
 modifications to any linux installation.
@@ -104,7 +67,7 @@
   $ make
 Apache Module Specific Instructions
@@ -143,7 +106,7 @@
 http://myserver/mapcache/demo
 CGI/FastCGI Specific Instructions
 A binary cgi/fastcgi is located in the src/ subfolder, and is named "mapcache".
 Activating fastcgi for the mapcache program on your web server is not part of
@@ -200,7 +163,7 @@
 (./configure --help should give you a full list).
 Apache apxs
@@ -214,7 +177,7 @@
 Apr
@@ -229,7 +192,7 @@
 Apr-Util
@@ -239,7 +202,7 @@
 Libcurl
@@ -248,7 +211,7 @@
 Libpng
@@ -261,7 +224,7 @@
 Libjpeg
@@ -274,7 +237,7 @@
 Pixman (recommended)
@@ -290,7 +253,7 @@
 Sqlite (optional)
@@ -304,7 +267,7 @@
 GDAL/OGR (optional, also requires geos)
@@ -317,7 +280,7 @@
 GEOS (optional)
@@ -332,7 +295,7 @@
 PCRE (optional)
@@ -349,7 +312,7 @@
 FastCGI Support (optional)
@@ -363,7 +326,7 @@
 TIFF Readonly Cache Support (optional)
@@ -373,7 +336,7 @@
 Debug Mode
@@ -386,7 +349,7 @@
 Memcached Cache Support (optional)
 The memcached cache backend is enabled by default, as it does not depend on
 other external libraries (support is obtained through apr-util). You can
@@ -399,7 +362,7 @@
 .. seealso:: :ref:`mapcache_cache_memcache`
 Apache Module Options
 You can disable the apache module building if you only plan on using the
 fastcgi executable or the seeder.
@@ -419,7 +382,7 @@
 TIFF read/write Cache Support (optional)
 TIFF write support (for creating new TIFF files and adding tiles to existing
 TIFF files) is still experimental and disabled by default. There is a risk in
@@ -451,7 +414,7 @@
 Native MapServer Mode
 MapCache is by default not linked to MapServer in any way, and communicates
 through the WMS protocol only. For performance reasons, there is a possibility
@@ -470,7 +433,102 @@
 safety on the mapserver side, you might want to have a look at tickets #4041 and
 #4044.
-Win32 compilation instructions
-Awaiting your contribution ;)
+Windows Instructions
+These instructions target a Windows 7 setup with an Apache httpd compiled from
+source. The Apache mapcache module has been successfully built with with
+Microsoft Visual Studio C++ versions 2003, 2008 and 2010.
+Dependencies
+Required:
+- **Apache / APR / APR-UTIL**: included with apache httpd installation
+Those can be installed manually, or using the appropriate Windows SDK
+from: http://vbkto.dyndns.org/sdk/
+- **PNG**
+- **JPEG**
+- **CURL**
+Recommended:
+- **PCRE**: ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
+Optional:
+- **FCGI**: Needed to build a fastcgi program if you don't want to run
+  mapcache as an apache module.
+- **GDAL / GEOS**: Needed to enable advanced seeding options (for only
+  seeding tiles that intersect a given geographical feature)
+- **SQLITE**: For enabling the sqlite backend storages
+- **TIFF**: For enabling the TIFF backend storages
+Configure Your Makefile
+Open nmake.opt and modify the paths to point to the various libraries.
+Compilation
+.. code-block:: bash
+  $ nmake /f Makefile.vc
+If successful, the resulting libraries and executables will generated in their associated
+directories:
+apache/
+  Apache module (mod_mapcache.dll)
+cgi/
+  FastCGI MapCache executable (mapcache.exe)
+util/
+  MapCache utilities (mapcache_seed.exe)
+Move the Module into Apache Directory
+Copy the *mod_mapcache.dll* file into one of your Apache subdirectories.
+.. note::
+    Although other modules are installed into */Apache/modules/*, you should place
+    mod_mapcache.dll wherever its required dll files (libcurl.dll, zlib.dll, etc.) live,
+    to avoid any loading issues later on.
+Configure Your Installed Apache
+- Modify your *httpd.conf* file to load the module:
+  .. code-block:: apache
+    LoadModule mapcache_module "D:/ms4w/Apache/cgi-bin/mod_mapcache.dll"
+- Next, configure your mapcache directory with the following
+  snippet
+     <IfModule mapcache_module>
+        <Directory "D:/ms4w/apps/mapcache/">
+           Order Allow,Deny
+           Allow from all
+        </Directory>
+        MapCacheAlias /mapcache "D:/ms4w/apps/mapcache/mapcache.xml"
+     </IfModule>
+- Configure your *mapcache.xml* file (see the :ref:`Configuration <mapcache_config>` section
+  for help)
+- Finally, restart your Apache.  You should see a message in Apache's error.log with a message
+  similar to:
+  .. code-block:: bash
+    [notice] Apache/2.2.21 (Win32) mod-mapcache/0.5-dev configured -- resuming normal operations
