[mapserver-commits] r13007 - sandbox/sdlime/rfc-77
Sat Jan 21 19:51:26 EST 2012
Author: sdlime
Date: 2012-01-21 16:51:26 -0800 (Sat, 21 Jan 2012)
New Revision: 13007
   sandbox/sdlime/rfc-77/mapdraw.c
Fixed label polygon handling within position auto loop.
Modified: sandbox/sdlime/rfc-77/mapdraw.c
--- sandbox/sdlime/rfc-77/mapdraw.c	2012-01-21 22:14:35 UTC (rev 13006)
+++ sandbox/sdlime/rfc-77/mapdraw.c	2012-01-22 00:51:26 UTC (rev 13007)
@@ -2288,8 +2288,6 @@
         labelCacheSlotObj *cacheslot;
         cacheslot = &(map->labelcache.slots[priority]);
-        fprintf(stderr, "  priority=%d has %d labels\n", priority, cacheslot->numlabels);
         for(l=cacheslot->numlabels-1; l>=0; l--) {
           double scalefactor,size;
           cachePtr = &(cacheslot->labels[l]); /* point to right spot in the label cache */
@@ -2303,8 +2301,8 @@
           if(cachePtr->labelpath) { /* path-based label */
             labelPtr = &(cachePtr->labels[0]);
-            if(!labelPtr->annotext || strlen(labelPtr->annotext) == 0)
-              continue; /* skip this label, nothing to with curved labels when there is nothing to draw */
+            if(labelPtr->status != MS_ON) continue; /* skip this label */
+            if(!labelPtr->annotext || strlen(labelPtr->annotext) == 0) continue; /* skip this label, nothing to with curved labels when there is nothing to draw */
             /* path-following labels *must* be TRUETYPE */
             size = labelPtr->size * layerPtr->scalefactor;
@@ -2390,6 +2388,7 @@
             cachePtr->status = MS_FALSE; /* assume this cache element *can't* be placed */
             for(ll=0; ll<cachePtr->numlabels; ll++) { /* RFC 77 TODO: Still may want to step through backwards... */
+              msFreeShape(poly);
               labelPtr = &(cachePtr->labels[ll]);
@@ -2462,6 +2461,8 @@
               if(drawLabelText && labelPtr->position == MS_AUTO) {
                 int positions[MS_POSITIONS_LENGTH], npositions=0;
+		fprintf(stderr, "    (%d) position auto:", cachePtr->status);
                 ** If the ANNOTATION has an associated marker then the position is handled like a point regardless of underlying shape type. (#2993)
                 **   (Note: might be able to re-order this for more speed.)
@@ -2480,16 +2481,18 @@
                 if(label_marker_width > 0 && label_marker_height > 0)
                   msRectToPolygon(label_marker_rect, poly); /* save marker bounding polygon */
-                for(i=0; i<npositions; i++) {
+                for(i=0; i<npositions; i++) {
+  		  fprintf(stderr, "%d ", i);
                   labelPtr->annopoint = get_metrics(&(cachePtr->point), positions[i], r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, label_buffer, poly);
-                  /* first, compare poly against cachePtr->poly (group poly) if not the first label in the group */
-                  if((ll != 0) && intersectLabelPolygons(poly, cachePtr->poly) == MS_TRUE) continue; /* next position */
+                  if((ll != 0) && intersectLabelPolygons(poly, cachePtr->poly) == MS_TRUE) {
+                    fprintf(stderr, "[%d] ", poly->numlines);
+                    msShapeDeleteLine(poly, poly->numlines-1);
+                    cachePtr->status = MS_FALSE;
+                    continue; /* next position */
-                  /* second, add poly to cachePtr->poly */
                   msCopyShape(poly, cachePtr->poly); // RFC 77 - HMMM, this isn't right (need to save existing cache->poly value in case there's a collision)...
-                  /* finally, compare against image bounds, rendered labels and markers (sets cachePtr->status) */
                   msTestLabelCacheCollisions(&(map->labelcache), labelPtr, image->width, image->height, (map_edge_buffer-label_buffer), cachePtr, priority, l, label_mindistance, (r.maxx-r.minx));
                   /* found a suitable place for this label */
@@ -2498,13 +2501,17 @@
                       get_metrics_line(&(cachePtr->point), positions[i], r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, 1, labelPoly.line);
                     break; /* ...out of position loop */
                   } else {
-                    /* reset some things */
+                    /* reset some things */
+                    fprintf(stderr, "{%d} ", poly->numlines);
                     msShapeDeleteLine(cachePtr->poly, cachePtr->poly->numlines-1);
                     if(poly->numlines == 2) msShapeDeleteLine(cachePtr->poly, cachePtr->poly->numlines-1); /* marker too */
+                    fprintf(stderr, "(%d) ", poly->numlines);
                 } /* next position */
+                fprintf(stderr, "end (%d)\n", cachePtr->status);
                 if(!cachePtr->status && labelPtr->force) {
                   if(drawLabelPoly)
                     get_metrics_line(&(cachePtr->point), positions[npositions-1], r, (marker_offset_x + label_offset_x), (marker_offset_y + label_offset_y), labelPtr->angle, 1, labelPoly.line);
@@ -2544,7 +2551,6 @@
               if(!cachePtr->status)
                 break; /* no point looking at more labels */
             } /* next label in the group */
