[mapserver-commits] r13015 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Fri Jan 27 03:10:15 EST 2012
Author: havatv
Date: 2012-01-27 00:10:15 -0800 (Fri, 27 Jan 2012)
New Revision: 13015
   branches/branch-6-0/docs/en/mapfile/index.txt
   trunk/docs/en/mapfile/index.txt
Added index entries (#4001) and made some formatting changes (long lines) - mapfile
Modified: branches/branch-6-0/docs/en/mapfile/index.txt
--- branches/branch-6-0/docs/en/mapfile/index.txt	2012-01-26 18:30:09 UTC (rev 13014)
+++ branches/branch-6-0/docs/en/mapfile/index.txt	2012-01-27 08:10:15 UTC (rev 13015)
@@ -1,3 +1,6 @@
+.. index::
+   single: Mapfile
 .. _mapfile:
@@ -11,20 +14,18 @@
 :Author: Jean-François Doyon
 :Contact: jdoyon at ccrs.nrcan.gc.ca
+The Mapfile is the heart of MapServer.  It defines the relationships
+between objects, points MapServer to where data are located and
+defines how things are to be drawn.
-The Mapfile is the heart of MapServer.  It defines the relationships between
-objects, points MapServer to where data are located and defines how things are
-to be drawn.
 The Mapfile consists of a :ref:`MAP` object, which has to start with
 the word `MAP`.
-There are some important concepts that you must understand before you can
-reliably use mapfiles to configure MapServer.  First is the concept of a
-:ref:`LAYER`.  A layer is the combination of data plus styling. Data, in
-the form of attributes plus geometry, are given styling using :ref:`CLASS`
-and :ref:`STYLE` directives.
+There are some important concepts that you must understand before you
+can reliably use mapfiles to configure MapServer.  First is the
+concept of a :ref:`LAYER`.  A layer is the combination of data plus
+styling.  Data, in the form of attributes plus geometry, are given
+styling using :ref:`CLASS` and :ref:`STYLE` directives.
 .. seealso::
     :ref:`introduction` for "An Introduction to the Mapfile"
@@ -35,14 +36,14 @@
    symbology/construction
    class
    cluster
-   labelencoding
+   labelencoding
    expressions
    feature
    fontset
    grid
    include
    join
-   label
+   label
    layer
    legend
    map
@@ -59,44 +60,79 @@
    variable_sub
    web
    xml_mapfile
 Notes
 * The Mapfile is NOT case-sensitive.
-* The ``Mapfile is read from top to bottom by MapServer``; this means that LAYERs
-  near the top of your Mapfile will be drawn before those near the bottom.  Therefore
-  users commonly place background imagery and other background layer types near the
-  top of their mapfile, and lines and points near the bottom of their mapfile.
-* Strings containing non-alphanumeric characters or a MapServer keyword MUST
-  be quoted. It is recommended to put ALL strings in double-quotes.
-* For MapServer versions < 5, there was a default maximum of 200 layers per
-  mapfile (there is no layer limit with MapServer >= 5).  This can be changed by
-  editing the map.h file to change the value of MS_MAXLAYERS to the desired
-  number and recompiling.  Here are other important default limits when using a
-  MapServer version < 5:
+* The ``Mapfile is read from top to bottom by MapServer``; this means
+  that LAYERs near the top of your Mapfile will be drawn before those
+  near the bottom.  Therefore users commonly place background imagery
+  and other background layer types near the top of their mapfile, and
+  lines and points near the bottom of their mapfile.
+* Strings containing non-alphanumeric characters or a MapServer
+  keyword MUST be quoted. It is recommended to put ALL strings in
+  double-quotes.
+* For MapServer versions < 5, there was a default maximum of 200
+  layers per mapfile (there is no layer limit with MapServer >= 5).
+  This can be changed by editing the map.h file to change the value of
+  MS_MAXLAYERS to the desired number and recompiling.  Here are other
+  important default limits when using a MapServer version < 5:
+  .. index::
+     single: MAXCLASSES
   * MAXCLASSES 250 (set in map.h)
+  .. index::
+     single: MAXSTYLES
   * MAXSTYLES 5 (set in map.h)
+  .. index::
+     single: MAXSYMBOLS
   * MAXSYMBOLS 64 (set in mapsymbol.h)
-  MapServer versions >= 5 have no limits for classes, styles, symbols, or layers.
-* File paths may be given as absolute paths, or as paths relative to the
-  location of the mapfile. In addition, data files may be specified relative
-  to the SHAPEPATH.
-* The mapfile has a hierarchical structure, with the MAP object being the
-  "root". All other objects fall under this one.
+  MapServer versions >= 5 have no limits for classes, styles, symbols,
+  or layers.
+.. index::
+   single: File paths
+* File paths may be given as absolute paths, or as paths relative to
+  the location of the mapfile. In addition, data files may be
+  specified relative to the SHAPEPATH.
+* The mapfile has a hierarchical structure, with the MAP object being
+  the "root". All other objects fall under this one.
+.. index::
+   single: Comments
 * Comments are designated with a #.
-* Attributes are named using the following syntax: [ATTRIBUTENAME] ... Note
-  that the name of the attribute included between the square brackets
-  *IS CASE SENSITIVE*. Generally ESRI generated shapefiles have their
-  attributes (.dbf column names) all in upper-case for instance, and for
-  PostGIS, *ALWAYS* use lower-case.
-* MapServer Regular Expressions are used through the operating system's
-  C Library. For information on how to use and write Regular Expressions on
-  your system, you should read the documentation provided with your C Library.
-  On Linux, this is GLibC, and you can read "man 7 regex" ... This man page is
-  also available on most UNIX's. Since these RegEx's are POSIX compliant, they
-  should be the same on Windows as well, so windows users can try searching
-  the web for "man 7 regex" since man pages are available all over the web.
+* Attributes are named using the following syntax: [ATTRIBUTENAME].
+  .. note::
+    that the name of the attribute included between the square
+    brackets *IS CASE SENSITIVE*. Generally ESRI generated shape data
+    sets have their attributes (.dbf column names) all in upper-case
+    for instance, and for PostGIS, *ALWAYS* use lower-case.
+.. index::
+   single: Regular expressions
+* MapServer Regular Expressions are used through the operating
+  system's C Library.  For information on how to use and write Regular
+  Expressions on your system, you should read the documentation
+  provided with your C Library.  On Linux, this is GLibC, and you can
+  read "man 7 regex" ... This man page is also available on most
+  UNIX's. Since these RegEx's are POSIX compliant, they should be the
+  same on Windows as well, so windows users can try searching the web
+  for "man 7 regex" since man pages are available all over the web.
Modified: trunk/docs/en/mapfile/index.txt
--- trunk/docs/en/mapfile/index.txt	2012-01-26 18:30:09 UTC (rev 13014)
+++ trunk/docs/en/mapfile/index.txt	2012-01-27 08:10:15 UTC (rev 13015)
@@ -1,3 +1,6 @@
+.. index::
+   single: Mapfile
 .. _mapfile:
@@ -11,20 +14,18 @@
-to be drawn.
 the word `MAP`.
 .. seealso::
@@ -35,14 +36,14 @@
    class
    cluster
-   labelencoding
+   labelencoding
    expressions
    feature
    fontset
    grid
    include
    join
-   label
+   label
    layer
    legend
    map
@@ -59,44 +60,79 @@
    variable_sub
    web
    xml_mapfile
 Notes
+  double-quotes.
+  .. index::
+  .. index::
+     single: MAXSTYLES
+  .. index::
-  to the SHAPEPATH.
+  or layers.
+.. index::
+.. index::
+   single: Comments
+  .. note::
+.. index::
